no menu visualddk after installing VisualGDB [Solved]
Sysprogs forums › Forums › VisualGDB › no menu visualddk after installing VisualGDB [Solved]
  • #405
    IzTexasa
    After installing VisualGDB, no menu visualddk to debug menu. Reinstall, – did not help …
    #2037
    Hi, please run the following commands:
    devenv /resetaddin VisualGDB.AddIn
    devenv /resetaddin DDKDebugConsole.Connect
    devenv /resetaddin DDKDebugLauncher.Connect
    devenv /resetaddin DDKProjectProperties.Connect
    It will reset all addin settings.
    If this does not help, please execute the Tools->Addins command in Visual Studio and ensure that all VisualDDK addins are enabled.
    Note that if you import previously saved Visual Studio settings after installing VisualGDB/VisualDDK, the newly created menus will be reset. Running /resetaddin will always restore the add-in menus to their default state.
    #2036
    IzTexasa
    Thank you
