Sysprogs forums › Forums › VisualGDB › There was a problem opening 'CMakeLists.txt'
- This topic has 4 replies, 2 voices, and was last updated 4 years, 10 months ago by
June 4, 2021 at 22:47 #30631
milamber
ParticipantI had installed the beta version VisualGDB-5.6.1.4114. Then when I tried to install the version VisualGDB-5.6.1.4134 i got an error “The specified account already exists” from the installer. After running the Microsoft troubleshooter (Fix problems that block programs from being installed or removed (microsoft.com) I was able to install visualgdb. Nevertheless when i tried to open a project in visual studio I get “There was a problem opening ‘CMakeLists.txt’. Please load the ‘xxxxx (incompatible)’ project and try again” error code 0x0000139f. it doesn’t seem that visualbdb is installed in vs2019. No visualgdb menus appear in vs2019. I uninstalled the beta version and installed the stable version but the problem remains. rebooted the computer, visualgdb appears in the list of ‘add and remove programs’ but no menus appear in vs2019 and vs cant open a project
June 5, 2021 at 07:41 #30632support
No problem. Please follow the instructions on the following page to fix this: https://visualgdb.com/support/loadfail/
June 5, 2021 at 11:54 #30634milamber
Participant<p style=”margin: 0in; font-family: Calibri; font-size: 11.0pt;”>Apparently the microsoft troubleshooter has deleted the key :’16.0′ value ; ‘C:\Program Files (x86)\Microsoft Visual Studio\2019\Enterprise’ under HKLM\SOFTWARE\Wow6432Node\Microsoft\VisualStudio\SxS\VS7\<version></p>
<p style=”margin: 0in; font-family: Calibri; font-size: 11.0pt;”>I have added the key and reinstalled VGDB but nothing happened. Then I repaired the VS installation and now vgdb menus are showing up, but when I am trying to open my solution I get the clang popup but by project is not loaded with the following message:</p>
System.Exception: No find_bsp statements in C:\xxxxx\.\CMakeLists.txt
at td3.n(b41 c, CMakeTargetReference& d, String a, Boolean b)
at td3.c1(CMakeTargetReference b, CMakeTargetReference a, CMakeTargetReference c)
at td3.p(String b, String a)
at ui1..ctor(cy1 c, EmbeddedProjectSubsystemSettings a, rx1 b)
at in2.b_4(cy1 b, rx1 a)
at zz..ctor(VisualGDBProjectSettings2 d, s01 f, bd1 b, e e, rx1 c, IDELevelProjectInfoForBuilding a)
at wh1.z(IDELevelProjectInfoForBuilding a)
at wh1.k5(qm1 a)
at wh1.e3(p5 a, Int32 b)
<p style=”margin: 0in; font-family: Calibri; font-size: 11.0pt;”></p>June 5, 2021 at 12:01 #30635milamber
Participanthere is the cmakelists.txt
cmake_minimum_required(VERSION 3.15)
project(test_mx LANGUAGES C CXX ASM)
find_bsp(ID com.sysprogs.project_importers.stm32.cubemx
SOURCE_PROJECT test_mx.ioc)
bsp_linker_flags()
bsp_include_directories(.)
add_bsp_based_executable(NAME test_mx
GENERATE_BIN
GENERATE_MAP
SOURCES
${BSP_ROOT}/i2c_comm.c
${BSP_ROOT}/i2c_comm.h
${BSP_ROOT}/prog_serial.c
${BSP_ROOT}/prog_serial.h
${BSP_ROOT}/x_serial.c
${BSP_ROOT}/x_serial.h
${BSP_ROOT}/Readme.md
${BSP_ROOT}/../.gitignore
${BSP_ROOT}/i2c_timing_utility.c
${BSP_ROOT}/i2c_timing_utility.h
${BSP_ROOT}/heap_useNewlib_ST.c
target_link_libraries(test_mx PRIVATE -Wl,--print-memory-usage)
set_source_files_properties(${BSP_ROOT}/Middlewares/Third_Party/FreeRTOS/Source/portable/MemMang/heap_4.c ${BSP_ROOT}/sysmem.c ${BSP_ROOT}/syscalls.c PROPERTIES HEADER_FILE_ONLY TRUE)
June 5, 2021 at 13:57 #30637support
This looks like the .vgdbcmake and CMakeLists.txt files got out-of-sync. Please try creating a new project for the same device from scratch and check if it works. If it does, please try comparing the .vgdbcmake and CMakeLists.txt files between the 2 projects and adjusting the broken project until it matches the one that loads successfully.
