I am trying to run the Instrument profiling and I keep running into an issue. It will run for a small amount of time (a couple seconds) and then it’ll just stop working. Sometimes I get no error message, the code just seems to stop running and if I hit pause on the debugger I’m off in the weeds in an invalid spot in flash. Sometimes it does pop up with the following error:
Instrumented stack stream corrupted: no frames found
I’m still in the initialization part of my code, I haven’t even gotten to normal operation yet. If I remove some functions from the instrumentation I seem to be able to make it a little bit further into the initialization before it dies again. I doubled the size of stack for the task that it dies in and it still dies at the same point.
I followed the instructions in this Tutorial to get it running: https://visualgdb.com/tutorials/arm/keil/rtx/instrumentation/
I have the Semihosting Buffersize set to 32768 rather than the 4K from the tutorial, but I’ve also tried 4K and 16K with the same results
Visual Studios 2012
VisualGDB 5.4 Beta 2 (Custom version)
FreeRTOS project
STM32L496
Any thoughts on things I should check or any other settings you need to be made aware of?
Thanks!
