Sysprogs forums › Forums › VisualGDB › ST-Link v2 device not found
- This topic has 9 replies, 4 voices, and was last updated 11 years, 7 months ago by
tekati.
July 25, 2014 at 17:45 #878
rraab
ParticipantI’m getting a “device not found” error using OpenOCD with ST-Link v2 for an STM32F103RBT6. I have the necessary USB drivers installed, and STM’s ST-Link utility connects to the board without issue. I see with “Test selected OpenOCD Settings” that it cannot find any hardware with Vendor ID of 0483 and Device ID of 3748. The driver utility and Windows Device Manager show the ST-Link has the right Vendor ID but has a Device ID of 374B (Note the hex “B” rather than “8”).
Are there any settings I can change to have OpenOCD look for the right Device ID?
(P.S. I’ve tried the Texane debug option and that doesn’t work either.)
July 26, 2014 at 02:19 #3316support
Looks like 374b is mentioned in the stlink-v2-1.cfg configuration file in the OpenOCD directory. You can edit the %LOCALAPPDATA%VisualGDBEmbeddedDebugPackagescom.sysprogs.arm.openocdQuickSetupinterfaces.xml file to make VisualGDB recognize it automatically:
stlink-v2-1
ST-Link v2
interface/stlink-v2-1.cfg
0483
374B
true
NotSupported
com.sysprogs.libusb.mini
July 28, 2014 at 15:07 #3317rraab
ParticipantThat allowed OpenOCD to find the ST-Link, thank you. However I’m now encountering the “OpenOCD error with ST-Link V2” reported by tekati. I’ll be watching that thread for any resolution.
July 31, 2014 at 07:24 #3318tekati
ParticipantI finally got mine to work. This is basically what I had to do or why it did not work to start with.
First off download and install the STLink V2 Drivers and Utility.
This is the link for STSW-LINK003 which is the DRIVERS file from ST
http://www.st.com/st-web-ui/static/active/en/st_prod_software_internet/resource/technical/software/driver/st-link_v2_usbdriver.zip
This is the link for STSW-LINK004 which is the UTILITY file from ST
http://www.st.com/st-web-ui/static/active/en/st_prod_software_internet/resource/technical/software/utility/stsw-link004.zipNow I uninstalled all my current drivers and then installed both of these files and drivers.
Then I plugged my board back in.
Once the drivers installed themselves I went back to Visual Studio and opened up a previous example so I could get to the settings.
Project > VisualGDB Project Properties > Debug settings. Debug Method: OpenOCD. View Mode: Quick Setup. The device type should be autodetected as STM32F4xxx. Programming Interface: ST-Link v2. Before Debugging: Load the program into FLASH/RAM. Then I clicked on the Test selected OpenOCD settings. Now when it asked me to install the WinUSB drivers I actually just hit cancel. I did not try to install them to see if that worked too but since it worked without them and I fought to get that far I just left it alone and OK’ed out. Have not had a problem since.Hope this helps others and if you have questions ask and I will try my best to answer them. Not sure why no one answered this before and for a product that I am expected to purchase I was hoping for better tech support. Now I have 24 days to evaluate the program which should be fine but what else am I going to have issues with and not get any support 🙁
August 1, 2014 at 18:18 #3315rraab
ParticipantI uninstalled all my drivers and reinstalled the ones you linked. When I plugged the STM board back in, Windows failed to install/find the right drivers. However OpenOCD found the ST-Link device. When it prompted for the WinUSB driver, I clicked “no” and it failed with the same error as before. If I click “OK” and install the winusb it still fails same as always. Tried using the driver tool to install the libusb-winusb driver over it, still fails.
The problem may be that the STM32 F103RBT6 I’m using has ST-Link v2.1, perhaps OpenOCD can’t handle that newer protocol. I can’t find any documentation of which ST-Link version the F103RB uses, so I’m not sure. But either way it’s killing me not to be able to debug my program.
August 3, 2014 at 17:08 #3310support
Sorry, we tried reproducing it on our hardware (ST-Link v1 and v2) and could not get the problem. It looks like OpenOCD may not fully support st-link v2.1 at this point. Does the Texane/STLink tool work for your hardware?
August 3, 2014 at 19:22 #3311G40
ParticipantHello Chaps,
OpenOCD 0.8 does support STLink V2.1. Not sure if this has yet made it into the VGDB builds?
August 3, 2014 at 19:25 #3312G40
Is this one of the ST Nucleo boards with mbed support etc? If so try ditching the ST drivers etc. completely and use Zadig to install a WinUSB driver for the board.
Good luck.
August 3, 2014 at 20:49 #3313support
Our build is using the source code from the official 0.8.0 release with the only modification being the Windows 8.1 fix (the package includes a patch file with all our changes to the source).
Could you please confirm that the original OpenOCD works with your hardware but our one does not given the same command-line arguments and driver?August 4, 2014 at 15:17 #3314rraab
ParticipantI ditched the ST drivers and went with the libusb-winusb option in the driver manager. I also changed the “stlink-v2.cfg” that was auto-set to “stlink-v2-1.cfg”, to reflect the ST-Link 2.1 that my board probably uses, and now everything works.
Thank you everyone for your help.
