Toolchain Test Failed
Sysprogs forums Forums VisualGDB Toolchain Test Failed
  • #6415
    jtohle
    I have setup a new RPi Cross compilation Project, however, when applying the settings I am getting this error message:
    Tool arguments:
    sh: /tmp/VisualGDB_ToolchainTestProgram_Deployed: No such file or directory
    So, I clicked ignore.
    Then when I compile my code and try to run it, i get that the gdbserver could not run, with this log:
    Process /tmp/RPiProj1 created; pid = 25389
    Cannot exec /tmp/RPiProj1: No such file or directory.
    Child exited with status 127
    No program to debug. GDBserver exiting.
    Any Ideas what the problem is,
    Thx,
    #6418
    Looks like VisualGDB cannot upload to the /tmp folder on your Raspberry Pi. Please double-check that the folder is writable from your user account and that you have enough free space on your Raspberry Pi.
    #6420
    jtohle
    @bazis,
    It does not explain why it works when the project is set to “build the project under linux over network”, and then when it is set to “Build the project  locally with a cross compiler” it does not work.
    Both options use the /tmp folder, and it works on the first option, as i see my code in /tmp, and can execute it.
    Any other suggestions/ideas.
    #6437
    This is true. Can you inspect the contents of View->Output->VisualGDB Launcher Output after an unsuccessful debugging session? It should normally show something like this:
    VisualGDB: Executing predebug actions
    VisualGDB: Deploying e:\PROJECTS\TEMP\test\test/Debug/test to /tmp/vgtest/test on raspberrypi...
    VisualGDB: Launching gdbserver
    VisualGDB: Run "gdbserver :2000 "$(DeployPath)" " in directory "$(DeployDir)" on pi@raspberrypi (SSH)
    VisualGDB: Launching custom program console
    VisualGDB: Executing postdebug actions
    Then check that:
    1) The file on the Windows machine exists and is readable under your account
    2) The remote file does not exist, the remote directory does and the device has enough free space
    If none of that provides clues, can you reproduce it with a “Hello, World” project? If yes, can you create an image of your SD card and send it to us so that we could reproduce it on our side?
    #6448
    jtohle
    I have managed to solve the issue by uninstalling GCC & GDB from remote the RPi, and then installed the latest version of GCC & GDB, after that I re-synchronized the sysroot folder.
    Now all is working.
