Switch between toolchains
Sysprogs forums Forums VisualGDB Switch between toolchains
  • #6843
    apettel
    I have installed the SysProgs 4.9.2 and the SysProgs 5.2.0 GCC-ARM toolchains. Both toolchains show up in the “Embedded Tool Manager”.
    But i am still not able to select the toolchain from “Visual GDB Properties”->”Makefile Settings”->”Build tools”->”Toolchain”, since the dropdown list is greyed out.
    #6844
    apettel
    I’m using VisualGDB 5.0r3 and Visual Studio 2013 and 2015
    #6846
    We do not allow switching toolchains for existing projects because different toolchains have different settings formats and switching them may introduce serious bugs. We would recommend creating a new project and then importing the existing files into it. If you absolutely want to override the toolchain, you can edit the <mcu>.xml and <mcu>.mak files in your project directory replacing the references manually.
