Sysprogs forums › Forums › VisualGDB › STUCKED!! Issues with ESP32 R.16 toolchain and VisualGDV 5.4
- This topic has 3 replies, 2 voices, and was last updated 7 years, 8 months ago by
January 14, 2019 at 14:04 #23437
lzambonelli @mexage
ParticipantHi Support,
My project (ESP-IDF), after updating both toolchain (R16) and VisualGDB (4.2) does not compile anymore.
At first i had to change manualli project file .vgdbproj and changed to 3.2 path, otherwise VS2017 wasn’t able to open project
<IDFCheckout> <Version>release/v3.2</Version> <Subdirectory>esp-idf/v3.2</Subdirectory> </IDFCheckout>
Then, i’ve cleaned solution, rebuilt and i’m getting
Severity Code Description Project File Line Suppression State Error undefined reference to `_loader_text_start' SimplyConnect C:/Projects/Mexage/xxx-IOT/source/Debug/bootloader/bootloader_support\libbootloader_support.a(esp_image_format.o) Error undefined reference to `_loader_text_end' SimplyConnect C:/Projects/Mexage/xxx-IOT/source/Debug/bootloader/bootloader_support\libbootloader_support.a(esp_image_format.o) Error undefined reference to `MD5Update' SimplyConnect C:/Projects/Mexage/xxx-IOT/source/Debug/bootloader/bootloader_support\libbootloader_support.a(flash_partitions.o) Error undefined reference to `MD5Final' SimplyConnect C:/Projects/Mexage/xxx-IOT/source/Debug/bootloader/bootloader_support\libbootloader_support.a(flash_partitions.o) Error undefined reference to `MD5Init' SimplyConnect C:/Projects/Mexage/xxx-IOT/source/Debug/bootloader/bootloader_support\libbootloader_support.a(flash_partitions.o) Error undefined reference to `MD5Init' SimplyConnect C:\SysGCC\esp32\esp-idf\v3.2\components\bootloader_support\src\flash_partitions.c 45 Error undefined reference to `MD5Update' SimplyConnect C:\SysGCC\esp32\esp-idf\v3.2\components\bootloader_support\src\flash_partitions.c 53 Error undefined reference to `MD5Final' SimplyConnect C:\SysGCC\esp32\esp-idf\v3.2\components\bootloader_support\src\flash_partitions.c 54
Do you have any idea?
My team cannot work with that issue!
Thanks in advance
Leonardo Zambonelli
This topic was modified 7 years, 8 months ago by
lzambonelli @mexage.
January 14, 2019 at 18:11 #23441support
Please try doing a full project rebuild (Build->Rebuild All). If this doesn’t help, please try creating a new project and if it doesn’t built, reinstall the toolchain.
If nothing helps, you can install the previous ESP-IDF (v3.1) via VisualGDB Project Properties -> ESP-IDF Settings. Simply use the “install” button on the ESP-IDF version selection control.
January 15, 2019 at 08:29 #23475lzambonelli @mexage
ParticipantHi, thanks for your reply.
Already reverted to previous version. Everything works good
Hope to get the fixed update to R16 as it will be available. It’s strange , because i had the same issue when you updated from 3.0 to 3.1.
Regards
Leonardo
January 15, 2019 at 19:17 #23478support
KeymasterThe issue is likely caused by some internal changes between different ESP-IDF versions. Normally doing a full rebuild should fix this (if you can confirm this, we can update VisualGDB to trigger a full rebuild automatically if the project was previously built with a different toolchain).
Please let us know whether a rebuild fixes the problem. If not, please also try creating a new project with the new toolchain and let us know if that works.
