Got a couple of minor issues with the editor help that I thought I’d report so you can look them over.
One is with the renaming feature, it seems to be a bit buggy visually when there are underscore in the names of what you rename.
The first underscore in what you rename is removed for some reason. This is only a visual bug though and the actual renaming works fine.
But it is a bit confusing when it’s not clear what it will do.
Another issue is the mouseover help you get from comments. The first character of the type is cut off and comes after the comment in a weird way.
See attached files for more info.
Regards
Jens Nilsson
This topic was modified 7 years, 9 months ago by
Jensa.
You must be
