Sysprogs forums › Forums › Other tools & products › Rasberry Pi QT cross-compiler setup step 16?
- This topic has 0 replies, 1 voice, and was last updated 10 years ago by
matbli.
September 12, 2016 at 15:04 #9041
matbli
Trying to follow http://visualgdb.com/tutorials/raspberry/qt/embedded/ in order to eventually be able to build my Pi application on my Win PC and deploy on my Raspberry Pi 3 using visualGDB.
Every thing works fine up until step 16. I am able to run configure script as described but it end with failure. I have run it with -verbose and enclosed to output in hope any one can provide some help.
+ cd qtbase
+ /c/download/qt-everywhere-opensource-src-5.5.0/qtbase/configure -top-level -platform win32-g++ -xplatform linux-arm-gnueabi-g++ -release -opengl es2 -device linux-rasp-pi2-g++ -sysroot C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -prefix /usr/local/qt5 -device-option CROSS_COMPILE=C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf- -qt-xcb -verbose
Which edition of Qt do you want to use ?Type ‘c’ if you want to use the Commercial Edition.
Type ‘o’ if you want to use the Open Source Edition.This is the Qt Open Source Edition.
You are licensed to use this software under the terms of
the Lesser GNU General Public License (LGPL) versions 2.1.
You are also licensed to use this software under the terms of
the GNU Lesser General Public License (LGPL) versions 3.Type ‘3’ to view the GNU Lesser General Public License version 3.
Type ‘L’ to view the Lesser GNU General Public License version 2.1.
Type ‘yes’ to accept this license offer.
Type ‘no’ to decline this license offer.Do you accept the terms of either license?
Performing shadow build…
Preparing build tree…
Precompiled-headers support enabled.
C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf-g++ -c -fvisibility=hidden fvisibility.c
Symbol visibility control enabled.
c:/sysgcc/raspberry/bin/../lib/gcc/arm-linux-gnueabihf/4.9/../../../../arm-linux-gnueabihf/bin/ld.gold.exe: -plugin: unknown option
c:/sysgcc/raspberry/bin/../lib/gcc/arm-linux-gnueabihf/4.9/../../../../arm-linux-gnueabihf/bin/ld.gold.exe: use the –help option for usage information
C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf-g++ –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -o libtest.so -shared -Wl,-Bsymbolic-functions -fPIC bsymbolic_functions.c
bsymbolic_functions.c:2:2: error: #error “Symbolic function binding on this architecture may be broken, disabling it (see QTBUG-36129).”
Symbolic function binding disabled.
tee: /dev/stderr: No such file or directory
Creating qmake…
make.exe: Nothing to be done for `first’.
Running configuration tests…
Determining architecture… ()
C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf-g++ -c -pipe -march=armv7-a -marm -mthumb-interwork -mfpu=neon-vfpv4 -mtune=cortex-a7 -mabi=aapcs-linux -mfloat-abi=hard –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -g -Wall -W -fPIC -I../../../../qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/arch -I. -Ic:/download/qt-everywhere-opensource-src-5.5.0/qtbase/mkspecs/devices/linux-rasp-pi2-g++ -o arch.obj ../../../../qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/arch/arch.cpp
C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf-g++ -Wl,-rpath-link,C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot/opt/vc/lib -mfloat-abi=hard –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -o arch arch.obj –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot
Found architecture in binary
CFG_ARCH=”arm”
CFG_CPUFEATURES=” neon”
g++ -c -pipe -fno-keep-inline-dllexport -U__STRICT_ANSI__ -g -Wall -Wextra -fno-rtti -fexceptions -mthreads -DUNICODE -DQT_NO_DYNAMIC_CAST -I../../../../qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/arch -I. -Ic:/download/qt-everywhere-opensource-src-5.5.0/qtbase/mkspecs/win32-g++ -o arch.o ../../../../qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/arch/arch.cpp
g++ -Wl,-subsystem,console -mthreads -o arch.exe arch.o
CFG_HOST_ARCH=”i386″
CFG_HOST_CPUFEATURES=””
System architecture: ‘arm’
Host architecture: ‘i386’
C++11 auto-detection… ()
C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf-g++ -c -pipe -march=armv7-a -marm -mthumb-interwork -mfpu=neon-vfpv4 -mtune=cortex-a7 -mabi=aapcs-linux -mfloat-abi=hard –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -O2 -std=c++0x -Wall -W -fPIC -IC:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/common/c++11 -Ic:/download/qt-build/qtbase/config.tests/common/c++11 -Ic:/download/qt-everywhere-opensource-src-5.5.0/qtbase/mkspecs/devices/linux-rasp-pi2-g++ -o c++11.obj C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/common/c++11/c++11.cpp
C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf-g++ -Wl,-rpath-link,C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot/opt/vc/lib -mfloat-abi=hard –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -Wl,-O1 -o c++11 c++11.obj –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot
C++11 enabled.
sse2 auto-detection… ()
C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf-g++ -c -pipe -march=armv7-a -marm -mthumb-interwork -mfpu=neon-vfpv4 -mtune=cortex-a7 -mabi=aapcs-linux -mfloat-abi=hard –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -msse2 -g -Wall -W -fPIC -IC:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/common/sse2 -Ic:/download/qt-build/qtbase/config.tests/common/sse2 -Ic:/download/qt-everywhere-opensource-src-5.5.0/qtbase/mkspecs/devices/linux-rasp-pi2-g++ -o sse2.obj C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/common/sse2/sse2.cpp
arm-linux-gnueabihf-g++.exe: error: unrecognized command line option ‘-msse2’
make.exe: *** [sse2.obj] Error 1
sse2 disabled.
ipc_sysv auto-detection… ()
C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf-g++ -c -pipe -march=armv7-a -marm -mthumb-interwork -mfpu=neon-vfpv4 -mtune=cortex-a7 -mabi=aapcs-linux -mfloat-abi=hard –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -O2 -Wall -W -fPIC -IC:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/ipc_sysv -Ic:/download/qt-build/qtbase/config.tests/unix/ipc_sysv -Ic:/download/qt-everywhere-opensource-src-5.5.0/qtbase/mkspecs/devices/linux-rasp-pi2-g++ -o ipc.obj C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/ipc_sysv/ipc.cpp
C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf-g++ -Wl,-rpath-link,C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot/opt/vc/lib -mfloat-abi=hard –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -Wl,-O1 -o ipc_sysv ipc.obj –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot
ipc_sysv enabled.
zlib auto-detection… ()
C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf-g++ -c -pipe -march=armv7-a -marm -mthumb-interwork -mfpu=neon-vfpv4 -mtune=cortex-a7 -mabi=aapcs-linux -mfloat-abi=hard –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -O2 -Wall -W -fPIC -IC:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/zlib -Ic:/download/qt-build/qtbase/config.tests/unix/zlib -Ic:/download/qt-everywhere-opensource-src-5.5.0/qtbase/mkspecs/devices/linux-rasp-pi2-g++ -o zlib.obj C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/zlib/zlib.cpp
C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/zlib/zlib.cpp: In function ‘int main(int, char**)’:
C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/zlib/zlib.cpp:38:15: warning: variable ‘stream’ set but not used [-Wunused-but-set-variable]
z_streamp stream;
C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/zlib/zlib.cpp:40:17: warning: variable ‘ver’ set but not used [-Wunused-but-set-variable]
const char *ver = zlibVersion();
C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/zlib/zlib.cpp:43:9: warning: variable ‘res’ set but not used [-Wunused-but-set-variable]
int res = compress2(0, 0, 0, 0, 1);
C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf-g++ -Wl,-rpath-link,C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot/opt/vc/lib -mfloat-abi=hard –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -Wl,-O1 -o zlib zlib.obj –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -lz
zlib enabled.
mtdev auto-detection… ()
Project ERROR: mtdev development package not found
mtdev disabled.
libjpeg auto-detection… ()
C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf-g++ -c -pipe -march=armv7-a -marm -mthumb-interwork -mfpu=neon-vfpv4 -mtune=cortex-a7 -mabi=aapcs-linux -mfloat-abi=hard –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -O2 -Wall -W -fPIC -IC:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/libjpeg -Ic:/download/qt-build/qtbase/config.tests/unix/libjpeg -Ic:/download/qt-everywhere-opensource-src-5.5.0/qtbase/mkspecs/devices/linux-rasp-pi2-g++ -o libjpeg.obj C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/libjpeg/libjpeg.cpp
C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/libjpeg/libjpeg.cpp:37:21: fatal error: jpeglib.h: No such file or directory
#include <jpeglib.h>
compilation terminated.
make.exe: *** [libjpeg.obj] Error 1
libjpeg disabled.
libpng auto-detection… ()
C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf-g++ -c -pipe -march=armv7-a -marm -mthumb-interwork -mfpu=neon-vfpv4 -mtune=cortex-a7 -mabi=aapcs-linux -mfloat-abi=hard –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -O2 -Wall -W -fPIC -IC:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/libpng -Ic:/download/qt-build/qtbase/config.tests/unix/libpng -Ic:/download/qt-everywhere-opensource-src-5.5.0/qtbase/mkspecs/devices/linux-rasp-pi2-g++ -o libpng.obj C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/libpng/libpng.cpp
C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/libpng/libpng.cpp: In function ‘int main(int, char**)’:
C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/libpng/libpng.cpp:42:17: warning: variable ‘png_ptr’ set but not used [-Wunused-but-set-variable]
png_structp png_ptr;
C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf-g++ -Wl,-rpath-link,C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot/opt/vc/lib -mfloat-abi=hard –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -Wl,-O1 -o libpng libpng.obj –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -lpng
libpng enabled.
DB2 auto-detection… ()
C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf-g++ -c -pipe -march=armv7-a -marm -mthumb-interwork -mfpu=neon-vfpv4 -mtune=cortex-a7 -mabi=aapcs-linux -mfloat-abi=hard –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -O2 -Wall -W -fPIC -IC:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/db2 -Ic:/download/qt-build/qtbase/config.tests/unix/db2 -Ic:/download/qt-everywhere-opensource-src-5.5.0/qtbase/mkspecs/devices/linux-rasp-pi2-g++ -o db2.obj C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/db2/db2.cpp
C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/db2/db2.cpp:34:20: fatal error: sqlcli.h: No such file or directory
#include <sqlcli.h>
make.exe: *** [db2.obj] Error 1
DB2 disabled.
InterBase auto-detection… ()
C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf-g++ -c -pipe -march=armv7-a -marm -mthumb-interwork -mfpu=neon-vfpv4 -mtune=cortex-a7 -mabi=aapcs-linux -mfloat-abi=hard –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -O2 -Wall -W -fPIC -IC:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/ibase -Ic:/download/qt-build/qtbase/config.tests/unix/ibase -Ic:/download/qt-everywhere-opensource-src-5.5.0/qtbase/mkspecs/devices/linux-rasp-pi2-g++ -o ibase.obj C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/ibase/ibase.cpp
C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/ibase/ibase.cpp:34:19: fatal error: ibase.h: No such file or directory
#include <ibase.h>
make.exe: *** [ibase.obj] Error 1
InterBase disabled.
MySQL (thread-safe) auto-detection… ()
C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf-g++ -c -pipe -march=armv7-a -marm -mthumb-interwork -mfpu=neon-vfpv4 -mtune=cortex-a7 -mabi=aapcs-linux -mfloat-abi=hard –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -O2 -Wall -W -fPIC -IC:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/mysql_r -Ic:/download/qt-build/qtbase/config.tests/unix/mysql_r -Ic:/download/qt-everywhere-opensource-src-5.5.0/qtbase/mkspecs/devices/linux-rasp-pi2-g++ -o mysql.obj C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/mysql/mysql.cpp
C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/mysql/mysql.cpp:34:19: fatal error: mysql.h: No such file or directory
#include “mysql.h”
make.exe: *** [mysql.obj] Error 1
MySQL (thread-safe) disabled.
MySQL (thread-unsafe) auto-detection… ()
C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf-g++ -c -pipe -march=armv7-a -marm -mthumb-interwork -mfpu=neon-vfpv4 -mtune=cortex-a7 -mabi=aapcs-linux -mfloat-abi=hard –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -O2 -Wall -W -fPIC -IC:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/mysql -Ic:/download/qt-build/qtbase/config.tests/unix/mysql -Ic:/download/qt-everywhere-opensource-src-5.5.0/qtbase/mkspecs/devices/linux-rasp-pi2-g++ -o mysql.obj C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/mysql/mysql.cpp
#include “mysql.h”
MySQL (thread-unsafe) disabled.
OCI auto-detection… ()
C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf-g++ -c -pipe -march=armv7-a -marm -mthumb-interwork -mfpu=neon-vfpv4 -mtune=cortex-a7 -mabi=aapcs-linux -mfloat-abi=hard –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -O2 -Wall -W -fPIC -IC:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/oci -Ic:/download/qt-build/qtbase/config.tests/unix/oci -Ic:/download/qt-everywhere-opensource-src-5.5.0/qtbase/mkspecs/devices/linux-rasp-pi2-g++ -o oci.obj C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/oci/oci.cpp
C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/oci/oci.cpp:34:17: fatal error: oci.h: No such file or directory
#include <oci.h>
make.exe: *** [oci.obj] Error 1
OCI disabled.
ODBC auto-detection… ()
C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf-g++ -c -pipe -march=armv7-a -marm -mthumb-interwork -mfpu=neon-vfpv4 -mtune=cortex-a7 -mabi=aapcs-linux -mfloat-abi=hard –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -O2 -Wall -W -fPIC -IC:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/odbc -Ic:/download/qt-build/qtbase/config.tests/unix/odbc -Ic:/download/qt-everywhere-opensource-src-5.5.0/qtbase/mkspecs/devices/linux-rasp-pi2-g++ -o odbc.obj C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/odbc/odbc.cpp
C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/odbc/odbc.cpp:37:17: fatal error: sql.h: No such file or directory
#include <sql.h>
make.exe: *** [odbc.obj] Error 1
ODBC disabled.
iODBC auto-detection… ()
C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf-g++ -c -pipe -march=armv7-a -marm -mthumb-interwork -mfpu=neon-vfpv4 -mtune=cortex-a7 -mabi=aapcs-linux -mfloat-abi=hard –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -O2 -Wall -W -fPIC -IC:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/iodbc -Ic:/download/qt-build/qtbase/config.tests/unix/iodbc -Ic:/download/qt-everywhere-opensource-src-5.5.0/qtbase/mkspecs/devices/linux-rasp-pi2-g++ -o iodbc.obj C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/iodbc/iodbc.cpp
C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/iodbc/iodbc.cpp:34:17: fatal error: sql.h: No such file or directory
#include <sql.h>
make.exe: *** [iodbc.obj] Error 1
iODBC disabled.
PostgreSQL auto-detection… ()
C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf-g++ -c -pipe -march=armv7-a -marm -mthumb-interwork -mfpu=neon-vfpv4 -mtune=cortex-a7 -mabi=aapcs-linux -mfloat-abi=hard –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -O2 -Wall -W -fPIC -IC:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/psql -Ic:/download/qt-build/qtbase/config.tests/unix/psql -Ic:/download/qt-everywhere-opensource-src-5.5.0/qtbase/mkspecs/devices/linux-rasp-pi2-g++ -o psql.obj C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/psql/psql.cpp
C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/psql/psql.cpp:34:22: fatal error: libpq-fe.h: No such file or directory
#include “libpq-fe.h”
make.exe: *** [psql.obj] Error 1
PostgreSQL disabled.
SQLite2 auto-detection… ()
C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf-g++ -c -pipe -march=armv7-a -marm -mthumb-interwork -mfpu=neon-vfpv4 -mtune=cortex-a7 -mabi=aapcs-linux -mfloat-abi=hard –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -O2 -Wall -W -fPIC -IC:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/sqlite2 -Ic:/download/qt-build/qtbase/config.tests/unix/sqlite2 -Ic:/download/qt-everywhere-opensource-src-5.5.0/qtbase/mkspecs/devices/linux-rasp-pi2-g++ -o sqlite2.obj C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/sqlite2/sqlite2.cpp
C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/sqlite2/sqlite2.cpp:34:20: fatal error: sqlite.h: No such file or directory
#include <sqlite.h>
make.exe: *** [sqlite2.obj] Error 1
SQLite2 disabled.
TDS auto-detection… ()
C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf-g++ -c -pipe -march=armv7-a -marm -mthumb-interwork -mfpu=neon-vfpv4 -mtune=cortex-a7 -mabi=aapcs-linux -mfloat-abi=hard –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -O2 -Wall -W -fPIC -IC:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/tds -Ic:/download/qt-build/qtbase/config.tests/unix/tds -Ic:/download/qt-everywhere-opensource-src-5.5.0/qtbase/mkspecs/devices/linux-rasp-pi2-g++ -o tds.obj C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/tds/tds.cpp
C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/tds/tds.cpp:34:22: fatal error: sybfront.h: No such file or directory
#include <sybfront.h>
make.exe: *** [tds.obj] Error 1
TDS disabled.
NIS auto-detection… ()
C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf-g++ -c -pipe -march=armv7-a -marm -mthumb-interwork -mfpu=neon-vfpv4 -mtune=cortex-a7 -mabi=aapcs-linux -mfloat-abi=hard –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -O2 -Wall -W -fPIC -IC:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/nis -Ic:/download/qt-build/qtbase/config.tests/unix/nis -Ic:/download/qt-everywhere-opensource-src-5.5.0/qtbase/mkspecs/devices/linux-rasp-pi2-g++ -o nis.obj C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/nis/nis.cpp
C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf-g++ -Wl,-rpath-link,C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot/opt/vc/lib -mfloat-abi=hard –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -Wl,-O1 -o nis nis.obj –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -lnsl
NIS enabled.
Cups auto-detection… ()
C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf-g++ -c -pipe -march=armv7-a -marm -mthumb-interwork -mfpu=neon-vfpv4 -mtune=cortex-a7 -mabi=aapcs-linux -mfloat-abi=hard –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -O2 -Wall -W -fPIC -IC:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/cups -Ic:/download/qt-build/qtbase/config.tests/unix/cups -Ic:/download/qt-everywhere-opensource-src-5.5.0/qtbase/mkspecs/devices/linux-rasp-pi2-g++ -o cups.obj C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/cups/cups.cpp
C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/cups/cups.cpp:34:23: fatal error: cups/cups.h: No such file or directory
#include <cups/cups.h>
make.exe: *** [cups.obj] Error 1
Cups disabled.
POSIX iconv auto-detection… ()
C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf-g++ -c -pipe -march=armv7-a -marm -mthumb-interwork -mfpu=neon-vfpv4 -mtune=cortex-a7 -mabi=aapcs-linux -mfloat-abi=hard –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -O2 -Wall -W -fPIC -IC:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/iconv -Ic:/download/qt-build/qtbase/config.tests/unix/iconv -Ic:/download/qt-everywhere-opensource-src-5.5.0/qtbase/mkspecs/devices/linux-rasp-pi2-g++ -o iconv.obj C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/iconv/iconv.cpp
C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf-g++ -Wl,-rpath-link,C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot/opt/vc/lib -mfloat-abi=hard –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -Wl,-O1 -o iconv iconv.obj –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot
POSIX iconv enabled.
libproxy auto-detection… ()
C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf-g++ -c -pipe -march=armv7-a -marm -mthumb-interwork -mfpu=neon-vfpv4 -mtune=cortex-a7 -mabi=aapcs-linux -mfloat-abi=hard –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -O2 -Wall -W -fPIC -IC:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/common/libproxy -Ic:/download/qt-build/qtbase/config.tests/common/libproxy -Ic:/download/qt-everywhere-opensource-src-5.5.0/qtbase/mkspecs/devices/linux-rasp-pi2-g++ -o libproxy.obj C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/common/libproxy/libproxy.cpp
C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/common/libproxy/libproxy.cpp:36:19: fatal error: proxy.h: No such file or directory
#include <proxy.h>
make.exe: *** [libproxy.obj] Error 1
libproxy disabled.
Glib auto-detection… ()
C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf-g++ -c -pipe -march=armv7-a -marm -mthumb-interwork -mfpu=neon-vfpv4 -mtune=cortex-a7 -mabi=aapcs-linux -mfloat-abi=hard –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -O2 -Wall -W -fPIC -IC:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/glib -Ic:/download/qt-build/qtbase/config.tests/unix/glib -Ic:/download/qt-everywhere-opensource-src-5.5.0/qtbase/mkspecs/devices/linux-rasp-pi2-g++ -o glib.obj C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/glib/glib.cpp
C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/glib/glib.cpp:36:18: fatal error: glib.h: No such file or directory
#include <glib.h>
make.exe: *** [glib.obj] Error 1
Glib disabled.
ICU auto-detection… ()
C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf-g++ -c -pipe -march=armv7-a -marm -mthumb-interwork -mfpu=neon-vfpv4 -mtune=cortex-a7 -mabi=aapcs-linux -mfloat-abi=hard –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -O2 -Wall -W -fPIC -IC:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/icu -Ic:/download/qt-build/qtbase/config.tests/unix/icu -Ic:/download/qt-everywhere-opensource-src-5.5.0/qtbase/mkspecs/devices/linux-rasp-pi2-g++ -o icu.obj C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/icu/icu.cpp
C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/icu/icu.cpp:34:28: fatal error: unicode/utypes.h: No such file or directory
#include <unicode/utypes.h>
make.exe: *** [icu.obj] Error 1
ICU disabled.
PulseAudio auto-detection… ()
C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf-g++ -c -pipe -march=armv7-a -marm -mthumb-interwork -mfpu=neon-vfpv4 -mtune=cortex-a7 -mabi=aapcs-linux -mfloat-abi=hard –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -O2 -Wall -W -fPIC -IC:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/pulseaudio -Ic:/download/qt-build/qtbase/config.tests/unix/pulseaudio -Ic:/download/qt-everywhere-opensource-src-5.5.0/qtbase/mkspecs/devices/linux-rasp-pi2-g++ -o pulseaudio.obj C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/pulseaudio/pulseaudio.cpp
C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/pulseaudio/pulseaudio.cpp:34:30: fatal error: pulse/pulseaudio.h: No such file or directory
#include <pulse/pulseaudio.h>
make.exe: *** [pulseaudio.obj] Error 1
PulseAudio disabled.
OpenGL auto-detection… ()
C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf-g++ -c -pipe -march=armv7-a -marm -mthumb-interwork -mfpu=neon-vfpv4 -mtune=cortex-a7 -mabi=aapcs-linux -mfloat-abi=hard –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -O2 -Wall -W -fPIC -IC:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/opengles2 -Ic:/download/qt-build/qtbase/config.tests/unix/opengles2 -IC:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot/opt/vc/include -IC:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot/opt/vc/include/interface/vcos/pthreads -IC:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot/opt/vc/include/interface/vmcs_host/linux -Ic:/download/qt-everywhere-opensource-src-5.5.0/qtbase/mkspecs/devices/linux-rasp-pi2-g++ -o opengles2.obj C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/opengles2/opengles2.cpp
C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf-g++ -Wl,-rpath-link,C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot/opt/vc/lib -mfloat-abi=hard –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -Wl,-O1 -o opengles2 opengles2.obj –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -LC:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot/opt/vc/lib -lGLESv2
OpenGL enabled.
C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf-g++ -c -pipe -march=armv7-a -marm -mthumb-interwork -mfpu=neon-vfpv4 -mtune=cortex-a7 -mabi=aapcs-linux -mfloat-abi=hard –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -O2 -Wall -W -fPIC -IC:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/opengles3 -Ic:/download/qt-build/qtbase/config.tests/unix/opengles3 -IC:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot/opt/vc/include -IC:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot/opt/vc/include/interface/vcos/pthreads -IC:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot/opt/vc/include/interface/vmcs_host/linux -Ic:/download/qt-everywhere-opensource-src-5.5.0/qtbase/mkspecs/devices/linux-rasp-pi2-g++ -o opengles3.obj C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/opengles3/opengles3.cpp
C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/opengles3/opengles3.cpp:37:25: fatal error: GLES3/gl3.h: No such file or directory
#include <GLES3/gl3.h>
make.exe: *** [opengles3.obj] Error 1
OpenGL disabled.
C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf-g++ -c -pipe -march=armv7-a -marm -mthumb-interwork -mfpu=neon-vfpv4 -mtune=cortex-a7 -mabi=aapcs-linux -mfloat-abi=hard –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -O2 -Wall -W -fPIC -IC:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/opengles31 -Ic:/download/qt-build/qtbase/config.tests/unix/opengles31 -IC:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot/opt/vc/include -IC:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot/opt/vc/include/interface/vcos/pthreads -IC:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot/opt/vc/include/interface/vmcs_host/linux -Ic:/download/qt-everywhere-opensource-src-5.5.0/qtbase/mkspecs/devices/linux-rasp-pi2-g++ -o opengles31.obj C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/opengles31/opengles31.cpp
C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/opengles31/opengles31.cpp:34:24: fatal error: GLES3/gl31.h: No such file or directory
#include <GLES3/gl31.h>
make.exe: *** [opengles31.obj] Error 1
OpenGL disabled.
FontConfig auto-detection… ()
C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf-g++ -c -pipe -march=armv7-a -marm -mthumb-interwork -mfpu=neon-vfpv4 -mtune=cortex-a7 -mabi=aapcs-linux -mfloat-abi=hard –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -O2 -Wall -W -fPIC -IC:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/fontconfig -Ic:/download/qt-build/qtbase/config.tests/unix/fontconfig -Ic:/download/qt-everywhere-opensource-src-5.5.0/qtbase/mkspecs/devices/linux-rasp-pi2-g++ -o fontconfig.obj C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/fontconfig/fontconfig.cpp
C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/fontconfig/fontconfig.cpp:34:22: fatal error: ft2build.h: No such file or directory
#include <ft2build.h>
make.exe: *** [fontconfig.obj] Error 1
FontConfig disabled.
libudev auto-detection… ()
C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf-g++ -c -pipe -march=armv7-a -marm -mthumb-interwork -mfpu=neon-vfpv4 -mtune=cortex-a7 -mabi=aapcs-linux -mfloat-abi=hard –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -O2 -Wall -W -fPIC -IC:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/libudev -Ic:/download/qt-build/qtbase/config.tests/unix/libudev -Ic:/download/qt-everywhere-opensource-src-5.5.0/qtbase/mkspecs/devices/linux-rasp-pi2-g++ -o libudev.obj C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/libudev/libudev.cpp
C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/libudev/libudev.cpp:34:21: fatal error: libudev.h: No such file or directory
#include <libudev.h>
make.exe: *** [libudev.obj] Error 1
libudev disabled.
evdev auto-detection… ()
C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf-g++ -c -pipe -march=armv7-a -marm -mthumb-interwork -mfpu=neon-vfpv4 -mtune=cortex-a7 -mabi=aapcs-linux -mfloat-abi=hard –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -O2 -Wall -W -fPIC -IC:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/evdev -Ic:/download/qt-build/qtbase/config.tests/unix/evdev -Ic:/download/qt-everywhere-opensource-src-5.5.0/qtbase/mkspecs/devices/linux-rasp-pi2-g++ -o evdev.obj C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/evdev/evdev.cpp
C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf-g++ -Wl,-rpath-link,C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot/opt/vc/lib -mfloat-abi=hard –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -Wl,-O1 -o evdev evdev.obj –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot
evdev enabled.
tslib auto-detection… ()
C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf-g++ -c -pipe -march=armv7-a -marm -mthumb-interwork -mfpu=neon-vfpv4 -mtune=cortex-a7 -mabi=aapcs-linux -mfloat-abi=hard –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -O2 -Wall -W -fPIC -IC:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/tslib -Ic:/download/qt-build/qtbase/config.tests/unix/tslib -Ic:/download/qt-everywhere-opensource-src-5.5.0/qtbase/mkspecs/devices/linux-rasp-pi2-g++ -o tslib.obj C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/tslib/tslib.cpp
C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/tslib/tslib.cpp:34:19: fatal error: tslib.h: No such file or directory
#include <tslib.h>
make.exe: *** [tslib.obj] Error 1
tslib disabled.
xkbcommon auto-detection… ()
C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf-g++ -c -pipe -march=armv7-a -marm -mthumb-interwork -mfpu=neon-vfpv4 -mtune=cortex-a7 -mabi=aapcs-linux -mfloat-abi=hard –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -O2 -Wall -W -fPIC -IC:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/xkbcommon -Ic:/download/qt-build/qtbase/config.tests/unix/xkbcommon -Ic:/download/qt-everywhere-opensource-src-5.5.0/qtbase/mkspecs/devices/linux-rasp-pi2-g++ -o xkbcommon.obj C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/xkbcommon/xkbcommon.cpp
C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/xkbcommon/xkbcommon.cpp:34:33: fatal error: xkbcommon/xkbcommon.h: No such file or directory
#include <xkbcommon/xkbcommon.h>
make.exe: *** [xkbcommon.obj] Error 1
xkbcommon disabled.
XLib auto-detection… ()
C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf-g++ -c -pipe -march=armv7-a -marm -mthumb-interwork -mfpu=neon-vfpv4 -mtune=cortex-a7 -mabi=aapcs-linux -mfloat-abi=hard –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -O2 -Wall -W -fPIC -IC:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/x11/xlib -Ic:/download/qt-build/qtbase/config.tests/x11/xlib -Ic:/download/qt-everywhere-opensource-src-5.5.0/qtbase/mkspecs/devices/linux-rasp-pi2-g++ -o xlib.obj C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/x11/xlib/xlib.cpp
C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf-g++ -Wl,-rpath-link,C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot/opt/vc/lib -mfloat-abi=hard –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -Wl,-O1 -o xlib xlib.obj –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -lXext -lX11 -lm
XLib enabled.
Xrender auto-detection… ()
C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf-g++ -c -pipe -march=armv7-a -marm -mthumb-interwork -mfpu=neon-vfpv4 -mtune=cortex-a7 -mabi=aapcs-linux -mfloat-abi=hard –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -O2 -Wall -W -fPIC -IC:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/x11/xrender -Ic:/download/qt-build/qtbase/config.tests/x11/xrender -Ic:/download/qt-everywhere-opensource-src-5.5.0/qtbase/mkspecs/devices/linux-rasp-pi2-g++ -o xrender.obj C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/x11/xrender/xrender.cpp
C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/x11/xrender/xrender.cpp: In function ‘int main(int, char**)’:
C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/x11/xrender/xrender.cpp:42:24: warning: variable ‘format’ set but not used [-Wunused-but-set-variable]
XRenderPictFormat *format;
C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf-g++ -Wl,-rpath-link,C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot/opt/vc/lib -mfloat-abi=hard –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -Wl,-O1 -o xrender xrender.obj –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -lXrender -lXext -lX11 -lm
Xrender enabled.
XInput2 auto-detection… ()
C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf-g++ -c -pipe -march=armv7-a -marm -mthumb-interwork -mfpu=neon-vfpv4 -mtune=cortex-a7 -mabi=aapcs-linux -mfloat-abi=hard –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -O2 -Wall -W -fPIC -IC:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/x11/xinput2 -Ic:/download/qt-build/qtbase/config.tests/x11/xinput2 -Ic:/download/qt-everywhere-opensource-src-5.5.0/qtbase/mkspecs/devices/linux-rasp-pi2-g++ -o xinput2.obj C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/x11/xinput2/xinput2.cpp
C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/x11/xinput2/xinput2.cpp: In function ‘int main(int, char**)’:
C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/x11/xinput2/xinput2.cpp:51:14: warning: variable ‘xievent’ set but not used [-Wunused-but-set-variable]
XIEvent *xievent;
C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/x11/xinput2/xinput2.cpp:54:20: warning: variable ‘xideviceevent’ set but not used [-Wunused-but-set-variable]
XIDeviceEvent *xideviceevent;
C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/x11/xinput2/xinput2.cpp:57:23: warning: variable ‘xihierarchyevent’ set but not used [-Wunused-but-set-variable]
XIHierarchyEvent *xihierarchyevent;
C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf-g++ -Wl,-rpath-link,C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot/opt/vc/lib -mfloat-abi=hard –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -Wl,-O1 -o xinput2 xinput2.obj –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -lXi -lXext -lX11 -lm
XInput2 enabled.
xcb auto-detection… ()
C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf-g++ -c -pipe -march=armv7-a -marm -mthumb-interwork -mfpu=neon-vfpv4 -mtune=cortex-a7 -mabi=aapcs-linux -mfloat-abi=hard –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -O2 -Wall -W -fPIC -IC:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/qpa/xcb -Ic:/download/qt-build/qtbase/config.tests/qpa/xcb -Ic:/download/qt-everywhere-opensource-src-5.5.0/qtbase/mkspecs/devices/linux-rasp-pi2-g++ -o xcb.obj C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/qpa/xcb/xcb.cpp
C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/qpa/xcb/xcb.cpp: In function ‘int main(int, char**)’:
C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/qpa/xcb/xcb.cpp:39:23: warning: unused variable ‘t’ [-Wunused-variable]
xcb_connection_t *t = xcb_connect(“”, &primaryScreen);
C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf-g++ -Wl,-rpath-link,C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot/opt/vc/lib -mfloat-abi=hard –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -Wl,-O1 -o xcb xcb.obj –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -lxcb
xcb enabled.
xcb-xlib auto-detection… ()
C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf-g++ -c -pipe -march=armv7-a -marm -mthumb-interwork -mfpu=neon-vfpv4 -mtune=cortex-a7 -mabi=aapcs-linux -mfloat-abi=hard –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -O2 -Wall -W -fPIC -IC:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/qpa/xcb-xlib -Ic:/download/qt-build/qtbase/config.tests/qpa/xcb-xlib -Ic:/download/qt-everywhere-opensource-src-5.5.0/qtbase/mkspecs/devices/linux-rasp-pi2-g++ -o xcb-xlib.obj C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/qpa/xcb-xlib/xcb-xlib.cpp
C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/qpa/xcb-xlib/xcb-xlib.cpp: In function ‘int main(int, char**)’:
C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/qpa/xcb-xlib/xcb-xlib.cpp:41:23: warning: unused variable ‘connection’ [-Wunused-variable]
xcb_connection_t *connection = XGetXCBConnection(dpy);
C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf-g++ -Wl,-rpath-link,C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot/opt/vc/lib -mfloat-abi=hard –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -Wl,-O1 -o xcb-xlib xcb-xlib.obj –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -lxcb -lX11 -lX11-xcb
xcb-xlib enabled.
LinuxFB auto-detection… ()
C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf-g++ -c -pipe -march=armv7-a -marm -mthumb-interwork -mfpu=neon-vfpv4 -mtune=cortex-a7 -mabi=aapcs-linux -mfloat-abi=hard –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -O2 -Wall -W -fPIC -IC:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/qpa/linuxfb -Ic:/download/qt-build/qtbase/config.tests/qpa/linuxfb -Ic:/download/qt-everywhere-opensource-src-5.5.0/qtbase/mkspecs/devices/linux-rasp-pi2-g++ -o linuxfb.obj C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/qpa/linuxfb/linuxfb.cpp
C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf-g++ -Wl,-rpath-link,C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot/opt/vc/lib -mfloat-abi=hard –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -Wl,-O1 -o linuxfb linuxfb.obj –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot
LinuxFB enabled.
KMS auto-detection… ()
Project ERROR: libdrm development package not found
KMS disabled.
EGL auto-detection… ()
C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf-g++ -c -pipe -march=armv7-a -marm -mthumb-interwork -mfpu=neon-vfpv4 -mtune=cortex-a7 -mabi=aapcs-linux -mfloat-abi=hard –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -O2 -Wall -W -fPIC -IC:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/qpa/egl -Ic:/download/qt-build/qtbase/config.tests/qpa/egl -IC:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot/opt/vc/include -IC:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot/opt/vc/include/interface/vcos/pthreads -IC:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot/opt/vc/include/interface/vmcs_host/linux -Ic:/download/qt-everywhere-opensource-src-5.5.0/qtbase/mkspecs/devices/linux-rasp-pi2-g++ -o egl.obj C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/qpa/egl/egl.cpp
C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/qpa/egl/egl.cpp: In function ‘int main(int, char**)’:
C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/qpa/egl/egl.cpp:38:12: warning: unused variable ‘x’ [-Wunused-variable]
EGLint x = 0;
C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf-g++ -Wl,-rpath-link,C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot/opt/vc/lib -mfloat-abi=hard –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -Wl,-O1 -o egl egl.obj –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -LC:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot/opt/vc/lib -lEGL -lGLESv2
EGL enabled.
EGL-X11 auto-detection… ()
C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf-g++ -c -pipe -march=armv7-a -marm -mthumb-interwork -mfpu=neon-vfpv4 -mtune=cortex-a7 -mabi=aapcs-linux -mfloat-abi=hard –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -O2 -Wall -W -fPIC -IC:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/qpa/egl-x11 -Ic:/download/qt-build/qtbase/config.tests/qpa/egl-x11 -IC:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot/opt/vc/include -IC:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot/opt/vc/include/interface/vcos/pthreads -IC:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot/opt/vc/include/interface/vmcs_host/linux -Ic:/download/qt-everywhere-opensource-src-5.5.0/qtbase/mkspecs/devices/linux-rasp-pi2-g++ -o egl-x11.obj C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/qpa/egl-x11/egl-x11.cpp
In file included from C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/qpa/egl-x11/egl-x11.cpp:34:0:
C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/qpa/egl-x11/egl-x11.cpp: In function ‘int main(int, char**)’:
C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot/opt/vc/include/EGL/egl.h:68:54: error: invalid conversion from ‘EGLNativeDisplayType {aka void*}’ to ‘Display* {aka _XDisplay*}’ [-fpermissive]
#define EGL_DEFAULT_DISPLAY ((EGLNativeDisplayType)0)
C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/qpa/egl-x11/egl-x11.cpp:47:20: note: in expansion of macro ‘EGL_DEFAULT_DISPLAY’
Display *dpy = EGL_DEFAULT_DISPLAY;
C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/qpa/egl-x11/egl-x11.cpp:49:9: error: invalid conversion from ‘EGLNativeDisplayType {aka void*}’ to ‘Display* {aka _XDisplay*}’ [-fpermissive]
dpy = egldpy;
C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/qpa/egl-x11/egl-x11.cpp:50:79: error: invalid conversion from ‘Window {aka long unsigned int}’ to ‘EGLNativeWindowType {aka void*}’ [-fpermissive]
EGLNativeWindowType w = XCreateWindow(dpy, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0);
C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/qpa/egl-x11/egl-x11.cpp:51:26: error: invalid conversion from ‘EGLNativeWindowType {aka void*}’ to ‘Window {aka long unsigned int}’ [-fpermissive]
XDestroyWindow(dpy, w);
In file included from C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/qpa/egl-x11/egl-x11.cpp:36:0:
C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot/usr/include/X11/Xlib.h:2255:12: note: initializing argument 2 of ‘int XDestroyWindow(Display*, Window)’
extern int XDestroyWindow(
make.exe: *** [egl-x11.obj] Error 1
EGL-X11 disabled.
eglfs-brcm auto-detection… ()
C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf-g++ -c -pipe -march=armv7-a -marm -mthumb-interwork -mfpu=neon-vfpv4 -mtune=cortex-a7 -mabi=aapcs-linux -mfloat-abi=hard –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -O2 -Wall -W -fPIC -IC:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/qpa/eglfs-brcm -Ic:/download/qt-build/qtbase/config.tests/qpa/eglfs-brcm -IC:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot/opt/vc/include -IC:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot/opt/vc/include/interface/vcos/pthreads -IC:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot/opt/vc/include/interface/vmcs_host/linux -Ic:/download/qt-everywhere-opensource-src-5.5.0/qtbase/mkspecs/devices/linux-rasp-pi2-g++ -o eglfs-brcm.obj C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/qpa/eglfs-brcm/eglfs-brcm.cpp
C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf-g++ -Wl,-rpath-link,C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot/opt/vc/lib -mfloat-abi=hard –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -Wl,-O1 -o eglfs-brcm eglfs-brcm.obj –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -LC:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot/opt/vc/lib -lEGL -lGLESv2 -lbcm_host
eglfs-brcm enabled.
eglfs-mali auto-detection… ()
C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf-g++ -c -pipe -march=armv7-a -marm -mthumb-interwork -mfpu=neon-vfpv4 -mtune=cortex-a7 -mabi=aapcs-linux -mfloat-abi=hard –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -O2 -Wall -W -fPIC -IC:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/qpa/eglfs-mali -Ic:/download/qt-build/qtbase/config.tests/qpa/eglfs-mali -Ic:/download/qt-everywhere-opensource-src-5.5.0/qtbase/mkspecs/devices/linux-rasp-pi2-g++ -o eglfs-mali.obj C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/qpa/eglfs-mali/eglfs-mali.cpp
C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/qpa/eglfs-mali/eglfs-mali.cpp:34:30: fatal error: EGL/fbdev_window.h: No such file or directory
#include <EGL/fbdev_window.h>
make.exe: *** [eglfs-mali.obj] Error 1
eglfs-mali disabled.
eglfs-viv auto-detection… ()
C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf-g++ -c -pipe -march=armv7-a -marm -mthumb-interwork -mfpu=neon-vfpv4 -mtune=cortex-a7 -mabi=aapcs-linux -mfloat-abi=hard –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -O2 -Wall -W -fPIC -DLINUX=1 -DEGL_API_FB=1 -IC:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/qpa/eglfs-viv -Ic:/download/qt-build/qtbase/config.tests/qpa/eglfs-viv -Ic:/download/qt-everywhere-opensource-src-5.5.0/qtbase/mkspecs/devices/linux-rasp-pi2-g++ -o eglfs-viv.obj C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/qpa/eglfs-viv/eglfs-viv.cpp
C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/qpa/eglfs-viv/eglfs-viv.cpp:34:21: fatal error: EGL/egl.h: No such file or directory
#include <EGL/egl.h>
make.exe: *** [eglfs-viv.obj] Error 1
eglfs-viv disabled.
WARNING: Unable to find file .device.vars
FreeType auto-detection… ()
C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf-g++ -c -pipe -march=armv7-a -marm -mthumb-interwork -mfpu=neon-vfpv4 -mtune=cortex-a7 -mabi=aapcs-linux -mfloat-abi=hard –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -O2 -Wall -W -fPIC -IC:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/freetype -Ic:/download/qt-build/qtbase/config.tests/unix/freetype -Ic:/download/qt-everywhere-opensource-src-5.5.0/qtbase/mkspecs/devices/linux-rasp-pi2-g++ -o freetype.obj C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/freetype/freetype.cpp
C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/freetype/freetype.cpp:34:22: fatal error: ft2build.h: No such file or directory
make.exe: *** [freetype.obj] Error 1
FreeType disabled.
STL auto-detection… ()
C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf-g++ -c -pipe -march=armv7-a -marm -mthumb-interwork -mfpu=neon-vfpv4 -mtune=cortex-a7 -mabi=aapcs-linux -mfloat-abi=hard –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -O2 -Wall -W -fPIC -IC:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/stl -Ic:/download/qt-build/qtbase/config.tests/unix/stl -Ic:/download/qt-everywhere-opensource-src-5.5.0/qtbase/mkspecs/devices/linux-rasp-pi2-g++ -o stltest.obj C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/stl/stltest.cpp
C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/stl/stltest.cpp: In function ‘int main()’:
C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/stl/stltest.cpp:128:13: warning: variable ‘first’ set but not used [-Wunused-but-set-variable]
int first = (*m1it).first;
C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/stl/stltest.cpp:130:16: warning: variable ‘second’ set but not used [-Wunused-but-set-variable]
double second = (*m1it).second;
C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/stl/stltest.cpp:101:9: warning: variable ‘v1size’ set but not used [-Wunused-but-set-variable]
int v1size = v1.size();
C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/stl/stltest.cpp:103:9: warning: variable ‘v1capacity’ set but not used [-Wunused-but-set-variable]
int v1capacity = v1.capacity();
C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/stl/stltest.cpp:107:10: warning: variable ‘v1notfound’ set but not used [-Wunused-but-set-variable]
bool v1notfound = (v1it == v1.end());
C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/stl/stltest.cpp:111:10: warning: variable ‘v1found’ set but not used [-Wunused-but-set-variable]
bool v1found = (v1it != v1.end());
C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/stl/stltest.cpp:116:9: warning: variable ‘v2size’ set but not used [-Wunused-but-set-variable]
int v2size = v2.size();
C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/stl/stltest.cpp:124:9: warning: variable ‘m1size’ set but not used [-Wunused-but-set-variable]
int m1size = m1.size();
C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/stl/stltest.cpp:134:9: warning: variable ‘m2size’ set but not used [-Wunused-but-set-variable]
int m2size = m2.size();
C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/stl/stltest.cpp:138:9: warning: unused variable ‘n’ [-Wunused-variable]
int n = std::distance(it1, it2);
C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf-g++ -Wl,-rpath-link,C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot/opt/vc/lib -mfloat-abi=hard –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -Wl,-O1 -o stl stltest.obj –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot
STL enabled.
POSIX clock_gettime() auto-detection… ()
C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf-g++ -c -pipe -march=armv7-a -marm -mthumb-interwork -mfpu=neon-vfpv4 -mtune=cortex-a7 -mabi=aapcs-linux -mfloat-abi=hard –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -O2 -Wall -W -fPIC -IC:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/clock-gettime -Ic:/download/qt-build/qtbase/config.tests/unix/clock-gettime -Ic:/download/qt-everywhere-opensource-src-5.5.0/qtbase/mkspecs/devices/linux-rasp-pi2-g++ -o clock-gettime.obj C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/clock-gettime/clock-gettime.cpp
C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf-g++ -Wl,-rpath-link,C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot/opt/vc/lib -mfloat-abi=hard –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -Wl,-O1 -o clock-gettime clock-gettime.obj –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -lrt
POSIX clock_gettime() enabled.
POSIX Monotonic Clock auto-detection… ()
C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf-g++ -c -pipe -march=armv7-a -marm -mthumb-interwork -mfpu=neon-vfpv4 -mtune=cortex-a7 -mabi=aapcs-linux -mfloat-abi=hard –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -O2 -Wall -W -fPIC -IC:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/clock-monotonic -Ic:/download/qt-build/qtbase/config.tests/unix/clock-monotonic -Ic:/download/qt-everywhere-opensource-src-5.5.0/qtbase/mkspecs/devices/linux-rasp-pi2-g++ -o clock-monotonic.obj C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/clock-monotonic/clock-monotonic.cpp
C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf-g++ -Wl,-rpath-link,C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot/opt/vc/lib -mfloat-abi=hard –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -Wl,-O1 -o clock-monotonic clock-monotonic.obj –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -lrt
POSIX Monotonic Clock enabled.
posix_fallocate auto-detection… ()
C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf-g++ -c -pipe -march=armv7-a -marm -mthumb-interwork -mfpu=neon-vfpv4 -mtune=cortex-a7 -mabi=aapcs-linux -mfloat-abi=hard –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -O2 -Wall -W -fPIC -IC:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/posix_fallocate -Ic:/download/qt-build/qtbase/config.tests/unix/posix_fallocate -Ic:/download/qt-everywhere-opensource-src-5.5.0/qtbase/mkspecs/devices/linux-rasp-pi2-g++ -o posix_fallocate.obj C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/posix_fallocate/posix_fallocate.cpp
C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf-g++ -Wl,-rpath-link,C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot/opt/vc/lib -mfloat-abi=hard –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -Wl,-O1 -o posix_fallocate posix_fallocate.obj –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot
posix_fallocate enabled.
mremap auto-detection… ()
C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf-g++ -c -pipe -march=armv7-a -marm -mthumb-interwork -mfpu=neon-vfpv4 -mtune=cortex-a7 -mabi=aapcs-linux -mfloat-abi=hard –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -O2 -Wall -W -fPIC -IC:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/mremap -Ic:/download/qt-build/qtbase/config.tests/unix/mremap -Ic:/download/qt-everywhere-opensource-src-5.5.0/qtbase/mkspecs/devices/linux-rasp-pi2-g++ -o mremap.obj C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/mremap/mremap.cpp
C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf-g++ -Wl,-rpath-link,C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot/opt/vc/lib -mfloat-abi=hard –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -Wl,-O1 -o mremap mremap.obj –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot
mremap enabled.
getaddrinfo auto-detection… ()
C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf-g++ -c -pipe -march=armv7-a -marm -mthumb-interwork -mfpu=neon-vfpv4 -mtune=cortex-a7 -mabi=aapcs-linux -mfloat-abi=hard –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -O2 -Wall -W -fPIC -IC:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/getaddrinfo -Ic:/download/qt-build/qtbase/config.tests/unix/getaddrinfo -Ic:/download/qt-everywhere-opensource-src-5.5.0/qtbase/mkspecs/devices/linux-rasp-pi2-g++ -o getaddrinfotest.obj C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/getaddrinfo/getaddrinfotest.cpp
C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf-g++ -Wl,-rpath-link,C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot/opt/vc/lib -mfloat-abi=hard –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -Wl,-O1 -o getaddrinfo getaddrinfotest.obj –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot
getaddrinfo enabled.
inotify auto-detection… ()
C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf-g++ -c -pipe -march=armv7-a -marm -mthumb-interwork -mfpu=neon-vfpv4 -mtune=cortex-a7 -mabi=aapcs-linux -mfloat-abi=hard –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -O2 -Wall -W -fPIC -IC:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/inotify -Ic:/download/qt-build/qtbase/config.tests/unix/inotify -Ic:/download/qt-everywhere-opensource-src-5.5.0/qtbase/mkspecs/devices/linux-rasp-pi2-g++ -o inotifytest.obj C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/inotify/inotifytest.cpp
C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf-g++ -Wl,-rpath-link,C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot/opt/vc/lib -mfloat-abi=hard –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -Wl,-O1 -o inotify inotifytest.obj –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot
inotify enabled.
eventfd auto-detection… ()
C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf-g++ -c -pipe -march=armv7-a -marm -mthumb-interwork -mfpu=neon-vfpv4 -mtune=cortex-a7 -mabi=aapcs-linux -mfloat-abi=hard –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -O2 -Wall -W -fPIC -IC:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/eventfd -Ic:/download/qt-build/qtbase/config.tests/unix/eventfd -Ic:/download/qt-everywhere-opensource-src-5.5.0/qtbase/mkspecs/devices/linux-rasp-pi2-g++ -o main.obj C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/eventfd/main.cpp
C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf-g++ -Wl,-rpath-link,C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot/opt/vc/lib -mfloat-abi=hard –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -Wl,-O1 -o eventfd main.obj –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot
eventfd enabled.
IPv6 interface name auto-detection… ()
C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf-g++ -c -pipe -march=armv7-a -marm -mthumb-interwork -mfpu=neon-vfpv4 -mtune=cortex-a7 -mabi=aapcs-linux -mfloat-abi=hard –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -O2 -Wall -W -fPIC -IC:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/ipv6ifname -Ic:/download/qt-build/qtbase/config.tests/unix/ipv6ifname -Ic:/download/qt-everywhere-opensource-src-5.5.0/qtbase/mkspecs/devices/linux-rasp-pi2-g++ -o ipv6ifname.obj C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/ipv6ifname/ipv6ifname.cpp
C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf-g++ -Wl,-rpath-link,C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot/opt/vc/lib -mfloat-abi=hard –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -Wl,-O1 -o ipv6ifname ipv6ifname.obj –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot
IPv6 interface name enabled.
getifaddrs auto-detection… ()
C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf-g++ -c -pipe -march=armv7-a -marm -mthumb-interwork -mfpu=neon-vfpv4 -mtune=cortex-a7 -mabi=aapcs-linux -mfloat-abi=hard –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -O2 -Wall -W -fPIC -IC:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/getifaddrs -Ic:/download/qt-build/qtbase/config.tests/unix/getifaddrs -Ic:/download/qt-everywhere-opensource-src-5.5.0/qtbase/mkspecs/devices/linux-rasp-pi2-g++ -o getifaddrs.obj C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/getifaddrs/getifaddrs.cpp
C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf-g++ -Wl,-rpath-link,C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot/opt/vc/lib -mfloat-abi=hard –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -Wl,-O1 -o getifaddrs getifaddrs.obj –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot
getifaddrs enabled.
OpenSSL auto-detection… ()
C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf-g++ -c -pipe -march=armv7-a -marm -mthumb-interwork -mfpu=neon-vfpv4 -mtune=cortex-a7 -mabi=aapcs-linux -mfloat-abi=hard –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -O2 -Wall -W -fPIC -IC:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/openssl -Ic:/download/qt-build/qtbase/config.tests/unix/openssl -Ic:/download/qt-everywhere-opensource-src-5.5.0/qtbase/mkspecs/devices/linux-rasp-pi2-g++ -o openssl.obj C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/openssl/openssl.cpp
C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/openssl/openssl.cpp:34:30: fatal error: openssl/opensslv.h: No such file or directory
#include <openssl/opensslv.h>
make.exe: *** [openssl.obj] Error 1
OpenSSL disabled.
PCRE auto-detection… ()
C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf-g++ -c -pipe -march=armv7-a -marm -mthumb-interwork -mfpu=neon-vfpv4 -mtune=cortex-a7 -mabi=aapcs-linux -mfloat-abi=hard –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -O2 -Wall -W -fPIC -IC:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/pcre -Ic:/download/qt-build/qtbase/config.tests/unix/pcre -Ic:/download/qt-everywhere-opensource-src-5.5.0/qtbase/mkspecs/devices/linux-rasp-pi2-g++ -o pcre.obj C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/pcre/pcre.cpp
C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/pcre/pcre.cpp:34:18: fatal error: pcre.h: No such file or directory
#include <pcre.h>
make.exe: *** [pcre.obj] Error 1
PCRE disabled.
OpenVG auto-detection… ()
C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf-g++ -c -pipe -march=armv7-a -marm -mthumb-interwork -mfpu=neon-vfpv4 -mtune=cortex-a7 -mabi=aapcs-linux -mfloat-abi=hard –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -O2 -Wall -W -fPIC -IC:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/openvg -Ic:/download/qt-build/qtbase/config.tests/unix/openvg -Ic:/download/qt-everywhere-opensource-src-5.5.0/qtbase/mkspecs/devices/linux-rasp-pi2-g++ -o openvg.obj C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/openvg/openvg.cpp
C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/openvg/openvg.cpp:40:23: fatal error: VG/openvg.h: No such file or directory
#include <VG/openvg.h>
make.exe: *** [openvg.obj] Error 1
OpenVG disabled.
OpenVG disabled.
OpenVG (lc includes) auto-detection… ()
C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf-g++ -c -pipe -march=armv7-a -marm -mthumb-interwork -mfpu=neon-vfpv4 -mtune=cortex-a7 -mabi=aapcs-linux -mfloat-abi=hard –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -O2 -Wall -W -fPIC -DQT_LOWER_CASE_VG_INCLUDES -IC:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/openvg -Ic:/download/qt-build/qtbase/config.tests/unix/openvg -Ic:/download/qt-everywhere-opensource-src-5.5.0/qtbase/mkspecs/devices/linux-rasp-pi2-g++ -o openvg.obj C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/openvg/openvg.cpp
C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/openvg/openvg.cpp:38:23: fatal error: vg/openvg.h: No such file or directory
#include <vg/openvg.h>
OpenVG (lc includes) disabled.
alsa auto-detection… ()
C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf-g++ -c -pipe -march=armv7-a -marm -mthumb-interwork -mfpu=neon-vfpv4 -mtune=cortex-a7 -mabi=aapcs-linux -mfloat-abi=hard –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -O2 -Wall -W -fPIC -IC:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/alsa -Ic:/download/qt-build/qtbase/config.tests/unix/alsa -Ic:/download/qt-everywhere-opensource-src-5.5.0/qtbase/mkspecs/devices/linux-rasp-pi2-g++ -o alsatest.obj C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/alsa/alsatest.cpp
C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/alsa/alsatest.cpp:34:28: fatal error: alsa/asoundlib.h: No such file or directory
#include <alsa/asoundlib.h>
make.exe: *** [alsatest.obj] Error 1
alsa disabled.
GStreamer 0.10 auto-detection… ()
Project ERROR: gstreamer-0.10 development package not found
GStreamer 0.10 disabled.
GStreamer 1.0 auto-detection… ()
Project ERROR: gstreamer-1.0 development package not found
GStreamer 1.0 disabled.
Testing size of pointers … (c:/download/qt-everywhere-opensource-src-5.5.0/qtbase/mkspecs/devices/linux-rasp-pi2-g++ yes c:/download/qt-everywhere-opensource-src-5.5.0/qtbase c:/download/qt-build/qtbase)
rm -f ptrsizetest.obj
rm -f *~ core *.core
C:/SysGCC/Raspberry/bin/arm-linux-gnueabihf-g++ -c -pipe -march=armv7-a -marm -mthumb-interwork -mfpu=neon-vfpv4 -mtune=cortex-a7 -mabi=aapcs-linux -mfloat-abi=hard –sysroot=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot -g -Wall -W -fPIC -IC:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/ptrsize -Ic:/download/qt-build/qtbase/config.tests/unix/ptrsize -Ic:/download/qt-everywhere-opensource-src-5.5.0/qtbase/mkspecs/devices/linux-rasp-pi2-g++ -o ptrsizetest.obj C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/ptrsize/ptrsizetest.cpp
C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/ptrsize/ptrsizetest.cpp: In function ‘int main(int, char**)’:
C:/download/qt-everywhere-opensource-src-5.5.0/qtbase/config.tests/unix/ptrsize/ptrsizetest.cpp:51:12: error: ‘PointerSize’ is not a member of ‘QPointerSizeTest<4>’
return QPointerSizeTest<sizeof(void*)>::PointerSize;
make.exe: *** [ptrsizetest.obj] Error 1
Pointer size: 4Configure summary
Building on: win32-g++ (i386, CPU features: none detected)
Building for: devices/linux-rasp-pi2-g++ (arm, CPU features: neon)qmake vars ………. styles += mac fusion windows DEFINES += QT_NO_MTDEV DEFINES += QT_NO_LIBUDEV DEFINES += QT_NO_TSLIB DEFINES += QT_NO_LIBINPUT QMAKE_X11_PREFIX = /usr QMAKE_XKB_CONFIG_ROOT = auto sql-drivers = sql-plugins = sqlite qmake switches ………
Build options:
Configuration ………. accessibility accessibility-atspi-bridge audio-backend c++11 clock-gettime clock-monotonic compile_examples concurrent cross_compile dbus egl eglfs eglfs_brcm enable_new_dtags evdev eventfd freetype full-config getaddrinfo getifaddrs harfbuzz iconv inotify ipv6ifname large-config largefile linuxfb medium-config minimal-config mremap neon nis no-pkg-config opengl opengles2 pcre png posix_fallocate precompile_header qpa qpa reduce_exports release rpath shared small-config system-png system-zlib xcb xcb-plugin xcb-qt xcb-xlib xinput2 xkbcommon-qt xlib xrender
Build parts ………… libs examples
Mode ………………. release
Using sanitizer(s)…… none
Using C++11 ………… yes
Using gold linker……. no
Using new DTAGS …….. yes
Using PCH ………….. yes
Target compiler supports:
Neon …………….. yesQt modules and options:
Qt D-Bus …………… yes (loading dbus-1 at runtime)
Qt Concurrent ………. yes
Qt GUI …………….. yes
Qt Widgets …………. yes
Large File …………. yes
QML debugging ………. yes
Use system proxies ….. noSupport enabled for:
Accessibility ………. yes
ALSA ………………. no
CUPS ………………. no
Evdev ……………… yes
FontConfig …………. no
FreeType …………… yes (bundled copy)
Glib ………………. no
GStreamer ………….. no
GTK theme ………….. no
HarfBuzz …………… yes (bundled copy)
Iconv ……………… yes
ICU ……………….. no
Image formats:
GIF ……………… yes (plugin, using bundled copy)
JPEG …………….. yes (plugin, using bundled copy)
PNG ……………… yes (in QtGui, using system library)
journald …………… no
libinput……………. no
mtdev ……………… no
Networking:
getaddrinfo ………. yes
getifaddrs ……….. yes
IPv6 ifname ………. yes
libproxy………….. no
OpenSSL ………….. no
NIS ……………….. yes
OpenGL / OpenVG:
EGL ……………… yes
OpenGL …………… yes (OpenGL ES 2.0+)
OpenVG …………… no
PCRE ………………. yes (bundled copy)
pkg-config …………. no
PulseAudio …………. no
QPA backends:
DirectFB …………. no
EGLFS ……………. yes
EGLFS i.MX6……. . no
EGLFS KMS ………. no
EGLFS Mali ……… no
EGLFS Raspberry Pi . yes
EGLFS X11 ………. no
LinuxFB ………….. yes
XCB ……………… yes (bundled copy)
EGL on X ……….. no
GLX ……………. no
MIT-SHM ………… yes
Xcb-Xlib ……….. yes
Xcursor ………… yes (loaded at runtime)
Xfixes …………. yes (loaded at runtime)
Xi …………….. no
Xi2 ……………. yes
Xinerama ……….. yes (loaded at runtime)
Xrandr …………. yes (loaded at runtime)
Xrender ………… yes
XKB ……………. yes
XShape …………. yes
XSync ………….. yes
XVideo …………. yes
Session management ….. yes
SQL drivers:
DB2 ……………… no
InterBase ………… no
MySQL ……………. no
OCI ……………… no
ODBC …………….. no
PostgreSQL ……….. no
SQLite 2 …………. no
SQLite …………… yes (plugin, using bundled copy)
TDS ……………… no
tslib ……………… no
udev ………………. no
xkbcommon-x11……….. yes (bundled copy, XKB config root: not found)
xkbcommon-evdev……… no
zlib ………………. yes (system library)
WARNING: Could not find XKB config root, use -xkb-config-root to set a path to
XKB configuration data. This is required for keyboard input support.NOTE: Qt is using double for qreal on this system. This is binary incompatible against Qt 5.1.
Configure with ‘-qreal float’ to create a build that is binary compatible with 5.1.
Cannot read C:/download/qt-everywhere-opensource-src-5.5.0: Åtkomst nekad. (Swedish for “access denied” My remark)
Error processing project file: c:\download\qt-everywhere-opensource-src-5.5.0Thanks
Mats
