Sysprogs forums › Forums › VisualGDB › Synchronize header and libraries error
- This topic has 2 replies, 2 voices, and was last updated 11 years, 3 months ago by
June 20, 2015 at 22:34 #6631
Jetty
ParticipantHi everbody,
I am trying to start a new project after a complete format of my computer and I have this error when trying to Synchronize headers and libraries :
Downloading /lib…
Downloading /usr/include…
tar: python2.6/numpy : stat impossible: Aucun fichier ou dossier de ce type
tar: python2.6_d/numpy : stat impossible: Aucun fichier ou dossier de ce type
tar: Arrêt avec code d’échec à cause des erreurs précédentes
Downloading /usr/lib…I Know it is in French but if anyone can help me it will be great.
King regards
JETTY
June 21, 2015 at 00:54 #6634Jetty
Participantis the error have a relation with this one ?
1>—— Début de la génération : Projet : LinuxProject10, Configuration : Debug Win32 ——
1>La génération a démarré 21/06/2015 01:52:12.
1>Build:
1> VisualGDB: Run “cmd.exe /c “C:\SysGCC\raspberry\bin\make.exe” CONFIG=Debug” in directory “G:\projectvisual\LinuxProject10\LinuxProject10” on local computer
1> C:/SysGCC/raspberry/bin/arm-linux-gnueabihf-g++.exe -ggdb -ffunction-sections -O0 -IC:/SysGCC/raspberry/arm-linux-gnueabihf/sysroot/usr/local/include -DDEBUG -c LinuxProject10.cpp -o Debug/LinuxProject10.o -MD -MF Debug/LinuxProject10.dep
1> C:/SysGCC/raspberry/bin/arm-linux-gnueabihf-g++.exe -o Debug/LinuxProject10 -Wl,-gc-sections -Wl,–start-group Debug/LinuxProject10.o -lpthread -lwiringPi -Wl,–rpath=’$ORIGIN’ -Wl,–end-group
1> c:/sysgcc/raspberry/bin/../lib/gcc/arm-linux-gnueabihf/4.9/../../../../arm-linux-gnueabihf/lib/libstdc++.so: undefined reference to `clock_gettime@GLIBC_2.17′
1> make: *** [Debug/LinuxProject10] Error 1
1> ————————————————————-
1> Command exited with code 2
1> Executable: cmd.exe
1> Arguments: /c “C:\SysGCC\raspberry\bin\make.exe” CONFIG=Debug
1> Directory: G:\projectvisual\LinuxProject10\LinuxProject10
1>C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\Microsoft.MakeFile.Targets(38,5): error MSB3073: La commande “”C:\Program Files (x86)\Sysprogs\VisualGDB\\VisualGDB.exe” /build “G:\projectvisual\LinuxProject10\LinuxProject10\LinuxProject10.vcxproj” “/solution:G:\projectvisual\LinuxProject10\LinuxProject10.sln” “/config:Debug” “/platform:Win32″” s’est arrêtée avec le code 1.
1>
1>ÉCHEC de la build.
1>
1>Temps écoulé 00:00:00.98
========== Génération : 0 a réussi, 1 a échoué, 0 mis à jour, 0 a été ignoré ==========For information I am following the tutorial here : http://visualgdb.com/tutorials/raspberry/wiringPi/
Best regard
June 23, 2015 at 20:08 #6638support
KeymasterLooks like the first problem is caused by some broken symlinks on the Linux side. You can investigate this by running “ls -l” in the target directory and checking that all symlink targets exist.
The glibc problem can be caused by incompatibility between your toolchain and the system image. Please try the instructions described here: http://sysprogs.com/w/forums/topic/raspberrypi-undefined-reference-to-clock_gettimeglibc_2-17/
