I trying to run the USB CDC Example but the PC does not recognize the USB.
I think it is the PLL Setting for the clock and I not sure how to set it up.
Can some one help.
My hardware use a 12MHz for the HSE and STM32105VC.
// Configure PPL Clock
oscinitstruct.OscillatorType = RCC_OSCILLATORTYPE_HSE; // Select HSE as Oscillator (12MHz input)
oscinitstruct.HSEState = RCC_HSE_ON; // Enable the HSE block
oscinitstruct.PLL2.HSEPrediv2Value = RCC_HSE_PREDIV2_DIV3; // Divide by 3 => 4MHz
oscinitstruct.PLL2.PLL2MUL = RCC_PLL2_MUL10; // Multiply by 10 => 40MHz
oscinitstruct.PLL2.PLL2State = RCC_PLL2_ON; // Enable the PLL2 block
oscinitstruct.Prediv1Source = RCC_PREDIV1_SOURCE_PLL2; // Select PLL2 (40MHz)
oscinitstruct.HSEPredivValue = RCC_HSE_PREDIV_DIV5; // Divide by PPL2 by 5 => 8MHz
oscinitstruct.PLL.PLLSource = RCC_PLLSOURCE_HSE; // as clock source the PLL block
oscinitstruct.PLL.PLLState = RCC_PLL_ON; // Enable the PLL block
oscinitstruct.PLL.PLLMUL = RCC_PLL_MUL9; // Multiply by 9 => 72MHz
HAL_RCC_OscConfig(&oscinitstruct);
/* USB clock selection */
rccperiphclkinit.PeriphClockSelection = RCC_PERIPHCLK_USB; // Set USB clock to
rccperiphclkinit.UsbClockSelection = RCC_USBPLLCLK_DIV3; // 72 x2 /3 = 48MHz
HAL_RCCEx_PeriphCLKConfig(&rccperiphclkinit);
The question is what clock the USB need? I thought the USB uses a 480MHz clock.
Thanks.
This topic was modified 10 years, 8 months ago by
