[SOLVED] Debugging Microsemi SmartFusion2 with Flashpro device and microsemi cus
Sysprogs forums Forums VisualGDB [SOLVED] Debugging Microsemi SmartFusion2 with Flashpro device and microsemi cus
Viewing 13 posts - 1 through 13 (of 13 total)
  • #25426
    christophe
    I’m trying to use VS2017 and VGDB5.4R11 to develop on Microsemi Smartfusion2 (based on a ARM Cortex M3).
    The toolchain comes with a custom Openocd built to support their microsemi FlashPro 4 JTAG interface. I’m not able to use the standard openocd because the lack of the support of a specific target.
    So, i created a custom GDB sub:
    command: link to the specific openocd.exe
    argument (copied from the ECLIPSE properties) : –command “set DEVICE M2S090” –file board/microsemi-cortex-m3.cfg -c “gdb_port 3333” -c init -c “reset init”
    working directory : pointing to the root dirs where i can find “board” directory
    TCP port for gdb 3333
    check Program with “load” command
    The first time i start the debug, all is working fine
    Here is the log:
    ../../src/gcc-8-8.3.0/src/configure --with-pkgversion="Raspbian 8.3.0-6+rpi1" --enable-languages=c,c++ --with-gcc-major-version-only --enable-shared --enable-linker-build-id --without-included-gettext --enable-threads=posix --enable-nls --enable-bootstrap --enable-clocale=gnu --enable-libstdcxx-debug --enable-libstdcxx-time=yes --with-default-libstdcxx-abi=new --enable-gnu-unique-object --disable-libitm --disable-libquadmath --disable-libquadmath-support --enable-plugin --with-system-zlib --with-target-system-zlib --enable-objc-gc=auto --enable-multiarch --disable-sjlj-exceptions --with-arch=armv6 --with-fpu=vfp --with-float=hard --disable-werror --enable-checking=release --target=arm-linux-gnueabihf --with-sysroot=/mnt/f/gnu/raspberry-buster/out/arm-linux-gnueabihf/sysroot --host=i686-w64-mingw32 --prefix /mnt/f/gnu/raspberry-buster/out/ --disable-nls C:\Microsemi\SoftConsole_v6.0\openocd\bin\openocd.exe --command "set DEVICE M2S090" --file board/microsemi-cortex-m3.cfg -c "gdb_port 3333" -c init -c "reset init"
    GNU MCU Eclipse (Microsemi - a Microchip company - SoftConsole build) 64-bit Open On-Chip Debugger 0.10.0+dev-00352-gaa6c7e9b-dirty (2018-10-22-10:08)
    Licensed under GNU GPL v2
    For bug reports, read
    M2S090
    Info : only one transport option; autoselect 'jtag'
    adapter speed: 6000 kHz
    cortex_m reset_config sysresetreq
    trst_only separate trst_push_pull
    do_board_reset_init
    fpServer v17 waiting for incoming connections on the port 3334 with API v5
    Info : 1 1563885367117 microsemi_flashpro_server.c:1739 microsemi_flashpro_initialize() FlashPro ports available: usb07461, E200NO0TX
    Info : 2 1563885367117 microsemi_flashpro_server.c:1740 microsemi_flashpro_initialize() FlashPro port selected: usb07461
    Info : clock speed 6000 kHz
    Info : JTAG tap: M2S090.tap tap/device found: 0x2f8071cf (mfg: 0x0e7 (GateField), part: 0xf807, ver: 0x2)
    Info : JTAG tap: M2S090.tap disabled
    Info : JTAG tap: M2S090.cpu enabled
    Info : Cortex-M3 IDCODE = 0x4ba00477
    Info : M2S090.cpu: hardware has 6 breakpoints, 4 watchpoints
    Info : Listening on port 3333 for gdb connections
    xPSR: 0x01000000 pc: 0x00000190 msp: 0x20010000
    lr (/32): 0x00000000
    xPSR (/32): 0x01000000
    Info : Listening on port 4444 for telnet connections
    Info : accepting 'gdb' connection on tcp/3333
    But, if i stop and restart the debug, i get an error message box saying “Failed to connect to the debug stub. Please click “view gdb stub log” to see the detailed gdb stub output.
    The “gdb stub log” is is the same as the first one.
    If i click on retry, it will work.
    So, except the first time, everytime i debug, i got this error message box and have to click on retry.
    I tried to set a startup delay, but the error seems coming before the delay.
    Can you help me?
    • This topic was modified 7 years, 2 months ago by support. Reason: formatting
    • This topic was modified 7 years, 1 month ago by support. Reason: updated title per user request
    #25431
    This could happen if an old instance of OpenOCD was still running in the background, preventing the new one from listening on port 3333. As an experiment, please try changing the port (by adding -c “gdb_port 1234” to OpenOCD command line) and update the gdb settings accordingly. If this solves the problem, please double-check that the old OpenOCD instance terminates successfully and that no other program is holding the TCP port open (you can use the netstat tool to do that).
    You can also troubleshoot this by starting OpenOCD and trying to telnet to its TCP port. If the connection fails, try disabling the firewall as it sometimes incorrectly prevents programs from connecting to OpenOCD.
    #25440
    christophe
    I tried to change the port, and it didn’t solve the issue. So I’ve checked the netstat info at some point (i returned to port 3333 for these tries)
    When I start the second time the debug session (when i receive the error message box), the netstat -a returns:
    TCP 127.0.0.1:3333  xxxMyPcNamexxx LISTENING
    TCP 127.0.0.1:3334  xxxMyPcNamexxx:57364 ESTABLISHED
    TCP 127.0.0.1:4444  xxxMyPcNamexxx LISTENING
    As soon as i click on the Retry button, i got
    TCP 127.0.0.1:3333  xxxMyPcNamexxx:57372 ESTABLISHED
    When I stop the debug session, all the listening ports are properly removed
    #25442
    Thanks for the update. It looks like the connection succeeds, so the error might be caused by something else.
    Please try switching the GDB Session log to “All GDB Interaction” and check the GDB output for a specific error.
    If you are not sure, please create a full gdb session log and attach it here so that we can review it.
    #25457
    christophe
    here are 2 files :
    abort.txt is the gdb log when i click on the abort button
    retry.txt is the log when i click on the retry button
    #25460
    Thanks, the relevant part of the log is this:
    [     105 ms] -target-select remote :3333
    [    1122 ms] ^error,msg=":3333: No connection could be made because the target machine actively refused it."
    It looks like gdb is indeed trying to connect to port 3333. Please try the following steps:
    1. Reproduce the problem, but don’t press Retry yet.
    2. Run “telnet localhost 3333” from another window (you may need to install Telnet client via Add/Remove Programs -> Windows Features).
    3. If the telnet connection succeeds, close the telnet window and retry the gdb connection.
    4. If the telnet connection fails, double-check that OpenOCD is listening on the port via netstat and that it doesn’t show any errors in the output window when you try to connect to it.
    If you still cannot connect to OpenOCD, please try running it manually and check whether connecting via telnet works.
    #25467
    christophe
    The telnet connection succeeded.
    As explained in a previous message, we checked that the port is in listening mode when the error message box is dispayed (before pressing any button)
    It seems that gdb attempts to connect to the port 3333 a little bit too early.
    Is it possible to specify a delay between the execution of openocd and when gdb attempts to connect to it ?
    #25489
    Oops, sorry we missed that the connection worked after you pressed ‘retry’.
    If you are using the “Custom GDB stub” mode, you can specify additional delay via VisualGDB Project Properties -> Debug Settings -> Startup Delay.
    If not, please let us know what debug mode you are using and we will help you configure the delay.
    #25490
    christophe
    I ve already tried the delay option. Whatever the delay i put,  I always get the error message box directly. But when i click on retry,  I can see the delay.
    I use a custom gdb stub
    #25495
    Strange. Please try setting the delay to something large (e.g. 1 minute) and then enable gdb logging via Advanced GDB Settings. Once VisualGDB begins waiting for the stub to start (i.e. delaying for 1 minute), please double-check in the gdb session log that the ‘target remote’ command hasn’t been issued yet.
    If it is indeed being issued before the delay elapses, please let us know and we will investigate. If it is issued after the delay, please try the following:
    • Start OpenOCD manually before the session and switch from “custom gdb stub” to “custom mode”. Check if this works as expected.
    • Start OpenOCD via the “custom gdb stub” mode and set a long delay (e.g. 10 minutes). Once the delay counter appears, run gdb manually and try connecting to OpenOCD.
    This should help narrow the problem down.
    #25535
    christophe
    Great news, it works !
    So, when i tried the delay option, I still was on an old 5.3 version. It seems that the delay didn’t work as it should.
    On the 5.4 R11, I set a delay to somehting like 250ms and it works as expected.
    So, for people who want to debug Microsemi SmartFusion 2 with VisualGDB :
    1. Choose as debug method : Custom GDB Stub
    2. point the cutsom OpenOCD.exe in the installation of SoftConsole (dev env by microsemi based on eclipse)
    3. add the following command line arg : -c “gdb_port 3333” -f board/microsemi_cortex_m3 -c “set DEVICE M2S090”
    4. In the working dir field, set the OpenOCD scripts directory (in the SoftConsole installation dir)
    Set the Delay to a 250ms
    This configuration allows to debug in internal SRAM (the script configure the VTOR register to the SRAM base address.
    Do not forget to use the xxx-sram/ld linker script provided in the SoftConsole Source package.
    #25536
    christophe
    Could you please update the post title to
    [SOLVED] Debugging Microsemi SmartFusion2 with Flashpro device and microsemi custom version of OpenOCD
    #25548
    Thanks for sharing the solution! We have updated the post.
