Sysprogs forums › Forums › VisualGDB › Texane debugger missing
- This topic has 4 replies, 2 voices, and was last updated 9 years ago by
rolfnoot.
February 21, 2017 at 00:11 #10500
rolfnoot
I’m missing the Texane debugger from the list of packages. How can it be installed?
Also using openOCD is starting debugging much slower on VisualGDB than SW4STM32 (GBD load: 8 seconds vs 50 seconds).
Info: Open On-Chip Debugger 0.9.0 (2016-10-14) [https://github.com/sysprogs/openocd] on the latest VGDB.
Regards,
Rolf
February 21, 2017 at 02:56 #10503support
We have discontinued the Texane debugger as it was less reliable than OpenOCD. You can still download it from github and specify as “custom gdb stub”, but we no longer ship a pre-built one with VisualGDB.
Slow loads could be the case if you are using a VM with USB virtualization, but should normally not happen on physical machines. If you are not using a VM, please try enabling the timing analysis mode in the GDB Session window and then check which command takes most of the time. Perhaps you are programming a large image with OpenOCD and a smaller one with the ST tool?
February 21, 2017 at 08:57 #10508rolfnoot
ParticipantThanks for your quick reply!
Yes, I’m using a VM with Windows (On mac using parallels). It’s the same code size I’m programming.
Also, can you tell me how to install the custom GBD stub to operate with Texane?
Thanks!
February 22, 2017 at 18:18 #10516support
You would need to download Texane ST-Link sources from github and build them.
Then you can actually reuse the definition file that we made when we supported it officially: create a %LOCALAPPDATA%\VisualGDB\EmbeddedDebugPackages\texane folder and copy st-util and st-flash there. Then create a edp.xml file with the following contents:
<?xml version="1.0"?> <EmbeddedDebugPackage xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"> <PackageID>com.sysprogs.arm.texane-stlink</PackageID> <PackageVersion>1.2</PackageVersion> <GNUTargetFilter>^arm-.*</GNUTargetFilter> <UserFriendlyName>Texane ST-Link</UserFriendlyName> <SupportedDebugMethods> <DebugMethod> <UserFriendlyName>Texane ST-Link</UserFriendlyName> <ID>texane-stlink</ID> <GDBServerApplication>$$SYS:DMSP_ROOT$$\st-util.exe </GDBServerApplication> <GDBServerArguments> <GNUStyle>true</GNUStyle> <Properties> <PropertyGroups> <PropertyGroup> <Properties> <PropertyEntry xsi:type="Enumerated"> <Name>ST-Link Version</Name> <UniqueID>com.sysprogs.arm.texane-stlink.version</UniqueID> <Description>Specifies the ST-Link version</Description> <SuggestionList> <Suggestion> <UserFriendlyName>ST-Link v1</UserFriendlyName> <InternalValue>-1</InternalValue> </Suggestion> <Suggestion> <UserFriendlyName>ST-Link v2</UserFriendlyName> <InternalValue></InternalValue> </Suggestion> </SuggestionList> <DefaultEntryIndex>1</DefaultEntryIndex> <AllowFreeEntry>false</AllowFreeEntry> </PropertyEntry> <PropertyEntry xsi:type="Boolean"> <Name>Reset target before programming</Name> <UniqueID>com.sysprogs.arm.texane-stlink.resetcommand</UniqueID> <Description>Automatically resets the target before programming</Description> <DefaultValue>false</DefaultValue> <ValueForTrue>mon reset</ValueForTrue> </PropertyEntry> </Properties> <CollapsedByDefault>false</CollapsedByDefault> </PropertyGroup> </PropertyGroups> </Properties> </GDBServerArguments> <GDBServerDelay>500</GDBServerDelay> <GDBStartupCommands> <string>target remote :4242</string> <string>$$com.sysprogs.arm.texane-stlink.resetcommand$$</string> <string>load</string> </GDBStartupCommands> <UseContinueToStart>true</UseContinueToStart> <SendCtrlCToGDBServer>false</SendCtrlCToGDBServer> <RequireExplicitDisconnect>true</RequireExplicitDisconnect> </DebugMethod> </SupportedDebugMethods> </EmbeddedDebugPackage>
This will add it to the list of VisualGDB’s debug methods so you won’t need to configure anything manually.
February 22, 2017 at 22:48 #10518rolfnoot
ParticipantThanks a lot! I’ll try this.
For now I ended up reprogramming the ST-link as Segger J-link which works extremely fast and stable.
Regards!
