Sysprogs forums › Forums › VisualKernel › Stuck on Loading LinuxKernelDebugHelper Module
- This topic has 2 replies, 3 voices, and was last updated 10 years, 5 months ago by
May 19, 2015 at 15:26 #6481
Moffatt
ParticipantI’m attempting to evaluate using VisualKernel for my development on the BeagleBone Black.
I have a Linux VM that I build my kernel on and then deploy to the BeagleBone Black, unfortunately when I attempt to debug with VisualKernel I get stuck on the Loading LinuxKernelDebugHelper module.
The following is the ouput from the details of VisualKernel.
make: Entering directory `/home/nanoptix/develop/dev20150407_SM_TI_SDK_V8_Investigation/linux-3.14.26-g2489c02′
CC [M] /tmp/LinuxKernelDebugHelper-3142ca0b-37b3-4934-bdf4-cc2b6d847c1a/AppendableBuffer.o
In file included from /tmp/LinuxKernelDebugHelper-3142ca0b-37b3-4934-bdf4-cc2b6d847c1a/AppendableBuffer.c:3:0:
/tmp/LinuxKernelDebugHelper-3142ca0b-37b3-4934-bdf4-cc2b6d847c1a/AppendableBuffer.h:14:13: warning: ‘ResetAppendableBuffer’ defined but not used [-Wunused-function]
CC [M] /tmp/LinuxKernelDebugHelper-3142ca0b-37b3-4934-bdf4-cc2b6d847c1a/LinuxKernelDebugHelper_main.o
In file included from /tmp/LinuxKernelDebugHelper-3142ca0b-37b3-4934-bdf4-cc2b6d847c1a/LinuxKernelDebugHelper_main.c:5:0:
/tmp/LinuxKernelDebugHelper-3142ca0b-37b3-4934-bdf4-cc2b6d847c1a/SerialInterface.h:32:26: warning: multi-character character constant [-Wmultichar]
/tmp/LinuxKernelDebugHelper-3142ca0b-37b3-4934-bdf4-cc2b6d847c1a/SerialInterface.h:33:27: warning: multi-character character constant [-Wmultichar]
/tmp/LinuxKernelDebugHelper-3142ca0b-37b3-4934-bdf4-cc2b6d847c1a/LinuxKernelDebugHelper_main.c:20:2: warning: multi-character character constant [-Wmultichar]
/tmp/LinuxKernelDebugHelper-3142ca0b-37b3-4934-bdf4-cc2b6d847c1a/LinuxKernelDebugHelper_main.c:23:2: warning: initialization makes integer from pointer without a cast [enabled by default]
/tmp/LinuxKernelDebugHelper-3142ca0b-37b3-4934-bdf4-cc2b6d847c1a/LinuxKernelDebugHelper_main.c:23:2: warning: (near initialization for ‘KernelDebugDataBlock.Reserved’) [enabled by default]
CC [M] /tmp/LinuxKernelDebugHelper-3142ca0b-37b3-4934-bdf4-cc2b6d847c1a/SequentialModuleInfo.o
In file included from /tmp/LinuxKernelDebugHelper-3142ca0b-37b3-4934-bdf4-cc2b6d847c1a/SequentialModuleInfo.h:2:0,
from /tmp/LinuxKernelDebugHelper-3142ca0b-37b3-4934-bdf4-cc2b6d847c1a/SequentialModuleInfo.c:2:
LD [M] /tmp/LinuxKernelDebugHelper-3142ca0b-37b3-4934-bdf4-cc2b6d847c1a/LinuxKernelDebugHelper.o
Building modules, stage 2.
MODPOST 1 modules
CC /tmp/LinuxKernelDebugHelper-3142ca0b-37b3-4934-bdf4-cc2b6d847c1a/LinuxKernelDebugHelper.mod.o
LD [M] /tmp/LinuxKernelDebugHelper-3142ca0b-37b3-4934-bdf4-cc2b6d847c1a/LinuxKernelDebugHelper.ko
make: Leaving directory `/home/nanoptix/develop/dev20150407_SM_TI_SDK_V8_Investigation/linux-3.14.26-g2489c02′Any assistance would be appreciated. Let me know if you need more information.
Thanks.
August 11, 2015 at 14:17 #6820janulo
ParticipantI have exactly the same problem with Toradex Colibri VF50.
I’m trying to debug LinuxKernelModule using VirtualBox Ubuntu 14.04 and as target Toradex Colibri VF50. Build is OK and output module is working on target when copied and insmod-ed. Only problem I have is with debug. It looks that loading of LinuxKernelDebugHelper.ko module, build automaticaly when debug is started, fails.
I can see error messages in target console:
[ 3597.524567] LinuxKernelDebugHelper: Unknown symbol tracepoint_probe_register (err 0) [ 3597.546720] LinuxKernelDebugHelper: Unknown symbol tracepoint_probe_unregister (err 0)
Any solution to fix this?
September 22, 2015 at 23:40 #6963support
Normally, tracepoint_probe_register() should be defined in source/kernel/tracepoint.c. Is your kernel patched to exclude it? Does it show in /proc/kallsyms?
