object reference not set to an instance of an object: Visual Studio 2017
Sysprogs forums Forums VisualGDB object reference not set to an instance of an object: Visual Studio 2017
  • #21532
    rohinidr
    I am setting up Visual GDB for OpenCv Raspberry Pi project . I am following the instructions provided in the link
    https://visualgdb.com/tutorials/raspberry/opencv/
    I am able to create a project and deploy project . But when I get to step 5, that to configure cMake settings , I click on Project->Visual GDB Object Properties , I get an error “Object Reference not set to an instance of an object”.
    I tried to uninstall and install Visual studio 2017 , deleted the folder in /User/name/Appdata/
    But nothing works . Is it a bug or I have some problem with installation?
    #21537
    Sorry, unfortunately this error message is too generic to fully pinpoint the problem. If you could try clicking the “show details” button and paste the results here, we should be able to see what is going on and suggest a fix/workaround.
    #21541
    rohinidr
    Hi ,
    Please check the error below when I click on Visual GDB properties
    VisualGDB version: 5.3.18.1973
    at jb1.u.b1()
    at o21.n()
    at o21..ctor(qp1 a)
    at jb1.GDBProjectProperties.ExecuteForProject(jb1 addin, Object objPrj)
    #21544
    Thanks for the log. It looks like you are using VisualGDB 5.3 that is not the latest available version. Please try VisualGDB 5.4 Preview 3 (or this build) and if the problem persists, submit an updated log.
    #21545
    rohinidr
    This worked.
    Thank you !
