New esp-idf project with r16 toolchain
Sysprogs forums › Forums › VisualGDB › New esp-idf project with r16 toolchain
  • #24973
    lzambonelli @mexage
    i’m trying to port my project from toolchain R15 to R16. I had a lot of problem, and in order to pen project in VS2017 i had to change MANUALLY the vdbproj file (very annoying). After VS2017 was able to open it, it was not able to compile.
    Than i tried to start from an example program, but when i try to create a new one the attached message appear.
    I’ve noticed another problem: ehn i open VisualGDB project PRoperties windows, within ESP-IDF configuration list i cannot find how to set serial port to flash the micro.
    Can you help me?
    In general, i’ve noticed that everytime an updated toolchain is installed, it’s a kind of mess
    Thanks in advance for your kindly help
    Best regards
    Leonardo
    #24976
    Sorry, ESP-IDF is not very backward-compatible. Unfortunately, it isn’t something controlled by us – it’s a design choice by Espressif to introduce new features faster at a cost of backward compatibility. Our best advice for porting the project would be to create a new one with the latest IDF/toolchain and then move your code one file at a time, resolving the build issues.
    We can help you find the COM port setting if you could post screenshots of the project properties and debug properties page of VisualGDB Project Properties.
    #24990
    lzambonelli @mexage
    Thanks for your reply (and sorry for my delay)
    Already solved. Just opened manually file and changed it
    Another suggestion when a new toolchain is set is delete VisualGDBCache, CodeDB and Debug folder within solution root folder.
    #24991
    Thanks for the suggestion. We can indeed cache the toolchain/IDF version used during the last build and force a full rebuild when it doesn’t match anymore. We will investigate this and get back to you around the middle of the next week.
    #24999
    OK, we have updated VisualGDB to automatically remove the temporary files from the previous ESP-IDF versions when changing the toolchain or the IDF checkout.
    Please try this build: VisualGDB-5.4.105.3154.msi
