Sysprogs forums › Forums › VisualGDB › There is an error in XML document
- This topic has 6 replies, 2 voices, and was last updated 10 years, 4 months ago by
December 3, 2015 at 14:58 #7285
osnwt
ParticipantHello,
Used VisualGDB a lot for Linux projects. All was fine till some day. But suddenly it started complaining “Cannot perform inline build: There is an error in XML document (148, 23)”, and the build is “running” but nothing happens, I have to stop it by a command to close the solution. If the behavior starts to occur, it is exactly the same for old existing projects as well as when I try to create a new “Hello world” Linux project with VisualGDB. It even cannot create new demo.
More details (probably irrelevant, but who knows): I have an “imported” linux project to be built via ssh natively. The sources are on a Windows computer. The VisualGDB project was created in a separate directory and references to the source directory. Sources are copied to linux to be built. I need two copies of this project to be built on two different linux boards. So I made two VisualGDB projects which both refer to the same source and open two copies of VisualStudio. Changes of any source immediately reloaded into the other VisualStudio.
I have never seen such behavior till now. Do you have any ideas what is the XML document it refers to, and what can I do?
Thanks!
December 3, 2015 at 15:12 #7286osnwt
ParticipantHere is some verbose output:
1>------ Build started: Project: trsim1.vgdb, Configuration: Debug Win32 ------ 1> VisualGDB: using project file C:\trsim1.vgdb\trsim1.vgdb.vcxproj 1> VisualGDB: using solution file C:\trsim1.vgdb\trsim1.vgdb.sln 1> VisualGDB: using configuration Debug 1> VisualGDB: Trying to detect if your Makefiles need updating... Using configuration: Debug|Win32 1> SSH: Looking up host... 1> SSH: Connecting... 1> SSH: Handshaking... 1> SSH: Checking key... 1> SSH: Authenticating... 1> Build/launch failed: В документе XML (148, 23) присутствует ошибка. 1> ------------------------------ 1> Detailed exception info: 1> System.InvalidOperationException: В документе XML (148, 23) присутствует ошибка. ---> System.Xml.XmlException: "", шестнадцатеричное значение 0x1B, является недопустимым знаком., строка 148, позиция 23. 1> в System.Xml.XmlTextReaderImpl.Throw(Exception e) 1> в System.Xml.XmlTextReaderImpl.Throw(String res, String[] args) 1> в System.Xml.XmlTextReaderImpl.Throw(Int32 pos, String res, String[] args) 1> в System.Xml.XmlTextReaderImpl.ParseNumericCharRefInline(Int32 startPos, Boolean expand, StringBuilder internalSubsetBuilder, Int32& charCount, EntityType& entityType) 1> в System.Xml.XmlTextReaderImpl.ParseCharRefInline(Int32 startPos, Int32& charCount, EntityType& entityType) 1> в System.Xml.XmlTextReaderImpl.ParseText(Int32& startPos, Int32& endPos, Int32& outOrChars) 1> в System.Xml.XmlTextReaderImpl.ParseText() 1> в System.Xml.XmlTextReaderImpl.ParseElementContent() 1> в System.Xml.XmlTextReaderImpl.Read() 1> в System.Xml.XmlTextReader.Read() 1> в System.Xml.XmlReader.ReadElementString() 1> в Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReaderHostWideSettingsCollection.Read2_Record(Boolean isNullable, Boolean checkType) 1> в Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReaderHostWideSettingsCollection.Read3_ModifiedEnvirionment(Boolean isNullable, Boolean checkType) 1> в Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReaderHostWideSettingsCollection.Read4_HostSettings(Boolean checkType) 1> в Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReaderHostWideSettingsCollection.Read5_HostWideSettingsCollection(Boolean isNullable, Boolean checkType) 1> в Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReaderHostWideSettingsCollection.Read6_HostWideSettingsCollection() 1> --- Конец трассировки внутреннего стека исключений --- 1> в System.Xml.Serialization.XmlSerializer.Deserialize(XmlReader xmlReader, String encodingStyle, XmlDeserializationEvents events) 1> в System.Xml.Serialization.XmlSerializer.Deserialize(Stream stream) 1> в BSPEngine.XmlTools.LoadObject[_Ty](String xmlFile, Type[] extraTypes) 1> в VisualGDB.Backend.SharedXmlSettingsContainer`1.c() 1> в ft.a() 1> в ft..ctor(yk A_0, SSHConnectionSettings A_1, Boolean A_2, le A_3) 1> в q8.a(String A_0, String A_1) 1> в q8.b.a(String A_0, String A_1, a A_2) 1> в q8.a(RemoteHostSettings A_0) 1> в rx.a(RemoteHostSettings A_0, Boolean A_1) 1> в d7.a(SourceTransferAction A_0, SourceCache A_1, aj3 A_2, Int32& A_3) 1> в acu.a(Boolean A_0, Boolean& A_1) 1> в ace.a(BuildMode A_0, a A_1) 1> в ace.b(BuildMode A_0, a A_1) 1> в no.a(String A_0, String A_1, BuildMode A_2, ael A_3, String A_4, String A_5) 1> в no.a(String[] A_0) 1> ------------------------------ 1> Detailed exception info: 1> System.Xml.XmlException: "", шестнадцатеричное значение 0x1B, является недопустимым знаком., строка 148, позиция 23. 1> в System.Xml.XmlTextReaderImpl.Throw(Exception e) 1> в System.Xml.XmlTextReaderImpl.Throw(String res, String[] args) 1> в System.Xml.XmlTextReaderImpl.Throw(Int32 pos, String res, String[] args) 1> в System.Xml.XmlTextReaderImpl.ParseNumericCharRefInline(Int32 startPos, Boolean expand, StringBuilder internalSubsetBuilder, Int32& charCount, EntityType& entityType) 1> в System.Xml.XmlTextReaderImpl.ParseCharRefInline(Int32 startPos, Int32& charCount, EntityType& entityType) 1> в System.Xml.XmlTextReaderImpl.ParseText(Int32& startPos, Int32& endPos, Int32& outOrChars) 1> в System.Xml.XmlTextReaderImpl.ParseText() 1> в System.Xml.XmlTextReaderImpl.ParseElementContent() 1> в System.Xml.XmlTextReaderImpl.Read() 1> в System.Xml.XmlTextReader.Read() 1> в System.Xml.XmlReader.ReadElementString() 1> в Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReaderHostWideSettingsCollection.Read2_Record(Boolean isNullable, Boolean checkType) 1> в Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReaderHostWideSettingsCollection.Read3_ModifiedEnvirionment(Boolean isNullable, Boolean checkType) 1> в Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReaderHostWideSettingsCollection.Read4_HostSettings(Boolean checkType) 1> в Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReaderHostWideSettingsCollection.Read5_HostWideSettingsCollection(Boolean isNullable, Boolean checkType) 1> в Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReaderHostWideSettingsCollection.Read6_HostWideSettingsCollection() 1> ------------------------------ 1> Product version: 5.0.18.529
December 6, 2015 at 03:40 #7301support
Most likely one of the .sshconnection files in %APPDATA%\VisualGDB\SSHConnections got corrupt. Please try removing those files and recreating the connection via Tools->SSH Connections.
December 7, 2015 at 11:09 #7308osnwt
ParticipantUnfortunately, no. All files are ok.
Also, I created a new connection using IP address as a host name, login/password authentication. Then started to create a new project, and got the same error in XML document 148, 23.
I should tell that user has been logged in successfully in both cases, and error is shown after login.
Please tell me what else can I do to help debugging this issue.
This reply was modified 10 years, 4 months ago by
osnwt.
December 9, 2015 at 20:05 #7317support
The only other place that could be related is the HostWideSettings.xml file in the same directory. Please try removing that file.
December 12, 2015 at 13:43 #7335osnwt
ParticipantRemoval of that file has helped.
Thank you!
December 12, 2015 at 20:05 #7339support
KeymasterNo problem. Enjoy VisualGDB!
