Solution-File (*.sln) on different locations
Sysprogs forums Forums VisualGDB Solution-File (*.sln) on different locations
  • #27294
    runout
    When I start a Project with VGDB-Wizard and “create new”, the *.sln-File
    is placed within the Project-Folder.
    When I start a Project with VGDB-Wizard and “import from gpdsc” (from CubeMx), the *.sln-File
    is placed outside the Project-Folder.
    Is there a good Reason for this behaviour?
    I wish the *.sln-File was inside the Project Folder.
    <span id=”tw-swap” class=”tw-menu-btn” tabindex=”0″ role=”button” aria-label=”Swap languages” data-ved=”2ahUKEwjus_Cv4qrnAhU7A2MBHTTCDRMQ8zQwAHoECAsQAw”></span><span id=”tw-swap” class=”tw-menu-btn” tabindex=”0″ role=”button” aria-label=”Swap languages” data-ved=”2ahUKEwjus_Cv4qrnAhU7A2MBHTTCDRMQ8zQwAHoECAsQAw”></span><span id=”tw-swap” class=”tw-menu-btn” tabindex=”0″ role=”button” aria-label=”Swap languages” data-ved=”2ahUKEwjus_Cv4qrnAhU7A2MBHTTCDRMQ8zQwAHoECAsQAw”></span><span id=”tw-swap” class=”tw-menu-btn” tabindex=”0″ role=”button” aria-label=”Swap languages” data-ved=”2ahUKEwjus_Cv4qrnAhU7A2MBHTTCDRMQ8zQwAHoECAsQAw”></span>Than the Handling with Git (for example) would be easier.
    Kind Regards
    Runout
    #27303
    The location of the project/solution files is normally handled by VS itself (see the checkbox next to the project name/location fields when creating the project).
