unable to create Qt application form embedded cross compile linux with QT base 5
Sysprogs forums Forums VisualGDB unable to create Qt application form embedded cross compile linux with QT base 5
  • #25468
    SHA
    Hi dears,
    I’m unable to create Qt application form embedded cross compile Linux with QT base 5,
    give me this Error below:
    Tool arguments: C:\SysGCC\beaglebone\Qt\v5\qmake.exe TestProFile.pro CONFIGNAME=Debug
    C:/SysGCC/beaglebone/arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/qt5/mkspecs/features/toolchain.prf:69: system(execute) requires one or two arguments.
    Project ERROR: Cannot run compiler ‘C:/SysGCC/beaglebone/bin/arm-linux-gnueabihf-g++.exe’. Output:
    Maybe you forgot to setup the environment?
    Is there any suggestion?
    BR
    #25482
    It looks like your toolchain is corrupt. Please try deleting it and installing the latest one (and FLASHing a compatible SD card image) from scratch.
