STM32 hardware float compilation failure
Sysprogs forums Forums VisualGDB STM32 hardware float compilation failure
  • #8904
    paradajz
    I just downloaded trial version of VisualGDB, and so far, I haven’t even managed to compile a test project. I’ve chosen “STM32F405RG” as processor, selected Hardware float support and then I get the following error:
    Tool arguments: -Wl,–start-group “C:\Users\paradajz\AppData\Local\Temp\/VisualGDB_TrivialProgram.o” -o “C:\Users\paradajz\AppData\Local\Temp\/VisualGDB_TrivialProgram.bin” -Wl,-gc-sections –specs=rdimon.specs -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -TC:\Users\paradajz\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/STM32F4xxxx/LinkerScripts/STM32F405RG_flash.lds -Wl,–end-group
    c:/stm32toolchain/gcc-arm/bin/../lib/gcc/arm-none-eabi/5.4.1/../../../../arm-none-eabi/bin/ld.exe: error: C:\Users\paradajz\AppData\Local\Temp\/VisualGDB_TrivialProgram.o uses VFP register arguments, C:\Users\paradajz\AppData\Local\Temp\/VisualGDB_TrivialProgram.bin does not
    c:/stm32toolchain/gcc-arm/bin/../lib/gcc/arm-none-eabi/5.4.1/../../../../arm-none-eabi/bin/ld.exe: failed to merge target specific data of file C:\Users\paradajz\AppData\Local\Temp\/VisualGDB_TrivialProgram.o
    c:/stm32toolchain/gcc-arm/bin/../lib/gcc/arm-none-eabi/5.4.1/../../../../arm-none-eabi/bin/ld.exe: warning: cannot find entry symbol Reset_Handler; defaulting to 08000000
    Why is this failing?
    #8909
    Looks like your toolchain might not support hardware floating point properly. Please try using the ARM toolchain that comes with VisualGDB.
    #9044
    MajesticRa
    I had exactly the same issue when I first time installed VisualGDB and used my tool chain (installed somewhere in the system).  As support answers, the problem disappeared after I allowed VisualGDB to download toolchain on its own.
