Sysprogs forums › Forums › VisualGDB › Unable to debug STM32 Unit Tests
- This topic has 4 replies, 2 voices, and was last updated 5 years, 11 months ago by
dabramson.
September 30, 2020 at 13:02 #29148
dabramson
ParticipantWhen I try to debug unit tests from the visual studio test explorer I get the following message in the test output window.
---------- Starting test run ---------- System.Runtime.InteropServices.COMException (0x89710080): Unable to attach. The debugger is not properly installed. Cannot debug the requested type of code. Run setup to install or repair the debugger. at Microsoft.VisualStudio.Shell.Interop.IVsDebuggerLaunchAsync.LaunchDebugTargetsAsync(UInt32 debugTargetCount, VsDebugTargetInfo4[] debugTargetArray, IVsDebuggerLaunchCompletionCallback completionCallback) at Microsoft.VisualStudio.TestWindow.ShellServices.DebuggerService.<>c__DisplayClass21_0.<<LaunchDebuggerAsync>b__0>d.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Microsoft.VisualStudio.TestWindow.Extensibility.ILoggerExtensions.<CallWithCatchAsync>d__11`1.MoveNext() --- End of stack trace from previous location where exception was thrown --- at Microsoft.VisualStudio.Telemetry.WindowsErrorReporting.WatsonReport.GetClrWatsonExceptionInfo(Exception exceptionObject) Running tests from C:\Clients\PH\Midas\MCB\TestMidasMCBLogicLib\VisualGDB\VisualGDBCache\TestMidasMCBLogicLib-Debug\TestMidasMCBLogicLib.vgdbtestcontainer... Test container loaded (lookup: 4 msec, fetch: 1 msec, symbol list: 48 msec) ========== Test run finished: 1 Tests run in 11.6 sec (1 Passed, 0 Failed, 0 Skipped) ==========
The tests still run to completion, but no breakpoints are hit.
Debugging a normal project still works. So I’m not sure what “The debugger is not properly installed” is supposed to mean.
I’m running visual studio 2019 16.7.5, but I also was having the issue with an older version (unfortunately I forget the version).
The Visual GDB is 5.4R12 (build 3309).
ST-link/v2 debugger
OpenOCD VGDB Package 20200310-0.10.0
Please help!
September 30, 2020 at 15:18 #29149support
Please try updating to the latest VisualGDB 5.5 RC1.
October 1, 2020 at 03:59 #29151dabramson
I updated visual gdb as suggested and I can now debug unit tests again.
That said, the first time I went to debug with the new VGDB webroot detected vgagent.exe (running out of the Visual GDB Program Files) as a threat and blocked it. I had to tell webroot that it was ok to let it run. I’m not sure what vgagent does, but you probably don’t want it getting flagged by virus/malware scanning software.
Dave
October 1, 2020 at 10:52 #29157support
KeymasterThe vgagent.exe process is responsible for sending Ctrl-C and Ctrl-Break events to the gdb debugger (you can view the description in File Properties). Unfortunately, this often triggers false positives with low-quality antivirus software.
If your antivirus reports vgagent as a potential threat, please consider submitting a false positive report to your antivirus vendor.
October 2, 2020 at 03:38 #29165dabramson
ParticipantAs it turns out, our IT contacted me to tell me they were going to whitelist it for me. So no problem here.
