Sysprogs forums › Forums › VisualGDB › template {{ENTER}} question
- This topic has 2 replies, 3 voices, and was last updated 3 years, 9 months ago by
michael127001.
June 23, 2022 at 02:12 #32778
kenohuyi
ParticipantHello,
Every time I type
template {{ENTER}}the next line is indented.This is very irritating. How can it be disabled?
June 23, 2022 at 08:17 #32779support
June 24, 2022 at 09:26 #32782michael127001
ParticipantI assume you are editing a cpp file in a VisualGDB project. I see what you mean that the next newline after typing
template {{is indented to the same length as the end of the wordtemplate. I thought you were typing ENTER literally at first 😅You can edit the clang-formatting settings at the document icon in the upper-right corner of the open source file:
I couldn’t find the exact setting to fix your issue, but you might find it in there. You can also try different formatting styles based on chromium, mozilla, google, etc. or disable the formatting entirely. I usually prefer to format on save or manually anyway.
This reply was modified 3 years, 9 months ago by
michael127001.
michael127001.
michael127001.
michael127001.
