The system cannot find the file specified
Sysprogs forums Forums VisualGDB The system cannot find the file specified
  • #32163
    tzgardner
    I’m getting the error mentioned in the title.  The file that it specifies is “make (e=2)”.  Not sure what this means.
    I’m new to VisualGDB and have inherited a Visual Studio project.  I just tried to build and get the error.
    • This topic was modified 4 years, 1 month ago by tzgardner.
    #32169
    Unfortunately, it is hard to suggest anything specific based on the description you provided.
    Please provide complete and detailed steps to reproduce the issue as described below:
    1. The steps should begin with launching Visual Studio. They should include every step necessary to create the project from scratch and reproduce the issue.
    2. Please make sure the steps do not involve any 3rd-party code as we will not be able to review it. If the problem only happens with a specific project, please make sure you can reproduce it on a clean project created from scratch.
    3. The steps should include uncropped screenshots of all wizard pages, VisualGDB Project Properties pages and any other GUI involved in reproducing the problem. This is critical for us to be able to reproduce the problem on our side.
