NRFConnect SDK from nordic Nordic v 2.4.1 and 2.4.2, unable to install.
Sysprogs forums Forums VisualGDB NRFConnect SDK from nordic Nordic v 2.4.1 and 2.4.2, unable to install.
  • #34689
    Manuel Elko
    As per Title.
    take care,
    Manuel.
    #34745
    Sorry for the delay. We have investigated this and it turns out NRFConnect 2.4+ requires a newer version of Python (we tested 3.11.5 and it worked). However, older NRFConnect versions, and some other frameworks used by VisualGDB are not compatible with Python 3.11 and require older versions (3.8 works).
    We have updated VisualGDB to keep separate track of several Python installations and pick them based on the project type and the SDK version.
    Please try installing this build [VisualGDB-6.0.2.4929.msi] and updating the package catalog via Tools->VisualGDB->Manage VisualGDB Packages->Online. It should fetch the correct package definitions and pick the correct Python package compatible with the NRFConnect version you are using.
    #34760
    Manuel Elko
    Dear Support Team,
    I confirm the reached functionality covered with v6.0.2.4929 (object of this post).
    thank you for actively supporting & take care,
    Manuel.
    #34828
    jkarch48
    I just had the same issue, I will try the newest version. The error comes from installing Pillow.
