No connection could be made because the target machine actively refused it
Sysprogs forums › Forums › VisualKernel › No connection could be made because the target machine actively refused it
  • #30273
    agricartel
    I am trying to set up a kernel module project, and connect to a Debian VM on my system via SSH (on localhost:4498). Below is the output from the error window:
    VisualKernel version: 3.1.7.2252
    —————— System.Net.Sockets.SocketException ——————
    System.Net.Sockets.SocketException (0x80004005): No connection could be made because the target machine actively refused it [::1]:4498
    at System.Net.Sockets.Socket.Connect(IPAddress[] addresses, Int32 port)
    at System.Net.Sockets.TcpClient.Connect(IPAddress[] ipAddresses, Int32 port)
    at hg2.x.d(IPAddress[] b, Int32 a)
    at hg2.e(SSHConnectionSettings d, String b, x c, Boolean e, Boolean a)
    I have confirmed that port is up, and can SSH into the VM from powershell on the host machine. I have also have currently disabled windows defender firewall.
    Thanks.
    #30281
    This looks like an IPv6/IPv4 issue. Please try specifying “127.0.0.1” or instead of localhost, or using the IP address from another network interface.
