Third Party Compilers
Sysprogs forums › Forums › VisualGDB › Third Party Compilers
  • #33336
    jettmusco
    Is there any support for using a different compilers than what is listed in the toolchain dropdown menu? For example, I want to use TI’s specific arm clang compiler
    #33339
    Sure, you can always click the “select a third-party toolchain” button to import an arbitrary toolchain. VisualGDB will create a Toolchain.xml/CustomToolchain.xml file either in the toolchain directory or under %LOCALAPPDATA%, where it will store the toolchain properties. You can then manually edit the file to customize various settings (e.g. add hardcoded CFLAGS). See this page for a detailed explanation.
