Property sheet
Sysprogs forums Forums VisualGDB Property sheet
  • #27818
    mattia
    I’m using visualGDB 5.5 (preview 2 build 3422). I watched your last tutorial “Using MSBuild Property Sheets”. I use it for two of my last project using STM32 microcontroller, and I saw two very different pages: in one of them I saw the configuration pages very similar to yours, in the other the debugger is “x86” on “Win32” platform, even if I started from both of my project from CubeMX. I attached the two configuration pages.
    In any case, is there any way to make the VS switch to “ARM” as Active platform, and then having the correct configuration pages?
    Thank you,
    Mattia Berton
    #27828
    Looks like the second project is based on GNU Make and hence does not support property sheets. You can find a detailed overview of various project types here: https://visualgdb.com/documentation/projects/overview/
    Normally, you can convert Make-based projects to MSBuild via the context menu in Solution Explorer, however this process is not 100% precise and may require manual troubleshooting afterwards.
