Sysprogs forums › Forums › VisualGDB › No executable file specified in Embedded project
- This topic has 6 replies, 3 voices, and was last updated 8 years, 7 months ago by
July 6, 2017 at 13:56 #11667
Artemdmitriev
ParticipantHello!
I created a project using of Embedded Project Wizard. For project i use my own Makefile. Project compiled successsfuly but when i try to debug(use OpenOCD) i get the following error:
No executable file specified.
Use the “file” or “exec-file” command.
Cannot resolve the address of _estack. Skipping stack pointer validity check.How to tell OpenOCD where executable file is located ?
July 7, 2017 at 06:19 #11670Artemdmitriev
ParticipantThe problem is solved
July 7, 2017 at 18:13 #11674support
Good to know it works now. In case anyone else runs into the same problem, this usually happens when the build actually does not succeed and the main executable is not created.
February 14, 2018 at 22:52 #20104Luna
ParticipantHi, I know it is an old thread, but I am facing the same issue, unable to flash or debug my device, but I am able to build my project
Device: nR52
my logs:
c:\SysGCC\arm-eabi\bin\arm-eabi-gdb.exe –interpreter mi C:\Users\DevTest – Test Dev\VisualGDB\Debug\Project
-gdb-version
-gdb-version
Excess command line arguments ignored. (Test …)
=thread-group-added,id=”i1″
~”GNU gdb (GDB) 8.0.1\n”
~”Copyright (C) 2017 Free Software Foundation, Inc.\n”
~”This GDB was configured as \”–host=i686-w64-mingw32 –target=arm-eabi\”.\nType \”show configuration\” for configuration details.”
~”For help, type \”help\”.\n”
&”C:\\Users\\DevTest: No such file or directory.\n”
&”C:\\Users\\DevTest – Test Dev\\Project/-: No such file or directory.\n”
(gdb)
^done
^done
^done
(gdb)
-list-features
-list-features
(gdb)
^error,msg=”No symbol table is loaded. Use the \”file\” command.”
(gdb)
-gdb-set print demangle off
^done
^done
^done
(gdb)
-break-insert -f main
&”No symbol table is loaded. Use the \”file\” command.\n”
(gdb)
-break-delete 1
-break-delete 1
^done
^done
^done
(gdb)
target remote :50963
&”target remote :50963\n”
~”Remote debugging using :50963\n”
&”warning: No executable has been specified and target does not support\ndetermining executable automatically. Try using the \”file\” command.”
&”\n”
&”\n”
&”\n”
~”0x0002d324 in ?? ()\n”
*stopped,frame={addr=”0x0002d324″,func=”??”,args=[]},thread-id=”1″,stopped-threads=”all”
^done
^done
^done
(gdb)
mon reset
mon reset
&”mon reset\n”
&”mon reset\n”
&”mon reset\n”
@”Resetting target\r\n”
^done
^done
^done
(gdb)
info shared
info shared
&”info shared\n”
&”info shared\n”
&”info shared\n”
~”No shared libraries loaded at this time.\n”
^done
^done
^done
(gdb)
load
load
&”load\n”
&”load\n”
&”load\n”
&”No executable file specified.\n”
&”Use the \”file\” or \”exec-file\” command.\n”
^error,msg=”No executable file specified.\nUse the \”file\” or \”exec-file\” command.”
(gdb)
mon reset
mon reset
&”mon reset\n”
&”mon reset\n”
&”mon reset\n”
^done
^done
^done
(gdb)
compare-sections
compare-sections
&”compare-sections\n”
&”command cannot be used without an exec file\n”
^error,msg=”command cannot be used without an exec file”
(gdb)-
This reply was modified 8 years, 7 months ago by
Luna.
February 14, 2018 at 22:56 #20107support
Please don’t use paths with spaces for your projects, as this confuses many GNU tools. Simply moving the project to a different path and reopening it should fully solve this.
February 14, 2018 at 23:20 #20109Luna
Participantomg! it is solved! it is like some black magic lol
Thanks a lot it was a true headache for me
February 14, 2018 at 23:40 #20110support
Good to know it works. VisualGDB actually warns about this when you create a project. If you are not familiar with the GNU tools internals, please do follow the VisualGDB suggestions – they are designed to save your time.
