Sysprogs forums › Forums › VisualGDB › nRF52 FreeRTOS LEDBlink
- This topic has 4 replies, 2 voices, and was last updated 10 years, 3 months ago by
June 17, 2016 at 19:57 #8444
Brian Walker
ParticipantThe Nordic SDK for the nRF52 includes a Blinky example using FreeRTOS. VisualGDB includes FreeRTOS examples for other platforms, but no option exists for the nRF52 when generating a new project. Can one be created?
My attempt to shoehorn FreeRTOS in has resulted in a large list of includes (which defeats the purpose of a managed build) and multiple definitions of parts of the project that are managed by the build.
June 17, 2016 at 21:12 #8445support
We are considering it for the next update of our nRF52 BSP, but it’s not there yet. However we can easily help you get through the errors you are encountering if you share more details.
June 17, 2016 at 22:23 #8453Brian Walker
ParticipantI may have made some “progress” since the original post, so here is what I’ve done.
I started an nRF52 blinky (BSP) demo.
(I’ve installed my shared files at the same root directory as my project, so that why the pathing may appear odd.)
Per the standard FreeRTOS setup, I added the following include directories:
../../bsp/nRF5x/external/freertos/source/include
../../bsp/nRF5x/external/freertos/portable/GCC/nrf52
Per the standard FreeRTOS setup, I added the following files to my project from the bsp install:
../../bsp/nRF5x/external/freertos/source/list.c
../../bsp/nRF5x/external/freertos/source/queue.c
../../bsp/nRF5x/external/freertos/source/tasks.c
../../bsp/nRF5x/external/freertos/source/portable/MemMang/heap_1.c
../../bsp/nRF5x/external/freertos/portable/GCC/nrf52/port.c
I also copied FreeRTOSConfig.h to my project and added it as a header file. I modified the file to match the config from blinky_freertos in the SDK.
I added the following includes to my LEDBlink.c and then built. (No actual FreeRTOS tasks.)
#include “FreeRTOS.h”
#include “task.h”This produced multiple build errors for portmacro_cmsis.h so I added the following include directory to the makefile.
../../bsp/nRF5x/external/freertos/portable/CMSIS/nrf52
This built cleanly.
I then created a task and added a call to vTaskStartScheduler().
This build failed.
I added the following sources to resolve missing file errors.
../../bsp/nRF5x/external/freertos/portable/CMSIS/nrf52/port_cmsis.c
../../bsp/nRF5x/external/freertos/portable/CMSIS/nrf52/port_cmsis_systick.c
This build failed with the following errors:
Error VGDB1000 undefined reference to ‘nrf_drv_clock_lfclk_request’ blink_freertos C:\Projects\nordic\visualgdb\bsp\nRF5x\external\freertos\portable\CMSIS\nrf52\port_cmsis_systick.c 200
Error VGDB1002 undefined reference to ‘__isr_vector’ blink_freertos C:\Projects\nordic\visualgdb\blink_freertos\blink_freertos\port.c 1
Error VGDB1000 undefined reference to ‘xTimerCreateTimerTask’ blink_freertos C:\Projects\nordic\visualgdb\bsp\nRF5x\external\freertos\source\tasks.c 1565
Error ld returned 1 exit status blink_freertos C:\Projects\nordic\visualgdb\blink_freertos\blink_freertos\collect2.exe 1
Error Command-line action failed blink_freertos C:\Projects\nordic\visualgdb\blink_freertos\blink_freertos\VisualGDB 1
Error MSB3073 The command “”C:\Program Files (x86)\Sysprogs\VisualGDB\\VisualGDB.exe” /rebuild “C:\Projects\nordic\visualgdb\blink_freertos\blink_freertos\blink_freertos.vcxproj” “/solution:C:\Projects\nordic\visualgdb\blink_freertos\blink_freertos.sln” “/config:Debug” “/platform:Win32″” exited with code 1. blink_freertos C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V140\Microsoft.MakeFile.Targets 42Clearly these are all linker errors, and that’s where I’m at.
This reply was modified 10 years, 3 months ago by
Brian Walker.
Brian Walker.
June 17, 2016 at 22:43 #8456Brian Walker
ParticipantI enabled the clock and added the following file:
../../bsp/nRF5x/external/freertos/source/timers.c
That leaves me with:
Error Command-line action failed blink_freertos C:\Projects\nordic\visualgdb\blink_freertos\blink_freertos\VisualGDB 1June 20, 2016 at 05:44 #8457support
This happens because the FreeRTOS port hardcodes the ISR vector table name variable name as ‘__isr_vector’ and the VisualGDB startup file uses a different name.
The easiest way to solve this is to replace this (in port.c):
" ldr r0, =__isr_vector \n" /* Locate the stack using __isr_vector table. */ " ldr r0, [r0] \n"
with that:
" ldr r0, =_estack \n"
Note that the “ldr ro, [r0]” line will be removed, as _estack already contains the end-of-stack address.
Let us know if you encounter further problems.
