Thanks for reporting this. The warning is indeed triggered by the syntax used in the VisualGDB’s Makefile. Please try changing the rules near the $(LINKER_SCRIPT) check as shown below:
EXTRA_DEPENDENCIES :=
ifneq ($(LINKER_SCRIPT),)
EXTRA_DEPENDENCIES += $(LINKER_SCRIPT)
endif
ifeq ($(TARGETTYPE),APP)
$(BINARYDIR)/$(TARGETNAME): $(all_objs) $(EXTERNAL_LIBS) $(EXTRA_DEPENDENCIES)
	$(LD) -o $@ $(LDFLAGS) $(START_GROUP) $(all_objs) $(LIBRARY_LDFLAGS) $(END_GROUP)
endif
ifeq ($(TARGETTYPE),SHARED)
	$(LD) -shared -o $@ $(LDFLAGS) $(START_GROUP) $(all_objs) $(LIBRARY_LDFLAGS) $(END_GROUP)
endif
ifeq ($(TARGETTYPE),STATIC)
$(BINARYDIR)/$(TARGETNAME): $(all_objs) $(EXTRA_DEPENDENCIES)
	$(AR) -r $@ $^
endif
If this triggers errors, please double-check that the ‘tab’ symbol before the $(LD) and $(AR) commands got copied correctly.
We have also updated VisualGDB internally so that it will now use the new rule syntax for new projects that won’t trigger any warnings.
