Sysprogs forums › Forums › VisualGDB › Trouble getting started with VisualGDB on the OUYA
- This topic has 6 replies, 5 voices, and was last updated 10 years, 8 months ago by
January 23, 2014 at 05:57 #740
ParticipantHi guys,
I am currently trying to start developing on the OUYA using VisualGDB for debugging and developing native code. When I attempt to run the “tutorial” on Sysprog’s website. I run into an odd error when creating the new project. After going through the entire wizard for creating the new project, I am presented with an error prompt that reads “Toolchain test failed: cannot query the value of TARGET_CXX. Please double-check your settings. If you ignore this error, your project may not build.”. I am assuming that TARGET_CXX must be some sort of environment value VisualGDB is expecting, but I’m not sure where or how this value needs set. I am running Microsoft Visual Studio 2012 Professional edition on Windows 7 x64 Professional, and VisualGDB 4.0.0.4.Thank you for your time.
January 23, 2014 at 22:37 #2948ket
TARGET_CXX is a variable value VisualGDB tries to get from gcc to test whether a trivial program will build, it is not something that you should set. All the toolchain test failure means is that the project may not build because there are some issues such as missing settings. Please try to ignore the toolchain test error and create the project anyway. When you build the actual project the build output provided should be more helpful in showing the actual issue.
A common cause for this error is if you are importing a project that needs the NDK_MODULE_PATH variable defined. There is no place to specify it in the wizard, but it can be defined once the project is made as an additional argument to ndk-build on the Build settings page in VisualGDB Project Properties.
January 24, 2014 at 05:29 #2949Anonymous
ParticipantThat did the trick. i ended up defining NDK_MODULE_PATH in Android.mk. I still need to do a bit of reading to know exactly what the paths Android.mk mean (for example what directory “$(call my-dir)” refers to relative to VS’s directory structure. Setting the NDK module path to an absolute path got things running. Thank you for the help.
April 13, 2015 at 09:29 #6325Fahid
Participant@ket i’m using visualGDB for developing android using cocos2d-x and i’m getting same error. How can i set NDK_MODULE_PATH in android.mk file?
April 17, 2015 at 06:59 #6346support
You can specify NDK_MODULE_PATH via Make arguments in VisualGDB Project Properties (Build Settings page).
August 3, 2015 at 17:16 #6781russov
ParticipantYou can specify NDK_MODULE_PATH via Make arguments in VisualGDB Project Properties (Build Settings page).
Hello, Bazis.
Could you provide me more descriptions, with print screen if possible? Because i am new user for VisualGDB and android development.
ThanksAugust 6, 2015 at 01:53 #6801support
Please try following the Cocos2d-x VisualGDB tutorial here: http://visualgdb.com/tutorials/android/cocos2dx/simplegame/. It contains all necessary steps. If it does not work for you, please let us know.
