L.S.
I have an issue with the timing in Real-time watch. The timing is of. It assumes a clock of 16MHz, while it is 168MHz. When I do recalibrate in the “Time unit:” window at set it to 168MHz the timing makes sense. An osDelay(100) will last 100ms. In the original position it says 1053ms which comes down to 100*(168/16) = 1050. Unfortunately, after doing “Recalibrate” and restarting the debugging it resets itself. Is there something I am missing that needs to be set in the VisualGDB settings? I have tried to set the “Chronometer” to 168MHz, but that does not help.
Thank you for your time.
Kind regards Björn
VisualGDB version: 5.5R4 (build 3920).
