Path is not of a legal form.
Sysprogs forums › Forums › VisualGDB › Path is not of a legal form.
  • #22379
    jonasjohansson
    Im running VisualGDB 4.3 and I get the the error "Path is not of a legal form." when trying to add a VisualGDB configuration (from Project->Add VisualGDB Configuration->New Linux Configuration).
    I am also unable to open the properties under (Project->VisualGDB Project Properties).
    Do you have any feedback on what I might be doing wrong?
    Best regards,
    /Jonas
    #22396
    VisualGDB 4.3 is very old and likely contains many bugs that have been fixed in later versions. Please consider updating to VisualGDB 5.4 Preview 7.
    #24647
    PeterFromSwe
    Hi
    This seems relevant for newer versions as well…
    VisualGDB version: 5.4.104.3031
    —————— System.ArgumentException ——————
    System.ArgumentException: The path is not of a legal form.
    at System.IO.Path.LegacyNormalizePath(String path, Boolean fullCheck, Int32 maxPathLength, Boolean expandShortPaths)
    at System.IO.Path.NormalizePath(String path, Boolean fullCheck, Int32 maxPathLength, Boolean expandShortPaths)
    at System.IO.Path.InternalGetDirectoryName(String path)
    at e11.m3(Project a)
    at e11.NewWindowsConfiguration.Execute()
    #24652
    No problem, we can help you resolve this.
    Adding a Windows configuration to a regular Win32 project is a part of our automated pre-release tests (we have also rechecked it manually now just in case), so the issue is likely caused by some specific setting in your project. If you could share either the project that triggers this, or compare with with a freshly created one and narrow down a specific setting, we should be able to release a hotfix promptly.
