Probleme with latest ARM Toolchain and time functions
Sysprogs forums › Forums › VisualGDB › Probleme with latest ARM Toolchain and time functions
  • #26856
    julieninnovel
    I have a project based on a STM32 using the internal RTC.
    I was using the toolchain “arm-eabi-gcc7.2.0-r3” to translate a timestamp UNIX to a tm struct and sthen set my RTC like this :
    #include
    #include <sys\time.h>
    void RTC_SetTimeByTimeStamp(uint32_t u32_TimeStamp)
    struct tm* p_time;
    /* convert into unix time struct */
    p_time = gmtime((time_t*)&u32_TimeStamp);
    All was OK. If I call this function with a timestamp at 1576158671, the p_time struct contain :
    12/12/2019  13:51:11
    But with the latset toolchain “arm-eabi-gcc9.2.1”, the same function, call with the same timestamp value set the p_time struct with random value like :
    2/1/1971721  11:25:06
    Thanks for your help.
    • This topic was modified 6 years, 9 months ago by support. Reason: formatting
    #26858
    Sorry, the latest ARM toolchain comes directly from ARM and we do not control the logic it uses for translating time.
    As a workaround, please try using a time conversion function from an external library, or try submitting a bugreport via ARM forums.
    #26954
    CrzyRndm
    https://os.mbed.com/questions/80116/time_t-is-broken-with-2017-q4-releas-of-/
    time_t is now a 64 bit integer, a 32 bit pointer is not going to end well
    #26955
    Thanks for pointing this out!
