Sysprogs forums › Forums › VisualGDB › Stray character in program.
- This topic has 15 replies, 2 voices, and was last updated 8 years, 1 month ago by
February 15, 2018 at 15:58 #20111
surahman
I’m working on the following rather basic tutorial to port a project to VGDB and I keep getting build errors:
Stray ‘/337’ in program.
But there are no stray/errant characters in the code.
February 15, 2018 at 16:04 #20112surahman
ParticipantFebruary 15, 2018 at 17:05 #20113surahman
ParticipantI forgot to add this is the tutorial I am working with: https://visualgdb.com/tutorials/porting/lxss/
February 15, 2018 at 17:16 #20114support
Please try removing the entire contents of the file and see if his helps the compilation. If it does, put half of the contents back and check again. Repeating this a few times, narrowing the scope each time should help pinpoint the location of the character.
Another option would be to try saving the file under a different encoding via File -> Save As (GCC may not support rare encodings that VS might be aware of).
February 16, 2018 at 00:08 #20119surahman
ParticipantI’m now getting the following error when I try to “convert” an already built project to use VisualGDB:
VisualGDB version: 5.3.18.1973
—————— System.InvalidOperationException ——————
System.InvalidOperationException: Platform ‘VisualGDB’ referenced in the project file ‘Server’ cannot be found.
at Microsoft.Verify.FailOperation(String message, Object[] args)
at Microsoft.VisualStudio.Project.VisualC.VCProjectEngine.VCProjectShim.<AddPlatformNoEventsAsync>d__336.MoveNext()
— End of stack trace from previous location where exception was thrown —
at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)
at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
at Microsoft.VisualStudio.Project.VisualC.VCProjectEngine.VCProjectShim.<>c__DisplayClass61_0.<<AddPlatform>b__0>d.MoveNext()
at Microsoft.VisualStudio.Project.VisualC.VCProjectEngine.ApartmentMarshaler.<>c__DisplayClass7_0.<<Invoke>b__0>d.MoveNext()
at Microsoft.VisualStudio.Threading.JoinableTask.CompleteOnCurrentThread()
at Microsoft.VisualStudio.Project.VisualC.VCProjectEngine.ApartmentMarshaler.Invoke(Func`1 method)
at Microsoft.VisualStudio.Project.VisualC.VCProjectEngine.VCProjectShim.AddPlatform(String platformName)
at mw.AddNewPlatformAndEnsureConfigurations(String b, String[] a)
at w9.b(qp1 f, IProjectEditContext e, t b, hj1 d, l g, Boolean c, a[] a)
at d61.c_2(v1 a, IProjectEditContext c, qp1 b, String d)
at jb1.NewLinuxConfiguration.Execute()February 16, 2018 at 05:05 #20122support
Looks like you have accidentally deleted the VisualGDB MSBuild platform. Please try repairing VisualGDB via Control Panel -> Add/Remove Programs.
February 16, 2018 at 16:48 #20126surahman
ParticipantThe problem persists, unfortunately.
February 16, 2018 at 18:15 #20128support
Strange. Another option would be to uninstall VisualGDB, repair the VS installation via the VS Installer, and install VisualGDB back. If this still doesn’t help, please let us know which Visual Studio version you are using and where is it installed and we will provide more detailed steps on diagnosing MSBuild-related files.
February 16, 2018 at 20:14 #20129surahman
ParticipantI uninstalled VisualGDB and that didn’t help. Repairing VS2017 Enterprise now…
Installation directory is the default one: C:\Program Files (x86)\Microsoft Visual Studio\2017\Enterprise\Common7\IDE
This reply was modified 8 years, 1 month ago by
surahman.
February 16, 2018 at 20:44 #20131support
Thanks for the update. Normally the VisualGDB platform should be installed to the following path:
C:\Program Files (x86)\Microsoft Visual Studio\2017\Enterprise\Common7\IDE\VC\VCTargets\Platforms\VisualGDB
Please double-check that this directory exists. If it doesn’t, please double-check that the VS installation path in registry is correct:
HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Microsoft\VisualStudio\SxS\VS7\15.0
Below is an example of a correct value:
If you change the VS path in the registry, please uninstall and reinstall VisualGDB so that it can pick up the updated path.
February 16, 2018 at 23:07 #20132surahman
ParticipantI can confirm that VGDB is installed in said directory and that the registry key is as specified. I ran a repair of VS2017 and a clean install of VGDB, but the problem still persists. Not sure what to try next.
February 17, 2018 at 02:12 #20139support
Strange. Could you please try creating a new MSBuild-based VisualGDB Linux project from scratch and confirm that the problem still persists? If yes, what are the contents of the C:\Program Files (x86)\Microsoft Visual Studio\2017\Enterprise\Common7\IDE\VC\VCTargets\Platforms\VisualGDB folder?
February 17, 2018 at 06:45 #20140surahman
ParticipantI can confirm that the MSBuild Project wizard works, but I can’t convert a ready-made project.
February 17, 2018 at 07:03 #20141support
Thanks for confirming this. Then it looks like the project file itself is missing some of the elements the normal .vcxproj files should have. The easiest way to pinpoint this would be to use a diffing tool (e.g. KDiff3) to compare the 2 .vcxproj files side-by-side and try editing one of them to make it as close as possible to the other one. Once you encounter the step that causes this problem, you should be able to revert it on the other project to fix it.
February 17, 2018 at 16:06 #20142surahman
ParticipantI think the issue might be that the project I’m trying to convert is one that was built using the VS Cross-platform wizard.
