Relative paths
Sysprogs forums Forums VisualGDB Relative paths
  • #12671
    hvbill
    Is it possible to have VisualGDB use relative paths for e.g. IntelliSense Directories?
    We will be a bunch of developers working with the same project and the source code location will vary.
    #12674
    Yes, normally you can just use the regular “subdir” or “..\dir\subdir” syntax.
    Also for many cases (like SDK directories), VisualGDB handles this automatically and uses generalized paths like $(BSP_ROOT) instead. Feel free to let us know more about your setup so that we could advise how to set it up in the easiest way.
    #12678
    hvbill
    We’re working in Windows, targeting an ARM-platform. And when I try to replace any of the paths to D:\ (see the attached image) with relative paths, they get replaced with absolute ones the next time a setting is changed that makes VisualGDB test the selected toolchain.
    [Edit: uploaded new image]
    • This reply was modified 8 years, 11 months ago by hvbill.
    #12690
    Those paths should be internally stored as relative paths. You can double-check it via VS project properties (not VisualGDB Project Properties) -> NMake -> Additional Include Directories.
    VisualGDB applies a few internal transformation to the paths when storing them to allow portability across different machines, so the displayed paths are shown as expanded full paths to avoid confusion.
    #12701
    hvbill
    I don’t find the Additional Include Directories mentioned above, but there is a line called Include Search Path with similar content (see attached image), and it also use absolute paths.
    But in VisualGDP Project Properties -> Makefile settings -> Include directories, I finally found my relative paths. These include paths are stored in debug.mak/gcc_Debug.h with relative paths but as soon as I change something in VisualGDP Project Properties, .vcxproj is updated with absolute paths.
    I don’t see how we can avoid to share the .vcxproj file via source control so is there a way to have relative paths there as well?
    #12710
    Sorry for the confusion, Include Search Path is the correct option.
    We have rechecked the behavior for the manually added directories and managed to reproduce and fix the issue. Please try this build: http://sysprogs.com/files/tmp/VisualGDB-5.3.13.1878.msi
    #12718
    hvbill
    It works perfectly!
    Tack så mycket!
