Prototype general purpose data logger?
Sysprogs forums Forums Other tools & products Prototype general purpose data logger?
Viewing 1 post (of 1 total)
  • #6697
    jonathan323
    <span id=”yui_3_17_2_3_1436701238956_827″ class=”ya-q-text”>program should read a suitable ADC channel of microcontroller at 1 second time intervals and convert the digital value into the corresponding voltage and display the value on the serial window.
    Stage 1
    Continuously read a single ADC channel and print the digital value to the serial debug output. Remember to initialise the serial debug channel.
    Stage2
    Take a copy of the previous program (and rename the copy) and convert the ADC value a corresponding voltage and print this value on the serial debug window output.
    Stage3
    Add a hardware delay (using one of the timers) into program to give a delay of approximately 1s. The delay routine should be a separate function which is called from main.
    Stage 4
    Add an alarm feature. If the voltage reaches a preset level the LED’s should flash.
    Stage 5
    Add features to improve the functionality of data logger. Some examples are
    • user selectable sample times
    • use of the Real time clock to timestamp your data
    • storage of the data into non volatile memory
    • Add your own innovative features…
    C libraries available are:- functions to read the ADC channels, output to the DAC, Serial I/O etc.</span>
    Can someone help me out here with this programme. It should be done using Keil Uvision and STM32F4 discovery board.
