Sysprogs forums › Forums › WinCDEmu › Source code
- This topic has 17 replies, 3 voices, and was last updated 15 years, 10 months ago by
applet.
June 15, 2009 at 19:47 #76
ParticipantAny chance of obtaining source code for this ?
October 29, 2009 at 01:18 #1011support
KeymasterSure, use the SourceForge download page here:
http://sourceforge.net/projects/wincdemuNovember 1, 2009 at 06:03 #1012applet
I try to build WinCDEmu.
but, indicate some errors.I think some header file not reading.
Could you tell me, Visual Studio’s tools/option/ VC++Directory include and lib Path.Thanks,
November 1, 2009 at 09:04 #1013support
KeymasterYou need BazisLib for that. It comes with automatic installer, so all paths will be set up automatically.
P.S. The only answer to the question ” some header file not reading” could be “you should add something somewhere”. Next time, please specify the exact error message, so I can provide a real answer, not just a guess 😀November 1, 2009 at 10:13 #1014applet
ParticipantSo, Thanks.
I use Visual Studio 2008 Express Edition. I think, It wrong for BazisLib-2.3.1.exe say
Setting up BazisLib…Downloading and unpacking OpenSSL 0.9.8k…
Building OpenSSL…
OpenSSL build failed. Consider rebuilding it manually.
Downloading and unpacking WTL…
Installing WTL wizards…
C:OpenSourceWTLAppWizsetup80.js exited with code 0
C:OpenSourceWTLAppWizMobilesetup80.js exited with code 0
Downloading and unpacking patched STLPort…
Updated Visual Studio include and library directories
Building and installing Project Wizard…
Visual Studio 2008 is required for building Project WizardBazisLib setup completed with some problems.
But, I think Its OK, because, I can manual install and some setting to Visual Studio.
But I did not go so well.
BTW. I have a plan. I get Visual Stdio 2008(not Express). I will try it, next time.Thanks,
November 1, 2009 at 10:31 #1015support
KeymasterVisual Studio Express does not support building ATL applications. So, some user-mode parts of BazisLib and some other stuff will not be functional. Otherwise, should work.
November 4, 2009 at 12:53 #1016applet
I get Visual Studio 2008(90 days Evaluation version).
I use BazisLib-2.2.1(not 2.3.1) and WDK 7600.16385.0 on Windows 7 x64.
I these files they were able build as BazisVirtualCD.sys(x64), VirtDiskBus.sys(x64), vmnt.exe (x64) and uninstall.exe (x86).
Thank you, so much. 😀 BazisLib do automatic setting. My fault, I use BazisLib-2.3.1. 😉BTW, I think nothing installer source code. It name WinCDEmu-2.3.exe. Could you tell me, Where is it?
November 4, 2009 at 19:09 #1017support
KeymasterI did not release the sources of the installer program, as it uses some old not-very-well-written code and has even more dependencies, than BazisLib. I suggest using some other free installer for your custom builds. If you really want to use the original one, I can send you the toolkit for compiling installation scripts and building the EXE, however, got to warn you, it is not very user-friendly 🙂
November 4, 2009 at 21:55 #1018applet
ParticipantThanks, your reply. 😀
It’s OK. I can try make original Installer and
I will put the my digital sign on the program and device drivers.
When it goes well, I will report again.It may be shareware(not free. because you know, digital sign is very expensive).
November 5, 2009 at 08:52 #1020support
KeymasterJust ensure that you don’t violate BazisLib and WinCDEmu license…
November 5, 2009 at 11:57 #1019applet
ParticipantYes. I think so.
I will disclose the execution file and the modified source code by GPL license.
I think that I will send the signed binary directly with E-mail
to the payment of the distribution commission.November 14, 2009 at 08:25 #1021applet
I just release WinCDEmuJ. J is Japanese version Windows Vista x64 and Windows 7 x64.
http://www.appletkan.com/digitalsined.html#WinCDEmuJ_2.3 (sorry, only Japanese.)
http://www.appletkan.com/download/ds-project/WinCDEmuJ_2.3_unsigned_setup.zip
unsigned binary and source. readme-en.txt use English.Thanks,
November 16, 2009 at 13:43 #1022support
KeymasterThanks for the translation. BTW, starting from WinCDEmu 3.0 (will be released soon), it will support language customization.
You can merge your translation into WinCDEmu 3.0 by translating the provided language file (see WinCDEmu homepage).November 17, 2009 at 12:19 #1023applet
ParticipantThank you for your informaion.
I tried translate to Japanese lng file.
I send it.Thanks,
November 17, 2009 at 16:30 #1024support
Version 3.0 is now out. Enjoy 😉 -
