Sysprogs forums › Forums › VisualGDB › Toolchain Test Failed
- This topic has 3 replies, 2 voices, and was last updated 11 years, 6 months ago by
Anonymous.
August 30, 2014 at 05:17 #895
ParticipantLatest update broke the toolchain? Is there a solution for this?
my application is now also failing to build
I just updated to latest VisualGDB and my project fail to compile. I am seeing this error when it tries to test
Tool arguments: -Wl,–start-group “C:UsersSteveAppDataLocalTemp/VisualGDB_TrivialProgram.o” -o “C:UsersSteveAppDataLocalTemp/VisualGDB_TrivialProgram.bin” -Wl,-gc-sections -mcpu=cortex-m4 -mthumb -TC:UsersSteveAppDataLocalVisualGDBEmbeddedBSPsarm-eabicom.sysprogs.arm.stm32/STM32F4xxxx-HAL/LinkerScripts/STM32F429xI_flash.lds -mfloat-abi=hard -l$$com.sysprogs.toolchainoptions.arm.compactcpp$$ -Wl,–end-group
c:/sysgcc/arm-eabi/bin/../lib/gcc/arm-eabi/4.9.1/../../../../arm-eabi/bin/ld.exe: cannot find -l$$com.sysprogs.toolchainoptions.arm.compactcpp$$
collect2.exe: error: ld returned 1 exit statusAugust 30, 2014 at 22:13 #3359Anonymous
ParticipantAlso something up with the “Command line” failing when it try’s to run the RM command to clean the target config dir
After the last update VisualGDB is now broken. Can’t compile, can’t clean. I would appreciate some assistance getting this working again.
1>
Clean started: Project: Havoc, Configuration: Debug Win32
1> VisualGDB: Run “cmd.exe /c “C:SysGCCarm-eabibinmake.exe” CONFIG=Debug clean” in directory “C:ProjectsDPRGDiscoveryHavocHavoc” on local computer
1> rm -rf Debug
1> rm: cannot remove directory `Debug’: Directory not empty
1> make: *** [clean] Error 1
1>1> Command exited with code 2
1> Executable: cmd.exe
1> Arguments: /c “C:SysGCCarm-eabibinmake.exe” CONFIG=Debug clean
1> Directory: C:ProjectsDPRGDiscoveryHavocHavoc
1>C:Program Files (x86)MSBuildMicrosoft.Cppv4.0V120Microsoft.MakeFile.Targets(33,5): error MSB3073: The command “”C:Program Files (x86)SysprogsVisualGDB\VisualGDB.exe” /clean “C:ProjectsDPRGDiscoveryHavocHavocHavoc.vcxproj” “/solution:C:ProjectsDPRGDiscoveryHavocHavoc.sln” “/config:Debug” “/platform:Win32″” exited with code -1.
========== Clean: 0 succeeded, 1 failed, 0 skipped ==========August 30, 2014 at 22:16 #3360Anonymous
ParticipantAlso on several of my existing projects I now get this new error, which compiled before the update without the error.
Error 2 error : ‘TICK_INT_PRIORITY’ undeclared (first use in this function) C:UsersSteveAppDataLocalVisualGDBEmbeddedBSPsarm-eabicom.sysprogs.arm.stm32STM32F4xxxx-HALSTM32F4xx_HAL_DriverSrcstm32f4xx_hal.c 175 16 Havoc
even though I can see its declared in C:UsersSteveAppDataLocalVisualGDBEmbeddedBSPsarm-eabicom.sysprogs.arm.stm32STM32F4xxxx-HALSTM32F4xx_HAL_DriverIncstm32f4xx_hal_conf_template.h
September 2, 2014 at 03:17 #3358support
The rebuild error is a known issue and can be safely ignored. Simply build the project afterwards and it will build properly.
The TICK_INT_PRIORITY issue can be solved by regenerating the Device-Specific files folder (change the MCU type and restore it back in VisualGDB Project Properties). -
