You can use either NFS shares or SMB shares (via samba) to setup folder sharing between two Linux computers. VisualGDB currently does not support configuring those automatically, however there are numerous tutorials on doing that, simply search online for the one relevant for your Linux distro.
Once you have setup the share simply go to VisualGDB Project Properties, Debug page, update the deployment path and enable the “don’t auto-deploy” checkbox. VisualGDB will then assume that the deployment is done by some other tool and will simply launch debugging using the path you have specified.
