STG_E_FILENOTFOUND in end of project wizard
Sysprogs forums Forums VisualGDB STG_E_FILENOTFOUND in end of project wizard
  • This topic has 3 replies, 2 voices, and was last updated 12 years ago by ket.
  • #730
    Maziar123
    Hi
    i today install visual studio 2013 & also update 1 of it. and install current version of visualGDB
    after it i try create one project for test after i finish last step of wizard get this Error
    VisualGDB
    could not found. Exception from HResult ox8003002
    STG_E_FILENOTFOUND
    an d nothing. Project not create …… !!!!
    #2912
    ket
    It could be a broken Visual Studio installation issue. Did you install Visual Studio for c/c++ ? Generic settings should have this included, if you chose VB.NET only then c/c++ will not be included.
    Which type of VisualGDB project are you trying to make?
    #2913
    Maziar123
    Hi
    Yes your think is True
    is problem happen via installation of vs2013 & 2012 in non default path
    reinstall windows & VS2013 solve problem
    #2914
    ket
    Glad to hear that things are working now. Installing VS in a non-default path should not be related, as VisualGDB uses the VS path from the registry.
