Project fails to load
Sysprogs forums Forums VisualGDB Project fails to load
  • #31259
    softtechza
    C++ project with WSL2. I restarted my PC and now the project will not load. It’s marked as ‘GLViewerGDB.vgdbcmake (failed)’ in the solution explorer. Nothing changed between when it loaded and I rebooted.
    Reloading the project always results in a Linq ‘Sequence contains more than one matching element’ exception from VisualGDB.
    Cleaning and trying to rebuild doesn’t fix it.
    I have twice quit Visual Studio, uninstalled VisualGDB and re-installed with no change.
    Exception text from VisualGDB below.
    System.InvalidOperationException: Sequence contains more than one matching element
    at System.Linq.Enumerable.SingleOrDefault[TSource](IEnumerable1 source, Func2 predicate)
    at lf.f()
    at eu1.p.z(CommandLineAction b, CommandFlags a, Boolean c)
    at eu1.p..ctor(cz1 a, CommandLineAction c, CommandFlags b, rs d, Boolean e)
    at eu1.j1(String a, IEnumerable1 e, IEnumerable1 c, ta b, hr2 f, ig2 d)
    at lm.g(wy[] a)
    at yv2.d_2(EventWaitHandle b, Boolean a, Object c)
    at hm.v5(i4 a, Int32 c, ui2 e, y41 d, ic1 b, Boolean f)
    at hm.r4(i4 b, Int32 a)
    #31265
    Please try updating to the latest VisualGDB 5.6 Beta 5 and deleting the .visualgdb subdirectory in the project folder. If the problem persists, please share the updated stack trace, and we will investigate this further.
    #31280
    softtechza
    Installed beta5 and deleted the .visualgdb folder.  Visual studio now just lists ‘Load failed. Double-click for details’ for the contents of the project under the first node (with the RGB triangle icon).
    The stack trace is slightly different by has the same exception. The stacktrace and log show from double clicking for details are included below.
    Both before and after updating to beta 5, when I tell visual studio to reload the project I sometimes get a short lived error dialog at the bottom of the screen stating that Visual Studio doesn’t know what that ‘VisualGDBProjectSettings2’ node in the .vgdbcmake project file is.
    Stacktrace:
    at vg3.a()
    at sa3.r.n(CommandLineAction a, CommandFlags c, Boolean b)
    at sa3.r..ctor(ap1 e, CommandLineAction d, CommandFlags b, l21 c, Boolean a)
    at sa3.d_2(String e, IEnumerable1 b, IEnumerable1 c, se3 a, in f, ha1 d)
    at s71.h(tr2[] a)
    at ee2.c_2(EventWaitHandle b, Boolean a, Object c)
    at ob2.a(f5 c, Int32 f, yf1 a, l63 e, c1 d, Boolean b)
    at ob2.d2(f5 b, Int32 a)
    Double click for details:
    Loaded D:\Dev\Flipper\configuration-scene\configuration-scene\src\GLViewerGDB\GLViewerGDB.vgdbcmake. Waiting for VS to set the active configuration…
    Loaded D:\Dev\Flipper\configuration-scene\configuration-scene\src\GLViewerGDB2\GLViewerGDB2.vgdbcmake. Waiting for VS to set the active configuration…
    D:\Dev\Flipper\configuration-scene\configuration-scene\src\GLViewerGDB\GLViewerGDB.vgdbcmake: active configuration changed to Debug
    D:\Dev\Flipper\configuration-scene\configuration-scene\src\GLViewerGDB2\GLViewerGDB2.vgdbcmake: active configuration changed to Debug
    Shutting down CMake project for D:\Dev\Flipper\configuration-scene\configuration-scene\src\GLViewerGDB\GLViewerGDB.vgdbcmake…
    Shutting down CMake project for D:\Dev\Flipper\configuration-scene\configuration-scene\src\GLViewerGDB2\GLViewerGDB2.vgdbcmake…
    #31281
    softtechza
    The short lived error dialog that will appear on reloading the project after it has been unloaded.
    • This reply was modified 5 years ago by softtechza.
    #31285
    softtechza
    Also note that if I create a new VisualGDB project of the same type, I exhibits all of the exact same errors.
    #31291
    Thanks, we have found the root cause. It looks like your system has multiple network interfaces marked with the (WSL) tag, so VisualGDB cannot determine the one to use for WSL connections.
    We have fixed the issue that was preventing VisualGDB from showing a more descriptive error message in this build: VisualGDB-5.6.5.4337.msi
    VisualGDB will now list all the interfaces it found in the error message, so you can manually select the one you would like to use for WSL targets via Tools->Options->VisualGDB->General->Other->Linux Subsystem Network Interface.
