Raspberry wiringPi.h problem
Sysprogs forums Forums VisualGDB Raspberry wiringPi.h problem
  • #21210
    gunahmt
    Hi everyone,
    I have some problem with my raspberry pi. When i try to this tutorial https://visualgdb.com/tutorials/raspberry/wiringPi/ my project giving error like that;
    ‘ Error wiringPi: No such file or directory ‘
    How can i fix that ? Thanks for help.
    • This topic was modified 7 years, 9 months ago by gunahmt.
    #21213
    Looks like the wiringPi library was either not built/installed successfully, or the toolchain synchronization after it was built did not complete.
    Could you confirm that the “build” command for wiringPi succeeded and that the libwiringPi.so file is present in /usr/lib on your Raspberry Pi and in the corresponding directory inside the toolchain’s sysroot.
    #21240
    gunahmt
    I confirm the “build” command. libwirinPi.so file is present on my raspberry pi :/
    #21244
    Thanks for checking this. Please also check that the .so file is present in the cross-toolchain’s sysroot directory.
    If it does, please try adding “-Wl,-verbose” to the linker flags and check the linker output. It will show where exactly the linker is searching for the library.
    If nothing helps, please attach a screenshot of the error and the build output with the verbose linker mode turned on.
    #21248
    gunahmt
    there is screenshots(Sory about visual studio language 🙁 );
    • This reply was modified 7 years, 8 months ago by gunahmt.
    #21257
    Thanks for the screenshots. Unfortunately as you have cropped them, it is hard to see your project type and give further diagnostic instructions.
    In order to pinpoint this further, please try adding “-Wl,-verbose” to the linker flags as suggested earlier and check the build output.
    #21261
    gunahmt
    is that right? I changed this. But still not working.
    #21269
    gunahmt
    I figure it out the problem. https://visualgdb.com/tutorials/raspberry/crosscompiler/ i tried this tutorial after that i saw that https://visualgdb.com/tutorials/raspberry/wiringPi/ and took error which showed in this topic . When i follow the first link’s tutorial,  i generate project msbuild type thats the reason why i am taking this error. create a new project to use gnu makes that work. thanks for help.
    #21272
    Good to know it works. If you encounter any further problems, feel free to get back to us.
