Segmentation Error on startup
Sysprogs forums Forums VisualGDB Segmentation Error on startup
  • #9352
    Jodo
    I am cross compiling for ubuntu 15.10 (to an odroid xu4). The very same project worked fine until 2 weeks ago. Now I get a seg error when the programm is starting. Here are some things I found out by now:
    • I can not even use a break point because the seg error occures before the main() is reached
    • The error occures if I want to read a file as a json object anywhere in my code
    • A test programm including such a file reading compilies and runs fine when working directly on the ubuntu machine but fails with the stated error when using visual gdb
    • I believe the error occures since visual gdb did some update about 2 weeks ago. I think it was something about Raspberry Pi. But to be honest I just klicked okay and didn’t read much into it
    Any idea what could cause all of this? I have tried forever now, but can not figure out what it is…
    #9354
    Jodo
    UPDATE: Upgrading fromĀ UbuntuĀ 15.10 to 16.04 fixes the Problem.
    #9404
    22u2
    Is there a tutorial to follow to do cross compiling on odroid xu4? I would like to develop some app on it with Qt
    #9407
    We don’t have a tutorial specific to odroid, but most of the steps for Raspberry Pi and other boards should be the same.
