Not Remembering Path Mappings
Sysprogs forums Forums VisualGDB Not Remembering Path Mappings
  • #30997
    MikeGranby
    VisualGDB doesn’t seem to be remembering path mappings between sessions–or if it does, a very small change to the debugging environment seems to break them. Are they stored with a QuickDebug preset? Also, I just set up a new machine, and I seem to have to enter path mappings where I never had to before. Am I missing some setting that might make VisualGDB figure out the mappings from the loaded project?
    #31004
    Normally, the paths should be remembered. If it doesn’t happen, please try installing the latest VisualGDB 5.6 Beta (you would need to renew your support here), make sure your can reproduce the problem from scratch, and share the steps we could follow on our side to reproduce the problem per our problem reporting guidelines.
