Sysprogs forums › Forums › VisualGDB › problems with cross-complie visualgdb and QT base
- This topic has 6 replies, 2 voices, and was last updated 10 years, 8 months ago by
July 4, 2015 at 19:53 #6677
vodanh1303
ParticipantThis is my installation
Win 7 32bit Host Visual Studio 2013
Target: Beaglebone black with debian-7.8-images_bone-lxde-4gb-armhf-2015-03-01-4gbI follow the instructions of Beaglebone and Raspberry with QT and see the following error:
Please take a look and help me. Thank you very much
Output Build:
1>—— Rebuild All started: Project: QtBeagleCross, Configuration: Debug Win32 —— 1> VisualGDB: Run “cmd /c rmdir /s /q “Debug”” in directory “D:\Qt4.8.1\project\QtBeagleCross\QtBeagleCross” on local computer 1> Debug\QtBeagleCross.log – The process cannot access the file because it is being used by another process. 1> VisualGDB: Run “D:\SysGCC\BeagleDebian\Qt\v4\qmake.exe QtBeagleCross.pro CONFIGNAME=Debug” in directory “D:\Qt4.8.1\project\QtBeagleCross\QtBeagleCross” on local computer 1> VisualGDB: Run “cmd.exe /c “D:\SysGCC\BeagleDebian\bin\make.exe”” in directory “D:\Qt4.8.1\project\QtBeagleCross\QtBeagleCross” on local computer 1> d:/SysGCC/BeagleDebian/Qt/v4/uic.exe MainWindow.ui -o Debug/ui_MainWindow.h 1> D:/SysGCC/BeagleDebian/bin/arm-linux-gnueabihf-g++.exe -c -pipe -Wno-psabi -g -Wall -W -D_REENTRANT -DQT_WEBKIT -DQT_WEBKIT -DQT_GUI_LIB -DQT_CORE_LIB -I../../../../sysgcc/beagledebian/arm-linux-gnueabihf/sysroot/usr/share/qt4/mkspecs/arm-linux-gnueabihf -I. -I../../../../sysgcc/beagledebian/arm-linux-gnueabihf/sysroot/usr/include/qt4/QtCore -I../../../../sysgcc/beagledebian/arm-linux-gnueabihf/sysroot/usr/include/qt4/QtGui -I../../../../sysgcc/beagledebian/arm-linux-gnueabihf/sysroot/usr/include/qt4 -IDebug -IDebug -o Debug/MainWindow.o MainWindow.cpp 1> D:/SysGCC/BeagleDebian/bin/arm-linux-gnueabihf-g++.exe -c -pipe -Wno-psabi -g -Wall -W -D_REENTRANT -DQT_WEBKIT -DQT_WEBKIT -DQT_GUI_LIB -DQT_CORE_LIB -I../../../../sysgcc/beagledebian/arm-linux-gnueabihf/sysroot/usr/share/qt4/mkspecs/arm-linux-gnueabihf -I. -I../../../../sysgcc/beagledebian/arm-linux-gnueabihf/sysroot/usr/include/qt4/QtCore -I../../../../sysgcc/beagledebian/arm-linux-gnueabihf/sysroot/usr/include/qt4/QtGui -I../../../../sysgcc/beagledebian/arm-linux-gnueabihf/sysroot/usr/include/qt4 -IDebug -IDebug -o Debug/QtBeagleCross.o QtBeagleCross.cpp 1> D:/SysGCC/BeagleDebian/Qt/v4/moc.exe -DQT_WEBKIT -DQT_WEBKIT -DQT_GUI_LIB -DQT_CORE_LIB -I../../../../sysgcc/beagledebian/arm-linux-gnueabihf/sysroot/usr/share/qt4/mkspecs/arm-linux-gnueabihf -I. -I../../../../sysgcc/beagledebian/arm-linux-gnueabihf/sysroot/usr/include/qt4/QtCore -I../../../../sysgcc/beagledebian/arm-linux-gnueabihf/sysroot/usr/include/qt4/QtGui -I../../../../sysgcc/beagledebian/arm-linux-gnueabihf/sysroot/usr/include/qt4 -IDebug -IDebug MainWindow.h -o Debug/moc_MainWindow.cpp 1> D:/SysGCC/BeagleDebian/bin/arm-linux-gnueabihf-g++.exe -c -pipe -Wno-psabi -g -Wall -W -D_REENTRANT -DQT_WEBKIT -DQT_WEBKIT -DQT_GUI_LIB -DQT_CORE_LIB -I../../../../sysgcc/beagledebian/arm-linux-gnueabihf/sysroot/usr/share/qt4/mkspecs/arm-linux-gnueabihf -I. -I../../../../sysgcc/beagledebian/arm-linux-gnueabihf/sysroot/usr/include/qt4/QtCore -I../../../../sysgcc/beagledebian/arm-linux-gnueabihf/sysroot/usr/include/qt4/QtGui -I../../../../sysgcc/beagledebian/arm-linux-gnueabihf/sysroot/usr/include/qt4 -IDebug -IDebug -o Debug/moc_MainWindow.o Debug/moc_MainWindow.cpp 1> D:/SysGCC/BeagleDebian/bin/arm-linux-gnueabihf-g++.exe -o Debug/QtBeagleCross Debug/MainWindow.o Debug/QtBeagleCross.o Debug/moc_MainWindow.o -Ld:/sysgcc/beagledebian/arm-linux-gnueabihf/sysroot/usr/lib -lQtGui -lQtCore -lpthread 1>d:/sysgcc/beagledebian/bin/../lib/gcc/arm-linux-gnueabihf/4.6/../../../../arm-linux-gnueabihf/bin/ld.exe : warning : libfontconfig.so.1, needed by d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so, not found (try using -rpath or -rpath-link) 1>d:/sysgcc/beagledebian/bin/../lib/gcc/arm-linux-gnueabihf/4.6/../../../../arm-linux-gnueabihf/bin/ld.exe : warning : libaudio.so.2, needed by d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so, not found (try using -rpath or -rpath-link) 1>d:/sysgcc/beagledebian/bin/../lib/gcc/arm-linux-gnueabihf/4.6/../../../../arm-linux-gnueabihf/bin/ld.exe : warning : libglib-2.0.so.0, needed by d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so, not found (try using -rpath or -rpath-link) 1>d:/sysgcc/beagledebian/bin/../lib/gcc/arm-linux-gnueabihf/4.6/../../../../arm-linux-gnueabihf/bin/ld.exe : warning : libpng12.so.0, needed by d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so, not found (try using -rpath or -rpath-link) 1>d:/sysgcc/beagledebian/bin/../lib/gcc/arm-linux-gnueabihf/4.6/../../../../arm-linux-gnueabihf/bin/ld.exe : warning : libz.so.1, needed by d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so, not found (try using -rpath or -rpath-link) 1>d:/sysgcc/beagledebian/bin/../lib/gcc/arm-linux-gnueabihf/4.6/../../../../arm-linux-gnueabihf/bin/ld.exe : warning : libfreetype.so.6, needed by d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so, not found (try using -rpath or -rpath-link) 1>d:/sysgcc/beagledebian/bin/../lib/gcc/arm-linux-gnueabihf/4.6/../../../../arm-linux-gnueabihf/bin/ld.exe : warning : libgobject-2.0.so.0, needed by d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so, not found (try using -rpath or -rpath-link) 1>d:/sysgcc/beagledebian/bin/../lib/gcc/arm-linux-gnueabihf/4.6/../../../../arm-linux-gnueabihf/bin/ld.exe : warning : libSM.so.6, needed by d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so, not found (try using -rpath or -rpath-link) 1>d:/sysgcc/beagledebian/bin/../lib/gcc/arm-linux-gnueabihf/4.6/../../../../arm-linux-gnueabihf/bin/ld.exe : warning : libICE.so.6, needed by d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so, not found (try using -rpath or -rpath-link) 1>d:/sysgcc/beagledebian/bin/../lib/gcc/arm-linux-gnueabihf/4.6/../../../../arm-linux-gnueabihf/bin/ld.exe : warning : libXrender.so.1, needed by d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so, not found (try using -rpath or -rpath-link) 1>d:/sysgcc/beagledebian/bin/../lib/gcc/arm-linux-gnueabihf/4.6/../../../../arm-linux-gnueabihf/bin/ld.exe : warning : libXext.so.6, needed by d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so, not found (try using -rpath or -rpath-link) 1>d:/sysgcc/beagledebian/bin/../lib/gcc/arm-linux-gnueabihf/4.6/../../../../arm-linux-gnueabihf/bin/ld.exe : warning : libX11.so.6, needed by d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so, not found (try using -rpath or -rpath-link) 1>d:/sysgcc/beagledebian/bin/../lib/gcc/arm-linux-gnueabihf/4.6/../../../../arm-linux-gnueabihf/bin/ld.exe : warning : libdl.so.2, needed by d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtCore.so, not found (try using -rpath or -rpath-link) 1>d:/sysgcc/beagledebian/bin/../lib/gcc/arm-linux-gnueabihf/4.6/../../../../arm-linux-gnueabihf/bin/ld.exe : warning : librt.so.1, needed by d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtCore.so, not found (try using -rpath or -rpath-link) 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference to
XSetTile' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference todeflateInit_’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toFT_New_Memory_Face' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXReparentWindow’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toAuCloseServer' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toFT_Matrix_Multiply’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXSetIMValues' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXConvertSelection’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXSetFillStyle' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXUnsetICFocus’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference topng_read_info@PNG12_0' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toFcFontSetDestroy’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXQueryColors' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference todeflateInit2_’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference topng_set_gAMA@PNG12_0' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toFcPatternAddString’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXGetImage' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toFT_Load_Sfnt_Table’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtCore.so: undefined reference tog_main_context_push_thread_default' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXSyncQueryExtension’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXGetFontProperty' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXRenderChangePicture’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference topng_get_tRNS@PNG12_0' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXSetWindowBackgroundPixmap’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference topng_set_PLTE@PNG12_0' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference tocompress’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXFreeFontNames' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toFcPatternGetLangSet’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtCore.so: undefined reference tog_main_context_ref' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXRenderCompositeText32′ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXFreeColormap' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXRestackWindows’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXDrawRectangles' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference topng_set_filler@PNG12_0′ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXFreeFont' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toAuSoundPlayFromFile’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtCore.so: undefined reference todlerror@GLIBC_2.4' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference topng_get_text@PNG12_0′ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXSetFillRule' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toFcCharSetDestroy’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXStoreName' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtCore.so: undefined reference tog_main_context_unref’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXCreatePixmap' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toFcPatternGetCharSet’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference topng_set_packing@PNG12_0' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXSendEvent’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXWindowEvent' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference tog_error_free’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtCore.so: undefined reference tog_main_context_default' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXFillRectangles’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXGetDefault' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXGetWindowProperty’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toFcObjectSetCreate' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXGetIMValues’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toAuStopFlow' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXCreateSimpleWindow’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXSetErrorHandler' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference topng_write_rows@PNG12_0′ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXListFonts' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toSmcInteractDone’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toFcPatternGetBool' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference topng_set_invert_mono@PNG12_0′ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXQueryExtension' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXSyncIntsToValue’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXSynchronize' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toFT_Load_Glyph’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXSetForeground' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXGrabPointer’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toFcDefaultSubstitute' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXRenderFindVisualFormat’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toSmcGetIceConnection' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtCore.so: undefined reference touncompress’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXQueryTree' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference tog_type_check_instance_cast’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference topng_set_error_fn@PNG12_0' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXSetWMHints’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toFcPatternGetInteger' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toFT_Set_Transform’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference topng_write_chunk@PNG12_0' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toFcCharSetHasChar’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXSetFont' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference todeflate’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtCore.so: undefined reference tog_main_context_pending' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXSetCloseDownMode’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXCopyArea' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXRenderFindStandardFormat’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXFreeFontSet' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXSetWMNormalHints’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toFcConfigGetFonts' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXAllowEvents’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXFilterEvent' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXDrawLines’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toFT_Outline_Transform' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference topng_get_image_width@PNG12_0′ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toFT_Get_Postscript_Name' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtCore.so: undefined reference tocompress2′ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXCreateGC' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXkbSetPerClientControls’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXFillRectangle' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXSetWMProtocols’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXCreateFontCursor' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtCore.so: undefined reference tog_source_set_priority’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXUngrabServer' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXKeycodeToKeysym’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference topng_set_IHDR@PNG12_0' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtCore.so: undefined reference tog_source_unref’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXRegisterIMInstantiateCallback' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference topng_set_sig_bytes@PNG12_0′ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference topng_read_update_info@PNG12_0' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXFreeGC’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXmbLookupString' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXDestroyRegion’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference todeflateEnd' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toFcNameConstant’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toFcPatternAddWeak' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toIceProcessMessages’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference topng_set_interlace_handling@PNG12_0' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXSelectInput’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXCreateColormap' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXSetClipMask’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toFcPatternGetString' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXFreeFontPath’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXGetRGBColormaps' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXBell’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference topng_set_write_fn@PNG12_0' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toFT_Get_PS_Font_Info’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXUnregisterIMInstantiateCallback' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXRenderQueryVersion’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toSmcRequestSaveYourselfPhase2' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXShapeGetRectangles’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXChangeGC' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toFcFontSort’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toSmcCloseConnection' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toFcPatternCreate’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toFT_Init_FreeType' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXDrawRectangle’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference topng_write_end@PNG12_0' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toFT_GlyphSlot_Embolden’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference tocrc32' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toSmcDeleteProperties’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXCreatePixmapCursor' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXShapeCombineMask’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXRenderSetPictureClipRectangles' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXInternAtom’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference topng_create_read_struct@PNG12_0' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXParseColor’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toFcFontSetAdd' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXStoreColors’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXDrawArc' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXSetInputFocus’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toSmcSetProperties' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtCore.so: undefined reference todlclose@GLIBC_2.4′ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXNextRequest' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toFT_Get_Char_Index’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXGetWMColormapWindows' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toFcConfigGetBlanks’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toinflate' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXWithdrawWindow’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXDrawPoint' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXGetWMNormalHints’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXGetVisualInfo' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXAllocColor’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toFcFontList' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXInitThreads’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXRenderQuerySubpixelOrder' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXMoveWindow’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXDrawPoints' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference topng_read_image@PNG12_0′ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXShmQueryVersion' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXkbGetState’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toAuDestroyBucket' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXkbQueryExtension’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXChangeProperty' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toFcObjectSetAdd’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXSetClipOrigin' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXSyncInitialize’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toinflateInit2_' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toFT_Outline_Get_Bitmap’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXLookupString' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXMoveResizeWindow’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference tog_source_set_can_recurse' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toFT_MulFix’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toFcConfigAppFontAddFile' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toFcPatternEqual’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXPending' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXCreateIC’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference topng_set_gray_to_rgb@PNG12_0' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXLocaleOfIM’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXDestroyIC' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtCore.so: undefined reference tog_main_context_pop_thread_default’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference tog_signal_connect_data' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXmbResetIC’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXkbGetMap' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXUngrabPointer’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference topng_get_IHDR@PNG12_0' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference tog_source_attach’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXSetTSOrigin' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtCore.so: undefined reference tog_main_context_iteration’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toFcFreeTypeQuery' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXSyncIntToValue’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference topng_get_channels@PNG12_0' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXGrabServer’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXCreateRegion' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference topng_set_strip_16@PNG12_0′ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference topng_set_expand@PNG12_0' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXParseGeometry’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference topng_set_pHYs@PNG12_0' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXShmDetach’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXCloseIM' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference tog_source_add_poll’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toinflateEnd' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXPutBackEvent’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toFcConfigSubstitute' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference topng_create_write_struct@PNG12_0′ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXFreeCursor' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toFcPatternAddLangSet’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXRenderCompositeTrapezoids' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXSetSelectionOwner’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXShmCreatePixmap' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXSetWMIconName’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXSupportsLocale' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXConnectionNumber’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXEventsQueued' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXSetSubwindowMode’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXMapWindow' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference topng_get_gAMA@PNG12_0′ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toFcPatternAddDouble' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXQueryPointer’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXRaiseWindow' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXmbTextListToTextProperty’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toFT_Set_Charmap' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXCreateBitmapFromData’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference topng_write_info@PNG12_0' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXShmAttach’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toFcLangSetHasLang' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXFreeModifiermap’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference tog_free' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXDisplayKeycodes’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toAuSoundCreateBucketFromFile' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference topng_set_text@PNG12_0′ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toAuHandleEvents' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXClearArea’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtCore.so: undefined reference todlopen@GLIBC_2.4' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference topng_get_PLTE@PNG12_0′ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference tog_object_set' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXCreateFontSet’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toFcFreeTypeQueryFace' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXRefreshKeyboardMapping’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXSetWMName' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXGrabKeyboard’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtCore.so: undefined reference tog_main_context_new' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toFT_Get_Sfnt_Table’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference topng_set_oFFs@PNG12_0' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toFcPatternAddInteger’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXCreateImage' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toFT_Library_SetLcdFilter’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference tog_object_get' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toFcPatternAdd’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference topng_destroy_write_struct@PNG12_0' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference topng_get_io_ptr@PNG12_0′ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXShmCreateImage' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXFree’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference tog_source_remove_poll' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference topng_get_image_height@PNG12_0′ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXRenderFreePicture' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXkbLookupKeySym’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXUngrabKeyboard' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXAddToSaveSet’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toAuFlush' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toFcObjectSetDestroy’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXSetBackground' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXSetLocaleModifiers’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toAuSync' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toAuSoundPlayFromBucket’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXCheckTypedWindowEvent' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXSyncSetCounter’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference tog_type_check_instance_is_a' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXSetIOErrorHandler’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXRenderFreeGlyphSet' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toFcPatternDestroy’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXCheckMaskEvent' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toFT_MulDiv’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toFcFontRenderPrepare' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toFT_Outline_Translate’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXOpenDisplay' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXRenderFillRectangle’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toFcPatternDuplicate' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXSetWMProperties’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference tog_source_new' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXFreeStringList’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXSyncCreateCounter' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toFT_Vector_Transform’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXRenderComposite' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXSetDashes’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXNextEvent' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toFcInit’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXInternAtoms' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference topng_get_y_pixels_per_meter@PNG12_0′ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXGetErrorText' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXRenderQueryExtension’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXResizeWindow' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXGetGeometry’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXSetWindowBackground' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXkbSelectEventDetails’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference tog_type_init' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXUnmapWindow’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toAuScanEvents' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference tog_object_set_data’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXWarpPointer' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXSetGraphicsExposures’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference topng_set_compression_level@PNG12_0' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toFcFontMatch’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference topng_get_x_pixels_per_meter@PNG12_0' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXSetStipple’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtCore.so: undefined reference todlsym@GLIBC_2.4' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference topng_set_gamma@PNG12_0′ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference tog_object_unref' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXSetTransientForHint’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXShmPutImage' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXFlush’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference topng_destroy_read_struct@PNG12_0' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toIceConnectionNumber’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXGetModifierMapping' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXCreateWindow’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference topng_read_end@PNG12_0' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXDisplayName’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXFillArc' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXSetICValues’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtCore.so: undefined reference tog_main_context_wakeup' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXkbFreeKeyboard’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXGetWMHints' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXDestroyWindow’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXLowerWindow' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference topng_set_packswap@PNG12_0′ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXConvertCase' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toFT_Done_FreeType’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXDrawLine' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toSmcInteractRequest’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXChangeWindowAttributes' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXTranslateCoordinates’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference topng_set_sBIT@PNG12_0' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXDeleteProperty’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXSetWMColormapWindows' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference topng_error@PNG12_0′ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXVisualIDFromVisual' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXSetICFocus’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXMaxRequestSize' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toFT_Set_Char_Size’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXGetErrorDatabaseText' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXRenderAddGlyphs’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXUngrabButton' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toFcPatternDel’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXOpenIM' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toFcLangSetDestroy’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXGetInputFocus' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXCheckTypedEvent’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXDefineCursor' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXSetFunction’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toFcCharSetCopy' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toAuOpenServer’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXKillClient' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXRenderCreatePicture’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toFcPatternAddBool' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXVaCreateNestedList’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toFT_New_Face' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXGetFontPath’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference topng_write_image@PNG12_0' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXShapeCombineRegion’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXSetClipRectangles' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toSmcOpenConnection’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXGetWindowAttributes' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXRemoveFromSaveSet’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXGrabButton' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toFT_Render_Glyph’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXGetKeyboardMapping' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXFreePixmap’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXLoadQueryFont' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference topng_set_read_fn@PNG12_0′ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference topng_set_tRNS@PNG12_0' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toFcConfigAppFontClear’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toFcPatternGetDouble' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXFillPolygon’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference topng_create_info_struct@PNG12_0' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toSmcSaveYourselfDone’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toFcLangSetAdd' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXUnionRectWithRegion’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXSyncDestroyCounter' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toFT_Done_Face’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXmbTextPropertyToTextList' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference tog_source_destroy’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXRenderCreateCursor' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toAuSetCloseDownMode’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toFT_Get_Glyph_Name' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXGetSelectionOwner’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXCloseDisplay' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXSync’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXGetAtomName' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtCore.so: undefined reference toclock_gettime@GLIBC_2.4′ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toFcLangSetCreate' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference topng_set_bgr@PNG12_0′ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference topng_get_valid@PNG12_0' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXCheckIfEvent’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXPutImage' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXRenderCreateGlyphSet’ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference tog_slist_free' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXDrawString16′ 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toXListPixmapFormats' 1> d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so: undefined reference toFcConfigGetCurrent’ 1> collect2: ld returned 1 exit status 1> make: *** [Debug/QtBeagleCross] Error 1 1> ————————————————————- 1> Command exited with code 2 1> Executable: cmd.exe 1> Arguments: /c “D:\SysGCC\BeagleDebian\bin\make.exe” 1> Directory: D:\Qt4.8.1\project\QtBeagleCross\QtBeagleCross 1>VisualGDB : error : Command-line action failed 1>EXEC : error : Build has failed. See the Output window for more details. 1>C:\Program Files\MSBuild\Microsoft.Cpp\v4.0\V120\Microsoft.MakeFile.Targets(43,5): error MSB3073: The command “”C:\Program Files\Sysprogs\VisualGDB\\VisualGDB.exe” /rebuild “D:\Qt4.8.1\project\QtBeagleCross\QtBeagleCross\QtBeagleCross.vcxproj” “/solution:D:\Qt4.8.1\project\QtBeagleCross\QtBeagleCross.sln” “/config:Debug” “/platform:Win32″” exited with code 1. ========== Rebuild All: 0 succeeded, 1 failed, 0 skipped ==========July 4, 2015 at 20:00 #6678vodanh1303
ParticipantError list:
Warning 5 warning : libz.so.1, needed by d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so, not found (try using -rpath or -rpath-link) d:\sysgcc\beagledebian\arm-linux-gnueabihf\bin\ld.exe 1 1 QtBeagleCross
Warning 10 warning : libXrender.so.1, needed by d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so, not found (try using -rpath or -rpath-link) d:\sysgcc\beagledebian\arm-linux-gnueabihf\bin\ld.exe 1 1 QtBeagleCross
Warning 11 warning : libXext.so.6, needed by d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so, not found (try using -rpath or -rpath-link) d:\sysgcc\beagledebian\arm-linux-gnueabihf\bin\ld.exe 1 1 QtBeagleCross
Warning 12 warning : libX11.so.6, needed by d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so, not found (try using -rpath or -rpath-link) d:\sysgcc\beagledebian\arm-linux-gnueabihf\bin\ld.exe 1 1 QtBeagleCross
Warning 8 warning : libSM.so.6, needed by d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so, not found (try using -rpath or -rpath-link) d:\sysgcc\beagledebian\arm-linux-gnueabihf\bin\ld.exe 1 1 QtBeagleCross
Warning 14 warning : librt.so.1, needed by d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtCore.so, not found (try using -rpath or -rpath-link) d:\sysgcc\beagledebian\arm-linux-gnueabihf\bin\ld.exe 1 1 QtBeagleCross
Warning 4 warning : libpng12.so.0, needed by d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so, not found (try using -rpath or -rpath-link) d:\sysgcc\beagledebian\arm-linux-gnueabihf\bin\ld.exe 1 1 QtBeagleCross
Warning 9 warning : libICE.so.6, needed by d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so, not found (try using -rpath or -rpath-link) d:\sysgcc\beagledebian\arm-linux-gnueabihf\bin\ld.exe 1 1 QtBeagleCross
Warning 7 warning : libgobject-2.0.so.0, needed by d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so, not found (try using -rpath or -rpath-link) d:\sysgcc\beagledebian\arm-linux-gnueabihf\bin\ld.exe 1 1 QtBeagleCross
Warning 3 warning : libglib-2.0.so.0, needed by d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so, not found (try using -rpath or -rpath-link) d:\sysgcc\beagledebian\arm-linux-gnueabihf\bin\ld.exe 1 1 QtBeagleCross
Warning 6 warning : libfreetype.so.6, needed by d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so, not found (try using -rpath or -rpath-link) d:\sysgcc\beagledebian\arm-linux-gnueabihf\bin\ld.exe 1 1 QtBeagleCross
Warning 1 warning : libfontconfig.so.1, needed by d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so, not found (try using -rpath or -rpath-link) d:\sysgcc\beagledebian\arm-linux-gnueabihf\bin\ld.exe 1 1 QtBeagleCross
Warning 13 warning : libdl.so.2, needed by d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtCore.so, not found (try using -rpath or -rpath-link) d:\sysgcc\beagledebian\arm-linux-gnueabihf\bin\ld.exe 1 1 QtBeagleCross
Warning 2 warning : libaudio.so.2, needed by d:/sysgcc/beagledebian/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/libQtGui.so, not found (try using -rpath or -rpath-link) d:\sysgcc\beagledebian\arm-linux-gnueabihf\bin\ld.exe 1 1 QtBeagleCross
Error 17 error MSB3073: The command “”C:\Program Files\Sysprogs\VisualGDB\\VisualGDB.exe” /rebuild “D:\Qt4.8.1\project\QtBeagleCross\QtBeagleCross\QtBeagleCross.vcxproj” “/solution:D:\Qt4.8.1\project\QtBeagleCross\QtBeagleCross.sln” “/config:Debug” “/platform:Win32″” exited with code 1. C:\Program Files\MSBuild\Microsoft.Cpp\v4.0\V120\Microsoft.MakeFile.Targets 43 5 QtBeagleCross
Error 15 error : Command-line action failed D:\Qt4.8.1\project\QtBeagleCross\QtBeagleCross\VisualGDB QtBeagleCross
Error 16 error : Build has failed. See the Output window for more details. D:\Qt4.8.1\project\QtBeagleCross\QtBeagleCross\EXEC QtBeagleCrossJuly 5, 2015 at 03:35 #6679support
KeymasterDo those files (e.g. libSM.so.6) exist in your toolchain’s sysroot? If yes, what is the directory containing them?
July 5, 2015 at 10:44 #6680vodanh1303
ParticipantYes. Its exist in directory D:\SysGCC\BeagleDebian\arm-linux-gnueabihf\sysroot\usr\lib\arm-linux-gnueabihf
July 6, 2015 at 19:42 #6684support
We have investigated the problem. Looks like our Beaglebone toolchain is missing one important file. We will update it soon.
As a workaround please create a file called ld.so.conf in d:/sysgcc/beagledebian/arm-linux-gnueabihf/sysroot/etc and put the following contents there:
# Multiarch support /lib/arm-linux-gnueabihf /usr/lib/arm-linux-gnueabihf # libc default configuration /usr/local/lib
July 7, 2015 at 02:58 #6686vodanh1303
Thanks you very much.
Yes, That’s ok.
I have a question. How to design QT form or QT windows in project visual studio?
July 7, 2015 at 20:26 #6691support
Please try installing the Qt addin: https://wiki.qt.io/Visual_Studio_Add-in
