Sysprogs forums › Forums › VisualGDB › Need help: visualgdb cannot find gdbserver even though the gdbserver exists
- This topic has 19 replies, 3 voices, and was last updated 10 years ago by
zhongliu.
March 3, 2016 at 01:57 #7706
zhongliu
ParticipantHi Friends,
Need your help on this issue.
Just installed Visualgdb on visual studio 2015, the app can be deployed to Hardware and be executed, but cannot do debug. Ran compatibility test, got the following error, complains gdbserver does not exist on …\libs\arm64, but it actually exist on …\libs\arm64-v8a.
My EABI: arm64-v8a platform version: 23
How to resolve this issue?
Thanks much in advance for your help !
Zhong
March 3, 2016 at 03:43 #7709support
Please try the following build:http://sysprogs.com/files/tmp/VisualGDB-5.1.4.650.msi
Then open a VisualGDB project, launch the toolchain testing and send us the contents of the VisualGDB Launcher Output view from the Output window. It should contain detailed log messages explaining the gdbserver location logic.March 5, 2016 at 01:29 #7717zhongliu
This is the output, please help fix the problem.
VisualGDB: C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe devices
VisualGDB: C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s bc738ea4 shell getprop ro.build.version.release
VisualGDB: C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s bc738ea4 shell getprop ro.product.cpu.abi
VisualGDB: C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s bc738ea4 shell getprop ro.build.version.sdk
VisualGDB: C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s bc738ea4 shell ps
VisualGDB: C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s bc738ea4 shell id
VisualGDB: C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s bc738ea4 install -r “C:\Users\zl121\AppData\Local\Temp\SysprogsAndroidTest-14804\4.9\bin\SysprogsAndroidAutoTest-debug.apk”
VisualGDB: C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s bc738ea4 shell run-as com.sysprogs.AndroidAutoTest /system/bin/sh -c pwd
Using app directory: /data/data/com.sysprogs.AndroidAutoTest
Detected device EABI: arm64-v8a
VisualGDB: C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s bc738ea4 shell ls /data/data/com.sysprogs.AndroidAutoTest/lib
VisualGDB: C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s bc738ea4 shell pm list packages -f
VisualGDB: C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s bc738ea4 shell ls /data/app/com.sysprogs.AndroidAutoTest-2/lib/arm64-v8a
Checking Android project ABI…
Device ABI: arm64
Library directory: C:\Users\zl121\AppData\Local\Temp\SysprogsAndroidTest-14804\4.9\libs
Missing C:\Users\zl121\AppData\Local\Temp\SysprogsAndroidTest-14804\4.9\libs\arm64
Checking for C:\Users\zl121\AppData\Local\Temp\SysprogsAndroidTest-14804\4.9\libs\arm64\gdbserver…
Checking for C:\Users\zl121\AppData\Local\Temp\SysprogsAndroidTest-14804\4.9\libs\arm64\libgdbserver.so…
VisualGDB: C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s bc738ea4 shell ls /data/app/com.sysprogs.AndroidAutoTest-1/lib/arm64-v8a
Device ABI: arm64
Device ABI: arm64
Checking for C:\Users\zl121\AppData\Local\Temp\SysprogsAndroidTest-14804\4.9\libs\arm64\libgdbserver.so…March 5, 2016 at 01:40 #7718supercachai
ParticipantHi, I just encountered the same issue, with a Nexus 5X. My logs are equal, VisualGDB somehow assumes “arm64”, where it should be “arm64-v8a”. I’ve set some symlinks from “arm64” to “arm64-v8a” in lib and obj folder, then the gsbserver seems to start but then crashing:
Cannot find a toolchain for EABI: arm64
System.NullReferenceException: Der Objektverweis wurde nicht auf eine Objektinstanz festgelegt.
bei fc..ctor(VisualGDBProjectSettings2 A_0, GDBSessionLaunchOptions A_1, pr A_2, alu A_3, Boolean A_4)
bei VisualGDB.GDBDebugEngine.a(adl A_0)Regards
FabianMarch 5, 2016 at 03:23 #7723support
Thanks for the logs. Please try this build: http://sysprogs.com/files/tmp/VisualGDB-5.1.4.652.msi
March 5, 2016 at 03:48 #7724supercachai
ParticipantThanks,
this gets the gdb started, I get a loading bar that it waits for the application to start but then crashes again (with a note to try 32-bit version NDK, tried it but same result):
~"/s/ndk-toolchain/src/build/../gdb/gdb-7.7/gdb/gdbarch.c:3991: internal-error: gdbarch_record_special_symbol_p: Assertion `gdbarch != NULL' failed.\nA problem internal to GDB has been detected,\nfurther debugging may prove unreliable.\nQuit this debugging session? "
~"(y or n) [answered Y; input not from terminal]\n"
~"/s/ndk-toolchain/src/build/../gdb/gdb-7.7/gdb/gdbarch.c:3991: internal-error: gdbarch_record_special_symbol_p: Assertion `gdbarch != NULL' failed.\nA problem internal to GDB has been detected,\nfurther debugging may prove unreliable.\nCreate a core file of GDB? "
This application has requested the Runtime to terminate it in an unusual way.
Please contact the application's support team for more information.
March 5, 2016 at 12:41 #7728supercachai
ParticipantUpdate: after debugging with the emulator it works on the device. Thanks for that fix!
I still get that assertion error when running a toolchain test though, leaving the toolchain untested. Can I somehow disable the dialog that asks for testing an untested toolchain?
March 6, 2016 at 05:45 #7729zhongliu
Thanks for your fix version http://sysprogs.com/files/tmp/VisualGDB-5.1.4.652.msi, gdbserver can be found, the last reported bug was fixed, but still got a new problem, I installed/used 32bit NDK android-ndk-r10e-windows-x86.exe, the issue does not matter with 32/64bit NDK, could you please help fix this new issue? the log is attached here:
VisualGDB: Run “C:\Android\android-ndk-r10e\ndk-build.cmd NDK_DEBUG=1 APP_PLATFORM=android-21 VGDB_VSCONFIG=” in directory “C:\Users\zl121\AppData\Local\Temp\SysprogsAndroidTest-10484\4.9” on local computer
Android NDK: WARNING: APP_PLATFORM android-21 is larger than android:minSdkVersion 3 in ./AndroidManifest.xml
[arm64-v8a] Gdbserver : [aarch64-linux-android-4.9] libs/arm64-v8a/gdbserver
[arm64-v8a] Gdbsetup : libs/arm64-v8a/gdb.setup
[arm64-v8a] Compile : first <= first.c
[arm64-v8a] SharedLibrary : libfirst.so
[arm64-v8a] Install : libfirst.so => libs/arm64-v8a/libfirst.so
[arm64-v8a] Compile : second <= second.c
[arm64-v8a] SharedLibrary : libsecond.so
[arm64-v8a] Install : libsecond.so => libs/arm64-v8a/libsecond.so
VisualGDB: build.xml/local.properties not found in C:\Users\zl121\AppData\Local\Temp\SysprogsAndroidTest-10484\4.9. Running “android update project” to generate it…
VisualGDB: Run “C:\Program Files (x86)\Android\android-sdk\tools\android.bat update project –path “C:\Users\zl121\AppData\Local\Temp\SysprogsAndroidTest-10484\4.9″” in directory “” on local computer
Updated local.properties
No project name specified, using Activity name ‘SysprogsAndroidAutoTest’.
If you wish to change it, edit the first line of build.xml.
Added file C:\Users\zl121\AppData\Local\Temp\SysprogsAndroidTest-10484\4.9\build.xml
Added file C:\Users\zl121\AppData\Local\Temp\SysprogsAndroidTest-10484\4.9\proguard-project.txt
VisualGDB: Run “C:\Android\ant-1.9.6\bin\ant.bat debug” in directory “C:\Users\zl121\AppData\Local\Temp\SysprogsAndroidTest-10484\4.9” on local computer
Buildfile: C:\Users\zl121\AppData\Local\Temp\SysprogsAndroidTest-10484\4.9\build.xml-set-mode-check:
-set-debug-files:
-check-env:
[checkenv] Android SDK Tools Revision 24.4.1
[checkenv] Installed at C:\Program Files (x86)\Android\android-sdk-setup:
[echo] Project Name: SysprogsAndroidAutoTest
[gettype] Project Type: Application-set-debug-mode:
-debug-obfuscation-check:
-pre-build:
-build-setup:
[getbuildtools] Using latest Build Tools: 23.0.2
[echo] Resolving Build Target for SysprogsAndroidAutoTest…
[gettarget] Project Target: Android 6.0
[gettarget] API level: 23
[echo] ———-
[echo] Creating output directories if needed…
[mkdir] Created dir: C:\Users\zl121\AppData\Local\Temp\SysprogsAndroidTest-10484\4.9\bin
[mkdir] Created dir: C:\Users\zl121\AppData\Local\Temp\SysprogsAndroidTest-10484\4.9\bin\res
[mkdir] Created dir: C:\Users\zl121\AppData\Local\Temp\SysprogsAndroidTest-10484\4.9\bin\rsObj
[mkdir] Created dir: C:\Users\zl121\AppData\Local\Temp\SysprogsAndroidTest-10484\4.9\bin\rsLibs
[mkdir] Created dir: C:\Users\zl121\AppData\Local\Temp\SysprogsAndroidTest-10484\4.9\gen
[mkdir] Created dir: C:\Users\zl121\AppData\Local\Temp\SysprogsAndroidTest-10484\4.9\bin\classes
[mkdir] Created dir: C:\Users\zl121\AppData\Local\Temp\SysprogsAndroidTest-10484\4.9\bin\dexedLibs
[echo] ———-
[echo] Resolving Dependencies for SysprogsAndroidAutoTest…
[dependency] Library dependencies:
[dependency] No Libraries
[dependency]
[dependency] ——————
[echo] ———-
[echo] Building Libraries with ‘debug’…
[subant] No sub-builds to iterate on-code-gen:
[mergemanifest] Merging AndroidManifest files into one.
[mergemanifest] Manifest merger disabled. Using project manifest only.
[echo] Handling aidl files…
[aidl] No AIDL files to compile.
[echo] ———-
[echo] Handling RenderScript files…
[echo] ———-
[echo] Handling Resources…
[aapt] Generating resource IDs…
[echo] ———-
[echo] Handling BuildConfig class…
[buildconfig] Generating BuildConfig class.-pre-compile:
-compile:
[javac] Compiling 3 source files to C:\Users\zl121\AppData\Local\Temp\SysprogsAndroidTest-10484\4.9\bin\classes
[javac] warning: [options] source value 1.5 is obsolete and will be removed in a future release
[javac] warning: [options] target value 1.5 is obsolete and will be removed in a future release
[javac] warning: [options] To suppress warnings about obsolete options, use -Xlint:-options.
[javac] 3 warnings-post-compile:
-obfuscate:
-dex:
[dex] input: C:\Users\zl121\AppData\Local\Temp\SysprogsAndroidTest-10484\4.9\bin\classes
[dex] Converting compiled files and external libraries into C:\Users\zl121\AppData\Local\Temp\SysprogsAndroidTest-10484\4.9\bin\classes.dex…-crunch:
[crunch] Crunching PNG Files in source dir: C:\Users\zl121\AppData\Local\Temp\SysprogsAndroidTest-10484\4.9\res
[crunch] To destination dir: C:\Users\zl121\AppData\Local\Temp\SysprogsAndroidTest-10484\4.9\bin\res
[crunch] Crunched 0 PNG files to update cache-package-resources:
[aapt] Creating full resource package…
[aapt] Warning: AndroidManifest.xml already defines debuggable (in http://schemas.android.com/apk/res/android); using existing value in manifest.-package:
[apkbuilder] Current build type is different than previous build: forced apkbuilder run.
[apkbuilder] Creating SysprogsAndroidAutoTest-debug-unaligned.apk and signing it with a debug key…-post-package:
-do-debug:
[zipalign] Running zip align on final apk…
[echo] Debug Package: C:\Users\zl121\AppData\Local\Temp\SysprogsAndroidTest-10484\4.9\bin\SysprogsAndroidAutoTest-debug.apk
[propertyfile] Creating new property file: C:\Users\zl121\AppData\Local\Temp\SysprogsAndroidTest-10484\4.9\bin\build.prop
[propertyfile] Updating property file: C:\Users\zl121\AppData\Local\Temp\SysprogsAndroidTest-10484\4.9\bin\build.prop
[propertyfile] Updating property file: C:\Users\zl121\AppData\Local\Temp\SysprogsAndroidTest-10484\4.9\bin\build.prop-post-build:
debug:
BUILD SUCCESSFUL
Total time: 8 seconds
Debug log:
——— Testing workaround mode: Disabled, attempt 1 ———
Preparing for launch…
C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s 9416189d shell ps
USER PID PPID VSIZE RSS WCHAN PC NAMEroot 1 0 5036 1720 SyS_epoll_ 0000000000 S /init
root 2 0 0 0 kthreadd 0000000000 S kthreadd
root 3 2 0 0 smpboot_th 0000000000 S ksoftirqd/0
root 4 2 0 0 worker_thr 0000000000 S kworker/0:0
root 6 2 0 0 worker_thr 0000000000 S kworker/u8:0
root 7 2 0 0 rcu_gp_kth 0000000000 S rcu_preempt
root 8 2 0 0 rcu_gp_kth 0000000000 S rcu_sched
root 9 2 0 0 rcu_gp_kth 0000000000 S rcu_bh
root 10 2 0 0 smpboot_th 0000000000 S migration/0
root 11 2 0 0 smpboot_th 0000000000 S watchdog/0
root 12 2 0 0 smpboot_th 0000000000 S watchdog/1
root 13 2 0 0 smpboot_th 0000000000 S migration/1
root 14 2 0 0 smpboot_th 0000000000 S ksoftirqd/1
root 15 2 0 0 worker_thr 0000000000 S kworker/1:0
root 16 2 0 0 worker_thr 0000000000 S kworker/1:0H
root 17 2 0 0 smpboot_th 0000000000 S watchdog/2
root 18 2 0 0 smpboot_th 0000000000 S migration/2
root 19 2 0 0 smpboot_th 0000000000 S ksoftirqd/2
root 21 2 0 0 worker_thr 0000000000 S kworker/2:0H
root 22 2 0 0 smpboot_th 0000000000 S watchdog/3
root 23 2 0 0 smpboot_th 0000000000 S migration/3
root 24 2 0 0 smpboot_th 0000000000 S ksoftirqd/3
root 25 2 0 0 worker_thr 0000000000 S kworker/3:0
root 27 2 0 0 rescuer_th 0000000000 S khelper
root 28 2 0 0 rescuer_th 0000000000 S netns
root 29 2 0 0 rescuer_th 0000000000 S perf
root 30 2 0 0 rescuer_th 0000000000 S smd_channel_clo
root 31 2 0 0 rescuer_th 0000000000 S glink_tx
root 32 2 0 0 rescuer_th 0000000000 S glink_tx
root 33 2 0 0 rescuer_th 0000000000 S glink_tx
root 34 2 0 0 rescuer_th 0000000000 S glink_tx
root 35 2 0 0 rescuer_th 0000000000 S glink_tx
root 36 2 0 0 watchdog_k 0000000000 S msm_watchdog
root 38 2 0 0 rescuer_th 0000000000 S rpm_requests
root 39 2 0 0 kthread_wo 0000000000 S smem_native_mps
root 40 2 0 0 rescuer_th 0000000000 S glink_tx
root 41 2 0 0 kthread_wo 0000000000 S smem_native_lpa
root 42 2 0 0 rescuer_th 0000000000 S glink_tx
root 43 2 0 0 kthread_wo 0000000000 S smem_native_dsp
root 44 2 0 0 rescuer_th 0000000000 S glink_tx
root 45 2 0 0 kthread_wo 0000000000 S smem_native_rpm
root 46 2 0 0 rescuer_th 0000000000 S glink_tx
root 47 2 0 0 worker_thr 0000000000 S kworker/0:1
root 48 2 0 0 rescuer_th 0000000000 S deferwq
root 49 2 0 0 msm_mpm_wo 0000000000 D kworker/u8:1
root 50 2 0 0 irq_thread 0000000000 S irq/219-cpr3
root 51 2 0 0 irq_thread 0000000000 S irq/220-cpr3_ce
root 52 2 0 0 irq_thread 0000000000 S irq/221-cpr3
root 53 2 0 0 rescuer_th 0000000000 S mpm
root 54 2 0 0 diag_socke 0000000000 S kworker/u8:2
root 55 2 0 0 worker_thr 0000000000 S kworker/u8:3
root 72 2 0 0 worker_thr 0000000000 S kworker/1:1
root 73 2 0 0 rescuer_th 0000000000 S writeback
root 74 2 0 0 rescuer_th 0000000000 S crypto
root 75 2 0 0 rescuer_th 0000000000 S bioset
root 76 2 0 0 rescuer_th 0000000000 S kblockd
root 77 2 0 0 ion_heap_d 0000000000 S system
root 78 2 0 0 ion_heap_d 0000000000 S secure_heap
root 79 2 0 0 rescuer_th 0000000000 S ipa_power_mgmt
root 80 2 0 0 rescuer_th 0000000000 S sps_ipa_power_m
root 81 2 0 0 worker_thr 0000000000 S kworker/u9:0
root 82 2 0 0 rescuer_th 0000000000 S ipawq14
root 83 2 0 0 rescuer_th 0000000000 S iparepwq14
root 84 2 0 0 worker_thr 0000000000 S kworker/u9:1
root 85 2 0 0 rescuer_th 0000000000 S ipawq47
root 86 2 0 0 rescuer_th 0000000000 S iparepwq47
root 87 2 0 0 rescuer_th 0000000000 S ipawq13
root 88 2 0 0 rescuer_th 0000000000 S iparepwq13
root 89 2 0 0 rescuer_th 0000000000 S ipa_rm_wq
root 90 2 0 0 rescuer_th 0000000000 S ipa_interrupt_w
root 91 2 0 0 irq_thread 0000000000 S irq/240-arm-smm
root 92 2 0 0 irq_thread 0000000000 S irq/245-arm-smm
root 93 2 0 0 irq_thread 0000000000 S irq/250-arm-smm
root 94 2 0 0 irq_thread 0000000000 S irq/255-arm-smm
root 95 2 0 0 irq_thread 0000000000 S irq/267-arm-smm
root 96 2 0 0 irq_thread 0000000000 S irq/272-arm-smm
root 97 2 0 0 irq_thread 0000000000 S irq/277-arm-smm
root 98 2 0 0 irq_thread 0000000000 S irq/282-arm-smm
root 99 2 0 0 irq_thread 0000000000 S irq/299-arm-smm
root 100 2 0 0 irq_thread 0000000000 S irq/306-arm-smm
root 101 2 0 0 irq_thread 0000000000 S irq/315-arm-smm
root 102 2 0 0 rescuer_th 0000000000 S devfreq_wq
root 103 2 0 0 rescuer_th 0000000000 S governor_msm_ad
root 104 2 0 0 worker_thr 0000000000 S kworker/3:1
root 105 2 0 0 rescuer_th 0000000000 S cfg80211
root 106 2 0 0 irq_thread 0000000000 S irq/143-bcl_vba
root 107 2 0 0 irq_thread 0000000000 S irq/142-bcl_iba
root 130 2 0 0 rescuer_th 0000000000 S power_off_alarm
root 131 2 0 0 kswapd 0000000000 S kswapd0
root 132 2 0 0 fsnotify_m 0000000000 S fsnotify_mark
root 133 2 0 0 ecryptfs_t 0000000000 S ecryptfs-kthrea
root 154 2 0 0 rescuer_th 0000000000 S ad_calc_wq
root 155 2 0 0 rescuer_th 0000000000 S rot_commit_work
root 156 2 0 0 rescuer_th 0000000000 S rot_workq_0
root 157 2 0 0 rescuer_th 0000000000 S rot_workq_1
root 158 2 0 0 dsi_event_ 0000000000 D mdss_dsi_event
root 159 2 0 0 rescuer_th 0000000000 S mdss_dsi_dba
root 160 2 0 0 rescuer_th 0000000000 S mdss_dsi_dba
root 161 2 0 0 rescuer_th 0000000000 S hdmi_tx_workq
root 162 2 0 0 rescuer_th 0000000000 S diag_cmd_wq
root 163 2 0 0 rescuer_th 0000000000 S remote_fw_updat
root 164 2 0 0 rescuer_th 0000000000 S wihd_sm_wq
root 165 2 0 0 rescuer_th 0000000000 S mhl_sm_wq
root 166 2 0 0 rescuer_th 0000000000 S diag_sm_wq
root 167 2 0 0 kthread_wo 0000000000 S hdcp_tz_lib
root 168 2 0 0 kthread_wo 0000000000 S hdmi_hdcp2p2
root 169 2 0 0 rescuer_th 0000000000 S glink_ssr_wq
root 170 2 0 0 rescuer_th 0000000000 S glink_lbsrv
root 171 2 0 0 rescuer_th 0000000000 S glink_xprt_wq
root 172 2 0 0 rescuer_th 0000000000 S IPCRTR_mpss_smd
root 173 2 0 0 rescuer_th 0000000000 S IPCRTR_lpass_sm
root 174 2 0 0 rescuer_th 0000000000 S IPCRTR
root 175 2 0 0 rescuer_th 0000000000 S IPCRTR_dsps_smd
root 176 2 0 0 rescuer_th 0000000000 S IPCRTR
root 177 2 0 0 rescuer_th 0000000000 S IPCRTR
root 178 2 0 0 rescuer_th 0000000000 S apr_driver
root 179 2 0 0 rescuer_th 0000000000 S glink_pkt_wq
root 180 2 0 0 rescuer_th 0000000000 S ssr_monitor_wai
root 181 2 0 0 rescuer_th 0000000000 S pacman_qmi_noti
root 182 2 0 0 rescuer_th 0000000000 S pacman_qmi_rx_w
root 183 2 0 0 rescuer_th 0000000000 S qmi_svc_event_w
root 184 2 0 0 rescuer_th 0000000000 S msm_ipc_router
root 185 2 0 0 rescuer_th 0000000000 S k_hsuart
root 186 2 0 0 kthread_wo 0000000000 S msm_serial_hs_0
root 187 2 0 0 kthread_wo 0000000000 S msm_serial_hs_0
root 188 2 0 0 add_hwgene 0000000000 S hwrng
root 190 2 0 0 rescuer_th 0000000000 S diag_real_time_
root 191 2 0 0 rescuer_th 0000000000 S diag_wq
root 192 2 0 0 rescuer_th 0000000000 S DIAG_USB_diag
root 193 2 0 0 rescuer_th 0000000000 S diag_cntl_wq
root 194 2 0 0 rescuer_th 0000000000 S diag_dci_wq
root 195 2 0 0 rescuer_th 0000000000 S DIAG_SMD_MODEM_
root 196 2 0 0 rescuer_th 0000000000 S DIAG_SMD_MODEM_
root 197 2 0 0 rescuer_th 0000000000 S DIAG_SMD_MODEM_
root 198 2 0 0 rescuer_th 0000000000 S DIAG_SMD_MODEM_
root 199 2 0 0 rescuer_th 0000000000 S DIAG_SMD_MODEM_
root 200 2 0 0 rescuer_th 0000000000 S DIAG_SMD_LPASS_
root 201 2 0 0 rescuer_th 0000000000 S DIAG_SMD_LPASS_
root 202 2 0 0 rescuer_th 0000000000 S DIAG_SMD_LPASS_
root 203 2 0 0 rescuer_th 0000000000 S DIAG_SMD_LPASS_
root 204 2 0 0 rescuer_th 0000000000 S DIAG_SMD_LPASS_
root 205 2 0 0 rescuer_th 0000000000 S DIAG_SMD_WCNSS_
root 206 2 0 0 rescuer_th 0000000000 S DIAG_SMD_WCNSS_
root 207 2 0 0 rescuer_th 0000000000 S DIAG_SMD_WCNSS_
root 208 2 0 0 rescuer_th 0000000000 S DIAG_SMD_WCNSS_
root 209 2 0 0 rescuer_th 0000000000 S DIAG_SMD_WCNSS_
root 210 2 0 0 rescuer_th 0000000000 S DIAG_SMD_SENSOR
root 211 2 0 0 rescuer_th 0000000000 S DIAG_SMD_SENSOR
root 212 2 0 0 rescuer_th 0000000000 S DIAG_SMD_SENSOR
root 213 2 0 0 rescuer_th 0000000000 S DIAG_SMD_SENSOR
root 214 2 0 0 rescuer_th 0000000000 S DIAG_SMD_SENSOR
root 215 2 0 0 rescuer_th 0000000000 S DIAG_SOCKMODEM_
root 216 2 0 0 rescuer_th 0000000000 S DIAG_SOCKMODEM_
root 217 2 0 0 rescuer_th 0000000000 S DIAG_SOCKMODEM_
root 218 2 0 0 rescuer_th 0000000000 S DIAG_SOCKMODEM_
root 219 2 0 0 rescuer_th 0000000000 S DIAG_SOCKMODEM_
root 220 2 0 0 rescuer_th 0000000000 S DIAG_SOCKLPASS_
root 221 2 0 0 rescuer_th 0000000000 S DIAG_SOCKLPASS_
root 222 2 0 0 rescuer_th 0000000000 S DIAG_SOCKLPASS_
root 223 2 0 0 rescuer_th 0000000000 S DIAG_SOCKLPASS_
root 224 2 0 0 rescuer_th 0000000000 S DIAG_SOCKLPASS_
root 225 2 0 0 rescuer_th 0000000000 S DIAG_SOCKWCNSS_
root 226 2 0 0 rescuer_th 0000000000 S DIAG_SOCKWCNSS_
root 227 2 0 0 rescuer_th 0000000000 S DIAG_SOCKWCNSS_
root 228 2 0 0 rescuer_th 0000000000 S DIAG_SOCKWCNSS_
root 229 2 0 0 rescuer_th 0000000000 S DIAG_SOCKWCNSS_
root 230 2 0 0 rescuer_th 0000000000 S DIAG_SOCKSENSOR
root 231 2 0 0 rescuer_th 0000000000 S DIAG_SOCKSENSOR
root 232 2 0 0 rescuer_th 0000000000 S DIAG_SOCKSENSOR
root 233 2 0 0 rescuer_th 0000000000 S DIAG_SOCKSENSOR
root 234 2 0 0 rescuer_th 0000000000 S DIAG_SOCKSENSOR
root 235 2 0 0 rescuer_th 0000000000 S DIAG_CNTL_SOCKE
root 236 2 0 0 rescuer_th 0000000000 S kgsl-workqueue
root 237 2 0 0 rescuer_th 0000000000 S kgsl-mementry
root 238 2 0 0 rescuer_th 0000000000 S qcrypto_seq_res
root 259 2 0 0 scsi_error 0000000000 S scsi_eh_0
root 260 2 0 0 rescuer_th 0000000000 S scsi_tmf_0
root 261 2 0 0 rescuer_th 0000000000 S ufs_pm_qos_0
root 262 2 0 0 rescuer_th 0000000000 S ufs_clkscaling_
root 263 2 0 0 kthread_wo 0000000000 S spi0
root 266 2 0 0 kthread_wo 0000000000 S spi11
root 270 2 0 0 diag_socke 0000000000 S kworker/u8:5
root 274 2 0 0 diag_socke 0000000000 S kworker/u8:9
root 275 2 0 0 irq_thread 0000000000 S irq/462-sii6400
root 276 2 0 0 rescuer_th 0000000000 S bond0
root 277 2 0 0 rescuer_th 0000000000 S usbnet
root 278 2 0 0 rescuer_th 0000000000 S sharedmem_qmi_w
root 279 2 0 0 rescuer_th 0000000000 S qmi_hndl0000000
root 280 2 0 0 irq_thread 0000000000 S irq/127-hs_phy_
root 281 2 0 0 irq_thread 0000000000 S irq/128-ss_phy_
root 282 2 0 0 irq_thread 0000000000 S irq/129-msm_dwc
root 283 2 0 0 rescuer_th 0000000000 S k_gserial
root 284 2 0 0 rescuer_th 0000000000 S k_ipa_usb
root 285 2 0 0 rescuer_th 0000000000 S uether
root 286 2 0 0 rescuer_th 0000000000 S k_gbridge
root 287 2 0 0 worker_thr 0000000000 S kworker/3:2
root 288 2 0 0 irq_thread 0000000000 S irq/465-atmel_t
root 289 2 0 0 irq_thread 0000000000 S irq/464-atmel_m
root 290 2 0 0 rescuer_th 0000000000 S msm_vidc_worker
root 291 2 0 0 rescuer_th 0000000000 S pm_workerq_venu
root 292 2 0 0 irq_thread 0000000000 S irq/256-arm-smm
root 293 2 0 0 irq_thread 0000000000 S irq/257-arm-smm
root 294 2 0 0 irq_thread 0000000000 S irq/258-arm-smm
root 295 2 0 0 irq_thread 0000000000 S irq/259-arm-smm
root 296 2 0 0 rescuer_th 0000000000 S msm_cci_wq
root 297 2 0 0 rescuer_th 0000000000 S msm_cci_wq
root 299 2 0 0 worker_thr 0000000000 S kworker/2:2
root 302 2 0 0 worker_thr 0000000000 S kworker/0:1H
root 305 2 0 0 rescuer_th 0000000000 S msm_cpp_workque
root 306 2 0 0 irq_thread 0000000000 S irq/192-batt-mi
root 307 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 308 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 309 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 310 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 311 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 312 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 313 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 314 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 315 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 316 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 317 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 318 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 319 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 320 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 321 2 0 0 irq_thread 0000000000 S irq/202-tsens_i
root 322 2 0 0 irq_thread 0000000000 S irq/203-tsens_c
root 323 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 324 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 325 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 326 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 327 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 328 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 329 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 330 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 331 2 0 0 irq_thread 0000000000 S irq/336-tsens_i
root 332 2 0 0 irq_thread 0000000000 S irq/337-tsens_c
root 333 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 334 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 335 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 336 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 337 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 338 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 339 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 340 2 0 0 rescuer_th 0000000000 S dm_bufio_cache
root 341 2 0 0 cpufreq_in 0000000000 S cfinteractive
root 342 2 0 0 irq_thread 0000000000 S irq/196-qpnp_wl
root 343 2 0 0 rescuer_th 0000000000 S binder
root 344 2 0 0 irq_thread 0000000000 S irq/197-qpnp_sc
root 345 2 0 0 rescuer_th 0000000000 S usb_bam_wq
root 346 2 0 0 irq_thread 0000000000 S irq/10-spdm_bw_
root 347 2 0 0 rescuer_th 0000000000 S soc:audio_etm0
root 348 2 0 0 rescuer_th 0000000000 S soc:rpm_etm0
root 349 2 0 0 rescuer_th 0000000000 S soc:modem_etm0
root 350 2 0 0 worker_thr 0000000000 S kworker/3:3
root 351 2 0 0 rescuer_th 0000000000 S ipv6_addrconf
root 352 2 0 0 rfcomm_run 0000000000 S krfcommd
root 353 2 0 0 irq_thread 0000000000 S irq/654-adsp
root 354 2 0 0 rescuer_th 0000000000 S sysmon_wq
root 355 2 0 0 rescuer_th 0000000000 S adsp
root 356 2 0 0 rescuer_th 0000000000 S sys_mon
root 357 2 0 0 irq_thread 0000000000 S irq/686-slpi
root 358 2 0 0 rescuer_th 0000000000 S slpi
root 359 2 0 0 rescuer_th 0000000000 S sys_mon
root 360 2 0 0 irq_thread 0000000000 S irq/622-modem
root 361 2 0 0 rescuer_th 0000000000 S kgsl-events
root 362 2 0 0 rescuer_th 0000000000 S kgsl_devfreq_wq
root 365 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 366 2 0 0 irq_thread 0000000000 S irq/147-chg-err
root 367 2 0 0 irq_thread 0000000000 S irq/153-chg-tap
root 368 2 0 0 irq_thread 0000000000 S irq/154-chg-tcc
root 369 2 0 0 irq_thread 0000000000 S irq/152-chg-rec
root 370 2 0 0 irq_thread 0000000000 S irq/151-chg-p2f
root 371 2 0 0 irq_thread 0000000000 S irq/155-batt-ho
root 372 2 0 0 irq_thread 0000000000 S irq/156-batt-wa
root 373 2 0 0 irq_thread 0000000000 S irq/158-batt-co
root 374 2 0 0 irq_thread 0000000000 S irq/157-batt-co
root 375 2 0 0 irq_thread 0000000000 S irq/161-batt-mi
root 376 2 0 0 irq_thread 0000000000 S irq/160-batt-lo
root 377 2 0 0 irq_thread 0000000000 S irq/163-usbin-u
root 378 2 0 0 irq_thread 0000000000 S irq/164-usbin-o
root 379 2 0 0 irq_thread 0000000000 S irq/165-usbin-s
root 380 2 0 0 irq_thread 0000000000 S irq/168-aicl-do
root 381 2 0 0 irq_thread 0000000000 S irq/166-otg-fai
root 382 2 0 0 irq_thread 0000000000 S irq/167-otg-oc
root 383 2 0 0 irq_thread 0000000000 S irq/169-usbid-c
root 384 2 0 0 irq_thread 0000000000 S irq/170-dcin-uv
root 385 2 0 0 irq_thread 0000000000 S irq/172-power-o
root 386 2 0 0 irq_thread 0000000000 S irq/173-temp-sh
root 387 2 0 0 irq_thread 0000000000 S irq/174-wdog-ti
root 388 2 0 0 rescuer_th 0000000000 S lk_wq
root 389 2 0 0 rescuer_th 0000000000 S rq_stats
root 390 2 0 0 events_not 0000000000 S msm_perf:events
root 391 2 0 0 irq_thread 0000000000 S irq/283-arm-smm
root 392 2 0 0 irq_thread 0000000000 S irq/284-arm-smm
root 393 2 0 0 irq_thread 0000000000 S irq/285-arm-smm
root 394 2 0 0 irq_thread 0000000000 S irq/286-arm-smm
root 395 2 0 0 irq_thread 0000000000 S irq/287-arm-smm
root 396 2 0 0 irq_thread 0000000000 S irq/288-arm-smm
root 397 2 0 0 irq_thread 0000000000 S irq/289-arm-smm
root 398 2 0 0 irq_thread 0000000000 S irq/290-arm-smm
root 399 2 0 0 rescuer_th 0000000000 S sb-1
root 400 2 0 0 ngd_slim_r 0000000000 D ngd_rx_thread1
root 401 2 0 0 ngd_notify 0000000000 D ngd_notify_sl1
root 402 2 0 0 rescuer_th 0000000000 S k_bam_data
root 403 2 0 0 rescuer_th 0000000000 S f_mtp
root 404 2 0 0 worker_thr 0000000000 S kworker/1:1H
root 405 2 0 0 do_samplin 0000000000 D msm-core:sampli
root 406 2 0 0 do_hotplug 0000000000 S msm_thermal:hot
root 407 2 0 0 do_freq_mi 0000000000 S msm_thermal:fre
root 408 2 0 0 do_thermal 0000000000 S msm_thermal:the
root 409 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 410 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 411 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 412 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 413 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 414 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 415 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 416 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 417 2 0 0 irq_thread 0000000000 S irq/218-lmh-int
root 418 2 0 0 boost_mig_ 0000000000 S boost_sync/0
root 419 2 0 0 boost_mig_ 0000000000 S boost_sync/1
root 420 2 0 0 boost_mig_ 0000000000 S boost_sync/2
root 421 2 0 0 boost_mig_ 0000000000 S boost_sync/3
root 422 2 0 0 rescuer_th 0000000000 S ipa_A7_svc
root 423 2 0 0 rescuer_th 0000000000 S qmi_hndl0000000
root 424 2 0 0 rescuer_th 0000000000 S clnt_req
root 425 2 0 0 rescuer_th 0000000000 S clnt_resp
root 426 2 0 0 rescuer_th 0000000000 S clnt_req
root 427 1 4520 1068 poll_sched 0000000000 S /sbin/ueventd
root 429 2 0 0 kjournald2 0000000000 S jbd2/sde19-8
root 430 2 0 0 rescuer_th 0000000000 S ext4-rsv-conver
root 433 2 0 0 worker_thr 0000000000 S kworker/3:1H
root 435 2 0 0 kjournald2 0000000000 S jbd2/sda9-8
root 436 2 0 0 rescuer_th 0000000000 S ext4-rsv-conver
root 438 2 0 0 kjournald2 0000000000 S jbd2/sda3-8
root 439 2 0 0 rescuer_th 0000000000 S ext4-rsv-conver
root 440 2 0 0 kjournald2 0000000000 S jbd2/sda2-8
root 441 2 0 0 rescuer_th 0000000000 S ext4-rsv-conver
root 442 2 0 0 kjournald2 0000000000 S jbd2/sde13-8
root 443 2 0 0 rescuer_th 0000000000 S ext4-rsv-conver
logd 444 1 13144 3316 sigsuspend 0000000000 S /system/bin/logd
root 449 1 15088 3016 hrtimer_na 0000000000 S /system/bin/vold
root 455 2 0 0 rescuer_th 0000000000 S lpass_IPCRTR
root 456 2 0 0 rescuer_th 0000000000 S LOOPBACK
root 457 2 0 0 rescuer_th 0000000000 S qmi_hndl0000000
root 458 2 0 0 rescuer_th 0000000000 S qmi_hndl0000000
root 459 2 0 0 kthread_wo 0000000000 S msm_slim_qmi_cl
root 460 2 0 0 rescuer_th 0000000000 S qmi_hndl0000000
root 461 2 0 0 irq_thread 0000000000 S irq/291-arm-smm
root 463 2 0 0 rescuer_th 0000000000 S dsps_IPCRTR
root 470 2 0 0 rescuer_th 0000000000 S qmi_hndl0000000
root 471 2 0 0 rescuer_th 0000000000 S qmi_hndl0000000
root 492 2 0 0 irq_thread 0000000000 S irq/393-wcd9xxx
root 510 2 0 0 rescuer_th 0000000000 S tfa98xx
root 524 1 4272 528 SyS_epoll_ 0000000000 S /sbin/healthd
root 525 1 6396 1236 SyS_epoll_ 0000000000 S /system/bin/lmkd
system 526 1 6272 1472 binder_thr 0000000000 S /system/bin/servicemanager
system 527 1 255824 23332 SyS_epoll_ 0000000000 S /system/bin/surfaceflinger
nobody 530 1 13632 1604 poll_sched 0000000000 S /system/bin/rmt_storage
system 534 1 18416 2060 do_sigtime 0000000000 S system/bin/pm-service
system 536 1 23048 3492 do_wait 0000000000 S /system/bin/qseecomd
shell 546 1 6076 1532 n_tty_read 7f7b50de3c S /system/bin/sh
root 547 1 19728 2528 hrtimer_na 0000000000 S /system/bin/netd
root 548 1 3188 1124 __skb_recv 0000000000 S /system/bin/debuggerd
root 549 1 6720 1304 __skb_recv 0000000000 S /system/bin/debuggerd64
radio 550 1 89812 13284 hrtimer_na 0000000000 S /system/bin/rild
drm 551 1 18340 5692 binder_thr 0000000000 S /system/bin/drmserver
media 552 1 147268 23352 binder_thr 0000000000 S /system/bin/mediaserver
root 554 1 6376 1804 unix_strea 0000000000 S /system/bin/installd
keystore 562 1 10936 2568 binder_thr 0000000000 S /system/bin/keystore
root 572 1 14284 2484 poll_sched 0000000000 S /system/bin/qcom-system-daemon
rfs 574 1 7488 1620 poll_sched 0000000000 S /system/bin/tftp_server
system 581 1 23848 7736 binder_thr 0000000000 S /system/bin/wfdservice
root 582 1 105660 3268 sigsuspend 0000000000 S /system/vendor/bin/thermal-engine
media 583 1 8060 1240 poll_sched 0000000000 S /system/bin/adsprpcd
system 585 1 10644 1796 poll_sched 0000000000 S /system/bin/imsqmidaemon
system 588 1 6596 1432 SyS_epoll_ 0000000000 S /system/bin/hvdcp_opti
root 596 1 3760 140 poll_sched 0000000000 S /system/bin/sw_coredump
root 597 1 2086020 66928 poll_sched 0000000000 S zygote64
root 598 1 1506028 55296 poll_sched 0000000000 S zygote
system 599 1 10256 2336 binder_thr 0000000000 S /system/bin/gatekeeperd
root 615 1 6088 1296 hrtimer_na 0000000000 S /system/xbin/perfprofd
system 620 1 72752 16368 SyS_epoll_ 0000000000 S /system/bin/cnd
root 621 1 12988 2132 unix_strea 0000000000 S /system/bin/dpmd
system 629 1 12904 2044 __skb_recv 0000000000 S /system/bin/cnss-daemon
gps 630 1 8064 1536 sigsuspend 0000000000 S /system/bin/loc_launcher
system 648 1 16864 2060 futex_wait 0000000000 S /system/bin/ATFWD-daemon
system 694 1 62876 13852 binder_thr 0000000000 S /system/vendor/bin/qseeproxydaemon
camera 695 1 86364 26712 poll_sched 0000000000 S /system/bin/mm-qcamera-daemon
system 696 1 65260 14388 binder_thr 0000000000 S /system/bin/fingerprintd
system 697 1 69120 14648 binder_thr 0000000000 S /system/bin/qfp-daemon
system 710 1 61776 13900 sigsuspend 0000000000 S /system/bin/qvop-daemon
system 711 1 15264 2224 futex_wait 0000000000 S /system/bin/time_daemon
system 712 1 28744 6580 binder_thr 0000000000 S /system/bin/audiod
gps 718 630 15268 2048 futex_wait 0000000000 S lowi-server
gps 719 630 23684 1788 futex_wait 0000000000 S xtwifi-inet-agent
gps 721 630 26364 3972 poll_sched 0000000000 S slim_daemon
system 723 1 13460 2224 futex_wait 0000000000 S /system/bin/tloc_daemon
system 724 1 12592 1996 binder_thr 0000000000 S /system/vendor/bin/mdtp_service
sensors 725 1 61100 3020 poll_sched 0000000000 S /system/bin/sensors.qcom
system 726 1 65740 14204 poll_sched 0000000000 S /system/bin/mm-pp-dpps
system 727 1 11748 1812 hrtimer_na 0000000000 S /system/bin/pm-proxy
shell 728 1 7888 772 poll_sched 0000000000 S /sbin/adbd
system 733 621 18376 2928 SyS_epoll_ 0000000000 S /system/bin/dpmd
system 772 536 32264 2192 sigsuspend 0000000000 S /system/bin/qseecomd
radio 783 1 13064 2268 poll_sched 0000000000 S /system/bin/qmuxd
system 827 1 9364 1412 poll_sched 0000000000 S /system/bin/ipacm-diag
root 830 2 0 0 irq_thread 0000000000 S irq/246-arm-smm
root 831 2 0 0 irq_thread 0000000000 S irq/247-arm-smm
system 833 1 14696 2428 poll_sched 0000000000 S /system/bin/imsdatadaemon
root 838 2 0 0 worker_thr 0000000000 S kworker/3:2H
root 846 2 0 0 rescuer_th 0000000000 S qmi_hndl0000000
net_admin 849 1 14772 2292 futex_wait 0000000000 S /system/bin/ipacm
radio 975 1 88260 13328 hrtimer_na 0000000000 S /system/bin/rild
radio 980 1 14752 1880 poll_sched 0000000000 S /system/vendor/bin/qti
radio 989 1 58864 4176 __skb_recv 0000000000 S /system/bin/netmgrd
root 995 1 10156 1412 futex_wait 0000000000 S /system/bin/port-bridge
root 1002 2 0 0 rescuer_th 0000000000 S DS
root 1035 2 0 0 rescuer_th 0000000000 S mpss_IPCRTR
root 1036 2 0 0 rescuer_th 0000000000 S LOOPBACK
root 1043 2 0 0 rescuer_th 0000000000 S SSM_RTR_MODEM_A
root 1050 2 0 0 rescuer_th 0000000000 S qmi_hndl0000000
root 1069 2 0 0 rescuer_th 0000000000 S qmi_hndl0000000
root 1071 2 0 0 irq_thread 0000000000 S irq/268-arm-smm
root 1072 2 0 0 irq_thread 0000000000 S irq/273-arm-smm
root 1073 2 0 0 irq_thread 0000000000 S irq/269-arm-smm
root 1075 2 0 0 irq_thread 0000000000 S irq/274-arm-smm
root 1132 2 0 0 rescuer_th 0000000000 S DATA1
root 1134 2 0 0 rescuer_th 0000000000 S DATA2
root 1135 2 0 0 rescuer_th 0000000000 S DATA3
root 1136 2 0 0 rescuer_th 0000000000 S DATA4
root 1137 2 0 0 rescuer_th 0000000000 S DATA11
system 1491 597 2289084 117012 SyS_epoll_ 0000000000 S system_server
root 1722 2 0 0 rescuer_th 0000000000 S ipawq48
root 1723 2 0 0 rescuer_th 0000000000 S iparepwq48
media_rw 2070 449 9336 2040 inotify_re 0000000000 S /system/bin/sdcard
u0_a8 2082 597 1573984 43576 SyS_epoll_ 0000000000 S android.process.media
u0_a21 2097 597 1678888 116372 SyS_epoll_ 0000000000 S com.android.systemui
root 2226 2 0 0 worker_thr 0000000000 S kworker/0:2H
u0_a47 2526 597 1583448 46660 SyS_epoll_ 0000000000 S com.android.inputmethod.latin
system 2562 597 1573704 36752 SyS_epoll_ 0000000000 S com.quicinc.cne.CNEService
nfc 2578 597 1571176 43360 SyS_epoll_ 0000000000 S com.android.nfc
ese 2587 597 1571528 35840 SyS_epoll_ 0000000000 S com.nxp.spi
radio 2598 597 1568004 32192 SyS_epoll_ 0000000000 S com.qualcomm.qti.rcsbootstraputil
system 2622 597 1574156 43684 SyS_epoll_ 0000000000 S com.dolby
system 2641 597 1569596 34892 SyS_epoll_ 0000000000 S com.quicinc.wbcserviceapp
system 2657 597 1569556 35816 SyS_epoll_ 0000000000 S com.qualcomm.qti.services.secureui:sui_service
radio 2678 597 1628444 59852 SyS_epoll_ 0000000000 S com.android.phone
system 2698 597 1568476 35364 SyS_epoll_ 0000000000 S com.letv.bsp.qccrashhandler
u0_a10 2730 597 1681472 88676 SyS_epoll_ 0000000000 S com.android.launcher
u0_a62 2770 597 1571412 35152 SyS_epoll_ 0000000000 S com.android.printspooler
u0_a3 2836 597 1577484 43168 SyS_epoll_ 0000000000 S android.process.acore
root 2921 2 0 0 worker_thr 0000000000 S kworker/2:2H
u0_a88 2949 598 1009324 33692 SyS_epoll_ 0000000000 S com.baidu.appsearch:bdservice_v1
u0_a74 2982 597 1567060 32976 SyS_epoll_ 0000000000 S com.android.smspush
radio 3008 597 1571620 34620 SyS_epoll_ 0000000000 S com.qualcomm.qcrilmsgtunnel
u0_a88 3063 598 1076060 67112 SyS_epoll_ 0000000000 S com.baidu.appsearch
u0_a34 3091 597 1575096 39588 SyS_epoll_ 0000000000 S com.android.deskclock
radio 3246 597 1568292 33660 SyS_epoll_ 0000000000 S org.codeaurora.ims
u0_a5 3304 597 1567412 34356 SyS_epoll_ 0000000000 S com.android.cellbroadcastreceiver
u0_a32 3318 597 1567164 32940 SyS_epoll_ 0000000000 S com.qti.cbwidget
root 3361 2 0 0 irq_thread 0000000000 S irq/21-408000.q
system 3364 597 1568260 36408 SyS_epoll_ 0000000000 S com.android.keychain
system 3373 597 1567244 33152 SyS_epoll_ 0000000000 S com.qualcomm.sta:STAProxyService
root 3380 1 12832 2792 futex_wait 0000000000 S /system/bin/iop
root 3416 1 10456 1344 futex_wait 0000000000 S /system/vendor/bin/perfd
u0_a7 3418 597 1574808 35744 SyS_epoll_ 0000000000 S com.android.dialer
root 3424 2 0 0 notify_use 0000000000 S wrkld_notify
system 3443 597 1569532 34792 SyS_epoll_ 0000000000 S com.qti.diagservices
system 3458 597 1574784 34068 SyS_epoll_ 0000000000 S com.qualcomm.qti.seemp.service:seemp_service
u0_a1 3473 597 1574888 38288 SyS_epoll_ 0000000000 S com.letv.bugpostbox
u0_a2 3489 597 1571516 38944 SyS_epoll_ 0000000000 S com.android.providers.calendar
u0_a11 3506 597 1568524 33944 SyS_epoll_ 0000000000 S com.android.managedprovisioning
u0_a12 3522 597 1579040 41368 SyS_epoll_ 0000000000 S com.android.mms
u0_a14 3546 597 1567232 33392 SyS_epoll_ 0000000000 S com.android.onetimeinitializer
root 3567 2 0 0 diag_socke 0000000000 S kworker/u8:10
system 3570 597 1575884 36628 SyS_epoll_ 0000000000 S com.qualcomm.qti.tetherservice
u0_a30 3615 597 1582940 38244 SyS_epoll_ 0000000000 S com.android.calendar
u0_a36 3641 597 1588856 43028 SyS_epoll_ 0000000000 S com.android.email
u0_a39 3655 597 1576252 36476 SyS_epoll_ 0000000000 S com.android.exchange
u0_a56 3678 597 1569964 35568 SyS_epoll_ 0000000000 S com.qualcomm.qct.dlt
root 3707 2 0 0 worker_thr 0000000000 S kworker/2:4
system 3709 597 1568444 34696 SyS_epoll_ 0000000000 S com.qualcomm.qti.GBAHttpAuthentication.auth
system 3723 597 1568160 35200 SyS_epoll_ 0000000000 S com.qualcomm.qualcommsettings
u0_a67 3728 597 1567716 34124 SyS_epoll_ 0000000000 S com.qualcomm.qti.telephonyservice
smartcard 3750 597 1568416 33232 SyS_epoll_ 0000000000 S org.simalliance.openmobileapi.service
root 3769 2 0 0 worker_thr 0000000000 S kworker/u8:12
root 3771 2 0 0 worker_thr 0000000000 S kworker/u8:13
smartcard 3773 597 1569768 36460 SyS_epoll_ 0000000000 S org.simalliance.openmobileapi.service:remote
u0_a88 3812 598 1010824 34912 SyS_epoll_ 0000000000 S com.baidu.appsearch:locationservice
system 3832 597 1567004 33292 SyS_epoll_ 0000000000 S com.qualcomm.qti.biometrics.voiceprint.service
system 3845 597 1566976 33468 SyS_epoll_ 0000000000 S com.letv.wihd
system 3858 597 1569620 34948 SyS_epoll_ 0000000000 S com.qualcomm.telephony
root 3865 2 0 0 worker_thr 0000000000 S kworker/0:4
u0_a78 3876 597 1566968 33856 SyS_epoll_ 0000000000 S com.quicinc.wipoweragent
u0_a79 3908 597 1567508 32992 SyS_epoll_ 0000000000 S com.qualcomm.embms
u0_a79 3921 597 1568836 37152 SyS_epoll_ 0000000000 S com.qualcomm.embms:remote
u0_a6 4036 597 1567632 35428 SyS_epoll_ 0000000000 S com.android.defcontainer
u0_a13 4064 597 1567184 34340 SyS_epoll_ 0000000000 S com.android.musicfx
u0_a42 4089 597 2101740 37416 SyS_epoll_ 0000000000 S com.android.gallery3d
u0_a61 4115 597 1566944 32972 SyS_epoll_ 0000000000 S com.svox.pico
root 4510 2 0 0 worker_thr 0000000000 S kworker/u8:4
root 4528 2 0 0 worker_thr 0000000000 S kworker/1:3
root 4568 2 0 0 worker_thr 0000000000 S kworker/u8:6
root 4569 2 0 0 worker_thr 0000000000 S kworker/3:4
root 4572 2 0 0 worker_thr 0000000000 S kworker/1:2
root 4591 2 0 0 worker_thr 0000000000 S kworker/0:2
root 4594 2 0 0 worker_thr 0000000000 S kworker/2:0
root 4596 2 0 0 worker_thr 0000000000 S kworker/2:1
root 4629 2 0 0 worker_thr 0000000000 S kworker/2:3
root 4844 2 0 0 worker_thr 0000000000 S kworker/1:4
root 4854 2 0 0 worker_thr 0000000000 S kworker/u8:7
root 4861 2 0 0 diag_socke 0000000000 S kworker/u8:11
root 4863 2 0 0 worker_thr 0000000000 S kworker/u8:15
root 4864 2 0 0 worker_thr 0000000000 S kworker/u8:16
root 4865 2 0 0 worker_thr 0000000000 S kworker/u8:17
system 4871 597 1567048 34164 SyS_epoll_ 0000000000 S com.qualcomm.timeservice
root 4890 2 0 0 worker_thr 0000000000 S kworker/0:3
root 4891 2 0 0 worker_thr 0000000000 S kworker/u8:18
root 4918 2 0 0 worker_thr 0000000000 S kworker/0:5
root 4919 2 0 0 worker_thr 0000000000 S kworker/0:6
root 4974 2 0 0 worker_thr 0000000000 S kworker/3:5
root 4975 2 0 0 worker_thr 0000000000 S kworker/3:6
root 4976 2 0 0 worker_thr 0000000000 S kworker/3:7
root 5008 2 0 0 diag_socke 0000000000 S kworker/u8:8
root 5015 2 0 0 worker_thr 0000000000 S kworker/2:5
root 5016 2 0 0 worker_thr 0000000000 S kworker/2:6
root 5017 2 0 0 worker_thr 0000000000 S kworker/2:7
root 5042 2 0 0 worker_thr 0000000000 S kworker/0:7
root 5079 2 0 0 worker_thr 0000000000 S kworker/0:8
shell 5366 728 6008 1256 0 7f78808e3c R ps
Command exited with code 0
C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s 9416189d shell id
uid=2000(shell) gid=2000(shell) groups=2000(shell),1004(input),1007(log),1011(adb),1015(sdcard_rw),1028(sdcard_r),3001(net_bt_admin),3002(net_bt),3003(inet),3006(net_bw_stats) context=u:r:shell:s0Command exited with code 0
C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s 9416189d install -r “C:\Users\zl121\AppData\Local\Temp\SysprogsAndroidTest-10484\4.9\bin\SysprogsAndroidAutoTest-debug.apk”
pkg: /data/local/tmp/SysprogsAndroidAutoTest-debug.apkSuccess
700 KB/s (400964 bytes in 0.559s)
C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s 9416189d shell run-as com.sysprogs.AndroidAutoTest /system/bin/sh -c pwd
/data/data/com.sysprogs.AndroidAutoTestCommand exited with code 0
C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s 9416189d shell getprop ro.product.cpu.abi
arm64-v8aCommand exited with code 0
C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s 9416189d shell getprop ro.build.version.sdk
23Command exited with code 0
C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s 9416189d shell ls /data/data/com.sysprogs.AndroidAutoTest/lib
/data/data/com.sysprogs.AndroidAutoTest/lib: No such file or directoryCommand exited with code 0
C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s 9416189d shell pm list packages -f
package:/system/priv-app/FMRadio/FMRadio.apk=com.android.fmradiopackage:/system/app/LetvFuseWire/LetvFuseWire.apk=com.letv.android.FuseWire
package:/system/app/RootPA/RootPA.apk=com.gd.mobicore.pa
package:/system/app/SampleExtAuthService/SampleExtAuthService.apk=com.qualcomm.qti.auth.sampleextauthservice
package:/system/priv-app/TelephonyProvider/TelephonyProvider.apk=com.android.providers.telephony
package:/system/app/UICC_eSE/UICC_eSE.apk=com.nxp.uiccese
package:/system/app/imsTests/imsTests.apk=com.qualcomm.ims.tests
package:/system/app/wipowerservice/wipowerservice.apk=org.codeaurora.bt_wipowersdk
package:/system/priv-app/CalendarProvider/CalendarProvider.apk=com.android.providers.calendar
package:/system/priv-app/MediaProvider/MediaProvider.apk=com.android.providers.media
package:/system/app/colorservice/colorservice.apk=com.qti.service.colorservice
package:/system/app/ModemTestMode/ModemTestMode.apk=com.qualcomm.qti.modemtestmode
package:/system/app/shutdownlistener/shutdownlistener.apk=com.qualcomm.shutdownlistner
package:/system/priv-app/WallpaperCropper/WallpaperCropper.apk=com.android.wallpapercropper
package:/system/priv-app/CNEService/CNEService.apk=com.quicinc.cne.CNEService
package:/system/app/com.qualcomm.qti.auth.fidocryptosample/com.qualcomm.qti.auth.fidocryptosample.apk=com.qualcomm.qti.auth.fidocryptosample
package:/system/app/Protips/Protips.apk=com.android.protips
package:/system/priv-app/Launcher2/Launcher2.apk=com.android.launcher
package:/system/app/SmartcardService/SmartcardService.apk=org.simalliance.openmobileapi.service
package:/system/vendor/app/DsUI/DsUI.apk=com.dolby.daxappUI
package:/system/app/QVTester/QVTester.apk=com.qualcomm.location.qvtester
package:/system/app/DocumentsUI/DocumentsUI.apk=com.android.documentsui
package:/system/app/Galaxy4/Galaxy4.apk=com.android.galaxy4
package:/system/priv-app/ExternalStorageProvider/ExternalStorageProvider.apk=com.android.externalstorage
package:/system/app/uimremoteclient/uimremoteclient.apk=com.qualcomm.uimremoteclient
package:/system/app/HTMLViewer/HTMLViewer.apk=com.android.htmlviewer
package:/system/app/FTMMode/FTMMode.apk=com.qualcomm.ftm
package:/system/app/StaProxyService/StaProxyService.apk=com.qualcomm.sta
package:/system/app/QuickSearchBox/QuickSearchBox.apk=com.android.quicksearchbox
package:/system/priv-app/MmsService/MmsService.apk=com.android.mms.service
package:/system/priv-app/DownloadProvider/DownloadProvider.apk=com.android.providers.downloads
package:/system/app/SampleAuthenticatorService/SampleAuthenticatorService.apk=com.qualcomm.qti.auth.sampleauthenticatorservice
package:/system/app/QCap/QCap.apk=com.qualcomm.qti.biometrics.fingerprint.qcap
package:/system/app/HiddTestApp/HiddTestApp.apk=org.codeaurora.bluetooth.hiddtestapp
package:/system/vendor/app/SecProtect/SecProtect.apk=com.qapp.secprotect
package:/system/app/QtiTelephonyService/QtiTelephonyService.apk=com.qualcomm.qti.telephonyservice
package:/system/app/BTTestApp/BTTestApp.apk=org.codeaurora.bluetooth.bttestapp
package:/system/app/FidoCryptoService/FidoCryptoService.apk=com.qualcomm.qti.auth.fidocryptoservice
package:/system/priv-app/SoundRecorder/SoundRecorder.apk=com.android.soundrecorder
package:/system/app/WiHDSampleApp/WiHDSampleApp.apk=com.letv.wihd.sample
package:/system/app/uimremoteserver/uimremoteserver.apk=com.qualcomm.uimremoteserver
package:/system/priv-app/DefaultContainerService/DefaultContainerService.apk=com.android.defcontainer
package:/system/app/DownloadProviderUi/DownloadProviderUi.apk=com.android.providers.downloads.ui
package:/system/app/PacProcessor/PacProcessor.apk=com.android.pacprocessor
package:/system/app/CertInstaller/CertInstaller.apk=com.android.certinstaller
package:/system/priv-app/CarrierConfig/CarrierConfig.apk=com.android.carrierconfig
package:/system/app/BluetoothExt/BluetoothExt.apk=org.codeaurora.bluetooth
package:/system/app/datastatusnotification/datastatusnotification.apk=com.qti.qualcomm.datastatusnotification
package:/system/framework/framework-res.apk=android
package:/system/priv-app/Contacts/Contacts.apk=com.android.contacts
package:/system/app/LetvCamera/LetvCamera.apk=com.android.camera2
package:/system/app/WfdService/WfdService.apk=com.qualcomm.wfd.service
package:/system/app/a4wpservice/a4wpservice.apk=org.codeaurora.bt_wipower
package:/system/app/VoicePrintDemo/VoicePrintDemo.apk=com.qualcomm.qti.biometrics.voiceprint.voiceprintdemo
package:/system/app/QtiGbaAuthService/QtiGbaAuthService.apk=com.qualcomm.qti.GBAHttpAuthentication.auth
package:/system/priv-app/Mms/Mms.apk=com.android.mms
package:/system/app/NfcNci/NfcNci.apk=com.android.nfc
package:/system/app/Stk/Stk.apk=com.android.stk
package:/system/priv-app/BackupRestoreConfirmation/BackupRestoreConfirmation.apk=com.android.backupconfirm
package:/system/app/EseSpi/EseSpi.apk=com.nxp.spi
package:/system/app/SenseID-M/SenseID-M.apk=com.qualcomm.qti.biometrics.fingerprint.senseidm
package:/system/app/CNESettings/CNESettings.apk=com.quicinc.cne.settings
package:/system/app/Provision/Provision.apk=com.android.provision
package:/system/app/BTLogKit/BTLogKit.apk=com.android.qlogging
package:/system/app/radioconfig/radioconfig.apk=com.qualcomm.qti.radioconfiginterface
package:/system/vendor/app/ims/ims.apk=org.codeaurora.ims
package:/system/priv-app/StatementService/StatementService.apk=com.android.statementservice
package:/system/app/HoloSpiralWallpaper/HoloSpiralWallpaper.apk=com.android.wallpaper.holospiral
package:/system/app/Calendar/Calendar.apk=com.android.calendar
package:/system/app/PhaseBeam/PhaseBeam.apk=com.android.phasebeam
package:/system/app/SecureExtAuthService/SecureExtAuthService.apk=com.qualcomm.qti.auth.secureextauthservice
package:/system/app/PrimaryCardController/PrimaryCardController.apk=com.qti.primarycardcontroller
package:/system/priv-app/qcrilmsgtunnel/qcrilmsgtunnel.apk=com.qualcomm.qcrilmsgtunnel
package:/system/priv-app/SettingsProvider/SettingsProvider.apk=com.android.providers.settings
package:/system/priv-app/SharedStorageBackup/SharedStorageBackup.apk=com.android.sharedstoragebackup
package:/system/app/PrintSpooler/PrintSpooler.apk=com.android.printspooler
package:/system/app/MdtpDemo/MdtpDemo.apk=com.qualcomm.qti.securemsm.mdtp.MdtpDemo
package:/system/app/BasicDreams/BasicDreams.apk=com.android.dreams.basic
package:/system/app/telresources/telresources.apk=com.android.frameworks.telresources
package:/data/app/com.baidu.appsearch-1/base.apk=com.baidu.appsearch
package:/system/app/webview/webview.apk=com.android.webview
package:/system/priv-app/InputDevices/InputDevices.apk=com.android.inputdevices
package:/system/app/QFingerprintService/QFingerprintService.apk=com.qualcomm.qti.biometrics.fingerprint.service
package:/system/app/SecureSampleAuthService/SecureSampleAuthService.apk=com.qualcomm.qti.auth.securesampleauthservice
package:/system/app/xdivert/xdivert.apk=com.qti.xdivert
package:/system/priv-app/MusicFX/MusicFX.apk=com.android.musicfx
package:/system/app/WfdClient/WfdClient.apk=com.qualcomm.wfd.client
package:/system/priv-app/BugPostbox/BugPostbox.apk=com.letv.bugpostbox
package:/system/priv-app/CellBroadcastReceiver/CellBroadcastReceiver.apk=com.android.cellbroadcastreceiver
package:/system/priv-app/OneTimeInitializer/OneTimeInitializer.apk=com.android.onetimeinitializer
package:/system/app/DeviceInfo/DeviceInfo.apk=com.android.qrd.engineeringmode
package:/system/priv-app/Telecom/Telecom.apk=com.android.server.telecom
package:/system/app/KeyChain/KeyChain.apk=com.android.keychain
package:/system/app/RCSBootstraputil/RCSBootstraputil.apk=com.qualcomm.qti.rcsbootstraputil
package:/system/priv-app/Dialer/Dialer.apk=com.android.dialer
package:/system/app/Gallery2/Gallery2.apk=com.android.gallery3d
package:/system/priv-app/CallLogBackup/CallLogBackup.apk=com.android.calllogbackup
package:/system/app/QFPCalibration/QFPCalibration.apk=com.qualcomm.qti.biometrics.fingerprint.qfpcalibration
package:/system/priv-app/PackageInstaller/PackageInstaller.apk=com.android.packageinstaller
package:/system/app/PicoTts/PicoTts.apk=com.svox.pico
package:/system/app/AntHalService/AntHalService.apk=com.dsi.ant.server
package:/system/priv-app/ProxyHandler/ProxyHandler.apk=com.android.proxyhandler
package:/system/app/LatinIME/LatinIME.apk=com.android.inputmethod.latin
package:/system/app/BTLogSave/BTLogSave.apk=org.codeaurora.bluetooth.btlogsave
package:/system/app/QtiBackupAgent/QtiBackupAgent.apk=com.qti.backupagent
package:/system/app/EmbmsTestApp/EmbmsTestApp.apk=com.qualcomm.embmstest
package:/system/priv-app/ManagedProvisioning/ManagedProvisioning.apk=com.android.managedprovisioning
package:/system/app/PhotoTable/PhotoTable.apk=com.android.dreams.phototable
package:/system/app/ODLT/ODLT.apk=com.qualcomm.qct.dlt
package:/system/app/CellBroadcastWidget/CellBroadcastWidget.apk=com.qti.cbwidget
package:/system/app/LetvDebugUtil/LetvDebugUtil.apk=com.letv.android.DebugUtils
package:/system/app/WiHDService/WiHDService.apk=com.letv.wihd
package:/system/app/NoiseField/NoiseField.apk=com.android.noisefield
package:/system/app/IRTest/IRTest.apk=com.irtest.letv
package:/system/app/WAPPushManager/WAPPushManager.apk=com.android.smspush
package:/system/app/LiveWallpapersPicker/LiveWallpapersPicker.apk=com.android.wallpaper.livepicker
package:/system/priv-app/Tag/Tag.apk=com.android.apps.tag
package:/system/app/SeempService/SeempService.apk=com.qualcomm.qti.seemp.service
package:/system/vendor/app/QDCMMobileApp/QDCMMobileApp.apk=com.qti.snapdragon.qdcm_mobile
package:/system/vendor/app/Ds/Ds.apk=com.dolby
package:/system/app/FactoryMode/FactoryMode.apk=com.letv.factorymode
package:/system/app/LetvStateInfo/LetvStateInfo.apk=com.letv.android.StateInfo
package:/system/app/SenseID/SenseID.apk=com.qualcomm.qti.biometrics.fingerprint.qfpmanager.debug
package:/system/app/OpenWnn/OpenWnn.apk=jp.co.omronsoft.openwnn
package:/system/priv-app/Settings/Settings.apk=com.android.settings
package:/system/priv-app/QtiMmsTestApp/QtiMmsTestApp.apk=com.qualcomm.qti.app
package:/system/vendor/app/imssettings/imssettings.apk=com.qualcomm.qti.ims
package:/system/app/com.quicinc.wbcserviceapp/com.quicinc.wbcserviceapp.apk=com.quicinc.wbcserviceapp
package:/system/app/ExactCalculator/ExactCalculator.apk=com.android.calculator2
package:/system/priv-app/com.qualcomm.location/com.qualcomm.location.apk=com.qualcomm.location
package:/system/app/com.quicinc.wipoweragent/com.quicinc.wipoweragent.apk=com.quicinc.wipoweragent
package:/system/priv-app/QtiTetherService/QtiTetherService.apk=com.qualcomm.qti.tetherservice
package:/system/app/FM2/FM2.apk=com.caf.fmradio
package:/system/app/MdtpService/MdtpService.apk=com.qualcomm.qti.securemsm.mdtp
package:/system/app/QTIDiagServices/QTIDiagServices.apk=com.qti.diagservices
package:/system/app/LiveWallpapers/LiveWallpapers.apk=com.android.wallpaper
package:/system/app/com.qualcomm.qti.services.secureui/com.qualcomm.qti.services.secureui.apk=com.qualcomm.qti.services.secureui
package:/system/priv-app/VpnDialogs/VpnDialogs.apk=com.android.vpndialogs
package:/system/app/UltrasoundSettings/UltrasoundSettings.apk=com.android.ultrasound
package:/system/app/Email/Email.apk=com.android.email
package:/system/app/Music/Music.apk=com.android.music
package:/system/priv-app/TeleService/TeleService.apk=com.android.phone
package:/system/priv-app/Shell/Shell.apk=com.android.shell
package:/system/app/SnapdragonCamera/SnapdragonCamera.apk=org.codeaurora.snapcam
package:/system/app/UserDictionaryProvider/UserDictionaryProvider.apk=com.android.providers.userdictionary
package:/system/priv-app/FusedLocation/FusedLocation.apk=com.android.location.fused
package:/system/app/DeskClock/DeskClock.apk=com.android.deskclock
package:/system/priv-app/SystemUI/SystemUI.apk=com.android.systemui
package:/system/app/Exchange2/Exchange2.apk=com.android.exchange
package:/data/app/com.sysprogs.AndroidAutoTest-2/base.apk=com.sysprogs.AndroidAutoTest
package:/system/priv-app/QcCrashHandler/QcCrashHandler.apk=com.letv.bsp.qccrashhandler
package:/system/app/BluetoothMidiService/BluetoothMidiService.apk=com.android.bluetoothmidiservice
package:/data/app/com.nd.assistance-1/base.apk=com.nd.assistance
package:/system/app/NetworkSetting/NetworkSetting.apk=com.qualcomm.qti.networksetting
package:/system/app/fastdormancy/fastdormancy.apk=com.qualcomm.fastdormancy
package:/system/app/MultiplePdpTest/MultiplePdpTest.apk=com.android.MultiplePdpTest
package:/system/app/FidoSuiService/FidoSuiService.apk=com.qualcomm.qti.auth.fidosuiservice
package:/system/app/QualcommSettings/QualcommSettings.apk=com.qualcomm.qualcommsettings
package:/system/app/VoicePrintService/VoicePrintService.apk=com.qualcomm.qti.biometrics.voiceprint.service
package:/system/app/Bluetooth/Bluetooth.apk=com.android.bluetooth
package:/system/app/TimeService/TimeService.apk=com.qualcomm.timeservice
package:/system/vendor/app/NativeAudioLatency/NativeAudioLatency.apk=com.android.nativeaudiolatency
package:/system/app/atfwd/atfwd.apk=com.qualcomm.atfwd
package:/system/app/embms/embms.apk=com.qualcomm.embms
package:/system/priv-app/ContactsProvider/ContactsProvider.apk=com.android.providers.contacts
package:/system/app/CaptivePortalLogin/CaptivePortalLogin.apk=com.android.captiveportallogin
package:/system/vendor/app/QSensorTest/QSensorTest.apk=com.qualcomm.qti.sensors.qsensortest
C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s 9416189d shell ls /data/app/com.sysprogs.AndroidAutoTest-2/lib/arm64-v8a
/data/app/com.sysprogs.AndroidAutoTest-2/lib/arm64-v8a: No such file or directoryCommand exited with code 0
gdbserverlibfirst.so
libsecond.so
C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s 9416189d shell am start -n com.sysprogs.AndroidAutoTest/.SysprogsAndroidAutoTest
Starting: Intent { cmp=com.sysprogs.AndroidAutoTest/.SysprogsAndroidAutoTest }Command exited with code 0
C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s 9416189d shell ls /data/app/com.sysprogs.AndroidAutoTest-2/lib/arm64/gdbserver
/data/app/com.sysprogs.AndroidAutoTest-2/lib/arm64/gdbserverCommand exited with code 0
logd 444 1 13144 3324 sigsuspend 0000000000 S /system/bin/logd
system 527 1 220380 23360 SyS_epoll_ 0000000000 S /system/bin/surfaceflinger
root 547 1 19728 2524 hrtimer_na 0000000000 S /system/bin/netd
radio 550 1 89812 13280 hrtimer_na 0000000000 S /system/bin/rild
root 597 1 2086020 66952 poll_sched 0000000000 S zygote64
shell 728 1 7888 688 0000000000 R /sbin/adbd
radio 975 1 88260 13324 hrtimer_na 0000000000 S /system/bin/rild
system 1491 597 2302136 121940 SyS_epoll_ 0000000000 S system_server
nfc 2578 597 1571156 43348 SyS_epoll_ 0000000000 S com.android.nfc
radio 2678 597 1629032 61020 SyS_epoll_ 0000000000 S com.android.phone
u0_a10 2730 597 1622120 88516 SyS_epoll_ 0000000000 S com.android.launcher
u0_a88 2949 598 1009324 33712 SyS_epoll_ 0000000000 S com.baidu.appsearch:bdservice_v1
u0_a88 3063 598 1075900 66932 SyS_epoll_ 0000000000 S com.baidu.appsearch
system 3364 597 1568260 36824 SyS_epoll_ 0000000000 S com.android.keychain
root 3380 1 15404 3040 futex_wait 0000000000 S /system/bin/iop
root 3416 1 11496 1344 futex_wait 0000000000 S /system/vendor/bin/perfd
system 3458 597 1575856 34312 SyS_epoll_ 0000000000 S com.qualcomm.qti.seemp.service:seemp_service
u0_a6 4036 597 1568704 35524 SyS_epoll_ 0000000000 S com.android.defcontainer
u0_a13 4064 597 1567184 34320 SyS_epoll_ 0000000000 S com.android.musicfx
u0_a42 4089 597 2101740 37360 SyS_epoll_ 0000000000 S com.android.gallery3d
u0_a89 5443 597 1577084 40120 SyS_epoll_ 0000000000 S com.sysprogs.AndroidAutoTest
shell 5460 728 6008 1260 0 7f970f4e3c R ps
C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s 9416189d forward tcp:5039 tcp:5039
Received launch context:
App PID: 5443
EABI: arm64-v8a
Workaround mode: Disabled
GDBServer: running
ADB log:
GDB startup log:
-gdb-set solib-search-path C:/Users/zl121/AppData/Local/VisualGDB/AndroidBinaryCache/9416189d;C:/Users/zl121/AppData/Local/Temp/SysprogsAndroidTest-10484/4.9/obj/local/arm64-v8a
^done
-target-select remote :5039
=thread-group-started,id=”i1″,pid=”5443″
=library-loaded,id=”/system/bin/linker64″,target-name=”/system/bin/linker64″,host-name=”C:\\Users\\zl121\\AppData\\Local\\VisualGDB\\AndroidBinaryCache\\9416189d\\linker64″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/vendor/lib64/libNimsWrap.so”,target-name=”/system/vendor/lib64/libNimsWrap.so”,host-name=”/system/vendor/lib64/libNimsWrap.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libcutils.so”,target-name=”/system/lib64/libcutils.so”,host-name=”/system/lib64/libcutils.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libutils.so”,target-name=”/system/lib64/libutils.so”,host-name=”/system/lib64/libutils.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/liblog.so”,target-name=”/system/lib64/liblog.so”,host-name=”/system/lib64/liblog.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libbinder.so”,target-name=”/system/lib64/libbinder.so”,host-name=”/system/lib64/libbinder.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libandroid_runtime.so”,target-name=”/system/lib64/libandroid_runtime.so”,host-name=”/system/lib64/libandroid_runtime.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libwilhelm.so”,target-name=”/system/lib64/libwilhelm.so”,host-name=”/system/lib64/libwilhelm.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libc++.so”,target-name=”/system/lib64/libc++.so”,host-name=”/system/lib64/libc++.so”,symbols-loaded=”0″,thread-group=”i1″
&”warning: `C:\\Users\\zl121\\AppData\\Local\\VisualGDB\\AndroidBinaryCache\\9416189d\\libc.so’: Shared library architecture arm is not compatible with target architecture aarch64.\n”
&”warning: .dynamic section for \”C:\\Users\\zl121\\AppData\\Local\\VisualGDB\\AndroidBinaryCache\\9416189d\\libc.so\” is not at the expected address (wrong library or version mismatch?)\n”
=library-loaded,id=”/system/lib64/libc.so”,target-name=”/system/lib64/libc.so”,host-name=”C:\\Users\\zl121\\AppData\\Local\\VisualGDB\\AndroidBinaryCache\\9416189d\\libc.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libm.so”,target-name=”/system/lib64/libm.so”,host-name=”/system/lib64/libm.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libbacktrace.so”,target-name=”/system/lib64/libbacktrace.so”,host-name=”/system/lib64/libbacktrace.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libmemtrack.so”,target-name=”/system/lib64/libmemtrack.so”,host-name=”/system/lib64/libmemtrack.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libandroidfw.so”,target-name=”/system/lib64/libandroidfw.so”,host-name=”/system/lib64/libandroidfw.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libexpat.so”,target-name=”/system/lib64/libexpat.so”,host-name=”/system/lib64/libexpat.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libnativehelper.so”,target-name=”/system/lib64/libnativehelper.so”,host-name=”/system/lib64/libnativehelper.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libnetutils.so”,target-name=”/system/lib64/libnetutils.so”,host-name=”/system/lib64/libnetutils.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libui.so”,target-name=”/system/lib64/libui.so”,host-name=”/system/lib64/libui.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libgui.so”,target-name=”/system/lib64/libgui.so”,host-name=”/system/lib64/libgui.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libinput.so”,target-name=”/system/lib64/libinput.so”,host-name=”/system/lib64/libinput.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libinputflinger.so”,target-name=”/system/lib64/libinputflinger.so”,host-name=”/system/lib64/libinputflinger.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libcamera_client.so”,target-name=”/system/lib64/libcamera_client.so”,host-name=”/system/lib64/libcamera_client.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libcamera_metadata.so”,target-name=”/system/lib64/libcamera_metadata.so”,host-name=”/system/lib64/libcamera_metadata.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libskia.so”,target-name=”/system/lib64/libskia.so”,host-name=”/system/lib64/libskia.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libsqlite.so”,target-name=”/system/lib64/libsqlite.so”,host-name=”/system/lib64/libsqlite.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libEGL.so”,target-name=”/system/lib64/libEGL.so”,host-name=”/system/lib64/libEGL.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libGLESv1_CM.so”,target-name=”/system/lib64/libGLESv1_CM.so”,host-name=”/system/lib64/libGLESv1_CM.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libGLESv2.so”,target-name=”/system/lib64/libGLESv2.so”,host-name=”/system/lib64/libGLESv2.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libETC1.so”,target-name=”/system/lib64/libETC1.so”,host-name=”/system/lib64/libETC1.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libhardware.so”,target-name=”/system/lib64/libhardware.so”,host-name=”/system/lib64/libhardware.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libhardware_legacy.so”,target-name=”/system/lib64/libhardware_legacy.so”,host-name=”/system/lib64/libhardware_legacy.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libselinux.so”,target-name=”/system/lib64/libselinux.so”,host-name=”/system/lib64/libselinux.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libsonivox.so”,target-name=”/system/lib64/libsonivox.so”,host-name=”/system/lib64/libsonivox.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libcrypto.so”,target-name=”/system/lib64/libcrypto.so”,host-name=”/system/lib64/libcrypto.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libssl.so”,target-name=”/system/lib64/libssl.so”,host-name=”/system/lib64/libssl.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libicuuc.so”,target-name=”/system/lib64/libicuuc.so”,host-name=”/system/lib64/libicuuc.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libicui18n.so”,target-name=”/system/lib64/libicui18n.so”,host-name=”/system/lib64/libicui18n.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libmedia.so”,target-name=”/system/lib64/libmedia.so”,host-name=”/system/lib64/libmedia.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libjpeg.so”,target-name=”/system/lib64/libjpeg.so”,host-name=”/system/lib64/libjpeg.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libusbhost.so”,target-name=”/system/lib64/libusbhost.so”,host-name=”/system/lib64/libusbhost.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libharfbuzz_ng.so”,target-name=”/system/lib64/libharfbuzz_ng.so”,host-name=”/system/lib64/libharfbuzz_ng.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libz.so”,target-name=”/system/lib64/libz.so”,host-name=”/system/lib64/libz.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libaudioutils.so”,target-name=”/system/lib64/libaudioutils.so”,host-name=”/system/lib64/libaudioutils.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libpdfium.so”,target-name=”/system/lib64/libpdfium.so”,host-name=”/system/lib64/libpdfium.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libimg_utils.so”,target-name=”/system/lib64/libimg_utils.so”,host-name=”/system/lib64/libimg_utils.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libnetd_client.so”,target-name=”/system/lib64/libnetd_client.so”,host-name=”/system/lib64/libnetd_client.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libradio.so”,target-name=”/system/lib64/libradio.so”,host-name=”/system/lib64/libradio.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libsoundtrigger.so”,target-name=”/system/lib64/libsoundtrigger.so”,host-name=”/system/lib64/libsoundtrigger.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libminikin.so”,target-name=”/system/lib64/libminikin.so”,host-name=”/system/lib64/libminikin.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libprocessgroup.so”,target-name=”/system/lib64/libprocessgroup.so”,host-name=”/system/lib64/libprocessgroup.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libnativebridge.so”,target-name=”/system/lib64/libnativebridge.so”,host-name=”/system/lib64/libnativebridge.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libradio_metadata.so”,target-name=”/system/lib64/libradio_metadata.so”,host-name=”/system/lib64/libradio_metadata.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libhwui.so”,target-name=”/system/lib64/libhwui.so”,host-name=”/system/lib64/libhwui.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libstagefright.so”,target-name=”/system/lib64/libstagefright.so”,host-name=”/system/lib64/libstagefright.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libstagefright_foundation.so”,target-name=”/system/lib64/libstagefright_foundation.so”,host-name=”/system/lib64/libstagefright_foundation.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libstagefright_http_support.so”,target-name=”/system/lib64/libstagefright_http_support.so”,host-name=”/system/lib64/libstagefright_http_support.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libeffects.so”,target-name=”/system/lib64/libeffects.so”,host-name=”/system/lib64/libeffects.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libbase.so”,target-name=”/system/lib64/libbase.so”,host-name=”/system/lib64/libbase.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libunwind.so”,target-name=”/system/lib64/libunwind.so”,host-name=”/system/lib64/libunwind.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libstdc++.so”,target-name=”/system/lib64/libstdc++.so”,host-name=”/system/lib64/libstdc++.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libsync.so”,target-name=”/system/lib64/libsync.so”,host-name=”/system/lib64/libsync.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libpng.so”,target-name=”/system/lib64/libpng.so”,host-name=”/system/lib64/libpng.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libft2.so”,target-name=”/system/lib64/libft2.so”,host-name=”/system/lib64/libft2.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/vendor/lib64/libqc-opt.so”,target-name=”/system/vendor/lib64/libqc-opt.so”,host-name=”/system/vendor/lib64/libqc-opt.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libGLES_trace.so”,target-name=”/system/lib64/libGLES_trace.so”,host-name=”/system/lib64/libGLES_trace.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libwpa_client.so”,target-name=”/system/lib64/libwpa_client.so”,host-name=”/system/lib64/libwpa_client.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libpcre.so”,target-name=”/system/lib64/libpcre.so”,host-name=”/system/lib64/libpcre.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libnbaio.so”,target-name=”/system/lib64/libnbaio.so”,host-name=”/system/lib64/libnbaio.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libspeexresampler.so”,target-name=”/system/lib64/libspeexresampler.so”,host-name=”/system/lib64/libspeexresampler.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libRS.so”,target-name=”/system/lib64/libRS.so”,host-name=”/system/lib64/libRS.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libRScpp.so”,target-name=”/system/lib64/libRScpp.so”,host-name=”/system/lib64/libRScpp.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libdrmframework.so”,target-name=”/system/lib64/libdrmframework.so”,host-name=”/system/lib64/libdrmframework.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libmediautils.so”,target-name=”/system/lib64/libmediautils.so”,host-name=”/system/lib64/libmediautils.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libopus.so”,target-name=”/system/lib64/libopus.so”,host-name=”/system/lib64/libopus.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libstagefright_omx.so”,target-name=”/system/lib64/libstagefright_omx.so”,host-name=”/system/lib64/libstagefright_omx.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libstagefright_yuv.so”,target-name=”/system/lib64/libstagefright_yuv.so”,host-name=”/system/lib64/libstagefright_yuv.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libvorbisidec.so”,target-name=”/system/lib64/libvorbisidec.so”,host-name=”/system/lib64/libvorbisidec.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libpowermanager.so”,target-name=”/system/lib64/libpowermanager.so”,host-name=”/system/lib64/libpowermanager.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libstagefright_enc_common.so”,target-name=”/system/lib64/libstagefright_enc_common.so”,host-name=”/system/lib64/libstagefright_enc_common.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libstagefright_avc_common.so”,target-name=”/system/lib64/libstagefright_avc_common.so”,host-name=”/system/lib64/libstagefright_avc_common.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libprotobuf-cpp-lite.so”,target-name=”/system/lib64/libprotobuf-cpp-lite.so”,host-name=”/system/lib64/libprotobuf-cpp-lite.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libcommon_time_client.so”,target-name=”/system/lib64/libcommon_time_client.so”,host-name=”/system/lib64/libcommon_time_client.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libbcc.so”,target-name=”/system/lib64/libbcc.so”,host-name=”/system/lib64/libbcc.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libbcinfo.so”,target-name=”/system/lib64/libbcinfo.so”,host-name=”/system/lib64/libbcinfo.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libLLVM.so”,target-name=”/system/lib64/libLLVM.so”,host-name=”/system/lib64/libLLVM.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”[vdso]”,target-name=”[vdso]”,host-name=”[vdso]”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/vendor/lib64/libcneconn.so”,target-name=”/system/vendor/lib64/libcneconn.so”,host-name=”/system/vendor/lib64/libcneconn.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/vendor/lib64/libvendorconn.so”,target-name=”/system/vendor/lib64/libvendorconn.so”,host-name=”/system/vendor/lib64/libvendorconn.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/vendor/lib64/libavenhancements.so”,target-name=”/system/vendor/lib64/libavenhancements.so”,host-name=”/system/vendor/lib64/libavenhancements.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libstagefright_httplive.so”,target-name=”/system/lib64/libstagefright_httplive.so”,host-name=”/system/lib64/libstagefright_httplive.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libmediaplayerservice.so”,target-name=”/system/lib64/libmediaplayerservice.so”,host-name=”/system/lib64/libmediaplayerservice.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libstagefright_wfd.so”,target-name=”/system/lib64/libstagefright_wfd.so”,host-name=”/system/lib64/libstagefright_wfd.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libcurl.so”,target-name=”/system/lib64/libcurl.so”,host-name=”/system/lib64/libcurl.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/vendor/lib64/libExtendedExtractor.so”,target-name=”/system/vendor/lib64/libExtendedExtractor.so”,host-name=”/system/vendor/lib64/libExtendedExtractor.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libdashplayer.so”,target-name=”/system/lib64/libdashplayer.so”,host-name=”/system/lib64/libdashplayer.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libart.so”,target-name=”/system/lib64/libart.so”,host-name=”/system/lib64/libart.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libsigchain.so”,target-name=”/system/lib64/libsigchain.so”,host-name=”/system/lib64/libsigchain.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libjavacore.so”,target-name=”/system/lib64/libjavacore.so”,host-name=”/system/lib64/libjavacore.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/hw/memtrack.msm8996.so”,target-name=”/system/lib64/hw/memtrack.msm8996.so”,host-name=”/system/lib64/hw/memtrack.msm8996.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/vendor/lib64/libqti-at.so”,target-name=”/system/vendor/lib64/libqti-at.so”,host-name=”/system/vendor/lib64/libqti-at.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/vendor/lib64/libqti-gt.so”,target-name=”/system/vendor/lib64/libqti-gt.so”,host-name=”/system/vendor/lib64/libqti-gt.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libxml2.so”,target-name=”/system/lib64/libxml2.so”,host-name=”/system/lib64/libxml2.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/vendor/lib64/libqti-perfd-client.so”,target-name=”/system/vendor/lib64/libqti-perfd-client.so”,host-name=”/system/vendor/lib64/libqti-perfd-client.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libmedia_jni.so”,target-name=”/system/lib64/libmedia_jni.so”,host-name=”/system/lib64/libmedia_jni.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libmtp.so”,target-name=”/system/lib64/libmtp.so”,host-name=”/system/lib64/libmtp.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libjhead.so”,target-name=”/system/lib64/libjhead.so”,host-name=”/system/lib64/libjhead.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libexif.so”,target-name=”/system/lib64/libexif.so”,host-name=”/system/lib64/libexif.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libstagefright_amrnb_common.so”,target-name=”/system/lib64/libstagefright_amrnb_common.so”,host-name=”/system/lib64/libstagefright_amrnb_common.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libextmedia_jni.so”,target-name=”/system/lib64/libextmedia_jni.so”,host-name=”/system/lib64/libextmedia_jni.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/data/dalvik-cache/arm64/system@framework@tcmclient.jar@classes.dex”,target-name=”/data/dalvik-cache/arm64/system@framework@tcmclient.jar@classes.dex”,host-name=”/data/dalvik-cache/arm64/system@framework@tcmclient.jar@classes.dex”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libjavacrypto.so”,target-name=”/system/lib64/libjavacrypto.so”,host-name=”/system/lib64/libjavacrypto.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libkeystore-engine.so”,target-name=”/system/lib64/libkeystore-engine.so”,host-name=”/system/lib64/libkeystore-engine.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libkeystore_binder.so”,target-name=”/system/lib64/libkeystore_binder.so”,host-name=”/system/lib64/libkeystore_binder.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libsoftkeymasterdevice.so”,target-name=”/system/lib64/libsoftkeymasterdevice.so”,host-name=”/system/lib64/libsoftkeymasterdevice.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libkeymaster_messages.so”,target-name=”/system/lib64/libkeymaster_messages.so”,host-name=”/system/lib64/libkeymaster_messages.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libkeymaster1.so”,target-name=”/system/lib64/libkeymaster1.so”,host-name=”/system/lib64/libkeymaster1.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/vendor/lib64/egl/libEGL_adreno.so”,target-name=”/system/vendor/lib64/egl/libEGL_adreno.so”,host-name=”/system/vendor/lib64/egl/libEGL_adreno.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/vendor/lib64/libadreno_utils.so”,target-name=”/system/vendor/lib64/libadreno_utils.so”,host-name=”/system/vendor/lib64/libadreno_utils.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/vendor/lib64/libgsl.so”,target-name=”/system/vendor/lib64/libgsl.so”,host-name=”/system/vendor/lib64/libgsl.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/vendor/lib64/egl/libGLESv2_adreno.so”,target-name=”/system/vendor/lib64/egl/libGLESv2_adreno.so”,host-name=”/system/vendor/lib64/egl/libGLESv2_adreno.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/vendor/lib64/libllvm-glnext.so”,target-name=”/system/vendor/lib64/libllvm-glnext.so”,host-name=”/system/vendor/lib64/libllvm-glnext.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/vendor/lib64/egl/libGLESv1_CM_adreno.so”,target-name=”/system/vendor/lib64/egl/libGLESv1_CM_adreno.so”,host-name=”/system/vendor/lib64/egl/libGLESv1_CM_adreno.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/vendor/lib64/egl/eglSubDriverAndroid.so”,target-name=”/system/vendor/lib64/egl/eglSubDriverAndroid.so”,host-name=”/system/vendor/lib64/egl/eglSubDriverAndroid.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/hw/gralloc.msm8996.so”,target-name=”/system/lib64/hw/gralloc.msm8996.so”,host-name=”/system/lib64/hw/gralloc.msm8996.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libmemalloc.so”,target-name=”/system/lib64/libmemalloc.so”,host-name=”/system/lib64/libmemalloc.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libqdMetaData.so”,target-name=”/system/lib64/libqdMetaData.so”,host-name=”/system/lib64/libqdMetaData.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libqdutils.so”,target-name=”/system/lib64/libqdutils.so”,host-name=”/system/lib64/libqdutils.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libqservice.so”,target-name=”/system/lib64/libqservice.so”,host-name=”/system/lib64/libqservice.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libandroid.so”,target-name=”/system/lib64/libandroid.so”,host-name=”/system/lib64/libandroid.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libcompiler_rt.so”,target-name=”/system/lib64/libcompiler_rt.so”,host-name=”/system/lib64/libcompiler_rt.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libjnigraphics.so”,target-name=”/system/lib64/libjnigraphics.so”,host-name=”/system/lib64/libjnigraphics.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libwebviewchromium_loader.so”,target-name=”/system/lib64/libwebviewchromium_loader.so”,host-name=”/system/lib64/libwebviewchromium_loader.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/data/app/com.sysprogs.AndroidAutoTest-2/oat/arm64/base.odex”,target-name=”/data/app/com.sysprogs.AndroidAutoTest-2/oat/arm64/base.odex”,host-name=”/data/app/com.sysprogs.AndroidAutoTest-2/oat/arm64/base.odex”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/data/app/com.sysprogs.AndroidAutoTest-2/lib/arm64/libfirst.so”,target-name=”/data/app/com.sysprogs.AndroidAutoTest-2/lib/arm64/libfirst.so”,host-name=”C:\\Users\\zl121\\AppData\\Local\\Temp\\SysprogsAndroidTest-10484\\4.9\\obj\\local\\arm64-v8a\\libfirst.so”,symbols-loaded=”0″,thread-group=”i1″
&”warning: Could not load shared library symbols for 131 libraries, e.g. /system/vendor/lib64/libNimsWrap.so.\nUse the \”info sharedlibrary\” command to see the complete listing.\nDo you need \”set solib-search-path\” or \”set sysroot\”?”
&”\n”
~”/s/ndk-toolchain/src/build/../gdb/gdb-7.7/gdb/gdbarch.c:3991: internal-error: gdbarch_record_special_symbol_p: Assertion `gdbarch != NULL’ failed.\nA problem internal to GDB has been detected,\nfurther debugging may prove unreliable.\nQuit this debugging session? ”
~”(y or n) [answered Y; input not from terminal]\n”
~”/s/ndk-toolchain/src/build/../gdb/gdb-7.7/gdb/gdbarch.c:3991: internal-error: gdbarch_record_special_symbol_p: Assertion `gdbarch != NULL’ failed.\nA problem internal to GDB has been detected,\nfurther debugging may prove unreliable.\nCreate a core file of GDB? ”
This application has requested the Runtime to terminate it in an unusual way.
Please contact the application’s support team for more information.
Launcher log:
GDBServer output:
Attached; pid = 5443gdbserver: Unable to determine the number of hardware watchpoints available.
gdbserver: Unable to determine the number of hardware breakpoints available.
Listening on port 5039
Remote debugging from host 127.0.0.1
readchar: Got EOF
Remote side has terminated connection. GDBserver will reopen the connection.
Exception: GDB has exited unexpectedly. If you are using a 64-bit version of NDK, consider trying a 32-bit one.
——— Testing workaround mode: EnabledWithEvenAddress, attempt 1 ———
Preparing for launch…
C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s 9416189d shell ps
USER PID PPID VSIZE RSS WCHAN PC NAMEroot 1 0 5036 1720 SyS_epoll_ 0000000000 S /init
root 2 0 0 0 kthreadd 0000000000 S kthreadd
root 3 2 0 0 smpboot_th 0000000000 S ksoftirqd/0
root 4 2 0 0 worker_thr 0000000000 S kworker/0:0
root 6 2 0 0 worker_thr 0000000000 S kworker/u8:0
root 7 2 0 0 rcu_gp_kth 0000000000 S rcu_preempt
root 8 2 0 0 rcu_gp_kth 0000000000 S rcu_sched
root 9 2 0 0 rcu_gp_kth 0000000000 S rcu_bh
root 10 2 0 0 smpboot_th 0000000000 S migration/0
root 11 2 0 0 smpboot_th 0000000000 S watchdog/0
root 12 2 0 0 smpboot_th 0000000000 S watchdog/1
root 13 2 0 0 smpboot_th 0000000000 S migration/1
root 14 2 0 0 smpboot_th 0000000000 S ksoftirqd/1
root 15 2 0 0 worker_thr 0000000000 S kworker/1:0
root 16 2 0 0 worker_thr 0000000000 S kworker/1:0H
root 17 2 0 0 smpboot_th 0000000000 S watchdog/2
root 18 2 0 0 smpboot_th 0000000000 S migration/2
root 19 2 0 0 smpboot_th 0000000000 S ksoftirqd/2
root 21 2 0 0 worker_thr 0000000000 S kworker/2:0H
root 22 2 0 0 smpboot_th 0000000000 S watchdog/3
root 23 2 0 0 smpboot_th 0000000000 S migration/3
root 24 2 0 0 smpboot_th 0000000000 S ksoftirqd/3
root 25 2 0 0 worker_thr 0000000000 S kworker/3:0
root 27 2 0 0 rescuer_th 0000000000 S khelper
root 28 2 0 0 rescuer_th 0000000000 S netns
root 29 2 0 0 rescuer_th 0000000000 S perf
root 30 2 0 0 rescuer_th 0000000000 S smd_channel_clo
root 31 2 0 0 rescuer_th 0000000000 S glink_tx
root 32 2 0 0 rescuer_th 0000000000 S glink_tx
root 33 2 0 0 rescuer_th 0000000000 S glink_tx
root 34 2 0 0 rescuer_th 0000000000 S glink_tx
root 35 2 0 0 rescuer_th 0000000000 S glink_tx
root 36 2 0 0 watchdog_k 0000000000 S msm_watchdog
root 38 2 0 0 rescuer_th 0000000000 S rpm_requests
root 39 2 0 0 kthread_wo 0000000000 S smem_native_mps
root 40 2 0 0 rescuer_th 0000000000 S glink_tx
root 41 2 0 0 kthread_wo 0000000000 S smem_native_lpa
root 42 2 0 0 rescuer_th 0000000000 S glink_tx
root 43 2 0 0 kthread_wo 0000000000 S smem_native_dsp
root 44 2 0 0 rescuer_th 0000000000 S glink_tx
root 45 2 0 0 kthread_wo 0000000000 S smem_native_rpm
root 46 2 0 0 rescuer_th 0000000000 S glink_tx
root 47 2 0 0 worker_thr 0000000000 S kworker/0:1
root 48 2 0 0 rescuer_th 0000000000 S deferwq
root 49 2 0 0 msm_mpm_wo 0000000000 D kworker/u8:1
root 50 2 0 0 irq_thread 0000000000 S irq/219-cpr3
root 51 2 0 0 irq_thread 0000000000 S irq/220-cpr3_ce
root 52 2 0 0 irq_thread 0000000000 S irq/221-cpr3
root 53 2 0 0 rescuer_th 0000000000 S mpm
root 54 2 0 0 diag_socke 0000000000 S kworker/u8:2
root 55 2 0 0 worker_thr 0000000000 S kworker/u8:3
root 72 2 0 0 worker_thr 0000000000 S kworker/1:1
root 73 2 0 0 rescuer_th 0000000000 S writeback
root 74 2 0 0 rescuer_th 0000000000 S crypto
root 75 2 0 0 rescuer_th 0000000000 S bioset
root 76 2 0 0 rescuer_th 0000000000 S kblockd
root 77 2 0 0 ion_heap_d 0000000000 S system
root 78 2 0 0 ion_heap_d 0000000000 S secure_heap
root 79 2 0 0 rescuer_th 0000000000 S ipa_power_mgmt
root 80 2 0 0 rescuer_th 0000000000 S sps_ipa_power_m
root 81 2 0 0 worker_thr 0000000000 S kworker/u9:0
root 82 2 0 0 rescuer_th 0000000000 S ipawq14
root 83 2 0 0 rescuer_th 0000000000 S iparepwq14
root 84 2 0 0 worker_thr 0000000000 S kworker/u9:1
root 85 2 0 0 rescuer_th 0000000000 S ipawq47
root 86 2 0 0 rescuer_th 0000000000 S iparepwq47
root 87 2 0 0 rescuer_th 0000000000 S ipawq13
root 88 2 0 0 rescuer_th 0000000000 S iparepwq13
root 89 2 0 0 rescuer_th 0000000000 S ipa_rm_wq
root 90 2 0 0 rescuer_th 0000000000 S ipa_interrupt_w
root 91 2 0 0 irq_thread 0000000000 S irq/240-arm-smm
root 92 2 0 0 irq_thread 0000000000 S irq/245-arm-smm
root 93 2 0 0 irq_thread 0000000000 S irq/250-arm-smm
root 94 2 0 0 irq_thread 0000000000 S irq/255-arm-smm
root 95 2 0 0 irq_thread 0000000000 S irq/267-arm-smm
root 96 2 0 0 irq_thread 0000000000 S irq/272-arm-smm
root 97 2 0 0 irq_thread 0000000000 S irq/277-arm-smm
root 98 2 0 0 irq_thread 0000000000 S irq/282-arm-smm
root 99 2 0 0 irq_thread 0000000000 S irq/299-arm-smm
root 100 2 0 0 irq_thread 0000000000 S irq/306-arm-smm
root 101 2 0 0 irq_thread 0000000000 S irq/315-arm-smm
root 102 2 0 0 rescuer_th 0000000000 S devfreq_wq
root 103 2 0 0 rescuer_th 0000000000 S governor_msm_ad
root 104 2 0 0 worker_thr 0000000000 S kworker/3:1
root 105 2 0 0 rescuer_th 0000000000 S cfg80211
root 106 2 0 0 irq_thread 0000000000 S irq/143-bcl_vba
root 107 2 0 0 irq_thread 0000000000 S irq/142-bcl_iba
root 130 2 0 0 rescuer_th 0000000000 S power_off_alarm
root 131 2 0 0 kswapd 0000000000 S kswapd0
root 132 2 0 0 fsnotify_m 0000000000 S fsnotify_mark
root 133 2 0 0 ecryptfs_t 0000000000 S ecryptfs-kthrea
root 154 2 0 0 rescuer_th 0000000000 S ad_calc_wq
root 155 2 0 0 rescuer_th 0000000000 S rot_commit_work
root 156 2 0 0 rescuer_th 0000000000 S rot_workq_0
root 157 2 0 0 rescuer_th 0000000000 S rot_workq_1
root 158 2 0 0 dsi_event_ 0000000000 D mdss_dsi_event
root 159 2 0 0 rescuer_th 0000000000 S mdss_dsi_dba
root 160 2 0 0 rescuer_th 0000000000 S mdss_dsi_dba
root 161 2 0 0 rescuer_th 0000000000 S hdmi_tx_workq
root 162 2 0 0 rescuer_th 0000000000 S diag_cmd_wq
root 163 2 0 0 rescuer_th 0000000000 S remote_fw_updat
root 164 2 0 0 rescuer_th 0000000000 S wihd_sm_wq
root 165 2 0 0 rescuer_th 0000000000 S mhl_sm_wq
root 166 2 0 0 rescuer_th 0000000000 S diag_sm_wq
root 167 2 0 0 kthread_wo 0000000000 S hdcp_tz_lib
root 168 2 0 0 kthread_wo 0000000000 S hdmi_hdcp2p2
root 169 2 0 0 rescuer_th 0000000000 S glink_ssr_wq
root 170 2 0 0 rescuer_th 0000000000 S glink_lbsrv
root 171 2 0 0 rescuer_th 0000000000 S glink_xprt_wq
root 172 2 0 0 rescuer_th 0000000000 S IPCRTR_mpss_smd
root 173 2 0 0 rescuer_th 0000000000 S IPCRTR_lpass_sm
root 174 2 0 0 rescuer_th 0000000000 S IPCRTR
root 175 2 0 0 rescuer_th 0000000000 S IPCRTR_dsps_smd
root 176 2 0 0 rescuer_th 0000000000 S IPCRTR
root 177 2 0 0 rescuer_th 0000000000 S IPCRTR
root 178 2 0 0 rescuer_th 0000000000 S apr_driver
root 179 2 0 0 rescuer_th 0000000000 S glink_pkt_wq
root 180 2 0 0 rescuer_th 0000000000 S ssr_monitor_wai
root 181 2 0 0 rescuer_th 0000000000 S pacman_qmi_noti
root 182 2 0 0 rescuer_th 0000000000 S pacman_qmi_rx_w
root 183 2 0 0 rescuer_th 0000000000 S qmi_svc_event_w
root 184 2 0 0 rescuer_th 0000000000 S msm_ipc_router
root 185 2 0 0 rescuer_th 0000000000 S k_hsuart
root 186 2 0 0 kthread_wo 0000000000 S msm_serial_hs_0
root 187 2 0 0 kthread_wo 0000000000 S msm_serial_hs_0
root 188 2 0 0 add_hwgene 0000000000 S hwrng
root 190 2 0 0 rescuer_th 0000000000 S diag_real_time_
root 191 2 0 0 rescuer_th 0000000000 S diag_wq
root 192 2 0 0 rescuer_th 0000000000 S DIAG_USB_diag
root 193 2 0 0 rescuer_th 0000000000 S diag_cntl_wq
root 194 2 0 0 rescuer_th 0000000000 S diag_dci_wq
root 195 2 0 0 rescuer_th 0000000000 S DIAG_SMD_MODEM_
root 196 2 0 0 rescuer_th 0000000000 S DIAG_SMD_MODEM_
root 197 2 0 0 rescuer_th 0000000000 S DIAG_SMD_MODEM_
root 198 2 0 0 rescuer_th 0000000000 S DIAG_SMD_MODEM_
root 199 2 0 0 rescuer_th 0000000000 S DIAG_SMD_MODEM_
root 200 2 0 0 rescuer_th 0000000000 S DIAG_SMD_LPASS_
root 201 2 0 0 rescuer_th 0000000000 S DIAG_SMD_LPASS_
root 202 2 0 0 rescuer_th 0000000000 S DIAG_SMD_LPASS_
root 203 2 0 0 rescuer_th 0000000000 S DIAG_SMD_LPASS_
root 204 2 0 0 rescuer_th 0000000000 S DIAG_SMD_LPASS_
root 205 2 0 0 rescuer_th 0000000000 S DIAG_SMD_WCNSS_
root 206 2 0 0 rescuer_th 0000000000 S DIAG_SMD_WCNSS_
root 207 2 0 0 rescuer_th 0000000000 S DIAG_SMD_WCNSS_
root 208 2 0 0 rescuer_th 0000000000 S DIAG_SMD_WCNSS_
root 209 2 0 0 rescuer_th 0000000000 S DIAG_SMD_WCNSS_
root 210 2 0 0 rescuer_th 0000000000 S DIAG_SMD_SENSOR
root 211 2 0 0 rescuer_th 0000000000 S DIAG_SMD_SENSOR
root 212 2 0 0 rescuer_th 0000000000 S DIAG_SMD_SENSOR
root 213 2 0 0 rescuer_th 0000000000 S DIAG_SMD_SENSOR
root 214 2 0 0 rescuer_th 0000000000 S DIAG_SMD_SENSOR
root 215 2 0 0 rescuer_th 0000000000 S DIAG_SOCKMODEM_
root 216 2 0 0 rescuer_th 0000000000 S DIAG_SOCKMODEM_
root 217 2 0 0 rescuer_th 0000000000 S DIAG_SOCKMODEM_
root 218 2 0 0 rescuer_th 0000000000 S DIAG_SOCKMODEM_
root 219 2 0 0 rescuer_th 0000000000 S DIAG_SOCKMODEM_
root 220 2 0 0 rescuer_th 0000000000 S DIAG_SOCKLPASS_
root 221 2 0 0 rescuer_th 0000000000 S DIAG_SOCKLPASS_
root 222 2 0 0 rescuer_th 0000000000 S DIAG_SOCKLPASS_
root 223 2 0 0 rescuer_th 0000000000 S DIAG_SOCKLPASS_
root 224 2 0 0 rescuer_th 0000000000 S DIAG_SOCKLPASS_
root 225 2 0 0 rescuer_th 0000000000 S DIAG_SOCKWCNSS_
root 226 2 0 0 rescuer_th 0000000000 S DIAG_SOCKWCNSS_
root 227 2 0 0 rescuer_th 0000000000 S DIAG_SOCKWCNSS_
root 228 2 0 0 rescuer_th 0000000000 S DIAG_SOCKWCNSS_
root 229 2 0 0 rescuer_th 0000000000 S DIAG_SOCKWCNSS_
root 230 2 0 0 rescuer_th 0000000000 S DIAG_SOCKSENSOR
root 231 2 0 0 rescuer_th 0000000000 S DIAG_SOCKSENSOR
root 232 2 0 0 rescuer_th 0000000000 S DIAG_SOCKSENSOR
root 233 2 0 0 rescuer_th 0000000000 S DIAG_SOCKSENSOR
root 234 2 0 0 rescuer_th 0000000000 S DIAG_SOCKSENSOR
root 235 2 0 0 rescuer_th 0000000000 S DIAG_CNTL_SOCKE
root 236 2 0 0 rescuer_th 0000000000 S kgsl-workqueue
root 237 2 0 0 rescuer_th 0000000000 S kgsl-mementry
root 238 2 0 0 rescuer_th 0000000000 S qcrypto_seq_res
root 259 2 0 0 scsi_error 0000000000 S scsi_eh_0
root 260 2 0 0 rescuer_th 0000000000 S scsi_tmf_0
root 261 2 0 0 rescuer_th 0000000000 S ufs_pm_qos_0
root 262 2 0 0 rescuer_th 0000000000 S ufs_clkscaling_
root 263 2 0 0 kthread_wo 0000000000 S spi0
root 266 2 0 0 kthread_wo 0000000000 S spi11
root 270 2 0 0 diag_socke 0000000000 S kworker/u8:5
root 274 2 0 0 diag_socke 0000000000 S kworker/u8:9
root 275 2 0 0 irq_thread 0000000000 S irq/462-sii6400
root 276 2 0 0 rescuer_th 0000000000 S bond0
root 277 2 0 0 rescuer_th 0000000000 S usbnet
root 278 2 0 0 rescuer_th 0000000000 S sharedmem_qmi_w
root 279 2 0 0 rescuer_th 0000000000 S qmi_hndl0000000
root 280 2 0 0 irq_thread 0000000000 S irq/127-hs_phy_
root 281 2 0 0 irq_thread 0000000000 S irq/128-ss_phy_
root 282 2 0 0 irq_thread 0000000000 S irq/129-msm_dwc
root 283 2 0 0 rescuer_th 0000000000 S k_gserial
root 284 2 0 0 rescuer_th 0000000000 S k_ipa_usb
root 285 2 0 0 rescuer_th 0000000000 S uether
root 286 2 0 0 rescuer_th 0000000000 S k_gbridge
root 287 2 0 0 worker_thr 0000000000 S kworker/3:2
root 288 2 0 0 irq_thread 0000000000 S irq/465-atmel_t
root 289 2 0 0 irq_thread 0000000000 S irq/464-atmel_m
root 290 2 0 0 rescuer_th 0000000000 S msm_vidc_worker
root 291 2 0 0 rescuer_th 0000000000 S pm_workerq_venu
root 292 2 0 0 irq_thread 0000000000 S irq/256-arm-smm
root 293 2 0 0 irq_thread 0000000000 S irq/257-arm-smm
root 294 2 0 0 irq_thread 0000000000 S irq/258-arm-smm
root 295 2 0 0 irq_thread 0000000000 S irq/259-arm-smm
root 296 2 0 0 rescuer_th 0000000000 S msm_cci_wq
root 297 2 0 0 rescuer_th 0000000000 S msm_cci_wq
root 299 2 0 0 worker_thr 0000000000 S kworker/2:2
root 302 2 0 0 worker_thr 0000000000 S kworker/0:1H
root 305 2 0 0 rescuer_th 0000000000 S msm_cpp_workque
root 306 2 0 0 irq_thread 0000000000 S irq/192-batt-mi
root 307 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 308 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 309 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 310 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 311 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 312 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 313 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 314 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 315 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 316 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 317 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 318 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 319 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 320 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 321 2 0 0 irq_thread 0000000000 S irq/202-tsens_i
root 322 2 0 0 irq_thread 0000000000 S irq/203-tsens_c
root 323 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 324 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 325 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 326 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 327 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 328 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 329 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 330 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 331 2 0 0 irq_thread 0000000000 S irq/336-tsens_i
root 332 2 0 0 irq_thread 0000000000 S irq/337-tsens_c
root 333 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 334 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 335 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 336 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 337 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 338 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 339 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 340 2 0 0 rescuer_th 0000000000 S dm_bufio_cache
root 341 2 0 0 cpufreq_in 0000000000 S cfinteractive
root 342 2 0 0 irq_thread 0000000000 S irq/196-qpnp_wl
root 343 2 0 0 rescuer_th 0000000000 S binder
root 344 2 0 0 irq_thread 0000000000 S irq/197-qpnp_sc
root 345 2 0 0 rescuer_th 0000000000 S usb_bam_wq
root 346 2 0 0 irq_thread 0000000000 S irq/10-spdm_bw_
root 347 2 0 0 rescuer_th 0000000000 S soc:audio_etm0
root 348 2 0 0 rescuer_th 0000000000 S soc:rpm_etm0
root 349 2 0 0 rescuer_th 0000000000 S soc:modem_etm0
root 350 2 0 0 worker_thr 0000000000 S kworker/3:3
root 351 2 0 0 rescuer_th 0000000000 S ipv6_addrconf
root 352 2 0 0 rfcomm_run 0000000000 S krfcommd
root 353 2 0 0 irq_thread 0000000000 S irq/654-adsp
root 354 2 0 0 rescuer_th 0000000000 S sysmon_wq
root 355 2 0 0 rescuer_th 0000000000 S adsp
root 356 2 0 0 rescuer_th 0000000000 S sys_mon
root 357 2 0 0 irq_thread 0000000000 S irq/686-slpi
root 358 2 0 0 rescuer_th 0000000000 S slpi
root 359 2 0 0 rescuer_th 0000000000 S sys_mon
root 360 2 0 0 irq_thread 0000000000 S irq/622-modem
root 361 2 0 0 rescuer_th 0000000000 S kgsl-events
root 362 2 0 0 rescuer_th 0000000000 S kgsl_devfreq_wq
root 365 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 366 2 0 0 irq_thread 0000000000 S irq/147-chg-err
root 367 2 0 0 irq_thread 0000000000 S irq/153-chg-tap
root 368 2 0 0 irq_thread 0000000000 S irq/154-chg-tcc
root 369 2 0 0 irq_thread 0000000000 S irq/152-chg-rec
root 370 2 0 0 irq_thread 0000000000 S irq/151-chg-p2f
root 371 2 0 0 irq_thread 0000000000 S irq/155-batt-ho
root 372 2 0 0 irq_thread 0000000000 S irq/156-batt-wa
root 373 2 0 0 irq_thread 0000000000 S irq/158-batt-co
root 374 2 0 0 irq_thread 0000000000 S irq/157-batt-co
root 375 2 0 0 irq_thread 0000000000 S irq/161-batt-mi
root 376 2 0 0 irq_thread 0000000000 S irq/160-batt-lo
root 377 2 0 0 irq_thread 0000000000 S irq/163-usbin-u
root 378 2 0 0 irq_thread 0000000000 S irq/164-usbin-o
root 379 2 0 0 irq_thread 0000000000 S irq/165-usbin-s
root 380 2 0 0 irq_thread 0000000000 S irq/168-aicl-do
root 381 2 0 0 irq_thread 0000000000 S irq/166-otg-fai
root 382 2 0 0 irq_thread 0000000000 S irq/167-otg-oc
root 383 2 0 0 irq_thread 0000000000 S irq/169-usbid-c
root 384 2 0 0 irq_thread 0000000000 S irq/170-dcin-uv
root 385 2 0 0 irq_thread 0000000000 S irq/172-power-o
root 386 2 0 0 irq_thread 0000000000 S irq/173-temp-sh
root 387 2 0 0 irq_thread 0000000000 S irq/174-wdog-ti
root 388 2 0 0 rescuer_th 0000000000 S lk_wq
root 389 2 0 0 rescuer_th 0000000000 S rq_stats
root 390 2 0 0 events_not 0000000000 S msm_perf:events
root 391 2 0 0 irq_thread 0000000000 S irq/283-arm-smm
root 392 2 0 0 irq_thread 0000000000 S irq/284-arm-smm
root 393 2 0 0 irq_thread 0000000000 S irq/285-arm-smm
root 394 2 0 0 irq_thread 0000000000 S irq/286-arm-smm
root 395 2 0 0 irq_thread 0000000000 S irq/287-arm-smm
root 396 2 0 0 irq_thread 0000000000 S irq/288-arm-smm
root 397 2 0 0 irq_thread 0000000000 S irq/289-arm-smm
root 398 2 0 0 irq_thread 0000000000 S irq/290-arm-smm
root 399 2 0 0 rescuer_th 0000000000 S sb-1
root 400 2 0 0 ngd_slim_r 0000000000 D ngd_rx_thread1
root 401 2 0 0 ngd_notify 0000000000 D ngd_notify_sl1
root 402 2 0 0 rescuer_th 0000000000 S k_bam_data
root 403 2 0 0 rescuer_th 0000000000 S f_mtp
root 404 2 0 0 worker_thr 0000000000 S kworker/1:1H
root 405 2 0 0 do_samplin 0000000000 D msm-core:sampli
root 406 2 0 0 do_hotplug 0000000000 S msm_thermal:hot
root 407 2 0 0 do_freq_mi 0000000000 S msm_thermal:fre
root 408 2 0 0 do_thermal 0000000000 S msm_thermal:the
root 409 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 410 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 411 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 412 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 413 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 414 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 415 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 416 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 417 2 0 0 irq_thread 0000000000 S irq/218-lmh-int
root 418 2 0 0 boost_mig_ 0000000000 S boost_sync/0
root 419 2 0 0 boost_mig_ 0000000000 S boost_sync/1
root 420 2 0 0 boost_mig_ 0000000000 S boost_sync/2
root 421 2 0 0 boost_mig_ 0000000000 S boost_sync/3
root 422 2 0 0 rescuer_th 0000000000 S ipa_A7_svc
root 423 2 0 0 rescuer_th 0000000000 S qmi_hndl0000000
root 424 2 0 0 rescuer_th 0000000000 S clnt_req
root 425 2 0 0 rescuer_th 0000000000 S clnt_resp
root 426 2 0 0 rescuer_th 0000000000 S clnt_req
root 427 1 4520 1068 poll_sched 0000000000 S /sbin/ueventd
root 429 2 0 0 kjournald2 0000000000 S jbd2/sde19-8
root 430 2 0 0 rescuer_th 0000000000 S ext4-rsv-conver
root 433 2 0 0 worker_thr 0000000000 S kworker/3:1H
root 435 2 0 0 kjournald2 0000000000 S jbd2/sda9-8
root 436 2 0 0 rescuer_th 0000000000 S ext4-rsv-conver
root 438 2 0 0 kjournald2 0000000000 S jbd2/sda3-8
root 439 2 0 0 rescuer_th 0000000000 S ext4-rsv-conver
root 440 2 0 0 kjournald2 0000000000 S jbd2/sda2-8
root 441 2 0 0 rescuer_th 0000000000 S ext4-rsv-conver
root 442 2 0 0 kjournald2 0000000000 S jbd2/sde13-8
root 443 2 0 0 rescuer_th 0000000000 S ext4-rsv-conver
root 449 1 15088 3016 hrtimer_na 0000000000 S /system/bin/vold
root 455 2 0 0 rescuer_th 0000000000 S lpass_IPCRTR
root 456 2 0 0 rescuer_th 0000000000 S LOOPBACK
root 457 2 0 0 rescuer_th 0000000000 S qmi_hndl0000000
root 458 2 0 0 rescuer_th 0000000000 S qmi_hndl0000000
root 459 2 0 0 kthread_wo 0000000000 S msm_slim_qmi_cl
root 460 2 0 0 rescuer_th 0000000000 S qmi_hndl0000000
root 461 2 0 0 irq_thread 0000000000 S irq/291-arm-smm
root 463 2 0 0 rescuer_th 0000000000 S dsps_IPCRTR
root 470 2 0 0 rescuer_th 0000000000 S qmi_hndl0000000
root 471 2 0 0 rescuer_th 0000000000 S qmi_hndl0000000
root 492 2 0 0 irq_thread 0000000000 S irq/393-wcd9xxx
root 510 2 0 0 rescuer_th 0000000000 S tfa98xx
root 524 1 4272 528 SyS_epoll_ 0000000000 S /sbin/healthd
root 525 1 6396 1236 SyS_epoll_ 0000000000 S /system/bin/lmkd
system 526 1 6272 1472 binder_thr 0000000000 S /system/bin/servicemanager
nobody 530 1 13632 1604 poll_sched 0000000000 S /system/bin/rmt_storage
system 534 1 18416 2060 do_sigtime 0000000000 S system/bin/pm-service
system 536 1 23048 3492 do_wait 0000000000 S /system/bin/qseecomd
shell 546 1 6076 1532 n_tty_read 7f7b50de3c S /system/bin/sh
root 547 1 19728 2520 hrtimer_na 0000000000 S /system/bin/netd
root 548 1 3188 1124 __skb_recv 0000000000 S /system/bin/debuggerd
root 549 1 6720 1304 __skb_recv 0000000000 S /system/bin/debuggerd64
drm 551 1 18340 5692 binder_thr 0000000000 S /system/bin/drmserver
media 552 1 147268 23352 binder_thr 0000000000 S /system/bin/mediaserver
root 554 1 6376 1804 unix_strea 0000000000 S /system/bin/installd
keystore 562 1 10936 2568 binder_thr 0000000000 S /system/bin/keystore
root 572 1 14284 2484 poll_sched 0000000000 S /system/bin/qcom-system-daemon
rfs 574 1 7488 1620 poll_sched 0000000000 S /system/bin/tftp_server
system 581 1 23848 7736 binder_thr 0000000000 S /system/bin/wfdservice
root 582 1 105660 3268 sigsuspend 0000000000 S /system/vendor/bin/thermal-engine
media 583 1 8060 1240 poll_sched 0000000000 S /system/bin/adsprpcd
system 585 1 10644 1796 poll_sched 0000000000 S /system/bin/imsqmidaemon
system 588 1 6596 1432 SyS_epoll_ 0000000000 S /system/bin/hvdcp_opti
root 596 1 3760 140 poll_sched 0000000000 S /system/bin/sw_coredump
root 598 1 1506028 55296 poll_sched 0000000000 S zygote
system 599 1 10256 2336 binder_thr 0000000000 S /system/bin/gatekeeperd
root 615 1 6088 1296 hrtimer_na 0000000000 S /system/xbin/perfprofd
system 620 1 72752 16368 SyS_epoll_ 0000000000 S /system/bin/cnd
root 621 1 12988 2132 unix_strea 0000000000 S /system/bin/dpmd
system 629 1 12904 2044 __skb_recv 0000000000 S /system/bin/cnss-daemon
gps 630 1 8064 1536 sigsuspend 0000000000 S /system/bin/loc_launcher
system 648 1 16864 2060 futex_wait 0000000000 S /system/bin/ATFWD-daemon
system 694 1 62876 13852 binder_thr 0000000000 S /system/vendor/bin/qseeproxydaemon
camera 695 1 86364 26712 poll_sched 0000000000 S /system/bin/mm-qcamera-daemon
system 696 1 65260 14388 binder_thr 0000000000 S /system/bin/fingerprintd
system 697 1 69120 14648 binder_thr 0000000000 S /system/bin/qfp-daemon
system 710 1 61776 13900 sigsuspend 0000000000 S /system/bin/qvop-daemon
system 711 1 15264 2224 futex_wait 0000000000 S /system/bin/time_daemon
system 712 1 28744 6580 binder_thr 0000000000 S /system/bin/audiod
gps 718 630 15268 2048 futex_wait 0000000000 S lowi-server
gps 719 630 23684 1788 futex_wait 0000000000 S xtwifi-inet-agent
gps 721 630 26364 3972 poll_sched 0000000000 S slim_daemon
system 723 1 13460 2224 futex_wait 0000000000 S /system/bin/tloc_daemon
system 724 1 12592 1996 binder_thr 0000000000 S /system/vendor/bin/mdtp_service
sensors 725 1 61100 3020 poll_sched 0000000000 S /system/bin/sensors.qcom
system 726 1 65740 14204 poll_sched 0000000000 S /system/bin/mm-pp-dpps
system 727 1 11748 1812 hrtimer_na 0000000000 S /system/bin/pm-proxy
shell 728 1 8928 700 poll_sched 0000000000 S /sbin/adbd
system 733 621 18376 2928 SyS_epoll_ 0000000000 S /system/bin/dpmd
system 772 536 32264 2192 sigsuspend 0000000000 S /system/bin/qseecomd
radio 783 1 13064 2268 poll_sched 0000000000 S /system/bin/qmuxd
system 827 1 9364 1412 poll_sched 0000000000 S /system/bin/ipacm-diag
root 830 2 0 0 irq_thread 0000000000 S irq/246-arm-smm
root 831 2 0 0 irq_thread 0000000000 S irq/247-arm-smm
system 833 1 14696 2428 poll_sched 0000000000 S /system/bin/imsdatadaemon
root 838 2 0 0 worker_thr 0000000000 S kworker/3:2H
root 846 2 0 0 rescuer_th 0000000000 S qmi_hndl0000000
net_admin 849 1 14772 2292 futex_wait 0000000000 S /system/bin/ipacm
radio 980 1 14752 1880 poll_sched 0000000000 S /system/vendor/bin/qti
radio 989 1 58864 4176 __skb_recv 0000000000 S /system/bin/netmgrd
root 995 1 10156 1412 futex_wait 0000000000 S /system/bin/port-bridge
root 1002 2 0 0 rescuer_th 0000000000 S DS
root 1035 2 0 0 rescuer_th 0000000000 S mpss_IPCRTR
root 1036 2 0 0 rescuer_th 0000000000 S LOOPBACK
root 1043 2 0 0 rescuer_th 0000000000 S SSM_RTR_MODEM_A
root 1050 2 0 0 rescuer_th 0000000000 S qmi_hndl0000000
root 1069 2 0 0 rescuer_th 0000000000 S qmi_hndl0000000
root 1071 2 0 0 irq_thread 0000000000 S irq/268-arm-smm
root 1072 2 0 0 irq_thread 0000000000 S irq/273-arm-smm
root 1073 2 0 0 irq_thread 0000000000 S irq/269-arm-smm
root 1075 2 0 0 irq_thread 0000000000 S irq/274-arm-smm
root 1132 2 0 0 rescuer_th 0000000000 S DATA1
root 1134 2 0 0 rescuer_th 0000000000 S DATA2
root 1135 2 0 0 rescuer_th 0000000000 S DATA3
root 1136 2 0 0 rescuer_th 0000000000 S DATA4
root 1137 2 0 0 rescuer_th 0000000000 S DATA11
system 1491 597 2302136 120644 SyS_epoll_ 0000000000 S system_server
root 1722 2 0 0 rescuer_th 0000000000 S ipawq48
root 1723 2 0 0 rescuer_th 0000000000 S iparepwq48
media_rw 2070 449 9336 2040 inotify_re 0000000000 S /system/bin/sdcard
u0_a8 2082 597 1573984 43576 SyS_epoll_ 0000000000 S android.process.media
u0_a21 2097 597 1678896 116588 SyS_epoll_ 0000000000 S com.android.systemui
root 2226 2 0 0 worker_thr 0000000000 S kworker/0:2H
u0_a47 2526 597 1583448 46660 SyS_epoll_ 0000000000 S com.android.inputmethod.latin
system 2562 597 1573704 36752 SyS_epoll_ 0000000000 S com.quicinc.cne.CNEService
nfc 2578 597 1571156 42808 SyS_epoll_ 0000000000 S com.android.nfc
ese 2587 597 1571528 35840 SyS_epoll_ 0000000000 S com.nxp.spi
radio 2598 597 1568004 32192 SyS_epoll_ 0000000000 S com.qualcomm.qti.rcsbootstraputil
system 2622 597 1574156 43684 SyS_epoll_ 0000000000 S com.dolby
system 2641 597 1569596 34892 SyS_epoll_ 0000000000 S com.quicinc.wbcserviceapp
system 2657 597 1569556 35816 SyS_epoll_ 0000000000 S com.qualcomm.qti.services.secureui:sui_service
system 2698 597 1568476 35364 SyS_epoll_ 0000000000 S com.letv.bsp.qccrashhandler
u0_a10 2730 597 1618852 84244 SyS_epoll_ 0000000000 S com.android.launcher
u0_a3 2836 597 1577484 43168 SyS_epoll_ 0000000000 S android.process.acore
root 2921 2 0 0 worker_thr 0000000000 S kworker/2:2H
u0_a74 2982 597 1567060 32976 SyS_epoll_ 0000000000 S com.android.smspush
radio 3008 597 1571620 34620 SyS_epoll_ 0000000000 S com.qualcomm.qcrilmsgtunnel
u0_a88 3063 598 1090524 73680 SyS_epoll_ 0000000000 S com.baidu.appsearch
u0_a34 3091 597 1575096 39588 SyS_epoll_ 0000000000 S com.android.deskclock
u0_a5 3304 597 1567412 34356 SyS_epoll_ 0000000000 S com.android.cellbroadcastreceiver
u0_a32 3318 597 1567164 32940 SyS_epoll_ 0000000000 S com.qti.cbwidget
root 3361 2 0 0 irq_thread 0000000000 S irq/21-408000.q
system 3364 597 1568260 36804 SyS_epoll_ 0000000000 S com.android.keychain
root 3380 1 15384 3140 futex_wait 0000000000 S /system/bin/iop
root 3416 1 10456 1360 futex_wait 0000000000 S /system/vendor/bin/perfd
root 3424 2 0 0 notify_use 0000000000 S wrkld_notify
system 3443 597 1569532 34792 SyS_epoll_ 0000000000 S com.qti.diagservices
system 3458 597 1575856 34136 SyS_epoll_ 0000000000 S com.qualcomm.qti.seemp.service:seemp_service
u0_a2 3489 597 1571516 38944 SyS_epoll_ 0000000000 S com.android.providers.calendar
u0_a12 3522 597 1579040 41368 SyS_epoll_ 0000000000 S com.android.mms
root 3567 2 0 0 diag_socke 0000000000 S kworker/u8:10
system 3570 597 1575884 36628 SyS_epoll_ 0000000000 S com.qualcomm.qti.tetherservice
u0_a30 3615 597 1582940 38244 SyS_epoll_ 0000000000 S com.android.calendar
u0_a36 3641 597 1588856 43028 SyS_epoll_ 0000000000 S com.android.email
root 3707 2 0 0 worker_thr 0000000000 S kworker/2:4
system 3709 597 1568444 34696 SyS_epoll_ 0000000000 S com.qualcomm.qti.GBAHttpAuthentication.auth
system 3723 597 1568160 35200 SyS_epoll_ 0000000000 S com.qualcomm.qualcommsettings
u0_a67 3728 597 1567716 34124 SyS_epoll_ 0000000000 S com.qualcomm.qti.telephonyservice
root 3769 2 0 0 worker_thr 0000000000 S kworker/u8:12
root 3771 2 0 0 worker_thr 0000000000 S kworker/u8:13
smartcard 3773 597 1569768 36460 SyS_epoll_ 0000000000 S org.simalliance.openmobileapi.service:remote
u0_a88 3812 598 1010824 34912 SyS_epoll_ 0000000000 S com.baidu.appsearch:locationservice
system 3858 597 1569620 34948 SyS_epoll_ 0000000000 S com.qualcomm.telephony
root 3865 2 0 0 worker_thr 0000000000 S kworker/0:4
u0_a78 3876 597 1566968 33856 SyS_epoll_ 0000000000 S com.quicinc.wipoweragent
u0_a6 4036 597 1567632 35528 SyS_epoll_ 0000000000 S com.android.defcontainer
u0_a42 4089 597 2101740 37276 SyS_epoll_ 0000000000 S com.android.gallery3d
u0_a61 4115 597 1566944 32972 SyS_epoll_ 0000000000 S com.svox.pico
root 4510 2 0 0 worker_thr 0000000000 S kworker/u8:4
root 4528 2 0 0 worker_thr 0000000000 S kworker/1:3
root 4568 2 0 0 worker_thr 0000000000 S kworker/u8:6
root 4569 2 0 0 worker_thr 0000000000 S kworker/3:4
root 4572 2 0 0 worker_thr 0000000000 S kworker/1:2
root 4591 2 0 0 worker_thr 0000000000 S kworker/0:2
root 4594 2 0 0 worker_thr 0000000000 S kworker/2:0
root 4596 2 0 0 worker_thr 0000000000 S kworker/2:1
root 4629 2 0 0 worker_thr 0000000000 S kworker/2:3
root 4844 2 0 0 worker_thr 0000000000 S kworker/1:4
root 4854 2 0 0 worker_thr 0000000000 S kworker/u8:7
root 4861 2 0 0 diag_socke 0000000000 S kworker/u8:11
root 4863 2 0 0 worker_thr 0000000000 S kworker/u8:15
root 4864 2 0 0 worker_thr 0000000000 S kworker/u8:16
root 4865 2 0 0 worker_thr 0000000000 S kworker/u8:17
system 4871 597 1567048 34164 SyS_epoll_ 0000000000 S com.qualcomm.timeservice
root 4890 2 0 0 worker_thr 0000000000 S kworker/0:3
root 4891 2 0 0 worker_thr 0000000000 S kworker/u8:18
root 4918 2 0 0 worker_thr 0000000000 S kworker/0:5
root 4919 2 0 0 worker_thr 0000000000 S kworker/0:6
root 4974 2 0 0 worker_thr 0000000000 S kworker/3:5
root 4975 2 0 0 worker_thr 0000000000 S kworker/3:6
root 4976 2 0 0 worker_thr 0000000000 S kworker/3:7
root 5008 2 0 0 diag_socke 0000000000 S kworker/u8:8
root 5015 2 0 0 worker_thr 0000000000 S kworker/2:5
root 5016 2 0 0 worker_thr 0000000000 S kworker/2:6
root 5017 2 0 0 worker_thr 0000000000 S kworker/2:7
root 5042 2 0 0 worker_thr 0000000000 S kworker/0:7
root 5079 2 0 0 worker_thr 0000000000 S kworker/0:8
u0_a89 5443 597 1577084 40120 ptrace_sto 0000000000 t com.sysprogs.AndroidAutoTest
u0_a89 5462 728 3140 528 poll_sched 0000000000 S /data/app/com.sysprogs.AndroidAutoTest-2/lib/arm64/gdbserver
shell 5597 728 6008 1260 0 7f9cb52e3c R ps
C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s 9416189d shell id
uid=2000(shell) gid=2000(shell) groups=2000(shell),1004(input),1007(log),1011(adb),1015(sdcard_rw),1028(sdcard_r),3001(net_bt_admin),3002(net_bt),3003(inet),3006(net_bw_stats) context=u:r:shell:s0Command exited with code 0
C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s 9416189d shell run-as com.sysprogs.AndroidAutoTest kill -9 5462
C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s 9416189d shell run-as com.sysprogs.AndroidAutoTest kill -9 5443
C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s 9416189d install -r “C:\Users\zl121\AppData\Local\Temp\SysprogsAndroidTest-10484\4.9\bin\SysprogsAndroidAutoTest-debug.apk”
pkg: /data/local/tmp/SysprogsAndroidAutoTest-debug.apkSuccess
1985 KB/s (400964 bytes in 0.197s)
C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s 9416189d shell run-as com.sysprogs.AndroidAutoTest /system/bin/sh -c pwd
/data/data/com.sysprogs.AndroidAutoTestCommand exited with code 0
C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s 9416189d shell getprop ro.product.cpu.abi
arm64-v8aCommand exited with code 0
C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s 9416189d shell getprop ro.build.version.sdk
23Command exited with code 0
C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s 9416189d shell ls /data/data/com.sysprogs.AndroidAutoTest/lib
/data/data/com.sysprogs.AndroidAutoTest/lib: No such file or directoryCommand exited with code 0
C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s 9416189d shell pm list packages -f
package:/system/priv-app/FMRadio/FMRadio.apk=com.android.fmradiopackage:/system/app/LetvFuseWire/LetvFuseWire.apk=com.letv.android.FuseWire
package:/system/app/RootPA/RootPA.apk=com.gd.mobicore.pa
package:/system/app/SampleExtAuthService/SampleExtAuthService.apk=com.qualcomm.qti.auth.sampleextauthservice
package:/system/priv-app/TelephonyProvider/TelephonyProvider.apk=com.android.providers.telephony
package:/system/app/UICC_eSE/UICC_eSE.apk=com.nxp.uiccese
package:/system/app/imsTests/imsTests.apk=com.qualcomm.ims.tests
package:/system/app/wipowerservice/wipowerservice.apk=org.codeaurora.bt_wipowersdk
package:/system/priv-app/CalendarProvider/CalendarProvider.apk=com.android.providers.calendar
package:/system/priv-app/MediaProvider/MediaProvider.apk=com.android.providers.media
package:/system/app/colorservice/colorservice.apk=com.qti.service.colorservice
package:/system/app/ModemTestMode/ModemTestMode.apk=com.qualcomm.qti.modemtestmode
package:/system/app/shutdownlistener/shutdownlistener.apk=com.qualcomm.shutdownlistner
package:/system/priv-app/WallpaperCropper/WallpaperCropper.apk=com.android.wallpapercropper
package:/system/priv-app/CNEService/CNEService.apk=com.quicinc.cne.CNEService
package:/system/app/com.qualcomm.qti.auth.fidocryptosample/com.qualcomm.qti.auth.fidocryptosample.apk=com.qualcomm.qti.auth.fidocryptosample
package:/system/app/Protips/Protips.apk=com.android.protips
package:/system/priv-app/Launcher2/Launcher2.apk=com.android.launcher
package:/system/app/SmartcardService/SmartcardService.apk=org.simalliance.openmobileapi.service
package:/system/vendor/app/DsUI/DsUI.apk=com.dolby.daxappUI
package:/system/app/QVTester/QVTester.apk=com.qualcomm.location.qvtester
package:/system/app/DocumentsUI/DocumentsUI.apk=com.android.documentsui
package:/system/app/Galaxy4/Galaxy4.apk=com.android.galaxy4
package:/system/priv-app/ExternalStorageProvider/ExternalStorageProvider.apk=com.android.externalstorage
package:/system/app/uimremoteclient/uimremoteclient.apk=com.qualcomm.uimremoteclient
package:/system/app/HTMLViewer/HTMLViewer.apk=com.android.htmlviewer
package:/system/app/FTMMode/FTMMode.apk=com.qualcomm.ftm
package:/system/app/StaProxyService/StaProxyService.apk=com.qualcomm.sta
package:/system/app/QuickSearchBox/QuickSearchBox.apk=com.android.quicksearchbox
package:/system/priv-app/MmsService/MmsService.apk=com.android.mms.service
package:/system/priv-app/DownloadProvider/DownloadProvider.apk=com.android.providers.downloads
package:/system/app/SampleAuthenticatorService/SampleAuthenticatorService.apk=com.qualcomm.qti.auth.sampleauthenticatorservice
package:/system/app/QCap/QCap.apk=com.qualcomm.qti.biometrics.fingerprint.qcap
package:/system/app/HiddTestApp/HiddTestApp.apk=org.codeaurora.bluetooth.hiddtestapp
package:/system/vendor/app/SecProtect/SecProtect.apk=com.qapp.secprotect
package:/system/app/QtiTelephonyService/QtiTelephonyService.apk=com.qualcomm.qti.telephonyservice
package:/system/app/BTTestApp/BTTestApp.apk=org.codeaurora.bluetooth.bttestapp
package:/system/app/FidoCryptoService/FidoCryptoService.apk=com.qualcomm.qti.auth.fidocryptoservice
package:/system/priv-app/SoundRecorder/SoundRecorder.apk=com.android.soundrecorder
package:/system/app/WiHDSampleApp/WiHDSampleApp.apk=com.letv.wihd.sample
package:/system/app/uimremoteserver/uimremoteserver.apk=com.qualcomm.uimremoteserver
package:/system/priv-app/DefaultContainerService/DefaultContainerService.apk=com.android.defcontainer
package:/system/app/DownloadProviderUi/DownloadProviderUi.apk=com.android.providers.downloads.ui
package:/system/app/PacProcessor/PacProcessor.apk=com.android.pacprocessor
package:/system/app/CertInstaller/CertInstaller.apk=com.android.certinstaller
package:/system/priv-app/CarrierConfig/CarrierConfig.apk=com.android.carrierconfig
package:/system/app/BluetoothExt/BluetoothExt.apk=org.codeaurora.bluetooth
package:/system/app/datastatusnotification/datastatusnotification.apk=com.qti.qualcomm.datastatusnotification
package:/system/framework/framework-res.apk=android
package:/system/priv-app/Contacts/Contacts.apk=com.android.contacts
package:/system/app/LetvCamera/LetvCamera.apk=com.android.camera2
package:/system/app/WfdService/WfdService.apk=com.qualcomm.wfd.service
package:/system/app/a4wpservice/a4wpservice.apk=org.codeaurora.bt_wipower
package:/system/app/VoicePrintDemo/VoicePrintDemo.apk=com.qualcomm.qti.biometrics.voiceprint.voiceprintdemo
package:/system/app/QtiGbaAuthService/QtiGbaAuthService.apk=com.qualcomm.qti.GBAHttpAuthentication.auth
package:/system/priv-app/Mms/Mms.apk=com.android.mms
package:/system/app/NfcNci/NfcNci.apk=com.android.nfc
package:/system/app/Stk/Stk.apk=com.android.stk
package:/system/priv-app/BackupRestoreConfirmation/BackupRestoreConfirmation.apk=com.android.backupconfirm
package:/system/app/EseSpi/EseSpi.apk=com.nxp.spi
package:/system/app/SenseID-M/SenseID-M.apk=com.qualcomm.qti.biometrics.fingerprint.senseidm
package:/system/app/CNESettings/CNESettings.apk=com.quicinc.cne.settings
package:/system/app/Provision/Provision.apk=com.android.provision
package:/system/app/BTLogKit/BTLogKit.apk=com.android.qlogging
package:/system/app/radioconfig/radioconfig.apk=com.qualcomm.qti.radioconfiginterface
package:/system/vendor/app/ims/ims.apk=org.codeaurora.ims
package:/system/priv-app/StatementService/StatementService.apk=com.android.statementservice
package:/system/app/HoloSpiralWallpaper/HoloSpiralWallpaper.apk=com.android.wallpaper.holospiral
package:/system/app/Calendar/Calendar.apk=com.android.calendar
package:/system/app/PhaseBeam/PhaseBeam.apk=com.android.phasebeam
package:/system/app/SecureExtAuthService/SecureExtAuthService.apk=com.qualcomm.qti.auth.secureextauthservice
package:/system/app/PrimaryCardController/PrimaryCardController.apk=com.qti.primarycardcontroller
package:/system/priv-app/qcrilmsgtunnel/qcrilmsgtunnel.apk=com.qualcomm.qcrilmsgtunnel
package:/system/priv-app/SettingsProvider/SettingsProvider.apk=com.android.providers.settings
package:/system/priv-app/SharedStorageBackup/SharedStorageBackup.apk=com.android.sharedstoragebackup
package:/system/app/PrintSpooler/PrintSpooler.apk=com.android.printspooler
package:/system/app/MdtpDemo/MdtpDemo.apk=com.qualcomm.qti.securemsm.mdtp.MdtpDemo
package:/system/app/BasicDreams/BasicDreams.apk=com.android.dreams.basic
package:/system/app/telresources/telresources.apk=com.android.frameworks.telresources
package:/data/app/com.baidu.appsearch-1/base.apk=com.baidu.appsearch
package:/system/app/webview/webview.apk=com.android.webview
package:/system/priv-app/InputDevices/InputDevices.apk=com.android.inputdevices
package:/system/app/QFingerprintService/QFingerprintService.apk=com.qualcomm.qti.biometrics.fingerprint.service
package:/system/app/SecureSampleAuthService/SecureSampleAuthService.apk=com.qualcomm.qti.auth.securesampleauthservice
package:/system/app/xdivert/xdivert.apk=com.qti.xdivert
package:/system/priv-app/MusicFX/MusicFX.apk=com.android.musicfx
package:/system/app/WfdClient/WfdClient.apk=com.qualcomm.wfd.client
package:/system/priv-app/BugPostbox/BugPostbox.apk=com.letv.bugpostbox
package:/system/priv-app/CellBroadcastReceiver/CellBroadcastReceiver.apk=com.android.cellbroadcastreceiver
package:/system/priv-app/OneTimeInitializer/OneTimeInitializer.apk=com.android.onetimeinitializer
package:/system/app/DeviceInfo/DeviceInfo.apk=com.android.qrd.engineeringmode
package:/system/priv-app/Telecom/Telecom.apk=com.android.server.telecom
package:/system/app/KeyChain/KeyChain.apk=com.android.keychain
package:/system/app/RCSBootstraputil/RCSBootstraputil.apk=com.qualcomm.qti.rcsbootstraputil
package:/system/priv-app/Dialer/Dialer.apk=com.android.dialer
package:/system/app/Gallery2/Gallery2.apk=com.android.gallery3d
package:/system/priv-app/CallLogBackup/CallLogBackup.apk=com.android.calllogbackup
package:/system/app/QFPCalibration/QFPCalibration.apk=com.qualcomm.qti.biometrics.fingerprint.qfpcalibration
package:/system/priv-app/PackageInstaller/PackageInstaller.apk=com.android.packageinstaller
package:/system/app/PicoTts/PicoTts.apk=com.svox.pico
package:/system/app/AntHalService/AntHalService.apk=com.dsi.ant.server
package:/system/priv-app/ProxyHandler/ProxyHandler.apk=com.android.proxyhandler
package:/system/app/LatinIME/LatinIME.apk=com.android.inputmethod.latin
package:/system/app/BTLogSave/BTLogSave.apk=org.codeaurora.bluetooth.btlogsave
package:/system/app/QtiBackupAgent/QtiBackupAgent.apk=com.qti.backupagent
package:/system/app/EmbmsTestApp/EmbmsTestApp.apk=com.qualcomm.embmstest
package:/system/priv-app/ManagedProvisioning/ManagedProvisioning.apk=com.android.managedprovisioning
package:/system/app/PhotoTable/PhotoTable.apk=com.android.dreams.phototable
package:/system/app/ODLT/ODLT.apk=com.qualcomm.qct.dlt
package:/system/app/CellBroadcastWidget/CellBroadcastWidget.apk=com.qti.cbwidget
package:/system/app/LetvDebugUtil/LetvDebugUtil.apk=com.letv.android.DebugUtils
package:/system/app/WiHDService/WiHDService.apk=com.letv.wihd
package:/system/app/NoiseField/NoiseField.apk=com.android.noisefield
package:/system/app/IRTest/IRTest.apk=com.irtest.letv
package:/system/app/WAPPushManager/WAPPushManager.apk=com.android.smspush
package:/system/app/LiveWallpapersPicker/LiveWallpapersPicker.apk=com.android.wallpaper.livepicker
package:/system/priv-app/Tag/Tag.apk=com.android.apps.tag
package:/system/app/SeempService/SeempService.apk=com.qualcomm.qti.seemp.service
package:/system/vendor/app/QDCMMobileApp/QDCMMobileApp.apk=com.qti.snapdragon.qdcm_mobile
package:/system/vendor/app/Ds/Ds.apk=com.dolby
package:/system/app/FactoryMode/FactoryMode.apk=com.letv.factorymode
package:/system/app/LetvStateInfo/LetvStateInfo.apk=com.letv.android.StateInfo
package:/system/app/SenseID/SenseID.apk=com.qualcomm.qti.biometrics.fingerprint.qfpmanager.debug
package:/system/app/OpenWnn/OpenWnn.apk=jp.co.omronsoft.openwnn
package:/system/priv-app/Settings/Settings.apk=com.android.settings
package:/system/priv-app/QtiMmsTestApp/QtiMmsTestApp.apk=com.qualcomm.qti.app
package:/system/vendor/app/imssettings/imssettings.apk=com.qualcomm.qti.ims
package:/system/app/com.quicinc.wbcserviceapp/com.quicinc.wbcserviceapp.apk=com.quicinc.wbcserviceapp
package:/system/app/ExactCalculator/ExactCalculator.apk=com.android.calculator2
package:/system/priv-app/com.qualcomm.location/com.qualcomm.location.apk=com.qualcomm.location
package:/system/app/com.quicinc.wipoweragent/com.quicinc.wipoweragent.apk=com.quicinc.wipoweragent
package:/system/priv-app/QtiTetherService/QtiTetherService.apk=com.qualcomm.qti.tetherservice
package:/system/app/FM2/FM2.apk=com.caf.fmradio
package:/system/app/MdtpService/MdtpService.apk=com.qualcomm.qti.securemsm.mdtp
package:/system/app/QTIDiagServices/QTIDiagServices.apk=com.qti.diagservices
package:/system/app/LiveWallpapers/LiveWallpapers.apk=com.android.wallpaper
package:/system/app/com.qualcomm.qti.services.secureui/com.qualcomm.qti.services.secureui.apk=com.qualcomm.qti.services.secureui
package:/system/priv-app/VpnDialogs/VpnDialogs.apk=com.android.vpndialogs
package:/system/app/UltrasoundSettings/UltrasoundSettings.apk=com.android.ultrasound
package:/system/app/Email/Email.apk=com.android.email
package:/system/app/Music/Music.apk=com.android.music
package:/system/priv-app/TeleService/TeleService.apk=com.android.phone
package:/system/priv-app/Shell/Shell.apk=com.android.shell
package:/system/app/SnapdragonCamera/SnapdragonCamera.apk=org.codeaurora.snapcam
package:/system/app/UserDictionaryProvider/UserDictionaryProvider.apk=com.android.providers.userdictionary
package:/system/priv-app/FusedLocation/FusedLocation.apk=com.android.location.fused
package:/system/app/DeskClock/DeskClock.apk=com.android.deskclock
package:/system/priv-app/SystemUI/SystemUI.apk=com.android.systemui
package:/system/app/Exchange2/Exchange2.apk=com.android.exchange
package:/data/app/com.sysprogs.AndroidAutoTest-1/base.apk=com.sysprogs.AndroidAutoTest
package:/system/priv-app/QcCrashHandler/QcCrashHandler.apk=com.letv.bsp.qccrashhandler
package:/system/app/BluetoothMidiService/BluetoothMidiService.apk=com.android.bluetoothmidiservice
package:/data/app/com.nd.assistance-1/base.apk=com.nd.assistance
package:/system/app/NetworkSetting/NetworkSetting.apk=com.qualcomm.qti.networksetting
package:/system/app/fastdormancy/fastdormancy.apk=com.qualcomm.fastdormancy
package:/system/app/MultiplePdpTest/MultiplePdpTest.apk=com.android.MultiplePdpTest
package:/system/app/FidoSuiService/FidoSuiService.apk=com.qualcomm.qti.auth.fidosuiservice
package:/system/app/QualcommSettings/QualcommSettings.apk=com.qualcomm.qualcommsettings
package:/system/app/VoicePrintService/VoicePrintService.apk=com.qualcomm.qti.biometrics.voiceprint.service
package:/system/app/Bluetooth/Bluetooth.apk=com.android.bluetooth
package:/system/app/TimeService/TimeService.apk=com.qualcomm.timeservice
package:/system/vendor/app/NativeAudioLatency/NativeAudioLatency.apk=com.android.nativeaudiolatency
package:/system/app/atfwd/atfwd.apk=com.qualcomm.atfwd
package:/system/app/embms/embms.apk=com.qualcomm.embms
package:/system/priv-app/ContactsProvider/ContactsProvider.apk=com.android.providers.contacts
package:/system/app/CaptivePortalLogin/CaptivePortalLogin.apk=com.android.captiveportallogin
package:/system/vendor/app/QSensorTest/QSensorTest.apk=com.qualcomm.qti.sensors.qsensortest
C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s 9416189d shell ls /data/app/com.sysprogs.AndroidAutoTest-1/lib/arm64-v8a
/data/app/com.sysprogs.AndroidAutoTest-1/lib/arm64-v8a: No such file or directoryCommand exited with code 0
gdbserverlibfirst.so
libsecond.so
C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s 9416189d shell am start -n com.sysprogs.AndroidAutoTest/.SysprogsAndroidAutoTest
Starting: Intent { cmp=com.sysprogs.AndroidAutoTest/.SysprogsAndroidAutoTest }Command exited with code 0
C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s 9416189d shell ls /data/app/com.sysprogs.AndroidAutoTest-1/lib/arm64/gdbserver
/data/app/com.sysprogs.AndroidAutoTest-1/lib/arm64/gdbserverCommand exited with code 0
logd 444 1 13144 3304 sigsuspend 0000000000 S /system/bin/logd
system 527 1 220380 23360 SyS_epoll_ 0000000000 S /system/bin/surfaceflinger
root 547 1 19728 2516 hrtimer_na 0000000000 S /system/bin/netd
root 549 1 7908 2424 __skb_recv 0000000000 S /system/bin/debuggerd64
radio 550 1 89812 13280 hrtimer_na 0000000000 S /system/bin/rild
root 597 1 2086020 66964 poll_sched 0000000000 S zygote64
shell 728 1 7888 744 0000000000 R /sbin/adbd
radio 975 1 88260 13324 hrtimer_na 0000000000 S /system/bin/rild
system 1491 597 2304288 124092 SyS_epoll_ 0000000000 S system_server
u0_a21 2097 597 1679076 114348 SyS_epoll_ 0000000000 S com.android.systemui
u0_a47 2526 597 1583448 46744 SyS_epoll_ 0000000000 S com.android.inputmethod.latin
system 2562 597 1573704 36988 SyS_epoll_ 0000000000 S com.quicinc.cne.CNEService
nfc 2578 597 1571176 43276 SyS_epoll_ 0000000000 S com.android.nfc
system 2641 597 1569596 35040 SyS_epoll_ 0000000000 S com.quicinc.wbcserviceapp
radio 2678 597 1628444 60288 SyS_epoll_ 0000000000 S com.android.phone
system 2698 597 1569548 35536 SyS_epoll_ 0000000000 S com.letv.bsp.qccrashhandler
u0_a10 2730 597 1622056 87144 SyS_epoll_ 0000000000 S com.android.launcher
u0_a88 2949 598 1009324 33852 SyS_epoll_ 0000000000 S com.baidu.appsearch:bdservice_v1
radio 3008 597 1571620 34856 SyS_epoll_ 0000000000 S com.qualcomm.qcrilmsgtunnel
u0_a88 3063 598 1075900 66692 SyS_epoll_ 0000000000 S com.baidu.appsearch
system 3364 597 1568260 36876 SyS_epoll_ 0000000000 S com.android.keychain
root 3416 1 11496 1360 futex_wait 0000000000 S /system/vendor/bin/perfd
system 3458 597 1576928 34136 SyS_epoll_ 0000000000 S com.qualcomm.qti.seemp.service:seemp_service
u0_a2 3489 597 1571516 39152 SyS_epoll_ 0000000000 S com.android.providers.calendar
system 3709 597 1568444 34904 SyS_epoll_ 0000000000 S com.qualcomm.qti.GBAHttpAuthentication.auth
u0_a67 3728 597 1567716 34352 SyS_epoll_ 0000000000 S com.qualcomm.qti.telephonyservice
u0_a88 3812 598 1010824 35140 SyS_epoll_ 0000000000 S com.baidu.appsearch:locationservice
u0_a6 4036 597 1568704 35460 SyS_epoll_ 0000000000 S com.android.defcontainer
u0_a13 4064 597 1567184 34168 SyS_epoll_ 0000000000 S com.android.musicfx
u0_a42 4089 597 2101740 37304 SyS_epoll_ 0000000000 S com.android.gallery3d
system 4871 597 1567048 34360 SyS_epoll_ 0000000000 S com.qualcomm.timeservice
u0_a89 5704 597 1577084 40428 SyS_epoll_ 0000000000 S com.sysprogs.AndroidAutoTest
root 5724 1 12832 2792 futex_wait 0000000000 S /system/bin/iop
shell 5728 728 6008 1256 0 7f83652e3c R ps
C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s 9416189d forward tcp:5039 tcp:5039
Received launch context:
App PID: 5704
EABI: arm64-v8a
Workaround mode: EnabledWithEvenAddress
GDBServer: running
ADB log:
GDB startup log:
-gdb-set solib-search-path C:/Users/zl121/AppData/Local/VisualGDB/AndroidBinaryCache/9416189d;C:/Users/zl121/AppData/Local/Temp/SysprogsAndroidTest-10484/4.9/obj/local/arm64-v8a
^done
Activating library load breakpoint bug workaround…
-target-select remote :5039
=thread-group-started,id=”i1″,pid=”5704″
=library-loaded,id=”/system/bin/linker64″,target-name=”/system/bin/linker64″,host-name=”C:\\Users\\zl121\\AppData\\Local\\VisualGDB\\AndroidBinaryCache\\9416189d\\linker64″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/vendor/lib64/libNimsWrap.so”,target-name=”/system/vendor/lib64/libNimsWrap.so”,host-name=”/system/vendor/lib64/libNimsWrap.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libcutils.so”,target-name=”/system/lib64/libcutils.so”,host-name=”/system/lib64/libcutils.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libutils.so”,target-name=”/system/lib64/libutils.so”,host-name=”/system/lib64/libutils.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/liblog.so”,target-name=”/system/lib64/liblog.so”,host-name=”/system/lib64/liblog.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libbinder.so”,target-name=”/system/lib64/libbinder.so”,host-name=”/system/lib64/libbinder.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libandroid_runtime.so”,target-name=”/system/lib64/libandroid_runtime.so”,host-name=”/system/lib64/libandroid_runtime.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libwilhelm.so”,target-name=”/system/lib64/libwilhelm.so”,host-name=”/system/lib64/libwilhelm.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libc++.so”,target-name=”/system/lib64/libc++.so”,host-name=”/system/lib64/libc++.so”,symbols-loaded=”0″,thread-group=”i1″
&”warning: `C:\\Users\\zl121\\AppData\\Local\\VisualGDB\\AndroidBinaryCache\\9416189d\\libc.so’: Shared library architecture arm is not compatible with target architecture aarch64.\n”
&”warning: .dynamic section for \”C:\\Users\\zl121\\AppData\\Local\\VisualGDB\\AndroidBinaryCache\\9416189d\\libc.so\” is not at the expected address (wrong library or version mismatch?)\n”
=library-loaded,id=”/system/lib64/libc.so”,target-name=”/system/lib64/libc.so”,host-name=”C:\\Users\\zl121\\AppData\\Local\\VisualGDB\\AndroidBinaryCache\\9416189d\\libc.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libm.so”,target-name=”/system/lib64/libm.so”,host-name=”/system/lib64/libm.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libbacktrace.so”,target-name=”/system/lib64/libbacktrace.so”,host-name=”/system/lib64/libbacktrace.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libmemtrack.so”,target-name=”/system/lib64/libmemtrack.so”,host-name=”/system/lib64/libmemtrack.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libandroidfw.so”,target-name=”/system/lib64/libandroidfw.so”,host-name=”/system/lib64/libandroidfw.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libexpat.so”,target-name=”/system/lib64/libexpat.so”,host-name=”/system/lib64/libexpat.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libnativehelper.so”,target-name=”/system/lib64/libnativehelper.so”,host-name=”/system/lib64/libnativehelper.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libnetutils.so”,target-name=”/system/lib64/libnetutils.so”,host-name=”/system/lib64/libnetutils.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libui.so”,target-name=”/system/lib64/libui.so”,host-name=”/system/lib64/libui.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libgui.so”,target-name=”/system/lib64/libgui.so”,host-name=”/system/lib64/libgui.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libinput.so”,target-name=”/system/lib64/libinput.so”,host-name=”/system/lib64/libinput.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libinputflinger.so”,target-name=”/system/lib64/libinputflinger.so”,host-name=”/system/lib64/libinputflinger.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libcamera_client.so”,target-name=”/system/lib64/libcamera_client.so”,host-name=”/system/lib64/libcamera_client.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libcamera_metadata.so”,target-name=”/system/lib64/libcamera_metadata.so”,host-name=”/system/lib64/libcamera_metadata.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libskia.so”,target-name=”/system/lib64/libskia.so”,host-name=”/system/lib64/libskia.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libsqlite.so”,target-name=”/system/lib64/libsqlite.so”,host-name=”/system/lib64/libsqlite.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libEGL.so”,target-name=”/system/lib64/libEGL.so”,host-name=”/system/lib64/libEGL.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libGLESv1_CM.so”,target-name=”/system/lib64/libGLESv1_CM.so”,host-name=”/system/lib64/libGLESv1_CM.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libGLESv2.so”,target-name=”/system/lib64/libGLESv2.so”,host-name=”/system/lib64/libGLESv2.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libETC1.so”,target-name=”/system/lib64/libETC1.so”,host-name=”/system/lib64/libETC1.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libhardware.so”,target-name=”/system/lib64/libhardware.so”,host-name=”/system/lib64/libhardware.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libhardware_legacy.so”,target-name=”/system/lib64/libhardware_legacy.so”,host-name=”/system/lib64/libhardware_legacy.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libselinux.so”,target-name=”/system/lib64/libselinux.so”,host-name=”/system/lib64/libselinux.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libsonivox.so”,target-name=”/system/lib64/libsonivox.so”,host-name=”/system/lib64/libsonivox.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libcrypto.so”,target-name=”/system/lib64/libcrypto.so”,host-name=”/system/lib64/libcrypto.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libssl.so”,target-name=”/system/lib64/libssl.so”,host-name=”/system/lib64/libssl.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libicuuc.so”,target-name=”/system/lib64/libicuuc.so”,host-name=”/system/lib64/libicuuc.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libicui18n.so”,target-name=”/system/lib64/libicui18n.so”,host-name=”/system/lib64/libicui18n.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libmedia.so”,target-name=”/system/lib64/libmedia.so”,host-name=”/system/lib64/libmedia.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libjpeg.so”,target-name=”/system/lib64/libjpeg.so”,host-name=”/system/lib64/libjpeg.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libusbhost.so”,target-name=”/system/lib64/libusbhost.so”,host-name=”/system/lib64/libusbhost.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libharfbuzz_ng.so”,target-name=”/system/lib64/libharfbuzz_ng.so”,host-name=”/system/lib64/libharfbuzz_ng.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libz.so”,target-name=”/system/lib64/libz.so”,host-name=”/system/lib64/libz.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libaudioutils.so”,target-name=”/system/lib64/libaudioutils.so”,host-name=”/system/lib64/libaudioutils.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libpdfium.so”,target-name=”/system/lib64/libpdfium.so”,host-name=”/system/lib64/libpdfium.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libimg_utils.so”,target-name=”/system/lib64/libimg_utils.so”,host-name=”/system/lib64/libimg_utils.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libnetd_client.so”,target-name=”/system/lib64/libnetd_client.so”,host-name=”/system/lib64/libnetd_client.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libradio.so”,target-name=”/system/lib64/libradio.so”,host-name=”/system/lib64/libradio.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libsoundtrigger.so”,target-name=”/system/lib64/libsoundtrigger.so”,host-name=”/system/lib64/libsoundtrigger.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libminikin.so”,target-name=”/system/lib64/libminikin.so”,host-name=”/system/lib64/libminikin.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libprocessgroup.so”,target-name=”/system/lib64/libprocessgroup.so”,host-name=”/system/lib64/libprocessgroup.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libnativebridge.so”,target-name=”/system/lib64/libnativebridge.so”,host-name=”/system/lib64/libnativebridge.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libradio_metadata.so”,target-name=”/system/lib64/libradio_metadata.so”,host-name=”/system/lib64/libradio_metadata.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libhwui.so”,target-name=”/system/lib64/libhwui.so”,host-name=”/system/lib64/libhwui.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libstagefright.so”,target-name=”/system/lib64/libstagefright.so”,host-name=”/system/lib64/libstagefright.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libstagefright_foundation.so”,target-name=”/system/lib64/libstagefright_foundation.so”,host-name=”/system/lib64/libstagefright_foundation.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libstagefright_http_support.so”,target-name=”/system/lib64/libstagefright_http_support.so”,host-name=”/system/lib64/libstagefright_http_support.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libeffects.so”,target-name=”/system/lib64/libeffects.so”,host-name=”/system/lib64/libeffects.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libbase.so”,target-name=”/system/lib64/libbase.so”,host-name=”/system/lib64/libbase.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libunwind.so”,target-name=”/system/lib64/libunwind.so”,host-name=”/system/lib64/libunwind.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libstdc++.so”,target-name=”/system/lib64/libstdc++.so”,host-name=”/system/lib64/libstdc++.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libsync.so”,target-name=”/system/lib64/libsync.so”,host-name=”/system/lib64/libsync.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libpng.so”,target-name=”/system/lib64/libpng.so”,host-name=”/system/lib64/libpng.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libft2.so”,target-name=”/system/lib64/libft2.so”,host-name=”/system/lib64/libft2.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/vendor/lib64/libqc-opt.so”,target-name=”/system/vendor/lib64/libqc-opt.so”,host-name=”/system/vendor/lib64/libqc-opt.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libGLES_trace.so”,target-name=”/system/lib64/libGLES_trace.so”,host-name=”/system/lib64/libGLES_trace.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libwpa_client.so”,target-name=”/system/lib64/libwpa_client.so”,host-name=”/system/lib64/libwpa_client.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libpcre.so”,target-name=”/system/lib64/libpcre.so”,host-name=”/system/lib64/libpcre.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libnbaio.so”,target-name=”/system/lib64/libnbaio.so”,host-name=”/system/lib64/libnbaio.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libspeexresampler.so”,target-name=”/system/lib64/libspeexresampler.so”,host-name=”/system/lib64/libspeexresampler.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libRS.so”,target-name=”/system/lib64/libRS.so”,host-name=”/system/lib64/libRS.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libRScpp.so”,target-name=”/system/lib64/libRScpp.so”,host-name=”/system/lib64/libRScpp.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libdrmframework.so”,target-name=”/system/lib64/libdrmframework.so”,host-name=”/system/lib64/libdrmframework.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libmediautils.so”,target-name=”/system/lib64/libmediautils.so”,host-name=”/system/lib64/libmediautils.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libopus.so”,target-name=”/system/lib64/libopus.so”,host-name=”/system/lib64/libopus.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libstagefright_omx.so”,target-name=”/system/lib64/libstagefright_omx.so”,host-name=”/system/lib64/libstagefright_omx.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libstagefright_yuv.so”,target-name=”/system/lib64/libstagefright_yuv.so”,host-name=”/system/lib64/libstagefright_yuv.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libvorbisidec.so”,target-name=”/system/lib64/libvorbisidec.so”,host-name=”/system/lib64/libvorbisidec.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libpowermanager.so”,target-name=”/system/lib64/libpowermanager.so”,host-name=”/system/lib64/libpowermanager.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libstagefright_enc_common.so”,target-name=”/system/lib64/libstagefright_enc_common.so”,host-name=”/system/lib64/libstagefright_enc_common.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libstagefright_avc_common.so”,target-name=”/system/lib64/libstagefright_avc_common.so”,host-name=”/system/lib64/libstagefright_avc_common.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libprotobuf-cpp-lite.so”,target-name=”/system/lib64/libprotobuf-cpp-lite.so”,host-name=”/system/lib64/libprotobuf-cpp-lite.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libcommon_time_client.so”,target-name=”/system/lib64/libcommon_time_client.so”,host-name=”/system/lib64/libcommon_time_client.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libbcc.so”,target-name=”/system/lib64/libbcc.so”,host-name=”/system/lib64/libbcc.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libbcinfo.so”,target-name=”/system/lib64/libbcinfo.so”,host-name=”/system/lib64/libbcinfo.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libLLVM.so”,target-name=”/system/lib64/libLLVM.so”,host-name=”/system/lib64/libLLVM.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”[vdso]”,target-name=”[vdso]”,host-name=”[vdso]”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/vendor/lib64/libcneconn.so”,target-name=”/system/vendor/lib64/libcneconn.so”,host-name=”/system/vendor/lib64/libcneconn.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/vendor/lib64/libvendorconn.so”,target-name=”/system/vendor/lib64/libvendorconn.so”,host-name=”/system/vendor/lib64/libvendorconn.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/vendor/lib64/libavenhancements.so”,target-name=”/system/vendor/lib64/libavenhancements.so”,host-name=”/system/vendor/lib64/libavenhancements.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libstagefright_httplive.so”,target-name=”/system/lib64/libstagefright_httplive.so”,host-name=”/system/lib64/libstagefright_httplive.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libmediaplayerservice.so”,target-name=”/system/lib64/libmediaplayerservice.so”,host-name=”/system/lib64/libmediaplayerservice.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libstagefright_wfd.so”,target-name=”/system/lib64/libstagefright_wfd.so”,host-name=”/system/lib64/libstagefright_wfd.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libcurl.so”,target-name=”/system/lib64/libcurl.so”,host-name=”/system/lib64/libcurl.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/vendor/lib64/libExtendedExtractor.so”,target-name=”/system/vendor/lib64/libExtendedExtractor.so”,host-name=”/system/vendor/lib64/libExtendedExtractor.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libdashplayer.so”,target-name=”/system/lib64/libdashplayer.so”,host-name=”/system/lib64/libdashplayer.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libart.so”,target-name=”/system/lib64/libart.so”,host-name=”/system/lib64/libart.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libsigchain.so”,target-name=”/system/lib64/libsigchain.so”,host-name=”/system/lib64/libsigchain.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libjavacore.so”,target-name=”/system/lib64/libjavacore.so”,host-name=”/system/lib64/libjavacore.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/hw/memtrack.msm8996.so”,target-name=”/system/lib64/hw/memtrack.msm8996.so”,host-name=”/system/lib64/hw/memtrack.msm8996.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/vendor/lib64/libqti-at.so”,target-name=”/system/vendor/lib64/libqti-at.so”,host-name=”/system/vendor/lib64/libqti-at.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/vendor/lib64/libqti-gt.so”,target-name=”/system/vendor/lib64/libqti-gt.so”,host-name=”/system/vendor/lib64/libqti-gt.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libxml2.so”,target-name=”/system/lib64/libxml2.so”,host-name=”/system/lib64/libxml2.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/vendor/lib64/libqti-perfd-client.so”,target-name=”/system/vendor/lib64/libqti-perfd-client.so”,host-name=”/system/vendor/lib64/libqti-perfd-client.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libmedia_jni.so”,target-name=”/system/lib64/libmedia_jni.so”,host-name=”/system/lib64/libmedia_jni.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libmtp.so”,target-name=”/system/lib64/libmtp.so”,host-name=”/system/lib64/libmtp.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libjhead.so”,target-name=”/system/lib64/libjhead.so”,host-name=”/system/lib64/libjhead.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libexif.so”,target-name=”/system/lib64/libexif.so”,host-name=”/system/lib64/libexif.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libstagefright_amrnb_common.so”,target-name=”/system/lib64/libstagefright_amrnb_common.so”,host-name=”/system/lib64/libstagefright_amrnb_common.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libextmedia_jni.so”,target-name=”/system/lib64/libextmedia_jni.so”,host-name=”/system/lib64/libextmedia_jni.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/data/dalvik-cache/arm64/system@framework@tcmclient.jar@classes.dex”,target-name=”/data/dalvik-cache/arm64/system@framework@tcmclient.jar@classes.dex”,host-name=”/data/dalvik-cache/arm64/system@framework@tcmclient.jar@classes.dex”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libjavacrypto.so”,target-name=”/system/lib64/libjavacrypto.so”,host-name=”/system/lib64/libjavacrypto.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libkeystore-engine.so”,target-name=”/system/lib64/libkeystore-engine.so”,host-name=”/system/lib64/libkeystore-engine.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libkeystore_binder.so”,target-name=”/system/lib64/libkeystore_binder.so”,host-name=”/system/lib64/libkeystore_binder.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libsoftkeymasterdevice.so”,target-name=”/system/lib64/libsoftkeymasterdevice.so”,host-name=”/system/lib64/libsoftkeymasterdevice.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libkeymaster_messages.so”,target-name=”/system/lib64/libkeymaster_messages.so”,host-name=”/system/lib64/libkeymaster_messages.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libkeymaster1.so”,target-name=”/system/lib64/libkeymaster1.so”,host-name=”/system/lib64/libkeymaster1.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/vendor/lib64/egl/libEGL_adreno.so”,target-name=”/system/vendor/lib64/egl/libEGL_adreno.so”,host-name=”/system/vendor/lib64/egl/libEGL_adreno.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/vendor/lib64/libadreno_utils.so”,target-name=”/system/vendor/lib64/libadreno_utils.so”,host-name=”/system/vendor/lib64/libadreno_utils.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/vendor/lib64/libgsl.so”,target-name=”/system/vendor/lib64/libgsl.so”,host-name=”/system/vendor/lib64/libgsl.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/vendor/lib64/egl/libGLESv2_adreno.so”,target-name=”/system/vendor/lib64/egl/libGLESv2_adreno.so”,host-name=”/system/vendor/lib64/egl/libGLESv2_adreno.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/vendor/lib64/libllvm-glnext.so”,target-name=”/system/vendor/lib64/libllvm-glnext.so”,host-name=”/system/vendor/lib64/libllvm-glnext.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/vendor/lib64/egl/libGLESv1_CM_adreno.so”,target-name=”/system/vendor/lib64/egl/libGLESv1_CM_adreno.so”,host-name=”/system/vendor/lib64/egl/libGLESv1_CM_adreno.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/vendor/lib64/egl/eglSubDriverAndroid.so”,target-name=”/system/vendor/lib64/egl/eglSubDriverAndroid.so”,host-name=”/system/vendor/lib64/egl/eglSubDriverAndroid.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/hw/gralloc.msm8996.so”,target-name=”/system/lib64/hw/gralloc.msm8996.so”,host-name=”/system/lib64/hw/gralloc.msm8996.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libmemalloc.so”,target-name=”/system/lib64/libmemalloc.so”,host-name=”/system/lib64/libmemalloc.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libqdMetaData.so”,target-name=”/system/lib64/libqdMetaData.so”,host-name=”/system/lib64/libqdMetaData.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libqdutils.so”,target-name=”/system/lib64/libqdutils.so”,host-name=”/system/lib64/libqdutils.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libqservice.so”,target-name=”/system/lib64/libqservice.so”,host-name=”/system/lib64/libqservice.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libandroid.so”,target-name=”/system/lib64/libandroid.so”,host-name=”/system/lib64/libandroid.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libcompiler_rt.so”,target-name=”/system/lib64/libcompiler_rt.so”,host-name=”/system/lib64/libcompiler_rt.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libjnigraphics.so”,target-name=”/system/lib64/libjnigraphics.so”,host-name=”/system/lib64/libjnigraphics.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libwebviewchromium_loader.so”,target-name=”/system/lib64/libwebviewchromium_loader.so”,host-name=”/system/lib64/libwebviewchromium_loader.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/data/app/com.sysprogs.AndroidAutoTest-1/oat/arm64/base.odex”,target-name=”/data/app/com.sysprogs.AndroidAutoTest-1/oat/arm64/base.odex”,host-name=”/data/app/com.sysprogs.AndroidAutoTest-1/oat/arm64/base.odex”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/data/app/com.sysprogs.AndroidAutoTest-1/lib/arm64/libfirst.so”,target-name=”/data/app/com.sysprogs.AndroidAutoTest-1/lib/arm64/libfirst.so”,host-name=”C:\\Users\\zl121\\AppData\\Local\\Temp\\SysprogsAndroidTest-10484\\4.9\\obj\\local\\arm64-v8a\\libfirst.so”,symbols-loaded=”0″,thread-group=”i1″
&”warning: Could not load shared library symbols for 131 libraries, e.g. /system/vendor/lib64/libNimsWrap.so.\nUse the \”info sharedlibrary\” command to see the complete listing.\nDo you need \”set solib-search-path\” or \”set sysroot\”?”
&”\n”
~”/s/ndk-toolchain/src/build/../gdb/gdb-7.7/gdb/gdbarch.c:3991: internal-error: gdbarch_record_special_symbol_p: Assertion `gdbarch != NULL’ failed.\nA problem internal to GDB has been detected,\nfurther debugging may prove unreliable.\nQuit this debugging session? ”
~”(y or n) [answered Y; input not from terminal]\n”
~”/s/ndk-toolchain/src/build/../gdb/gdb-7.7/gdb/gdbarch.c:3991: internal-error: gdbarch_record_special_symbol_p: Assertion `gdbarch != NULL’ failed.\nA problem internal to GDB has been detected,\nfurther debugging may prove unreliable.\nCreate a core file of GDB? ”
This application has requested the Runtime to terminate it in an unusual way.
Please contact the application’s support team for more information.
Launcher log:
GDBServer output:
Attached; pid = 5704gdbserver: Unable to determine the number of hardware watchpoints available.
gdbserver: Unable to determine the number of hardware breakpoints available.
Listening on port 5039
Remote debugging from host 127.0.0.1
readchar: Got EOF
Remote side has terminated connection. GDBserver will reopen the connection.
Exception: GDB has exited unexpectedly. If you are using a 64-bit version of NDK, consider trying a 32-bit one.
——— Testing workaround mode: EnabledWithOddAddress, attempt 1 ———
Preparing for launch…
C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s 9416189d shell ps
USER PID PPID VSIZE RSS WCHAN PC NAMEroot 1 0 5036 1720 SyS_epoll_ 0000000000 S /init
root 2 0 0 0 kthreadd 0000000000 S kthreadd
root 3 2 0 0 smpboot_th 0000000000 S ksoftirqd/0
root 4 2 0 0 worker_thr 0000000000 S kworker/0:0
root 6 2 0 0 worker_thr 0000000000 S kworker/u8:0
root 7 2 0 0 rcu_gp_kth 0000000000 S rcu_preempt
root 8 2 0 0 rcu_gp_kth 0000000000 S rcu_sched
root 9 2 0 0 rcu_gp_kth 0000000000 S rcu_bh
root 10 2 0 0 smpboot_th 0000000000 S migration/0
root 11 2 0 0 smpboot_th 0000000000 S watchdog/0
root 12 2 0 0 smpboot_th 0000000000 S watchdog/1
root 13 2 0 0 smpboot_th 0000000000 S migration/1
root 14 2 0 0 smpboot_th 0000000000 S ksoftirqd/1
root 15 2 0 0 worker_thr 0000000000 S kworker/1:0
root 16 2 0 0 worker_thr 0000000000 S kworker/1:0H
root 17 2 0 0 smpboot_th 0000000000 S watchdog/2
root 18 2 0 0 smpboot_th 0000000000 S migration/2
root 19 2 0 0 smpboot_th 0000000000 S ksoftirqd/2
root 21 2 0 0 worker_thr 0000000000 S kworker/2:0H
root 22 2 0 0 smpboot_th 0000000000 S watchdog/3
root 23 2 0 0 smpboot_th 0000000000 S migration/3
root 24 2 0 0 smpboot_th 0000000000 S ksoftirqd/3
root 25 2 0 0 worker_thr 0000000000 S kworker/3:0
root 27 2 0 0 rescuer_th 0000000000 S khelper
root 28 2 0 0 rescuer_th 0000000000 S netns
root 29 2 0 0 rescuer_th 0000000000 S perf
root 30 2 0 0 rescuer_th 0000000000 S smd_channel_clo
root 31 2 0 0 rescuer_th 0000000000 S glink_tx
root 32 2 0 0 rescuer_th 0000000000 S glink_tx
root 33 2 0 0 rescuer_th 0000000000 S glink_tx
root 34 2 0 0 rescuer_th 0000000000 S glink_tx
root 35 2 0 0 rescuer_th 0000000000 S glink_tx
root 36 2 0 0 watchdog_k 0000000000 S msm_watchdog
root 38 2 0 0 rescuer_th 0000000000 S rpm_requests
root 39 2 0 0 kthread_wo 0000000000 S smem_native_mps
root 40 2 0 0 rescuer_th 0000000000 S glink_tx
root 41 2 0 0 kthread_wo 0000000000 S smem_native_lpa
root 42 2 0 0 rescuer_th 0000000000 S glink_tx
root 43 2 0 0 kthread_wo 0000000000 S smem_native_dsp
root 44 2 0 0 rescuer_th 0000000000 S glink_tx
root 45 2 0 0 kthread_wo 0000000000 S smem_native_rpm
root 46 2 0 0 rescuer_th 0000000000 S glink_tx
root 47 2 0 0 worker_thr 0000000000 S kworker/0:1
root 48 2 0 0 rescuer_th 0000000000 S deferwq
root 49 2 0 0 msm_mpm_wo 0000000000 D kworker/u8:1
root 50 2 0 0 irq_thread 0000000000 S irq/219-cpr3
root 51 2 0 0 irq_thread 0000000000 S irq/220-cpr3_ce
root 52 2 0 0 irq_thread 0000000000 S irq/221-cpr3
root 53 2 0 0 rescuer_th 0000000000 S mpm
root 54 2 0 0 diag_socke 0000000000 S kworker/u8:2
root 55 2 0 0 worker_thr 0000000000 S kworker/u8:3
root 72 2 0 0 worker_thr 0000000000 S kworker/1:1
root 73 2 0 0 rescuer_th 0000000000 S writeback
root 74 2 0 0 rescuer_th 0000000000 S crypto
root 75 2 0 0 rescuer_th 0000000000 S bioset
root 76 2 0 0 rescuer_th 0000000000 S kblockd
root 77 2 0 0 ion_heap_d 0000000000 S system
root 78 2 0 0 ion_heap_d 0000000000 S secure_heap
root 79 2 0 0 rescuer_th 0000000000 S ipa_power_mgmt
root 80 2 0 0 rescuer_th 0000000000 S sps_ipa_power_m
root 81 2 0 0 worker_thr 0000000000 S kworker/u9:0
root 82 2 0 0 rescuer_th 0000000000 S ipawq14
root 83 2 0 0 rescuer_th 0000000000 S iparepwq14
root 84 2 0 0 worker_thr 0000000000 S kworker/u9:1
root 85 2 0 0 rescuer_th 0000000000 S ipawq47
root 86 2 0 0 rescuer_th 0000000000 S iparepwq47
root 87 2 0 0 rescuer_th 0000000000 S ipawq13
root 88 2 0 0 rescuer_th 0000000000 S iparepwq13
root 89 2 0 0 rescuer_th 0000000000 S ipa_rm_wq
root 90 2 0 0 rescuer_th 0000000000 S ipa_interrupt_w
root 91 2 0 0 irq_thread 0000000000 S irq/240-arm-smm
root 92 2 0 0 irq_thread 0000000000 S irq/245-arm-smm
root 93 2 0 0 irq_thread 0000000000 S irq/250-arm-smm
root 94 2 0 0 irq_thread 0000000000 S irq/255-arm-smm
root 95 2 0 0 irq_thread 0000000000 S irq/267-arm-smm
root 96 2 0 0 irq_thread 0000000000 S irq/272-arm-smm
root 97 2 0 0 irq_thread 0000000000 S irq/277-arm-smm
root 98 2 0 0 irq_thread 0000000000 S irq/282-arm-smm
root 99 2 0 0 irq_thread 0000000000 S irq/299-arm-smm
root 100 2 0 0 irq_thread 0000000000 S irq/306-arm-smm
root 101 2 0 0 irq_thread 0000000000 S irq/315-arm-smm
root 102 2 0 0 rescuer_th 0000000000 S devfreq_wq
root 103 2 0 0 rescuer_th 0000000000 S governor_msm_ad
root 104 2 0 0 worker_thr 0000000000 S kworker/3:1
root 105 2 0 0 rescuer_th 0000000000 S cfg80211
root 106 2 0 0 irq_thread 0000000000 S irq/143-bcl_vba
root 107 2 0 0 irq_thread 0000000000 S irq/142-bcl_iba
root 130 2 0 0 rescuer_th 0000000000 S power_off_alarm
root 131 2 0 0 kswapd 0000000000 S kswapd0
root 132 2 0 0 fsnotify_m 0000000000 S fsnotify_mark
root 133 2 0 0 ecryptfs_t 0000000000 S ecryptfs-kthrea
root 154 2 0 0 rescuer_th 0000000000 S ad_calc_wq
root 155 2 0 0 rescuer_th 0000000000 S rot_commit_work
root 156 2 0 0 rescuer_th 0000000000 S rot_workq_0
root 157 2 0 0 rescuer_th 0000000000 S rot_workq_1
root 158 2 0 0 dsi_event_ 0000000000 D mdss_dsi_event
root 159 2 0 0 rescuer_th 0000000000 S mdss_dsi_dba
root 160 2 0 0 rescuer_th 0000000000 S mdss_dsi_dba
root 161 2 0 0 rescuer_th 0000000000 S hdmi_tx_workq
root 162 2 0 0 rescuer_th 0000000000 S diag_cmd_wq
root 163 2 0 0 rescuer_th 0000000000 S remote_fw_updat
root 164 2 0 0 rescuer_th 0000000000 S wihd_sm_wq
root 165 2 0 0 rescuer_th 0000000000 S mhl_sm_wq
root 166 2 0 0 rescuer_th 0000000000 S diag_sm_wq
root 167 2 0 0 kthread_wo 0000000000 S hdcp_tz_lib
root 168 2 0 0 kthread_wo 0000000000 S hdmi_hdcp2p2
root 169 2 0 0 rescuer_th 0000000000 S glink_ssr_wq
root 170 2 0 0 rescuer_th 0000000000 S glink_lbsrv
root 171 2 0 0 rescuer_th 0000000000 S glink_xprt_wq
root 172 2 0 0 rescuer_th 0000000000 S IPCRTR_mpss_smd
root 173 2 0 0 rescuer_th 0000000000 S IPCRTR_lpass_sm
root 174 2 0 0 rescuer_th 0000000000 S IPCRTR
root 175 2 0 0 rescuer_th 0000000000 S IPCRTR_dsps_smd
root 176 2 0 0 rescuer_th 0000000000 S IPCRTR
root 177 2 0 0 rescuer_th 0000000000 S IPCRTR
root 178 2 0 0 rescuer_th 0000000000 S apr_driver
root 179 2 0 0 rescuer_th 0000000000 S glink_pkt_wq
root 180 2 0 0 rescuer_th 0000000000 S ssr_monitor_wai
root 181 2 0 0 rescuer_th 0000000000 S pacman_qmi_noti
root 182 2 0 0 rescuer_th 0000000000 S pacman_qmi_rx_w
root 183 2 0 0 rescuer_th 0000000000 S qmi_svc_event_w
root 184 2 0 0 rescuer_th 0000000000 S msm_ipc_router
root 185 2 0 0 rescuer_th 0000000000 S k_hsuart
root 186 2 0 0 kthread_wo 0000000000 S msm_serial_hs_0
root 187 2 0 0 kthread_wo 0000000000 S msm_serial_hs_0
root 188 2 0 0 add_hwgene 0000000000 S hwrng
root 190 2 0 0 rescuer_th 0000000000 S diag_real_time_
root 191 2 0 0 rescuer_th 0000000000 S diag_wq
root 192 2 0 0 rescuer_th 0000000000 S DIAG_USB_diag
root 193 2 0 0 rescuer_th 0000000000 S diag_cntl_wq
root 194 2 0 0 rescuer_th 0000000000 S diag_dci_wq
root 195 2 0 0 rescuer_th 0000000000 S DIAG_SMD_MODEM_
root 196 2 0 0 rescuer_th 0000000000 S DIAG_SMD_MODEM_
root 197 2 0 0 rescuer_th 0000000000 S DIAG_SMD_MODEM_
root 198 2 0 0 rescuer_th 0000000000 S DIAG_SMD_MODEM_
root 199 2 0 0 rescuer_th 0000000000 S DIAG_SMD_MODEM_
root 200 2 0 0 rescuer_th 0000000000 S DIAG_SMD_LPASS_
root 201 2 0 0 rescuer_th 0000000000 S DIAG_SMD_LPASS_
root 202 2 0 0 rescuer_th 0000000000 S DIAG_SMD_LPASS_
root 203 2 0 0 rescuer_th 0000000000 S DIAG_SMD_LPASS_
root 204 2 0 0 rescuer_th 0000000000 S DIAG_SMD_LPASS_
root 205 2 0 0 rescuer_th 0000000000 S DIAG_SMD_WCNSS_
root 206 2 0 0 rescuer_th 0000000000 S DIAG_SMD_WCNSS_
root 207 2 0 0 rescuer_th 0000000000 S DIAG_SMD_WCNSS_
root 208 2 0 0 rescuer_th 0000000000 S DIAG_SMD_WCNSS_
root 209 2 0 0 rescuer_th 0000000000 S DIAG_SMD_WCNSS_
root 210 2 0 0 rescuer_th 0000000000 S DIAG_SMD_SENSOR
root 211 2 0 0 rescuer_th 0000000000 S DIAG_SMD_SENSOR
root 212 2 0 0 rescuer_th 0000000000 S DIAG_SMD_SENSOR
root 213 2 0 0 rescuer_th 0000000000 S DIAG_SMD_SENSOR
root 214 2 0 0 rescuer_th 0000000000 S DIAG_SMD_SENSOR
root 215 2 0 0 rescuer_th 0000000000 S DIAG_SOCKMODEM_
root 216 2 0 0 rescuer_th 0000000000 S DIAG_SOCKMODEM_
root 217 2 0 0 rescuer_th 0000000000 S DIAG_SOCKMODEM_
root 218 2 0 0 rescuer_th 0000000000 S DIAG_SOCKMODEM_
root 219 2 0 0 rescuer_th 0000000000 S DIAG_SOCKMODEM_
root 220 2 0 0 rescuer_th 0000000000 S DIAG_SOCKLPASS_
root 221 2 0 0 rescuer_th 0000000000 S DIAG_SOCKLPASS_
root 222 2 0 0 rescuer_th 0000000000 S DIAG_SOCKLPASS_
root 223 2 0 0 rescuer_th 0000000000 S DIAG_SOCKLPASS_
root 224 2 0 0 rescuer_th 0000000000 S DIAG_SOCKLPASS_
root 225 2 0 0 rescuer_th 0000000000 S DIAG_SOCKWCNSS_
root 226 2 0 0 rescuer_th 0000000000 S DIAG_SOCKWCNSS_
root 227 2 0 0 rescuer_th 0000000000 S DIAG_SOCKWCNSS_
root 228 2 0 0 rescuer_th 0000000000 S DIAG_SOCKWCNSS_
root 229 2 0 0 rescuer_th 0000000000 S DIAG_SOCKWCNSS_
root 230 2 0 0 rescuer_th 0000000000 S DIAG_SOCKSENSOR
root 231 2 0 0 rescuer_th 0000000000 S DIAG_SOCKSENSOR
root 232 2 0 0 rescuer_th 0000000000 S DIAG_SOCKSENSOR
root 233 2 0 0 rescuer_th 0000000000 S DIAG_SOCKSENSOR
root 234 2 0 0 rescuer_th 0000000000 S DIAG_SOCKSENSOR
root 235 2 0 0 rescuer_th 0000000000 S DIAG_CNTL_SOCKE
root 236 2 0 0 rescuer_th 0000000000 S kgsl-workqueue
root 237 2 0 0 rescuer_th 0000000000 S kgsl-mementry
root 238 2 0 0 rescuer_th 0000000000 S qcrypto_seq_res
root 259 2 0 0 scsi_error 0000000000 S scsi_eh_0
root 260 2 0 0 rescuer_th 0000000000 S scsi_tmf_0
root 261 2 0 0 rescuer_th 0000000000 S ufs_pm_qos_0
root 262 2 0 0 rescuer_th 0000000000 S ufs_clkscaling_
root 263 2 0 0 kthread_wo 0000000000 S spi0
root 266 2 0 0 kthread_wo 0000000000 S spi11
root 270 2 0 0 diag_socke 0000000000 S kworker/u8:5
root 274 2 0 0 diag_socke 0000000000 S kworker/u8:9
root 275 2 0 0 irq_thread 0000000000 S irq/462-sii6400
root 276 2 0 0 rescuer_th 0000000000 S bond0
root 277 2 0 0 rescuer_th 0000000000 S usbnet
root 278 2 0 0 rescuer_th 0000000000 S sharedmem_qmi_w
root 279 2 0 0 rescuer_th 0000000000 S qmi_hndl0000000
root 280 2 0 0 irq_thread 0000000000 S irq/127-hs_phy_
root 281 2 0 0 irq_thread 0000000000 S irq/128-ss_phy_
root 282 2 0 0 irq_thread 0000000000 S irq/129-msm_dwc
root 283 2 0 0 rescuer_th 0000000000 S k_gserial
root 284 2 0 0 rescuer_th 0000000000 S k_ipa_usb
root 285 2 0 0 rescuer_th 0000000000 S uether
root 286 2 0 0 rescuer_th 0000000000 S k_gbridge
root 287 2 0 0 worker_thr 0000000000 S kworker/3:2
root 288 2 0 0 irq_thread 0000000000 S irq/465-atmel_t
root 289 2 0 0 irq_thread 0000000000 S irq/464-atmel_m
root 290 2 0 0 rescuer_th 0000000000 S msm_vidc_worker
root 291 2 0 0 rescuer_th 0000000000 S pm_workerq_venu
root 292 2 0 0 irq_thread 0000000000 S irq/256-arm-smm
root 293 2 0 0 irq_thread 0000000000 S irq/257-arm-smm
root 294 2 0 0 irq_thread 0000000000 S irq/258-arm-smm
root 295 2 0 0 irq_thread 0000000000 S irq/259-arm-smm
root 296 2 0 0 rescuer_th 0000000000 S msm_cci_wq
root 297 2 0 0 rescuer_th 0000000000 S msm_cci_wq
root 299 2 0 0 worker_thr 0000000000 S kworker/2:2
root 302 2 0 0 worker_thr 0000000000 S kworker/0:1H
root 305 2 0 0 rescuer_th 0000000000 S msm_cpp_workque
root 306 2 0 0 irq_thread 0000000000 S irq/192-batt-mi
root 307 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 308 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 309 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 310 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 311 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 312 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 313 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 314 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 315 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 316 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 317 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 318 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 319 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 320 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 321 2 0 0 irq_thread 0000000000 S irq/202-tsens_i
root 322 2 0 0 irq_thread 0000000000 S irq/203-tsens_c
root 323 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 324 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 325 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 326 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 327 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 328 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 329 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 330 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 331 2 0 0 irq_thread 0000000000 S irq/336-tsens_i
root 332 2 0 0 irq_thread 0000000000 S irq/337-tsens_c
root 333 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 334 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 335 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 336 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 337 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 338 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 339 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 340 2 0 0 rescuer_th 0000000000 S dm_bufio_cache
root 341 2 0 0 cpufreq_in 0000000000 S cfinteractive
root 342 2 0 0 irq_thread 0000000000 S irq/196-qpnp_wl
root 343 2 0 0 rescuer_th 0000000000 S binder
root 344 2 0 0 irq_thread 0000000000 S irq/197-qpnp_sc
root 345 2 0 0 rescuer_th 0000000000 S usb_bam_wq
root 346 2 0 0 irq_thread 0000000000 S irq/10-spdm_bw_
root 347 2 0 0 rescuer_th 0000000000 S soc:audio_etm0
root 348 2 0 0 rescuer_th 0000000000 S soc:rpm_etm0
root 349 2 0 0 rescuer_th 0000000000 S soc:modem_etm0
root 350 2 0 0 worker_thr 0000000000 S kworker/3:3
root 351 2 0 0 rescuer_th 0000000000 S ipv6_addrconf
root 352 2 0 0 rfcomm_run 0000000000 S krfcommd
root 353 2 0 0 irq_thread 0000000000 S irq/654-adsp
root 354 2 0 0 rescuer_th 0000000000 S sysmon_wq
root 355 2 0 0 rescuer_th 0000000000 S adsp
root 356 2 0 0 rescuer_th 0000000000 S sys_mon
root 357 2 0 0 irq_thread 0000000000 S irq/686-slpi
root 358 2 0 0 rescuer_th 0000000000 S slpi
root 359 2 0 0 rescuer_th 0000000000 S sys_mon
root 360 2 0 0 irq_thread 0000000000 S irq/622-modem
root 361 2 0 0 rescuer_th 0000000000 S kgsl-events
root 362 2 0 0 rescuer_th 0000000000 S kgsl_devfreq_wq
root 365 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 366 2 0 0 irq_thread 0000000000 S irq/147-chg-err
root 367 2 0 0 irq_thread 0000000000 S irq/153-chg-tap
root 368 2 0 0 irq_thread 0000000000 S irq/154-chg-tcc
root 369 2 0 0 irq_thread 0000000000 S irq/152-chg-rec
root 370 2 0 0 irq_thread 0000000000 S irq/151-chg-p2f
root 371 2 0 0 irq_thread 0000000000 S irq/155-batt-ho
root 372 2 0 0 irq_thread 0000000000 S irq/156-batt-wa
root 373 2 0 0 irq_thread 0000000000 S irq/158-batt-co
root 374 2 0 0 irq_thread 0000000000 S irq/157-batt-co
root 375 2 0 0 irq_thread 0000000000 S irq/161-batt-mi
root 376 2 0 0 irq_thread 0000000000 S irq/160-batt-lo
root 377 2 0 0 irq_thread 0000000000 S irq/163-usbin-u
root 378 2 0 0 irq_thread 0000000000 S irq/164-usbin-o
root 379 2 0 0 irq_thread 0000000000 S irq/165-usbin-s
root 380 2 0 0 irq_thread 0000000000 S irq/168-aicl-do
root 381 2 0 0 irq_thread 0000000000 S irq/166-otg-fai
root 382 2 0 0 irq_thread 0000000000 S irq/167-otg-oc
root 383 2 0 0 irq_thread 0000000000 S irq/169-usbid-c
root 384 2 0 0 irq_thread 0000000000 S irq/170-dcin-uv
root 385 2 0 0 irq_thread 0000000000 S irq/172-power-o
root 386 2 0 0 irq_thread 0000000000 S irq/173-temp-sh
root 387 2 0 0 irq_thread 0000000000 S irq/174-wdog-ti
root 388 2 0 0 rescuer_th 0000000000 S lk_wq
root 389 2 0 0 rescuer_th 0000000000 S rq_stats
root 390 2 0 0 events_not 0000000000 S msm_perf:events
root 391 2 0 0 irq_thread 0000000000 S irq/283-arm-smm
root 392 2 0 0 irq_thread 0000000000 S irq/284-arm-smm
root 393 2 0 0 irq_thread 0000000000 S irq/285-arm-smm
root 394 2 0 0 irq_thread 0000000000 S irq/286-arm-smm
root 395 2 0 0 irq_thread 0000000000 S irq/287-arm-smm
root 396 2 0 0 irq_thread 0000000000 S irq/288-arm-smm
root 397 2 0 0 irq_thread 0000000000 S irq/289-arm-smm
root 398 2 0 0 irq_thread 0000000000 S irq/290-arm-smm
root 399 2 0 0 rescuer_th 0000000000 S sb-1
root 400 2 0 0 ngd_slim_r 0000000000 D ngd_rx_thread1
root 401 2 0 0 ngd_notify 0000000000 D ngd_notify_sl1
root 402 2 0 0 rescuer_th 0000000000 S k_bam_data
root 403 2 0 0 rescuer_th 0000000000 S f_mtp
root 404 2 0 0 worker_thr 0000000000 S kworker/1:1H
root 405 2 0 0 do_samplin 0000000000 D msm-core:sampli
root 406 2 0 0 do_hotplug 0000000000 S msm_thermal:hot
root 407 2 0 0 do_freq_mi 0000000000 S msm_thermal:fre
root 408 2 0 0 do_thermal 0000000000 S msm_thermal:the
root 409 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 410 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 411 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 412 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 413 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 414 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 415 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 416 2 0 0 sensor_sys 0000000000 S therm_core:noti
root 417 2 0 0 irq_thread 0000000000 S irq/218-lmh-int
root 418 2 0 0 boost_mig_ 0000000000 S boost_sync/0
root 419 2 0 0 boost_mig_ 0000000000 S boost_sync/1
root 420 2 0 0 boost_mig_ 0000000000 S boost_sync/2
root 421 2 0 0 boost_mig_ 0000000000 S boost_sync/3
root 422 2 0 0 rescuer_th 0000000000 S ipa_A7_svc
root 423 2 0 0 rescuer_th 0000000000 S qmi_hndl0000000
root 424 2 0 0 rescuer_th 0000000000 S clnt_req
root 425 2 0 0 rescuer_th 0000000000 S clnt_resp
root 426 2 0 0 rescuer_th 0000000000 S clnt_req
root 427 1 4520 1068 poll_sched 0000000000 S /sbin/ueventd
root 429 2 0 0 kjournald2 0000000000 S jbd2/sde19-8
root 430 2 0 0 rescuer_th 0000000000 S ext4-rsv-conver
root 433 2 0 0 worker_thr 0000000000 S kworker/3:1H
root 435 2 0 0 kjournald2 0000000000 S jbd2/sda9-8
root 436 2 0 0 rescuer_th 0000000000 S ext4-rsv-conver
root 438 2 0 0 kjournald2 0000000000 S jbd2/sda3-8
root 439 2 0 0 rescuer_th 0000000000 S ext4-rsv-conver
root 440 2 0 0 kjournald2 0000000000 S jbd2/sda2-8
root 441 2 0 0 rescuer_th 0000000000 S ext4-rsv-conver
root 442 2 0 0 kjournald2 0000000000 S jbd2/sde13-8
root 443 2 0 0 rescuer_th 0000000000 S ext4-rsv-conver
logd 444 1 13144 3300 sigsuspend 0000000000 S /system/bin/logd
root 449 1 15088 3016 hrtimer_na 0000000000 S /system/bin/vold
root 455 2 0 0 rescuer_th 0000000000 S lpass_IPCRTR
root 456 2 0 0 rescuer_th 0000000000 S LOOPBACK
root 457 2 0 0 rescuer_th 0000000000 S qmi_hndl0000000
root 458 2 0 0 rescuer_th 0000000000 S qmi_hndl0000000
root 459 2 0 0 kthread_wo 0000000000 S msm_slim_qmi_cl
root 460 2 0 0 rescuer_th 0000000000 S qmi_hndl0000000
root 461 2 0 0 irq_thread 0000000000 S irq/291-arm-smm
root 463 2 0 0 rescuer_th 0000000000 S dsps_IPCRTR
root 470 2 0 0 rescuer_th 0000000000 S qmi_hndl0000000
root 471 2 0 0 rescuer_th 0000000000 S qmi_hndl0000000
root 492 2 0 0 irq_thread 0000000000 S irq/393-wcd9xxx
root 510 2 0 0 rescuer_th 0000000000 S tfa98xx
root 524 1 4272 528 SyS_epoll_ 0000000000 S /sbin/healthd
root 525 1 6396 1236 SyS_epoll_ 0000000000 S /system/bin/lmkd
system 526 1 6272 1472 binder_thr 0000000000 S /system/bin/servicemanager
nobody 530 1 13632 1604 poll_sched 0000000000 S /system/bin/rmt_storage
system 534 1 18416 2060 do_sigtime 0000000000 S system/bin/pm-service
system 536 1 23048 3492 do_wait 0000000000 S /system/bin/qseecomd
shell 546 1 6076 1532 n_tty_read 7f7b50de3c S /system/bin/sh
root 548 1 3188 1124 __skb_recv 0000000000 S /system/bin/debuggerd
drm 551 1 18340 5692 binder_thr 0000000000 S /system/bin/drmserver
media 552 1 147268 23352 binder_thr 0000000000 S /system/bin/mediaserver
root 554 1 6376 1804 unix_strea 0000000000 S /system/bin/installd
keystore 562 1 10936 2568 binder_thr 0000000000 S /system/bin/keystore
root 572 1 14284 2484 poll_sched 0000000000 S /system/bin/qcom-system-daemon
rfs 574 1 7488 1620 poll_sched 0000000000 S /system/bin/tftp_server
system 581 1 23848 7736 binder_thr 0000000000 S /system/bin/wfdservice
root 582 1 105660 3268 sigsuspend 0000000000 S /system/vendor/bin/thermal-engine
media 583 1 8060 1240 poll_sched 0000000000 S /system/bin/adsprpcd
system 585 1 10644 1796 poll_sched 0000000000 S /system/bin/imsqmidaemon
system 588 1 6596 1432 SyS_epoll_ 0000000000 S /system/bin/hvdcp_opti
root 596 1 3760 140 poll_sched 0000000000 S /system/bin/sw_coredump
root 597 1 2086020 66988 poll_sched 0000000000 S zygote64
root 598 1 1506028 55296 poll_sched 0000000000 S zygote
system 599 1 10256 2336 binder_thr 0000000000 S /system/bin/gatekeeperd
root 615 1 6088 1296 hrtimer_na 0000000000 S /system/xbin/perfprofd
system 620 1 72752 16368 SyS_epoll_ 0000000000 S /system/bin/cnd
root 621 1 12988 2132 unix_strea 0000000000 S /system/bin/dpmd
system 629 1 12904 2044 __skb_recv 0000000000 S /system/bin/cnss-daemon
gps 630 1 8064 1536 sigsuspend 0000000000 S /system/bin/loc_launcher
system 648 1 16864 2060 futex_wait 0000000000 S /system/bin/ATFWD-daemon
system 694 1 62876 13852 binder_thr 0000000000 S /system/vendor/bin/qseeproxydaemon
camera 695 1 86364 26712 poll_sched 0000000000 S /system/bin/mm-qcamera-daemon
system 696 1 65260 14388 binder_thr 0000000000 S /system/bin/fingerprintd
system 697 1 69120 14648 binder_thr 0000000000 S /system/bin/qfp-daemon
system 710 1 61776 13900 sigsuspend 0000000000 S /system/bin/qvop-daemon
system 711 1 15264 2224 futex_wait 0000000000 S /system/bin/time_daemon
system 712 1 28744 6580 binder_thr 0000000000 S /system/bin/audiod
gps 718 630 15268 2048 futex_wait 0000000000 S lowi-server
gps 719 630 23684 1788 futex_wait 0000000000 S xtwifi-inet-agent
gps 721 630 26364 3972 poll_sched 0000000000 S slim_daemon
system 723 1 13460 2224 futex_wait 0000000000 S /system/bin/tloc_daemon
system 724 1 12592 1996 binder_thr 0000000000 S /system/vendor/bin/mdtp_service
sensors 725 1 61100 3020 poll_sched 0000000000 S /system/bin/sensors.qcom
system 726 1 65740 14204 poll_sched 0000000000 S /system/bin/mm-pp-dpps
system 727 1 11748 1812 hrtimer_na 0000000000 S /system/bin/pm-proxy
shell 728 1 8928 788 poll_sched 0000000000 S /sbin/adbd
system 733 621 18376 2928 SyS_epoll_ 0000000000 S /system/bin/dpmd
system 772 536 32264 2192 sigsuspend 0000000000 S /system/bin/qseecomd
radio 783 1 13064 2268 poll_sched 0000000000 S /system/bin/qmuxd
system 827 1 9364 1412 poll_sched 0000000000 S /system/bin/ipacm-diag
root 830 2 0 0 irq_thread 0000000000 S irq/246-arm-smm
root 831 2 0 0 irq_thread 0000000000 S irq/247-arm-smm
system 833 1 14696 2428 poll_sched 0000000000 S /system/bin/imsdatadaemon
root 838 2 0 0 worker_thr 0000000000 S kworker/3:2H
root 846 2 0 0 rescuer_th 0000000000 S qmi_hndl0000000
net_admin 849 1 14772 2292 futex_wait 0000000000 S /system/bin/ipacm
radio 980 1 14752 1880 poll_sched 0000000000 S /system/vendor/bin/qti
radio 989 1 58864 4176 __skb_recv 0000000000 S /system/bin/netmgrd
root 995 1 10156 1412 futex_wait 0000000000 S /system/bin/port-bridge
root 1002 2 0 0 rescuer_th 0000000000 S DS
root 1035 2 0 0 rescuer_th 0000000000 S mpss_IPCRTR
root 1036 2 0 0 rescuer_th 0000000000 S LOOPBACK
root 1043 2 0 0 rescuer_th 0000000000 S SSM_RTR_MODEM_A
root 1050 2 0 0 rescuer_th 0000000000 S qmi_hndl0000000
root 1069 2 0 0 rescuer_th 0000000000 S qmi_hndl0000000
root 1071 2 0 0 irq_thread 0000000000 S irq/268-arm-smm
root 1072 2 0 0 irq_thread 0000000000 S irq/273-arm-smm
root 1073 2 0 0 irq_thread 0000000000 S irq/269-arm-smm
root 1075 2 0 0 irq_thread 0000000000 S irq/274-arm-smm
root 1132 2 0 0 rescuer_th 0000000000 S DATA1
root 1134 2 0 0 rescuer_th 0000000000 S DATA2
root 1135 2 0 0 rescuer_th 0000000000 S DATA3
root 1136 2 0 0 rescuer_th 0000000000 S DATA4
root 1137 2 0 0 rescuer_th 0000000000 S DATA11
system 1491 597 2303216 123104 SyS_epoll_ 0000000000 S system_server
root 1722 2 0 0 rescuer_th 0000000000 S ipawq48
root 1723 2 0 0 rescuer_th 0000000000 S iparepwq48
media_rw 2070 449 9336 2040 inotify_re 0000000000 S /system/bin/sdcard
u0_a8 2082 597 1573984 43576 SyS_epoll_ 0000000000 S android.process.media
u0_a21 2097 597 1679076 112844 SyS_epoll_ 0000000000 S com.android.systemui
root 2226 2 0 0 worker_thr 0000000000 S kworker/0:2H
ese 2587 597 1571528 35840 SyS_epoll_ 0000000000 S com.nxp.spi
radio 2598 597 1568004 32192 SyS_epoll_ 0000000000 S com.qualcomm.qti.rcsbootstraputil
system 2622 597 1574156 43684 SyS_epoll_ 0000000000 S com.dolby
system 2657 597 1569556 35816 SyS_epoll_ 0000000000 S com.qualcomm.qti.services.secureui:sui_service
system 2698 597 1569804 36668 SyS_epoll_ 0000000000 S com.letv.bsp.qccrashhandler
u0_a10 2730 597 1622056 87128 SyS_epoll_ 0000000000 S com.android.launcher
u0_a3 2836 597 1577484 43168 SyS_epoll_ 0000000000 S android.process.acore
root 2921 2 0 0 worker_thr 0000000000 S kworker/2:2H
u0_a88 2949 598 1009324 33604 SyS_epoll_ 0000000000 S com.baidu.appsearch:bdservice_v1
u0_a74 2982 597 1567060 32976 SyS_epoll_ 0000000000 S com.android.smspush
u0_a88 3063 598 1075900 66384 SyS_epoll_ 0000000000 S com.baidu.appsearch
u0_a34 3091 597 1575096 39588 SyS_epoll_ 0000000000 S com.android.deskclock
u0_a5 3304 597 1567412 34356 SyS_epoll_ 0000000000 S com.android.cellbroadcastreceiver
u0_a32 3318 597 1567164 32940 SyS_epoll_ 0000000000 S com.qti.cbwidget
root 3361 2 0 0 irq_thread 0000000000 S irq/21-408000.q
root 3416 1 10456 1356 futex_wait 0000000000 S /system/vendor/bin/perfd
root 3424 2 0 0 notify_use 0000000000 S wrkld_notify
system 3443 597 1569532 34792 SyS_epoll_ 0000000000 S com.qti.diagservices
u0_a12 3522 597 1579040 41368 SyS_epoll_ 0000000000 S com.android.mms
root 3567 2 0 0 diag_socke 0000000000 S kworker/u8:10
system 3570 597 1575884 36628 SyS_epoll_ 0000000000 S com.qualcomm.qti.tetherservice
u0_a30 3615 597 1582940 38244 SyS_epoll_ 0000000000 S com.android.calendar
u0_a36 3641 597 1588856 43028 SyS_epoll_ 0000000000 S com.android.email
root 3707 2 0 0 worker_thr 0000000000 S kworker/2:4
system 3723 597 1568160 35200 SyS_epoll_ 0000000000 S com.qualcomm.qualcommsettings
root 3769 2 0 0 worker_thr 0000000000 S kworker/u8:12
root 3771 2 0 0 worker_thr 0000000000 S kworker/u8:13
smartcard 3773 597 1569768 36460 SyS_epoll_ 0000000000 S org.simalliance.openmobileapi.service:remote
system 3858 597 1569620 34948 SyS_epoll_ 0000000000 S com.qualcomm.telephony
root 3865 2 0 0 worker_thr 0000000000 S kworker/0:4
u0_a78 3876 597 1566968 33856 SyS_epoll_ 0000000000 S com.quicinc.wipoweragent
u0_a13 4064 597 1567184 34140 SyS_epoll_ 0000000000 S com.android.musicfx
u0_a61 4115 597 1566944 32972 SyS_epoll_ 0000000000 S com.svox.pico
root 4510 2 0 0 worker_thr 0000000000 S kworker/u8:4
root 4528 2 0 0 worker_thr 0000000000 S kworker/1:3
root 4568 2 0 0 worker_thr 0000000000 S kworker/u8:6
root 4569 2 0 0 worker_thr 0000000000 S kworker/3:4
root 4572 2 0 0 worker_thr 0000000000 S kworker/1:2
root 4591 2 0 0 worker_thr 0000000000 S kworker/0:2
root 4594 2 0 0 worker_thr 0000000000 S kworker/2:0
root 4596 2 0 0 worker_thr 0000000000 S kworker/2:1
root 4629 2 0 0 worker_thr 0000000000 S kworker/2:3
root 4844 2 0 0 worker_thr 0000000000 S kworker/1:4
root 4854 2 0 0 worker_thr 0000000000 S kworker/u8:7
root 4861 2 0 0 diag_socke 0000000000 S kworker/u8:11
root 4863 2 0 0 worker_thr 0000000000 S kworker/u8:15
root 4864 2 0 0 worker_thr 0000000000 S kworker/u8:16
root 4865 2 0 0 worker_thr 0000000000 S kworker/u8:17
root 4890 2 0 0 worker_thr 0000000000 S kworker/0:3
root 4891 2 0 0 worker_thr 0000000000 S kworker/u8:18
root 4918 2 0 0 worker_thr 0000000000 S kworker/0:5
root 4919 2 0 0 worker_thr 0000000000 S kworker/0:6
root 4974 2 0 0 worker_thr 0000000000 S kworker/3:5
root 4975 2 0 0 worker_thr 0000000000 S kworker/3:6
root 4976 2 0 0 worker_thr 0000000000 S kworker/3:7
root 5008 2 0 0 diag_socke 0000000000 S kworker/u8:8
root 5015 2 0 0 worker_thr 0000000000 S kworker/2:5
root 5016 2 0 0 worker_thr 0000000000 S kworker/2:6
root 5017 2 0 0 worker_thr 0000000000 S kworker/2:7
root 5042 2 0 0 worker_thr 0000000000 S kworker/0:7
root 5079 2 0 0 worker_thr 0000000000 S kworker/0:8
u0_a89 5704 597 1577084 40432 ptrace_sto 0000000000 t com.sysprogs.AndroidAutoTest
root 5724 1 12832 2796 futex_wait 0000000000 S /system/bin/iop
u0_a89 5730 728 3140 528 poll_sched 0000000000 S /data/app/com.sysprogs.AndroidAutoTest-1/lib/arm64/gdbserver
u0_a1 5749 597 1575208 39172 SyS_epoll_ 0000000000 S com.letv.bugpostbox
root 5754 1 6320 1304 hrtimer_na 0000000000 S /system/bin/letv_log_collector
shell 5798 728 6008 1260 0 7f7b11ae3c R ps
root 5801 5754 7916 1592 binder_thr 0000000000 S /system/bin/dumpsys
C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s 9416189d shell id
uid=2000(shell) gid=2000(shell) groups=2000(shell),1004(input),1007(log),1011(adb),1015(sdcard_rw),1028(sdcard_r),3001(net_bt_admin),3002(net_bt),3003(inet),3006(net_bw_stats) context=u:r:shell:s0Command exited with code 0
C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s 9416189d shell run-as com.sysprogs.AndroidAutoTest kill -9 5730
C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s 9416189d shell run-as com.sysprogs.AndroidAutoTest kill -9 5704
C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s 9416189d install -r “C:\Users\zl121\AppData\Local\Temp\SysprogsAndroidTest-10484\4.9\bin\SysprogsAndroidAutoTest-debug.apk”
pkg: /data/local/tmp/SysprogsAndroidAutoTest-debug.apkSuccess
2141 KB/s (400964 bytes in 0.182s)
C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s 9416189d shell run-as com.sysprogs.AndroidAutoTest /system/bin/sh -c pwd
/data/data/com.sysprogs.AndroidAutoTestCommand exited with code 0
C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s 9416189d shell getprop ro.product.cpu.abi
arm64-v8aCommand exited with code 0
C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s 9416189d shell getprop ro.build.version.sdk
23Command exited with code 0
C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s 9416189d shell ls /data/data/com.sysprogs.AndroidAutoTest/lib
/data/data/com.sysprogs.AndroidAutoTest/lib: No such file or directoryCommand exited with code 0
C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s 9416189d shell pm list packages -f
package:/system/priv-app/FMRadio/FMRadio.apk=com.android.fmradiopackage:/system/app/LetvFuseWire/LetvFuseWire.apk=com.letv.android.FuseWire
package:/system/app/RootPA/RootPA.apk=com.gd.mobicore.pa
package:/system/app/SampleExtAuthService/SampleExtAuthService.apk=com.qualcomm.qti.auth.sampleextauthservice
package:/system/priv-app/TelephonyProvider/TelephonyProvider.apk=com.android.providers.telephony
package:/system/app/UICC_eSE/UICC_eSE.apk=com.nxp.uiccese
package:/system/app/imsTests/imsTests.apk=com.qualcomm.ims.tests
package:/system/app/wipowerservice/wipowerservice.apk=org.codeaurora.bt_wipowersdk
package:/system/priv-app/CalendarProvider/CalendarProvider.apk=com.android.providers.calendar
package:/system/priv-app/MediaProvider/MediaProvider.apk=com.android.providers.media
package:/system/app/colorservice/colorservice.apk=com.qti.service.colorservice
package:/system/app/ModemTestMode/ModemTestMode.apk=com.qualcomm.qti.modemtestmode
package:/system/app/shutdownlistener/shutdownlistener.apk=com.qualcomm.shutdownlistner
package:/system/priv-app/WallpaperCropper/WallpaperCropper.apk=com.android.wallpapercropper
package:/system/priv-app/CNEService/CNEService.apk=com.quicinc.cne.CNEService
package:/system/app/com.qualcomm.qti.auth.fidocryptosample/com.qualcomm.qti.auth.fidocryptosample.apk=com.qualcomm.qti.auth.fidocryptosample
package:/system/app/Protips/Protips.apk=com.android.protips
package:/system/priv-app/Launcher2/Launcher2.apk=com.android.launcher
package:/system/app/SmartcardService/SmartcardService.apk=org.simalliance.openmobileapi.service
package:/system/vendor/app/DsUI/DsUI.apk=com.dolby.daxappUI
package:/system/app/QVTester/QVTester.apk=com.qualcomm.location.qvtester
package:/system/app/DocumentsUI/DocumentsUI.apk=com.android.documentsui
package:/system/app/Galaxy4/Galaxy4.apk=com.android.galaxy4
package:/system/priv-app/ExternalStorageProvider/ExternalStorageProvider.apk=com.android.externalstorage
package:/system/app/uimremoteclient/uimremoteclient.apk=com.qualcomm.uimremoteclient
package:/system/app/HTMLViewer/HTMLViewer.apk=com.android.htmlviewer
package:/system/app/FTMMode/FTMMode.apk=com.qualcomm.ftm
package:/system/app/StaProxyService/StaProxyService.apk=com.qualcomm.sta
package:/system/app/QuickSearchBox/QuickSearchBox.apk=com.android.quicksearchbox
package:/system/priv-app/MmsService/MmsService.apk=com.android.mms.service
package:/system/priv-app/DownloadProvider/DownloadProvider.apk=com.android.providers.downloads
package:/system/app/SampleAuthenticatorService/SampleAuthenticatorService.apk=com.qualcomm.qti.auth.sampleauthenticatorservice
package:/system/app/QCap/QCap.apk=com.qualcomm.qti.biometrics.fingerprint.qcap
package:/system/app/HiddTestApp/HiddTestApp.apk=org.codeaurora.bluetooth.hiddtestapp
package:/system/vendor/app/SecProtect/SecProtect.apk=com.qapp.secprotect
package:/system/app/QtiTelephonyService/QtiTelephonyService.apk=com.qualcomm.qti.telephonyservice
package:/system/app/BTTestApp/BTTestApp.apk=org.codeaurora.bluetooth.bttestapp
package:/system/app/FidoCryptoService/FidoCryptoService.apk=com.qualcomm.qti.auth.fidocryptoservice
package:/system/priv-app/SoundRecorder/SoundRecorder.apk=com.android.soundrecorder
package:/system/app/WiHDSampleApp/WiHDSampleApp.apk=com.letv.wihd.sample
package:/system/app/uimremoteserver/uimremoteserver.apk=com.qualcomm.uimremoteserver
package:/system/priv-app/DefaultContainerService/DefaultContainerService.apk=com.android.defcontainer
package:/system/app/DownloadProviderUi/DownloadProviderUi.apk=com.android.providers.downloads.ui
package:/system/app/PacProcessor/PacProcessor.apk=com.android.pacprocessor
package:/system/app/CertInstaller/CertInstaller.apk=com.android.certinstaller
package:/system/priv-app/CarrierConfig/CarrierConfig.apk=com.android.carrierconfig
package:/system/app/BluetoothExt/BluetoothExt.apk=org.codeaurora.bluetooth
package:/system/app/datastatusnotification/datastatusnotification.apk=com.qti.qualcomm.datastatusnotification
package:/system/framework/framework-res.apk=android
package:/system/priv-app/Contacts/Contacts.apk=com.android.contacts
package:/system/app/LetvCamera/LetvCamera.apk=com.android.camera2
package:/system/app/WfdService/WfdService.apk=com.qualcomm.wfd.service
package:/system/app/a4wpservice/a4wpservice.apk=org.codeaurora.bt_wipower
package:/system/app/VoicePrintDemo/VoicePrintDemo.apk=com.qualcomm.qti.biometrics.voiceprint.voiceprintdemo
package:/system/app/QtiGbaAuthService/QtiGbaAuthService.apk=com.qualcomm.qti.GBAHttpAuthentication.auth
package:/system/priv-app/Mms/Mms.apk=com.android.mms
package:/system/app/NfcNci/NfcNci.apk=com.android.nfc
package:/system/app/Stk/Stk.apk=com.android.stk
package:/system/priv-app/BackupRestoreConfirmation/BackupRestoreConfirmation.apk=com.android.backupconfirm
package:/system/app/EseSpi/EseSpi.apk=com.nxp.spi
package:/system/app/SenseID-M/SenseID-M.apk=com.qualcomm.qti.biometrics.fingerprint.senseidm
package:/system/app/CNESettings/CNESettings.apk=com.quicinc.cne.settings
package:/system/app/Provision/Provision.apk=com.android.provision
package:/system/app/BTLogKit/BTLogKit.apk=com.android.qlogging
package:/system/app/radioconfig/radioconfig.apk=com.qualcomm.qti.radioconfiginterface
package:/system/vendor/app/ims/ims.apk=org.codeaurora.ims
package:/system/priv-app/StatementService/StatementService.apk=com.android.statementservice
package:/system/app/HoloSpiralWallpaper/HoloSpiralWallpaper.apk=com.android.wallpaper.holospiral
package:/system/app/Calendar/Calendar.apk=com.android.calendar
package:/system/app/PhaseBeam/PhaseBeam.apk=com.android.phasebeam
package:/system/app/SecureExtAuthService/SecureExtAuthService.apk=com.qualcomm.qti.auth.secureextauthservice
package:/system/app/PrimaryCardController/PrimaryCardController.apk=com.qti.primarycardcontroller
package:/system/priv-app/qcrilmsgtunnel/qcrilmsgtunnel.apk=com.qualcomm.qcrilmsgtunnel
package:/system/priv-app/SettingsProvider/SettingsProvider.apk=com.android.providers.settings
package:/system/priv-app/SharedStorageBackup/SharedStorageBackup.apk=com.android.sharedstoragebackup
package:/system/app/PrintSpooler/PrintSpooler.apk=com.android.printspooler
package:/system/app/MdtpDemo/MdtpDemo.apk=com.qualcomm.qti.securemsm.mdtp.MdtpDemo
package:/system/app/BasicDreams/BasicDreams.apk=com.android.dreams.basic
package:/system/app/telresources/telresources.apk=com.android.frameworks.telresources
package:/data/app/com.baidu.appsearch-1/base.apk=com.baidu.appsearch
package:/system/app/webview/webview.apk=com.android.webview
package:/system/priv-app/InputDevices/InputDevices.apk=com.android.inputdevices
package:/system/app/QFingerprintService/QFingerprintService.apk=com.qualcomm.qti.biometrics.fingerprint.service
package:/system/app/SecureSampleAuthService/SecureSampleAuthService.apk=com.qualcomm.qti.auth.securesampleauthservice
package:/system/app/xdivert/xdivert.apk=com.qti.xdivert
package:/system/priv-app/MusicFX/MusicFX.apk=com.android.musicfx
package:/system/app/WfdClient/WfdClient.apk=com.qualcomm.wfd.client
package:/system/priv-app/BugPostbox/BugPostbox.apk=com.letv.bugpostbox
package:/system/priv-app/CellBroadcastReceiver/CellBroadcastReceiver.apk=com.android.cellbroadcastreceiver
package:/system/priv-app/OneTimeInitializer/OneTimeInitializer.apk=com.android.onetimeinitializer
package:/system/app/DeviceInfo/DeviceInfo.apk=com.android.qrd.engineeringmode
package:/system/priv-app/Telecom/Telecom.apk=com.android.server.telecom
package:/system/app/KeyChain/KeyChain.apk=com.android.keychain
package:/system/app/RCSBootstraputil/RCSBootstraputil.apk=com.qualcomm.qti.rcsbootstraputil
package:/system/priv-app/Dialer/Dialer.apk=com.android.dialer
package:/system/app/Gallery2/Gallery2.apk=com.android.gallery3d
package:/system/priv-app/CallLogBackup/CallLogBackup.apk=com.android.calllogbackup
package:/system/app/QFPCalibration/QFPCalibration.apk=com.qualcomm.qti.biometrics.fingerprint.qfpcalibration
package:/system/priv-app/PackageInstaller/PackageInstaller.apk=com.android.packageinstaller
package:/system/app/PicoTts/PicoTts.apk=com.svox.pico
package:/system/app/AntHalService/AntHalService.apk=com.dsi.ant.server
package:/system/priv-app/ProxyHandler/ProxyHandler.apk=com.android.proxyhandler
package:/system/app/LatinIME/LatinIME.apk=com.android.inputmethod.latin
package:/system/app/BTLogSave/BTLogSave.apk=org.codeaurora.bluetooth.btlogsave
package:/system/app/QtiBackupAgent/QtiBackupAgent.apk=com.qti.backupagent
package:/system/app/EmbmsTestApp/EmbmsTestApp.apk=com.qualcomm.embmstest
package:/system/priv-app/ManagedProvisioning/ManagedProvisioning.apk=com.android.managedprovisioning
package:/system/app/PhotoTable/PhotoTable.apk=com.android.dreams.phototable
package:/system/app/ODLT/ODLT.apk=com.qualcomm.qct.dlt
package:/system/app/CellBroadcastWidget/CellBroadcastWidget.apk=com.qti.cbwidget
package:/system/app/LetvDebugUtil/LetvDebugUtil.apk=com.letv.android.DebugUtils
package:/system/app/WiHDService/WiHDService.apk=com.letv.wihd
package:/system/app/NoiseField/NoiseField.apk=com.android.noisefield
package:/system/app/IRTest/IRTest.apk=com.irtest.letv
package:/system/app/WAPPushManager/WAPPushManager.apk=com.android.smspush
package:/system/app/LiveWallpapersPicker/LiveWallpapersPicker.apk=com.android.wallpaper.livepicker
package:/system/priv-app/Tag/Tag.apk=com.android.apps.tag
package:/system/app/SeempService/SeempService.apk=com.qualcomm.qti.seemp.service
package:/system/vendor/app/QDCMMobileApp/QDCMMobileApp.apk=com.qti.snapdragon.qdcm_mobile
package:/system/vendor/app/Ds/Ds.apk=com.dolby
package:/system/app/FactoryMode/FactoryMode.apk=com.letv.factorymode
package:/system/app/LetvStateInfo/LetvStateInfo.apk=com.letv.android.StateInfo
package:/system/app/SenseID/SenseID.apk=com.qualcomm.qti.biometrics.fingerprint.qfpmanager.debug
package:/system/app/OpenWnn/OpenWnn.apk=jp.co.omronsoft.openwnn
package:/system/priv-app/Settings/Settings.apk=com.android.settings
package:/system/priv-app/QtiMmsTestApp/QtiMmsTestApp.apk=com.qualcomm.qti.app
package:/system/vendor/app/imssettings/imssettings.apk=com.qualcomm.qti.ims
package:/system/app/com.quicinc.wbcserviceapp/com.quicinc.wbcserviceapp.apk=com.quicinc.wbcserviceapp
package:/system/app/ExactCalculator/ExactCalculator.apk=com.android.calculator2
package:/system/priv-app/com.qualcomm.location/com.qualcomm.location.apk=com.qualcomm.location
package:/system/app/com.quicinc.wipoweragent/com.quicinc.wipoweragent.apk=com.quicinc.wipoweragent
package:/system/priv-app/QtiTetherService/QtiTetherService.apk=com.qualcomm.qti.tetherservice
package:/system/app/FM2/FM2.apk=com.caf.fmradio
package:/system/app/MdtpService/MdtpService.apk=com.qualcomm.qti.securemsm.mdtp
package:/system/app/QTIDiagServices/QTIDiagServices.apk=com.qti.diagservices
package:/system/app/LiveWallpapers/LiveWallpapers.apk=com.android.wallpaper
package:/system/app/com.qualcomm.qti.services.secureui/com.qualcomm.qti.services.secureui.apk=com.qualcomm.qti.services.secureui
package:/system/priv-app/VpnDialogs/VpnDialogs.apk=com.android.vpndialogs
package:/system/app/UltrasoundSettings/UltrasoundSettings.apk=com.android.ultrasound
package:/system/app/Email/Email.apk=com.android.email
package:/system/app/Music/Music.apk=com.android.music
package:/system/priv-app/TeleService/TeleService.apk=com.android.phone
package:/system/priv-app/Shell/Shell.apk=com.android.shell
package:/system/app/SnapdragonCamera/SnapdragonCamera.apk=org.codeaurora.snapcam
package:/system/app/UserDictionaryProvider/UserDictionaryProvider.apk=com.android.providers.userdictionary
package:/system/priv-app/FusedLocation/FusedLocation.apk=com.android.location.fused
package:/system/app/DeskClock/DeskClock.apk=com.android.deskclock
package:/system/priv-app/SystemUI/SystemUI.apk=com.android.systemui
package:/system/app/Exchange2/Exchange2.apk=com.android.exchange
package:/data/app/com.sysprogs.AndroidAutoTest-2/base.apk=com.sysprogs.AndroidAutoTest
package:/system/priv-app/QcCrashHandler/QcCrashHandler.apk=com.letv.bsp.qccrashhandler
package:/system/app/BluetoothMidiService/BluetoothMidiService.apk=com.android.bluetoothmidiservice
package:/data/app/com.nd.assistance-1/base.apk=com.nd.assistance
package:/system/app/NetworkSetting/NetworkSetting.apk=com.qualcomm.qti.networksetting
package:/system/app/fastdormancy/fastdormancy.apk=com.qualcomm.fastdormancy
package:/system/app/MultiplePdpTest/MultiplePdpTest.apk=com.android.MultiplePdpTest
package:/system/app/FidoSuiService/FidoSuiService.apk=com.qualcomm.qti.auth.fidosuiservice
package:/system/app/QualcommSettings/QualcommSettings.apk=com.qualcomm.qualcommsettings
package:/system/app/VoicePrintService/VoicePrintService.apk=com.qualcomm.qti.biometrics.voiceprint.service
package:/system/app/Bluetooth/Bluetooth.apk=com.android.bluetooth
package:/system/app/TimeService/TimeService.apk=com.qualcomm.timeservice
package:/system/vendor/app/NativeAudioLatency/NativeAudioLatency.apk=com.android.nativeaudiolatency
package:/system/app/atfwd/atfwd.apk=com.qualcomm.atfwd
package:/system/app/embms/embms.apk=com.qualcomm.embms
package:/system/priv-app/ContactsProvider/ContactsProvider.apk=com.android.providers.contacts
package:/system/app/CaptivePortalLogin/CaptivePortalLogin.apk=com.android.captiveportallogin
package:/system/vendor/app/QSensorTest/QSensorTest.apk=com.qualcomm.qti.sensors.qsensortest
C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s 9416189d shell ls /data/app/com.sysprogs.AndroidAutoTest-2/lib/arm64-v8a
/data/app/com.sysprogs.AndroidAutoTest-2/lib/arm64-v8a: No such file or directoryCommand exited with code 0
gdbserverlibfirst.so
libsecond.so
C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s 9416189d shell am start -n com.sysprogs.AndroidAutoTest/.SysprogsAndroidAutoTest
Starting: Intent { cmp=com.sysprogs.AndroidAutoTest/.SysprogsAndroidAutoTest }Command exited with code 0
C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s 9416189d shell ls /data/app/com.sysprogs.AndroidAutoTest-2/lib/arm64/gdbserver
/data/app/com.sysprogs.AndroidAutoTest-2/lib/arm64/gdbserverCommand exited with code 0
system 527 1 220380 23412 SyS_epoll_ 0000000000 S /system/bin/surfaceflinger
root 547 1 19728 2508 hrtimer_na 0000000000 S /system/bin/netd
root 549 1 7908 2424 __skb_recv 0000000000 S /system/bin/debuggerd64
radio 550 1 89812 13276 hrtimer_na 0000000000 S /system/bin/rild
root 597 1 2086020 67000 poll_sched 0000000000 S zygote64
shell 728 1 7888 716 poll_sched 0000000000 S /sbin/adbd
radio 975 1 88260 13320 hrtimer_na 0000000000 S /system/bin/rild
system 1491 597 2304288 123340 SyS_epoll_ 0000000000 S system_server
u0_a21 2097 597 1679076 112500 SyS_epoll_ 0000000000 S com.android.systemui
u0_a47 2526 597 1583448 46744 SyS_epoll_ 0000000000 S com.android.inputmethod.latin
system 2562 597 1573704 36988 SyS_epoll_ 0000000000 S com.quicinc.cne.CNEService
nfc 2578 597 1571144 43340 SyS_epoll_ 0000000000 S com.android.nfc
system 2641 597 1569596 35040 SyS_epoll_ 0000000000 S com.quicinc.wbcserviceapp
radio 2678 597 1629544 60964 SyS_epoll_ 0000000000 S com.android.phone
system 2698 597 1569804 37516 SyS_epoll_ 0000000000 S com.letv.bsp.qccrashhandler
u0_a10 2730 597 1622056 86812 SyS_epoll_ 0000000000 S com.android.launcher
u0_a88 2949 598 1009324 33828 SyS_epoll_ 0000000000 S com.baidu.appsearch:bdservice_v1
radio 3008 597 1571620 34856 SyS_epoll_ 0000000000 S com.qualcomm.qcrilmsgtunnel
u0_a88 3063 598 1075900 66640 SyS_epoll_ 0000000000 S com.baidu.appsearch
system 3364 597 1568516 36936 SyS_epoll_ 0000000000 S com.android.keychain
root 3416 1 11496 1356 futex_wait 0000000000 S /system/vendor/bin/perfd
system 3458 597 1578000 34348 SyS_epoll_ 0000000000 S com.qualcomm.qti.seemp.service:seemp_service
u0_a2 3489 597 1571516 39152 SyS_epoll_ 0000000000 S com.android.providers.calendar
system 3709 597 1568444 34904 SyS_epoll_ 0000000000 S com.qualcomm.qti.GBAHttpAuthentication.auth
u0_a67 3728 597 1567716 34352 SyS_epoll_ 0000000000 S com.qualcomm.qti.telephonyservice
u0_a88 3812 598 1010824 35140 SyS_epoll_ 0000000000 S com.baidu.appsearch:locationservice
u0_a6 4036 597 1568704 35476 SyS_epoll_ 0000000000 S com.android.defcontainer
u0_a42 4089 597 2101740 37328 SyS_epoll_ 0000000000 S com.android.gallery3d
system 4871 597 1567048 34360 SyS_epoll_ 0000000000 S com.qualcomm.timeservice
root 4975 2 0 0 usleep_ran 0000000000 D kworker/3:6
root 4976 2 0 0 usleep_ran 0000000000 D kworker/3:7
root 5724 1 15660 3152 futex_wait 0000000000 S /system/bin/iop
u0_a1 5749 597 1576984 41708 SyS_epoll_ 0000000000 S com.letv.bugpostbox
u0_a89 5915 597 1577084 40320 SyS_epoll_ 0000000000 S com.sysprogs.AndroidAutoTest
shell 5936 728 6008 1256 0 7f7e253e3c R ps
C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s 9416189d forward tcp:5039 tcp:5039
Received launch context:
App PID: 5915
EABI: arm64-v8a
Workaround mode: EnabledWithOddAddress
GDBServer: running
ADB log:
GDB startup log:
-gdb-set solib-search-path C:/Users/zl121/AppData/Local/VisualGDB/AndroidBinaryCache/9416189d;C:/Users/zl121/AppData/Local/Temp/SysprogsAndroidTest-10484/4.9/obj/local/arm64-v8a
^done
Activating library load breakpoint bug workaround…
-target-select remote :5039
=thread-group-started,id=”i1″,pid=”5915″
=library-loaded,id=”/system/bin/linker64″,target-name=”/system/bin/linker64″,host-name=”C:\\Users\\zl121\\AppData\\Local\\VisualGDB\\AndroidBinaryCache\\9416189d\\linker64″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/vendor/lib64/libNimsWrap.so”,target-name=”/system/vendor/lib64/libNimsWrap.so”,host-name=”/system/vendor/lib64/libNimsWrap.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libcutils.so”,target-name=”/system/lib64/libcutils.so”,host-name=”/system/lib64/libcutils.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libutils.so”,target-name=”/system/lib64/libutils.so”,host-name=”/system/lib64/libutils.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/liblog.so”,target-name=”/system/lib64/liblog.so”,host-name=”/system/lib64/liblog.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libbinder.so”,target-name=”/system/lib64/libbinder.so”,host-name=”/system/lib64/libbinder.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libandroid_runtime.so”,target-name=”/system/lib64/libandroid_runtime.so”,host-name=”/system/lib64/libandroid_runtime.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libwilhelm.so”,target-name=”/system/lib64/libwilhelm.so”,host-name=”/system/lib64/libwilhelm.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libc++.so”,target-name=”/system/lib64/libc++.so”,host-name=”/system/lib64/libc++.so”,symbols-loaded=”0″,thread-group=”i1″
&”warning: `C:\\Users\\zl121\\AppData\\Local\\VisualGDB\\AndroidBinaryCache\\9416189d\\libc.so’: Shared library architecture arm is not compatible with target architecture aarch64.\n”
&”warning: .dynamic section for \”C:\\Users\\zl121\\AppData\\Local\\VisualGDB\\AndroidBinaryCache\\9416189d\\libc.so\” is not at the expected address (wrong library or version mismatch?)\n”
=library-loaded,id=”/system/lib64/libc.so”,target-name=”/system/lib64/libc.so”,host-name=”C:\\Users\\zl121\\AppData\\Local\\VisualGDB\\AndroidBinaryCache\\9416189d\\libc.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libm.so”,target-name=”/system/lib64/libm.so”,host-name=”/system/lib64/libm.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libbacktrace.so”,target-name=”/system/lib64/libbacktrace.so”,host-name=”/system/lib64/libbacktrace.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libmemtrack.so”,target-name=”/system/lib64/libmemtrack.so”,host-name=”/system/lib64/libmemtrack.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libandroidfw.so”,target-name=”/system/lib64/libandroidfw.so”,host-name=”/system/lib64/libandroidfw.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libexpat.so”,target-name=”/system/lib64/libexpat.so”,host-name=”/system/lib64/libexpat.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libnativehelper.so”,target-name=”/system/lib64/libnativehelper.so”,host-name=”/system/lib64/libnativehelper.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libnetutils.so”,target-name=”/system/lib64/libnetutils.so”,host-name=”/system/lib64/libnetutils.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libui.so”,target-name=”/system/lib64/libui.so”,host-name=”/system/lib64/libui.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libgui.so”,target-name=”/system/lib64/libgui.so”,host-name=”/system/lib64/libgui.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libinput.so”,target-name=”/system/lib64/libinput.so”,host-name=”/system/lib64/libinput.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libinputflinger.so”,target-name=”/system/lib64/libinputflinger.so”,host-name=”/system/lib64/libinputflinger.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libcamera_client.so”,target-name=”/system/lib64/libcamera_client.so”,host-name=”/system/lib64/libcamera_client.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libcamera_metadata.so”,target-name=”/system/lib64/libcamera_metadata.so”,host-name=”/system/lib64/libcamera_metadata.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libskia.so”,target-name=”/system/lib64/libskia.so”,host-name=”/system/lib64/libskia.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libsqlite.so”,target-name=”/system/lib64/libsqlite.so”,host-name=”/system/lib64/libsqlite.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libEGL.so”,target-name=”/system/lib64/libEGL.so”,host-name=”/system/lib64/libEGL.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libGLESv1_CM.so”,target-name=”/system/lib64/libGLESv1_CM.so”,host-name=”/system/lib64/libGLESv1_CM.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libGLESv2.so”,target-name=”/system/lib64/libGLESv2.so”,host-name=”/system/lib64/libGLESv2.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libETC1.so”,target-name=”/system/lib64/libETC1.so”,host-name=”/system/lib64/libETC1.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libhardware.so”,target-name=”/system/lib64/libhardware.so”,host-name=”/system/lib64/libhardware.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libhardware_legacy.so”,target-name=”/system/lib64/libhardware_legacy.so”,host-name=”/system/lib64/libhardware_legacy.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libselinux.so”,target-name=”/system/lib64/libselinux.so”,host-name=”/system/lib64/libselinux.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libsonivox.so”,target-name=”/system/lib64/libsonivox.so”,host-name=”/system/lib64/libsonivox.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libcrypto.so”,target-name=”/system/lib64/libcrypto.so”,host-name=”/system/lib64/libcrypto.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libssl.so”,target-name=”/system/lib64/libssl.so”,host-name=”/system/lib64/libssl.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libicuuc.so”,target-name=”/system/lib64/libicuuc.so”,host-name=”/system/lib64/libicuuc.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libicui18n.so”,target-name=”/system/lib64/libicui18n.so”,host-name=”/system/lib64/libicui18n.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libmedia.so”,target-name=”/system/lib64/libmedia.so”,host-name=”/system/lib64/libmedia.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libjpeg.so”,target-name=”/system/lib64/libjpeg.so”,host-name=”/system/lib64/libjpeg.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libusbhost.so”,target-name=”/system/lib64/libusbhost.so”,host-name=”/system/lib64/libusbhost.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libharfbuzz_ng.so”,target-name=”/system/lib64/libharfbuzz_ng.so”,host-name=”/system/lib64/libharfbuzz_ng.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libz.so”,target-name=”/system/lib64/libz.so”,host-name=”/system/lib64/libz.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libaudioutils.so”,target-name=”/system/lib64/libaudioutils.so”,host-name=”/system/lib64/libaudioutils.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libpdfium.so”,target-name=”/system/lib64/libpdfium.so”,host-name=”/system/lib64/libpdfium.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libimg_utils.so”,target-name=”/system/lib64/libimg_utils.so”,host-name=”/system/lib64/libimg_utils.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libnetd_client.so”,target-name=”/system/lib64/libnetd_client.so”,host-name=”/system/lib64/libnetd_client.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libradio.so”,target-name=”/system/lib64/libradio.so”,host-name=”/system/lib64/libradio.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libsoundtrigger.so”,target-name=”/system/lib64/libsoundtrigger.so”,host-name=”/system/lib64/libsoundtrigger.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libminikin.so”,target-name=”/system/lib64/libminikin.so”,host-name=”/system/lib64/libminikin.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libprocessgroup.so”,target-name=”/system/lib64/libprocessgroup.so”,host-name=”/system/lib64/libprocessgroup.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libnativebridge.so”,target-name=”/system/lib64/libnativebridge.so”,host-name=”/system/lib64/libnativebridge.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libradio_metadata.so”,target-name=”/system/lib64/libradio_metadata.so”,host-name=”/system/lib64/libradio_metadata.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libhwui.so”,target-name=”/system/lib64/libhwui.so”,host-name=”/system/lib64/libhwui.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libstagefright.so”,target-name=”/system/lib64/libstagefright.so”,host-name=”/system/lib64/libstagefright.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libstagefright_foundation.so”,target-name=”/system/lib64/libstagefright_foundation.so”,host-name=”/system/lib64/libstagefright_foundation.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libstagefright_http_support.so”,target-name=”/system/lib64/libstagefright_http_support.so”,host-name=”/system/lib64/libstagefright_http_support.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libeffects.so”,target-name=”/system/lib64/libeffects.so”,host-name=”/system/lib64/libeffects.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libbase.so”,target-name=”/system/lib64/libbase.so”,host-name=”/system/lib64/libbase.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libunwind.so”,target-name=”/system/lib64/libunwind.so”,host-name=”/system/lib64/libunwind.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libstdc++.so”,target-name=”/system/lib64/libstdc++.so”,host-name=”/system/lib64/libstdc++.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libsync.so”,target-name=”/system/lib64/libsync.so”,host-name=”/system/lib64/libsync.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libpng.so”,target-name=”/system/lib64/libpng.so”,host-name=”/system/lib64/libpng.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libft2.so”,target-name=”/system/lib64/libft2.so”,host-name=”/system/lib64/libft2.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/vendor/lib64/libqc-opt.so”,target-name=”/system/vendor/lib64/libqc-opt.so”,host-name=”/system/vendor/lib64/libqc-opt.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libGLES_trace.so”,target-name=”/system/lib64/libGLES_trace.so”,host-name=”/system/lib64/libGLES_trace.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libwpa_client.so”,target-name=”/system/lib64/libwpa_client.so”,host-name=”/system/lib64/libwpa_client.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libpcre.so”,target-name=”/system/lib64/libpcre.so”,host-name=”/system/lib64/libpcre.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libnbaio.so”,target-name=”/system/lib64/libnbaio.so”,host-name=”/system/lib64/libnbaio.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libspeexresampler.so”,target-name=”/system/lib64/libspeexresampler.so”,host-name=”/system/lib64/libspeexresampler.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libRS.so”,target-name=”/system/lib64/libRS.so”,host-name=”/system/lib64/libRS.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libRScpp.so”,target-name=”/system/lib64/libRScpp.so”,host-name=”/system/lib64/libRScpp.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libdrmframework.so”,target-name=”/system/lib64/libdrmframework.so”,host-name=”/system/lib64/libdrmframework.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libmediautils.so”,target-name=”/system/lib64/libmediautils.so”,host-name=”/system/lib64/libmediautils.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libopus.so”,target-name=”/system/lib64/libopus.so”,host-name=”/system/lib64/libopus.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libstagefright_omx.so”,target-name=”/system/lib64/libstagefright_omx.so”,host-name=”/system/lib64/libstagefright_omx.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libstagefright_yuv.so”,target-name=”/system/lib64/libstagefright_yuv.so”,host-name=”/system/lib64/libstagefright_yuv.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libvorbisidec.so”,target-name=”/system/lib64/libvorbisidec.so”,host-name=”/system/lib64/libvorbisidec.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libpowermanager.so”,target-name=”/system/lib64/libpowermanager.so”,host-name=”/system/lib64/libpowermanager.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libstagefright_enc_common.so”,target-name=”/system/lib64/libstagefright_enc_common.so”,host-name=”/system/lib64/libstagefright_enc_common.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libstagefright_avc_common.so”,target-name=”/system/lib64/libstagefright_avc_common.so”,host-name=”/system/lib64/libstagefright_avc_common.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libprotobuf-cpp-lite.so”,target-name=”/system/lib64/libprotobuf-cpp-lite.so”,host-name=”/system/lib64/libprotobuf-cpp-lite.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libcommon_time_client.so”,target-name=”/system/lib64/libcommon_time_client.so”,host-name=”/system/lib64/libcommon_time_client.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libbcc.so”,target-name=”/system/lib64/libbcc.so”,host-name=”/system/lib64/libbcc.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libbcinfo.so”,target-name=”/system/lib64/libbcinfo.so”,host-name=”/system/lib64/libbcinfo.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libLLVM.so”,target-name=”/system/lib64/libLLVM.so”,host-name=”/system/lib64/libLLVM.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”[vdso]”,target-name=”[vdso]”,host-name=”[vdso]”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/vendor/lib64/libcneconn.so”,target-name=”/system/vendor/lib64/libcneconn.so”,host-name=”/system/vendor/lib64/libcneconn.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/vendor/lib64/libvendorconn.so”,target-name=”/system/vendor/lib64/libvendorconn.so”,host-name=”/system/vendor/lib64/libvendorconn.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/vendor/lib64/libavenhancements.so”,target-name=”/system/vendor/lib64/libavenhancements.so”,host-name=”/system/vendor/lib64/libavenhancements.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libstagefright_httplive.so”,target-name=”/system/lib64/libstagefright_httplive.so”,host-name=”/system/lib64/libstagefright_httplive.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libmediaplayerservice.so”,target-name=”/system/lib64/libmediaplayerservice.so”,host-name=”/system/lib64/libmediaplayerservice.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libstagefright_wfd.so”,target-name=”/system/lib64/libstagefright_wfd.so”,host-name=”/system/lib64/libstagefright_wfd.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libcurl.so”,target-name=”/system/lib64/libcurl.so”,host-name=”/system/lib64/libcurl.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/vendor/lib64/libExtendedExtractor.so”,target-name=”/system/vendor/lib64/libExtendedExtractor.so”,host-name=”/system/vendor/lib64/libExtendedExtractor.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libdashplayer.so”,target-name=”/system/lib64/libdashplayer.so”,host-name=”/system/lib64/libdashplayer.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libart.so”,target-name=”/system/lib64/libart.so”,host-name=”/system/lib64/libart.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libsigchain.so”,target-name=”/system/lib64/libsigchain.so”,host-name=”/system/lib64/libsigchain.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libjavacore.so”,target-name=”/system/lib64/libjavacore.so”,host-name=”/system/lib64/libjavacore.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/hw/memtrack.msm8996.so”,target-name=”/system/lib64/hw/memtrack.msm8996.so”,host-name=”/system/lib64/hw/memtrack.msm8996.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/vendor/lib64/libqti-at.so”,target-name=”/system/vendor/lib64/libqti-at.so”,host-name=”/system/vendor/lib64/libqti-at.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/vendor/lib64/libqti-gt.so”,target-name=”/system/vendor/lib64/libqti-gt.so”,host-name=”/system/vendor/lib64/libqti-gt.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libxml2.so”,target-name=”/system/lib64/libxml2.so”,host-name=”/system/lib64/libxml2.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/vendor/lib64/libqti-perfd-client.so”,target-name=”/system/vendor/lib64/libqti-perfd-client.so”,host-name=”/system/vendor/lib64/libqti-perfd-client.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libmedia_jni.so”,target-name=”/system/lib64/libmedia_jni.so”,host-name=”/system/lib64/libmedia_jni.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libmtp.so”,target-name=”/system/lib64/libmtp.so”,host-name=”/system/lib64/libmtp.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libjhead.so”,target-name=”/system/lib64/libjhead.so”,host-name=”/system/lib64/libjhead.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libexif.so”,target-name=”/system/lib64/libexif.so”,host-name=”/system/lib64/libexif.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libstagefright_amrnb_common.so”,target-name=”/system/lib64/libstagefright_amrnb_common.so”,host-name=”/system/lib64/libstagefright_amrnb_common.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libextmedia_jni.so”,target-name=”/system/lib64/libextmedia_jni.so”,host-name=”/system/lib64/libextmedia_jni.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/data/dalvik-cache/arm64/system@framework@tcmclient.jar@classes.dex”,target-name=”/data/dalvik-cache/arm64/system@framework@tcmclient.jar@classes.dex”,host-name=”/data/dalvik-cache/arm64/system@framework@tcmclient.jar@classes.dex”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libjavacrypto.so”,target-name=”/system/lib64/libjavacrypto.so”,host-name=”/system/lib64/libjavacrypto.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libkeystore-engine.so”,target-name=”/system/lib64/libkeystore-engine.so”,host-name=”/system/lib64/libkeystore-engine.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libkeystore_binder.so”,target-name=”/system/lib64/libkeystore_binder.so”,host-name=”/system/lib64/libkeystore_binder.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libsoftkeymasterdevice.so”,target-name=”/system/lib64/libsoftkeymasterdevice.so”,host-name=”/system/lib64/libsoftkeymasterdevice.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libkeymaster_messages.so”,target-name=”/system/lib64/libkeymaster_messages.so”,host-name=”/system/lib64/libkeymaster_messages.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libkeymaster1.so”,target-name=”/system/lib64/libkeymaster1.so”,host-name=”/system/lib64/libkeymaster1.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/vendor/lib64/egl/libEGL_adreno.so”,target-name=”/system/vendor/lib64/egl/libEGL_adreno.so”,host-name=”/system/vendor/lib64/egl/libEGL_adreno.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/vendor/lib64/libadreno_utils.so”,target-name=”/system/vendor/lib64/libadreno_utils.so”,host-name=”/system/vendor/lib64/libadreno_utils.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/vendor/lib64/libgsl.so”,target-name=”/system/vendor/lib64/libgsl.so”,host-name=”/system/vendor/lib64/libgsl.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/vendor/lib64/egl/libGLESv2_adreno.so”,target-name=”/system/vendor/lib64/egl/libGLESv2_adreno.so”,host-name=”/system/vendor/lib64/egl/libGLESv2_adreno.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/vendor/lib64/libllvm-glnext.so”,target-name=”/system/vendor/lib64/libllvm-glnext.so”,host-name=”/system/vendor/lib64/libllvm-glnext.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/vendor/lib64/egl/libGLESv1_CM_adreno.so”,target-name=”/system/vendor/lib64/egl/libGLESv1_CM_adreno.so”,host-name=”/system/vendor/lib64/egl/libGLESv1_CM_adreno.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/vendor/lib64/egl/eglSubDriverAndroid.so”,target-name=”/system/vendor/lib64/egl/eglSubDriverAndroid.so”,host-name=”/system/vendor/lib64/egl/eglSubDriverAndroid.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/hw/gralloc.msm8996.so”,target-name=”/system/lib64/hw/gralloc.msm8996.so”,host-name=”/system/lib64/hw/gralloc.msm8996.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libmemalloc.so”,target-name=”/system/lib64/libmemalloc.so”,host-name=”/system/lib64/libmemalloc.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libqdMetaData.so”,target-name=”/system/lib64/libqdMetaData.so”,host-name=”/system/lib64/libqdMetaData.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libqdutils.so”,target-name=”/system/lib64/libqdutils.so”,host-name=”/system/lib64/libqdutils.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libqservice.so”,target-name=”/system/lib64/libqservice.so”,host-name=”/system/lib64/libqservice.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libandroid.so”,target-name=”/system/lib64/libandroid.so”,host-name=”/system/lib64/libandroid.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libcompiler_rt.so”,target-name=”/system/lib64/libcompiler_rt.so”,host-name=”/system/lib64/libcompiler_rt.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libjnigraphics.so”,target-name=”/system/lib64/libjnigraphics.so”,host-name=”/system/lib64/libjnigraphics.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libwebviewchromium_loader.so”,target-name=”/system/lib64/libwebviewchromium_loader.so”,host-name=”/system/lib64/libwebviewchromium_loader.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/data/app/com.sysprogs.AndroidAutoTest-2/oat/arm64/base.odex”,target-name=”/data/app/com.sysprogs.AndroidAutoTest-2/oat/arm64/base.odex”,host-name=”/data/app/com.sysprogs.AndroidAutoTest-2/oat/arm64/base.odex”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/data/app/com.sysprogs.AndroidAutoTest-2/lib/arm64/libfirst.so”,target-name=”/data/app/com.sysprogs.AndroidAutoTest-2/lib/arm64/libfirst.so”,host-name=”C:\\Users\\zl121\\AppData\\Local\\Temp\\SysprogsAndroidTest-10484\\4.9\\obj\\local\\arm64-v8a\\libfirst.so”,symbols-loaded=”0″,thread-group=”i1″
&”warning: Could not load shared library symbols for 131 libraries, e.g. /system/vendor/lib64/libNimsWrap.so.\nUse the \”info sharedlibrary\” command to see the complete listing.\nDo you need \”set solib-search-path\” or \”set sysroot\”?”
&”\n”
~”/s/ndk-toolchain/src/build/../gdb/gdb-7.7/gdb/gdbarch.c:3991: internal-error: gdbarch_record_special_symbol_p: Assertion `gdbarch != NULL’ failed.\nA problem internal to GDB has been detected,\nfurther debugging may prove unreliable.\nQuit this debugging session? ”
~”(y or n) [answered Y; input not from terminal]\n”
~”/s/ndk-toolchain/src/build/../gdb/gdb-7.7/gdb/gdbarch.c:3991: internal-error: gdbarch_record_special_symbol_p: Assertion `gdbarch != NULL’ failed.\nA problem internal to GDB has been detected,\nfurther debugging may prove unreliable.\nCreate a core file of GDB? ”
This application has requested the Runtime to terminate it in an unusual way.
Please contact the application’s support team for more information.
Launcher log:
GDBServer output:
Attached; pid = 5915gdbserver: Unable to determine the number of hardware watchpoints available.
gdbserver: Unable to determine the number of hardware breakpoints available.
Listening on port 5039
Remote debugging from host 127.0.0.1
Exception: GDB has exited unexpectedly. If you are using a 64-bit version of NDK, consider trying a 32-bit one.
Debug failed: GDB has exited unexpectedly. If you are using a 64-bitMarch 7, 2016 at 20:13 #7735support
Strange. The log looks like the gdb included in the Android NDK itself does not support your device. Can you check the VisualGDB Launcher Output for the path of the GDB executable? Perhaps VisualGDB is launching an incorrect version of gdb?
March 7, 2016 at 20:29 #7736zhongliu
Here is the VisualGDB Launcher Output:
VisualGDB: C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe devices
VisualGDB: C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s 9416189d shell getprop ro.build.version.release
VisualGDB: C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s 9416189d shell getprop ro.product.cpu.abi
VisualGDB: C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s 9416189d shell getprop ro.build.version.sdk
VisualGDB: C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s 9416189d shell ps
VisualGDB: C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s 9416189d shell id
VisualGDB: C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s 9416189d install -r “C:\Users\zl121\AppData\Local\Temp\SysprogsAndroidTest-3504\4.9\bin\SysprogsAndroidAutoTest-debug.apk”
VisualGDB: C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s 9416189d shell run-as com.sysprogs.AndroidAutoTest /system/bin/sh -c pwd
Using app directory: /data/data/com.sysprogs.AndroidAutoTest
Detected device EABI: arm64-v8a
VisualGDB: C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s 9416189d shell ls /data/data/com.sysprogs.AndroidAutoTest/lib
VisualGDB: C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s 9416189d shell pm list packages -f
APK file path on device: /data/app/com.sysprogs.AndroidAutoTest-1/base.apk
Normal library directory: /data/app/com.sysprogs.AndroidAutoTest-1/lib/arm64-v8a
VisualGDB: C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s 9416189d shell ls /data/app/com.sysprogs.AndroidAutoTest-1/lib/arm64-v8a
Normal library directory contains no .so files. Searching for replacements…
Checking /data/app/com.sysprogs.AndroidAutoTest-1/lib/arm64…
Found .so files. Using /data/data/com.sysprogs.AndroidAutoTest/lib as the new library directory
Checking Android project ABI…
Device ABI: arm64-v8a
Library directory: C:\Users\zl121\AppData\Local\Temp\SysprogsAndroidTest-3504\4.9\libs
Checking for C:\Users\zl121\AppData\Local\Temp\SysprogsAndroidTest-3504\4.9\libs\arm64-v8a\gdbserver…
VisualGDB: C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s 9416189d shell am start -n com.sysprogs.AndroidAutoTest/.SysprogsAndroidAutoTest
VisualGDB: C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s 9416189d shell ls /data/app/com.sysprogs.AndroidAutoTest-1/lib/arm64/gdbserver
VisualGDB: C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s 9416189d shell run-as com.sysprogs.AndroidAutoTest /data/app/com.sysprogs.AndroidAutoTest-1/lib/arm64/gdbserver localhost:5039 –attach 4733
VisualGDB: C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s 9416189d forward tcp:5039 tcp:5039
Looking up GDB…
GDB reported by ndk-build: C:/Android/android-ndk-r10e/toolchains/aarch64-linux-android-4.9/prebuilt/windows/bin/aarch64-linux-android-gdb.exe
Found toolchain: C:\Android\android-ndk-r10e\toolchains\aarch64-linux-android-4.9
Found GDB: C:\Android\android-ndk-r10e\toolchains\aarch64-linux-android-4.9\prebuilt\windows\bin\aarch64-linux-android-gdb.exe
Found existing app instance: PID = 4733
VisualGDB: C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s 9416189d shell run-as com.sysprogs.AndroidAutoTest kill -9 4752
VisualGDB: C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s 9416189d shell run-as com.sysprogs.AndroidAutoTest kill -9 4733
APK file path on device: /data/app/com.sysprogs.AndroidAutoTest-2/base.apk
Normal library directory: /data/app/com.sysprogs.AndroidAutoTest-2/lib/arm64-v8a
VisualGDB: C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s 9416189d shell ls /data/app/com.sysprogs.AndroidAutoTest-2/lib/arm64-v8a
Checking /data/app/com.sysprogs.AndroidAutoTest-2/lib/arm64…
VisualGDB: C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s 9416189d shell ls /data/app/com.sysprogs.AndroidAutoTest-2/lib/arm64/gdbserver
VisualGDB: C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s 9416189d shell run-as com.sysprogs.AndroidAutoTest /data/app/com.sysprogs.AndroidAutoTest-2/lib/arm64/gdbserver localhost:5039 –attach 5042
Looking up GDB…
VisualGDB: C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s 9416189d shell run-as com.sysprogs.AndroidAutoTest cat /proc/5042/maps
Found existing app instance: PID = 5042
VisualGDB: C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s 9416189d shell run-as com.sysprogs.AndroidAutoTest kill -9 5061
VisualGDB: C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s 9416189d shell run-as com.sysprogs.AndroidAutoTest kill -9 5042
VisualGDB: C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s 9416189d shell run-as com.sysprogs.AndroidAutoTest /data/app/com.sysprogs.AndroidAutoTest-1/lib/arm64/gdbserver localhost:5039 –attach 5249
Looking up GDB…
VisualGDB: C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s 9416189d shell run-as com.sysprogs.AndroidAutoTest cat /proc/5249/maps
VisualGDB: C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s 9416189d uninstall com.sysprogs.AndroidAutoTestThanks
Zhong
March 8, 2016 at 18:55 #7738zhongliu
Any progress for the fix? I cannot use VisualGDB at all, can you please have fix as soon as possible?
Zhong
March 9, 2016 at 18:38 #7741support
Yes, please try this build: http://sysprogs.com/files/tmp/VisualGDB-5.1.4.656.msi
If it does not work, please send us the contents of the %LOCALAPPDATA%\VisualGDB\AndroidBinaryCache folder so that we can try reproducing the problem locally.
March 11, 2016 at 00:54 #7749zhongliu
ParticipantHi
That fixed the compatibility test issue, but it has problem to support debug, it cannot stop at the break points, I just used the default Android application created by Wizard.
Please help..
Zhong
March 11, 2016 at 02:51 #7750zhongliu
I just debug this function:
jstring
Java_com_visualgdb_example_gdb_1app_1test1_gdb_1app_1test1_stringFromJNI( JNIEnv* env,
jobject thiz )
char szBuf[512];
sprintf(szBuf, “You have pressed this huge button %d times”, s_ButtonPressCounter++);jstring str = (*env)->NewStringUTF(env, szBuf);
return str;
}I set breakpoint at line “sprintf….”, got this error:
C:\Android\android-ndk-r10e\toolchains\arm-linux-androideabi-4.8\prebuilt\windows\bin\arm-linux-androideabi-gdb.exe –interpreter mi “C:\Users\zl121\AppData\Local\VisualGDB\AndroidBinaryCache\9416189d\app_process64” -x “C:\Zhong\workspace\gdb_app_test1\gdb_app_test1\libs\armeabi-v7a\gdb.setup”
VisualGDB for Android is trying to repair your breakpoints…The below is the output of “All GDB interactions”:
=thread-group-added,id=”i1″
GNU gdb (GDB) 7.7
Copyright (C) 2014 Free Software Foundation, Inc.
This GDB was configured as “–host=i586-pc-mingw32msvc –target=arm-linux-android”.
<http://source.android.com/source/report-bugs.html>.
For help, type “help”.
&”\”C:\\Users\\zl121\\AppData\\Local\\VisualGDB\\AndroidBinaryCache\\9416189d\\app_process64\”: not in executable format: File format not recognized\n”
=cmd-param-changed,param=”solib-search-path”,value=”./obj/local/armeabi-v7a”
-gdb-version
GNU gdb (GDB) 7.7
OK
-list-features
^done,features=[“frozen-varobjs”,”pending-breakpoints”,”thread-info”,”data-read-memory-bytes”,”breakpoint-notifications”,”ada-task-info”,”language-option”,”info-gdb-mi-command”,”undefined-command-error-code”,”exec-run-start-option”,”python”]
OK
No symbol table is loaded. Use the “file” command.
-gdb-set print demangle off
OK
-gdb-set solib-search-path C:/Users/zl121/AppData/Local/VisualGDB/AndroidBinaryCache/9416189d;C:/Zhong/workspace/gdb_app_test1/gdb_app_test1/obj/local/armeabi-v7a
OK
=thread-group-started,id=”i1″,pid=”3758″
&”Cannot access memory at address 0x1c\n”
*stopped,frame={addr=”0xf745de84″,func=”??”,args=[]},thread-id=”1″,stopped-threads=”all”,core=”2″
^connected
info shared
&”info shared\n”
&”Error reading attached process’s symbol file.\n”
&”com.visualgdb.example.gdb_app_test1: No such file or directory.\n”
=library-loaded,id=”/system/bin/linker”,target-name=”/system/bin/linker”,host-name=”C:\\Users\\zl121\\AppData\\Local\\VisualGDB\\AndroidBinaryCache\\9416189d\\linker”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/vendor/lib/libNimsWrap.so”,target-name=”/system/vendor/lib/libNimsWrap.so”,host-name=”/system/vendor/lib/libNimsWrap.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libcutils.so”,target-name=”/system/lib/libcutils.so”,host-name=”/system/lib/libcutils.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libutils.so”,target-name=”/system/lib/libutils.so”,host-name=”/system/lib/libutils.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/liblog.so”,target-name=”/system/lib/liblog.so”,host-name=”/system/lib/liblog.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libbinder.so”,target-name=”/system/lib/libbinder.so”,host-name=”/system/lib/libbinder.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libandroid_runtime.so”,target-name=”/system/lib/libandroid_runtime.so”,host-name=”/system/lib/libandroid_runtime.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libwilhelm.so”,target-name=”/system/lib/libwilhelm.so”,host-name=”/system/lib/libwilhelm.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libc++.so”,target-name=”/system/lib/libc++.so”,host-name=”/system/lib/libc++.so”,symbols-loaded=”0″,thread-group=”i1″
&”Error while mapping shared library sections:\n”
&”`C:\\Users\\zl121\\AppData\\Local\\VisualGDB\\AndroidBinaryCache\\9416189d\\libc.so’: not in executable format: File format not recognized\n”
=library-loaded,id=”/system/lib/libc.so”,target-name=”/system/lib/libc.so”,host-name=”/system/lib/libc.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libm.so”,target-name=”/system/lib/libm.so”,host-name=”/system/lib/libm.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libbacktrace.so”,target-name=”/system/lib/libbacktrace.so”,host-name=”/system/lib/libbacktrace.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libmemtrack.so”,target-name=”/system/lib/libmemtrack.so”,host-name=”/system/lib/libmemtrack.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libandroidfw.so”,target-name=”/system/lib/libandroidfw.so”,host-name=”/system/lib/libandroidfw.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libexpat.so”,target-name=”/system/lib/libexpat.so”,host-name=”/system/lib/libexpat.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libnativehelper.so”,target-name=”/system/lib/libnativehelper.so”,host-name=”/system/lib/libnativehelper.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libnetutils.so”,target-name=”/system/lib/libnetutils.so”,host-name=”/system/lib/libnetutils.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libui.so”,target-name=”/system/lib/libui.so”,host-name=”/system/lib/libui.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libgui.so”,target-name=”/system/lib/libgui.so”,host-name=”/system/lib/libgui.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libinput.so”,target-name=”/system/lib/libinput.so”,host-name=”/system/lib/libinput.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libinputflinger.so”,target-name=”/system/lib/libinputflinger.so”,host-name=”/system/lib/libinputflinger.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libcamera_client.so”,target-name=”/system/lib/libcamera_client.so”,host-name=”/system/lib/libcamera_client.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libcamera_metadata.so”,target-name=”/system/lib/libcamera_metadata.so”,host-name=”/system/lib/libcamera_metadata.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libskia.so”,target-name=”/system/lib/libskia.so”,host-name=”/system/lib/libskia.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libsqlite.so”,target-name=”/system/lib/libsqlite.so”,host-name=”/system/lib/libsqlite.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libEGL.so”,target-name=”/system/lib/libEGL.so”,host-name=”/system/lib/libEGL.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libGLESv1_CM.so”,target-name=”/system/lib/libGLESv1_CM.so”,host-name=”/system/lib/libGLESv1_CM.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libGLESv2.so”,target-name=”/system/lib/libGLESv2.so”,host-name=”/system/lib/libGLESv2.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libETC1.so”,target-name=”/system/lib/libETC1.so”,host-name=”/system/lib/libETC1.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libhardware.so”,target-name=”/system/lib/libhardware.so”,host-name=”/system/lib/libhardware.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libhardware_legacy.so”,target-name=”/system/lib/libhardware_legacy.so”,host-name=”/system/lib/libhardware_legacy.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libselinux.so”,target-name=”/system/lib/libselinux.so”,host-name=”/system/lib/libselinux.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libsonivox.so”,target-name=”/system/lib/libsonivox.so”,host-name=”/system/lib/libsonivox.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libcrypto.so”,target-name=”/system/lib/libcrypto.so”,host-name=”/system/lib/libcrypto.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libssl.so”,target-name=”/system/lib/libssl.so”,host-name=”/system/lib/libssl.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libicuuc.so”,target-name=”/system/lib/libicuuc.so”,host-name=”/system/lib/libicuuc.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libicui18n.so”,target-name=”/system/lib/libicui18n.so”,host-name=”/system/lib/libicui18n.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libmedia.so”,target-name=”/system/lib/libmedia.so”,host-name=”/system/lib/libmedia.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libjpeg.so”,target-name=”/system/lib/libjpeg.so”,host-name=”/system/lib/libjpeg.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libusbhost.so”,target-name=”/system/lib/libusbhost.so”,host-name=”/system/lib/libusbhost.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libharfbuzz_ng.so”,target-name=”/system/lib/libharfbuzz_ng.so”,host-name=”/system/lib/libharfbuzz_ng.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libz.so”,target-name=”/system/lib/libz.so”,host-name=”/system/lib/libz.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libaudioutils.so”,target-name=”/system/lib/libaudioutils.so”,host-name=”/system/lib/libaudioutils.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libpdfium.so”,target-name=”/system/lib/libpdfium.so”,host-name=”/system/lib/libpdfium.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libimg_utils.so”,target-name=”/system/lib/libimg_utils.so”,host-name=”/system/lib/libimg_utils.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libnetd_client.so”,target-name=”/system/lib/libnetd_client.so”,host-name=”/system/lib/libnetd_client.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libradio.so”,target-name=”/system/lib/libradio.so”,host-name=”/system/lib/libradio.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libsoundtrigger.so”,target-name=”/system/lib/libsoundtrigger.so”,host-name=”/system/lib/libsoundtrigger.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libminikin.so”,target-name=”/system/lib/libminikin.so”,host-name=”/system/lib/libminikin.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libprocessgroup.so”,target-name=”/system/lib/libprocessgroup.so”,host-name=”/system/lib/libprocessgroup.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libnativebridge.so”,target-name=”/system/lib/libnativebridge.so”,host-name=”/system/lib/libnativebridge.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libradio_metadata.so”,target-name=”/system/lib/libradio_metadata.so”,host-name=”/system/lib/libradio_metadata.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libhwui.so”,target-name=”/system/lib/libhwui.so”,host-name=”/system/lib/libhwui.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libstagefright.so”,target-name=”/system/lib/libstagefright.so”,host-name=”/system/lib/libstagefright.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libstagefright_foundation.so”,target-name=”/system/lib/libstagefright_foundation.so”,host-name=”/system/lib/libstagefright_foundation.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libstagefright_http_support.so”,target-name=”/system/lib/libstagefright_http_support.so”,host-name=”/system/lib/libstagefright_http_support.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libeffects.so”,target-name=”/system/lib/libeffects.so”,host-name=”/system/lib/libeffects.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libbase.so”,target-name=”/system/lib/libbase.so”,host-name=”/system/lib/libbase.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libunwind.so”,target-name=”/system/lib/libunwind.so”,host-name=”/system/lib/libunwind.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libstdc++.so”,target-name=”/system/lib/libstdc++.so”,host-name=”/system/lib/libstdc++.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libsync.so”,target-name=”/system/lib/libsync.so”,host-name=”/system/lib/libsync.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libpng.so”,target-name=”/system/lib/libpng.so”,host-name=”/system/lib/libpng.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libft2.so”,target-name=”/system/lib/libft2.so”,host-name=”/system/lib/libft2.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/vendor/lib/libqc-opt.so”,target-name=”/system/vendor/lib/libqc-opt.so”,host-name=”/system/vendor/lib/libqc-opt.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libGLES_trace.so”,target-name=”/system/lib/libGLES_trace.so”,host-name=”/system/lib/libGLES_trace.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libwpa_client.so”,target-name=”/system/lib/libwpa_client.so”,host-name=”/system/lib/libwpa_client.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libpcre.so”,target-name=”/system/lib/libpcre.so”,host-name=”/system/lib/libpcre.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libnbaio.so”,target-name=”/system/lib/libnbaio.so”,host-name=”/system/lib/libnbaio.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libspeexresampler.so”,target-name=”/system/lib/libspeexresampler.so”,host-name=”/system/lib/libspeexresampler.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libRS.so”,target-name=”/system/lib/libRS.so”,host-name=”/system/lib/libRS.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libRScpp.so”,target-name=”/system/lib/libRScpp.so”,host-name=”/system/lib/libRScpp.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libdrmframework.so”,target-name=”/system/lib/libdrmframework.so”,host-name=”/system/lib/libdrmframework.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libmediautils.so”,target-name=”/system/lib/libmediautils.so”,host-name=”/system/lib/libmediautils.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libopus.so”,target-name=”/system/lib/libopus.so”,host-name=”/system/lib/libopus.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libstagefright_omx.so”,target-name=”/system/lib/libstagefright_omx.so”,host-name=”/system/lib/libstagefright_omx.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libstagefright_yuv.so”,target-name=”/system/lib/libstagefright_yuv.so”,host-name=”/system/lib/libstagefright_yuv.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libvorbisidec.so”,target-name=”/system/lib/libvorbisidec.so”,host-name=”/system/lib/libvorbisidec.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libpowermanager.so”,target-name=”/system/lib/libpowermanager.so”,host-name=”/system/lib/libpowermanager.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libstagefright_enc_common.so”,target-name=”/system/lib/libstagefright_enc_common.so”,host-name=”/system/lib/libstagefright_enc_common.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libstagefright_avc_common.so”,target-name=”/system/lib/libstagefright_avc_common.so”,host-name=”/system/lib/libstagefright_avc_common.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libprotobuf-cpp-lite.so”,target-name=”/system/lib/libprotobuf-cpp-lite.so”,host-name=”/system/lib/libprotobuf-cpp-lite.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libcommon_time_client.so”,target-name=”/system/lib/libcommon_time_client.so”,host-name=”/system/lib/libcommon_time_client.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libbcc.so”,target-name=”/system/lib/libbcc.so”,host-name=”/system/lib/libbcc.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libbcinfo.so”,target-name=”/system/lib/libbcinfo.so”,host-name=”/system/lib/libbcinfo.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libLLVM.so”,target-name=”/system/lib/libLLVM.so”,host-name=”/system/lib/libLLVM.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/vendor/lib/libcneconn.so”,target-name=”/system/vendor/lib/libcneconn.so”,host-name=”/system/vendor/lib/libcneconn.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/vendor/lib/libvendorconn.so”,target-name=”/system/vendor/lib/libvendorconn.so”,host-name=”/system/vendor/lib/libvendorconn.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/vendor/lib/libavenhancements.so”,target-name=”/system/vendor/lib/libavenhancements.so”,host-name=”/system/vendor/lib/libavenhancements.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libstagefright_httplive.so”,target-name=”/system/lib/libstagefright_httplive.so”,host-name=”/system/lib/libstagefright_httplive.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libmediaplayerservice.so”,target-name=”/system/lib/libmediaplayerservice.so”,host-name=”/system/lib/libmediaplayerservice.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libstagefright_wfd.so”,target-name=”/system/lib/libstagefright_wfd.so”,host-name=”/system/lib/libstagefright_wfd.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libcurl.so”,target-name=”/system/lib/libcurl.so”,host-name=”/system/lib/libcurl.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/vendor/lib/libExtendedExtractor.so”,target-name=”/system/vendor/lib/libExtendedExtractor.so”,host-name=”/system/vendor/lib/libExtendedExtractor.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libdashplayer.so”,target-name=”/system/lib/libdashplayer.so”,host-name=”/system/lib/libdashplayer.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libart.so”,target-name=”/system/lib/libart.so”,host-name=”/system/lib/libart.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libsigchain.so”,target-name=”/system/lib/libsigchain.so”,host-name=”/system/lib/libsigchain.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libjavacore.so”,target-name=”/system/lib/libjavacore.so”,host-name=”/system/lib/libjavacore.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/hw/memtrack.msm8996.so”,target-name=”/system/lib/hw/memtrack.msm8996.so”,host-name=”/system/lib/hw/memtrack.msm8996.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/vendor/lib/libqti-at.so”,target-name=”/system/vendor/lib/libqti-at.so”,host-name=”/system/vendor/lib/libqti-at.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/vendor/lib/libqti-gt.so”,target-name=”/system/vendor/lib/libqti-gt.so”,host-name=”/system/vendor/lib/libqti-gt.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libxml2.so”,target-name=”/system/lib/libxml2.so”,host-name=”/system/lib/libxml2.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/vendor/lib/libqti-perfd-client.so”,target-name=”/system/vendor/lib/libqti-perfd-client.so”,host-name=”/system/vendor/lib/libqti-perfd-client.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libmedia_jni.so”,target-name=”/system/lib/libmedia_jni.so”,host-name=”/system/lib/libmedia_jni.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libmtp.so”,target-name=”/system/lib/libmtp.so”,host-name=”/system/lib/libmtp.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libjhead.so”,target-name=”/system/lib/libjhead.so”,host-name=”/system/lib/libjhead.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libexif.so”,target-name=”/system/lib/libexif.so”,host-name=”/system/lib/libexif.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libstagefright_amrnb_common.so”,target-name=”/system/lib/libstagefright_amrnb_common.so”,host-name=”/system/lib/libstagefright_amrnb_common.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libextmedia_jni.so”,target-name=”/system/lib/libextmedia_jni.so”,host-name=”/system/lib/libextmedia_jni.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/data/dalvik-cache/arm/system@framework@tcmclient.jar@classes.dex”,target-name=”/data/dalvik-cache/arm/system@framework@tcmclient.jar@classes.dex”,host-name=”/data/dalvik-cache/arm/system@framework@tcmclient.jar@classes.dex”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libjavacrypto.so”,target-name=”/system/lib/libjavacrypto.so”,host-name=”/system/lib/libjavacrypto.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libkeystore-engine.so”,target-name=”/system/lib/libkeystore-engine.so”,host-name=”/system/lib/libkeystore-engine.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libkeystore_binder.so”,target-name=”/system/lib/libkeystore_binder.so”,host-name=”/system/lib/libkeystore_binder.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libsoftkeymasterdevice.so”,target-name=”/system/lib/libsoftkeymasterdevice.so”,host-name=”/system/lib/libsoftkeymasterdevice.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libkeymaster_messages.so”,target-name=”/system/lib/libkeymaster_messages.so”,host-name=”/system/lib/libkeymaster_messages.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libkeymaster1.so”,target-name=”/system/lib/libkeymaster1.so”,host-name=”/system/lib/libkeymaster1.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/vendor/lib/egl/libEGL_adreno.so”,target-name=”/system/vendor/lib/egl/libEGL_adreno.so”,host-name=”/system/vendor/lib/egl/libEGL_adreno.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/vendor/lib/libadreno_utils.so”,target-name=”/system/vendor/lib/libadreno_utils.so”,host-name=”/system/vendor/lib/libadreno_utils.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/vendor/lib/libgsl.so”,target-name=”/system/vendor/lib/libgsl.so”,host-name=”/system/vendor/lib/libgsl.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/vendor/lib/egl/libGLESv2_adreno.so”,target-name=”/system/vendor/lib/egl/libGLESv2_adreno.so”,host-name=”/system/vendor/lib/egl/libGLESv2_adreno.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/vendor/lib/libllvm-glnext.so”,target-name=”/system/vendor/lib/libllvm-glnext.so”,host-name=”/system/vendor/lib/libllvm-glnext.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/vendor/lib/egl/libGLESv1_CM_adreno.so”,target-name=”/system/vendor/lib/egl/libGLESv1_CM_adreno.so”,host-name=”/system/vendor/lib/egl/libGLESv1_CM_adreno.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/vendor/lib/egl/eglSubDriverAndroid.so”,target-name=”/system/vendor/lib/egl/eglSubDriverAndroid.so”,host-name=”/system/vendor/lib/egl/eglSubDriverAndroid.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/hw/gralloc.msm8996.so”,target-name=”/system/lib/hw/gralloc.msm8996.so”,host-name=”/system/lib/hw/gralloc.msm8996.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libmemalloc.so”,target-name=”/system/lib/libmemalloc.so”,host-name=”/system/lib/libmemalloc.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libqdMetaData.so”,target-name=”/system/lib/libqdMetaData.so”,host-name=”/system/lib/libqdMetaData.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libqdutils.so”,target-name=”/system/lib/libqdutils.so”,host-name=”/system/lib/libqdutils.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libqservice.so”,target-name=”/system/lib/libqservice.so”,host-name=”/system/lib/libqservice.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libandroid.so”,target-name=”/system/lib/libandroid.so”,host-name=”/system/lib/libandroid.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libcompiler_rt.so”,target-name=”/system/lib/libcompiler_rt.so”,host-name=”/system/lib/libcompiler_rt.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libjnigraphics.so”,target-name=”/system/lib/libjnigraphics.so”,host-name=”/system/lib/libjnigraphics.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib/libwebviewchromium_loader.so”,target-name=”/system/lib/libwebviewchromium_loader.so”,host-name=”/system/lib/libwebviewchromium_loader.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/data/app/com.visualgdb.example.gdb_app_test1-1/oat/arm/base.odex”,target-name=”/data/app/com.visualgdb.example.gdb_app_test1-1/oat/arm/base.odex”,host-name=”/data/app/com.visualgdb.example.gdb_app_test1-1/oat/arm/base.odex”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/data/app/com.visualgdb.example.gdb_app_test1-1/lib/arm/libgdb_app_test1.so”,target-name=”/data/app/com.visualgdb.example.gdb_app_test1-1/lib/arm/libgdb_app_test1.so”,host-name=”C:\\Zhong\\workspace\\gdb_app_test1\\gdb_app_test1\\obj\\local\\armeabi-v7a\\libgdb_app_test1.so”,symbols-loaded=”0″,thread-group=”i1″
&”warning: Could not load shared library symbols for 130 libraries, e.g. /system/vendor/lib/libNimsWrap.so.\nUse the \”info sharedlibrary\” command to see the complete listing.\nDo you need \”set solib-search-path\” or \”set sysroot\”?”
&”\n”
From To Syms Read Shared Object Library
0xf76d3e20 0xf76e966c No C:\Users\zl121\AppData\Local\VisualGDB\AndroidBinaryCache\9416189d\linker
No /system/vendor/lib/libNimsWrap.so
No /system/lib/libcutils.so
No /system/lib/libutils.so
No /system/lib/liblog.so
No /system/lib/libbinder.so
No /system/lib/libandroid_runtime.so
No /system/lib/libwilhelm.so
No /system/lib/libc++.so
No /system/lib/libc.so
No /system/lib/libm.so
No /system/lib/libbacktrace.so
No /system/lib/libmemtrack.so
No /system/lib/libandroidfw.so
No /system/lib/libexpat.so
No /system/lib/libnativehelper.so
No /system/lib/libnetutils.so
No /system/lib/libui.so
No /system/lib/libgui.so
No /system/lib/libinput.so
No /system/lib/libinputflinger.so
No /system/lib/libcamera_client.so
No /system/lib/libcamera_metadata.so
No /system/lib/libskia.so
No /system/lib/libsqlite.so
No /system/lib/libEGL.so
No /system/lib/libGLESv1_CM.so
No /system/lib/libGLESv2.so
No /system/lib/libETC1.so
No /system/lib/libhardware.so
No /system/lib/libhardware_legacy.so
No /system/lib/libselinux.so
No /system/lib/libsonivox.so
No /system/lib/libcrypto.so
No /system/lib/libssl.so
No /system/lib/libicuuc.so
No /system/lib/libicui18n.so
No /system/lib/libmedia.so
No /system/lib/libjpeg.so
No /system/lib/libusbhost.so
No /system/lib/libharfbuzz_ng.so
No /system/lib/libz.so
No /system/lib/libaudioutils.so
No /system/lib/libpdfium.so
No /system/lib/libimg_utils.so
No /system/lib/libnetd_client.so
No /system/lib/libradio.so
No /system/lib/libsoundtrigger.so
No /system/lib/libminikin.so
No /system/lib/libprocessgroup.so
No /system/lib/libnativebridge.so
No /system/lib/libradio_metadata.so
No /system/lib/libhwui.so
No /system/lib/libstagefright.so
No /system/lib/libstagefright_foundation.so
No /system/lib/libstagefright_http_support.so
No /system/lib/libeffects.so
No /system/lib/libbase.so
No /system/lib/libunwind.so
No /system/lib/libstdc++.so
No /system/lib/libsync.so
No /system/lib/libpng.so
No /system/lib/libft2.so
No /system/vendor/lib/libqc-opt.so
No /system/lib/libGLES_trace.so
No /system/lib/libwpa_client.so
No /system/lib/libpcre.so
No /system/lib/libnbaio.so
No /system/lib/libspeexresampler.so
No /system/lib/libRS.so
No /system/lib/libRScpp.so
No /system/lib/libdrmframework.so
No /system/lib/libmediautils.so
No /system/lib/libopus.so
No /system/lib/libstagefright_omx.so
No /system/lib/libstagefright_yuv.so
No /system/lib/libvorbisidec.so
No /system/lib/libpowermanager.so
No /system/lib/libstagefright_enc_common.so
No /system/lib/libstagefright_avc_common.so
No /system/lib/libprotobuf-cpp-lite.so
No /system/lib/libcommon_time_client.so
No /system/lib/libbcc.so
No /system/lib/libbcinfo.so
No /system/lib/libLLVM.so
No /system/vendor/lib/libcneconn.so
No /system/vendor/lib/libvendorconn.so
No /system/vendor/lib/libavenhancements.so
No /system/lib/libstagefright_httplive.so
No /system/lib/libmediaplayerservice.so
No /system/lib/libstagefright_wfd.so
No /system/lib/libcurl.so
No /system/vendor/lib/libExtendedExtractor.so
No /system/lib/libdashplayer.so
No /system/lib/libart.so
No /system/lib/libsigchain.so
No /system/lib/libjavacore.so
No /system/lib/hw/memtrack.msm8996.so
No /system/vendor/lib/libqti-at.so
No /system/vendor/lib/libqti-gt.so
No /system/lib/libxml2.so
No /system/vendor/lib/libqti-perfd-client.so
No /system/lib/libmedia_jni.so
No /system/lib/libmtp.so
No /system/lib/libjhead.so
No /system/lib/libexif.so
No /system/lib/libstagefright_amrnb_common.so
No /system/lib/libextmedia_jni.so
No /data/dalvik-cache/arm/system@framework@tcmclient.jar@classes.dex
No /system/lib/libjavacrypto.so
No /system/lib/libkeystore-engine.so
No /system/lib/libkeystore_binder.so
No /system/lib/libsoftkeymasterdevice.so
No /system/lib/libkeymaster_messages.so
No /system/lib/libkeymaster1.so
No /system/vendor/lib/egl/libEGL_adreno.so
No /system/vendor/lib/libadreno_utils.so
No /system/vendor/lib/libgsl.so
No /system/vendor/lib/egl/libGLESv2_adreno.so
No /system/vendor/lib/libllvm-glnext.so
No /system/vendor/lib/egl/libGLESv1_CM_adreno.so
No /system/vendor/lib/egl/eglSubDriverAndroid.so
No /system/lib/hw/gralloc.msm8996.so
No /system/lib/libmemalloc.so
No /system/lib/libqdMetaData.so
No /system/lib/libqdutils.so
No /system/lib/libqservice.so
No /system/lib/libandroid.so
No /system/lib/libcompiler_rt.so
No /system/lib/libjnigraphics.so
No /system/lib/libwebviewchromium_loader.so
No /data/app/com.visualgdb.example.gdb_app_test1-1/oat/arm/base.odex
0xf40cacb8 0xf40cc2c0 No C:\Zhong\workspace\gdb_app_test1\gdb_app_test1\obj\local\armeabi-v7a\libgdb_app_test1.so
OK
-break-insert -f C:\Zhong\workspace\gdb_app_test1\gdb_app_test1\jni\gdb_app_test1.c:30
&”No symbol table is loaded. Use the \”file\” command.\n”
^done,bkpt={number=”1″,type=”breakpoint”,disp=”keep”,enabled=”y”,addr=”<PENDING>”,pending=”C:\\Zhong\\workspace\\gdb_app_test1\\gdb_app_test1\\jni\\gdb_app_test1.c:30″,times=”0″,original-location=”C:\\Zhong\\workspace\\gdb_app_test1\\gdb_app_test1\\jni\\gdb_app_test1.c:30″}
-file-list-exec-source-files
^done,files=[]
info shared
&”info shared\n”
OK
sharedlibrary
&”sharedlibrary\n”
Reading symbols from C:\Users\zl121\AppData\Local\VisualGDB\AndroidBinaryCache\9416189d\linker…
(no debugging symbols found)…done.
Loaded symbols for C:\Users\zl121\AppData\Local\VisualGDB\AndroidBinaryCache\9416189d\linker
Reading symbols from C:\Zhong\workspace\gdb_app_test1\gdb_app_test1\obj\local\armeabi-v7a\libgdb_app_test1.so…
done.
Loaded symbols for C:\Zhong\workspace\gdb_app_test1\gdb_app_test1\obj\local\armeabi-v7a\libgdb_app_test1.so
=breakpoint-modified,bkpt={number=”1″,type=”breakpoint”,disp=”keep”,enabled=”y”,addr=”0xf40cad28″,func=”Java_com_visualgdb_example_gdb_1app_1test1_gdb_1app_1test1_stringFromJNI”,file=”jni/gdb_app_test1.c”,fullname=”C:\\\\Zhong\\\\workspace\\\\gdb_app_test1\\\\gdb_app_test1\\\\jni\\\\gdb_app_test1.c”,line=”30″,thread-groups=[“i1″],times=”0″,original-location=”C:\\\\Zhong\\\\workspace\\\\gdb_app_test1\\\\gdb_app_test1\\\\jni\\\\gdb_app_test1.c:30″}
OK
-break-delete 1
OK
^done,bkpt={number=”2″,type=”breakpoint”,disp=”keep”,enabled=”y”,addr=”0xf40cad28″,func=”Java_com_visualgdb_example_gdb_1app_1test1_gdb_1app_1test1_stringFromJNI”,file=”jni/gdb_app_test1.c”,fullname=”C:\\Zhong\\workspace\\gdb_app_test1\\gdb_app_test1\\jni\\gdb_app_test1.c”,line=”30″,thread-groups=[“i1″],times=”0″,original-location=”C:\\Zhong\\workspace\\gdb_app_test1\\gdb_app_test1\\jni\\gdb_app_test1.c:30″}
-break-info 2
^done,BreakpointTable={nr_rows=”1″,nr_cols=”6″,hdr=[{width=”7″,alignment=”-1″,col_name=”number”,colhdr=”Num”},{width=”14″,alignment=”-1″,col_name=”type”,colhdr=”Type”},{width=”4″,alignment=”-1″,col_name=”disp”,colhdr=”Disp”},{width=”3″,alignment=”-1″,col_name=”enabled”,colhdr=”Enb”},{width=”10″,alignment=”-1″,col_name=”addr”,colhdr=”Address”},{width=”40″,alignment=”2″,col_name=”what”,colhdr=”What”}],body=[bkpt={number=”2″,type=”breakpoint”,disp=”keep”,enabled=”y”,addr=”0xf40cad28″,func=”Java_com_visualgdb_example_gdb_1app_1test1_gdb_1app_1test1_stringFromJNI”,file=”jni/gdb_app_test1.c”,fullname=”C:\\Zhong\\workspace\\gdb_app_test1\\gdb_app_test1\\jni\\gdb_app_test1.c”,line=”30″,thread-groups=[“i1″],times=”0″,original-location=”C:\\Zhong\\workspace\\gdb_app_test1\\gdb_app_test1\\jni\\gdb_app_test1.c:30″}]}
-break-after 2 0
OK
info symbol 0xf40cad28
&”info symbol 0xf40cad28\n”
Java_com_visualgdb_example_gdb_1app_1test1_gdb_1app_1test1_stringFromJNI + 44 in section .text of C:\Zhong\workspace\gdb_app_test1\gdb_app_test1\obj\local\armeabi-v7a\libgdb_app_test1.so
OK
info line *0xf40cad28
&”info line *0xf40cad28\n”
Line 30 of “jni/gdb_app_test1.c” starts at address 0xf40cad28 <Java_com_visualgdb_example_gdb_1app_1test1_gdb_1app_1test1_stringFromJNI+44> and ends at 0xf40cad60 <Java_com_visualgdb_example_gdb_1app_1test1_gdb_1app_1test1_stringFromJNI+100>.
OK
-exec-continue
^running
*running,thread-id=”all”March 11, 2016 at 05:30 #7751support
OK, it looks like VisualGDB is somehow using the obj/local/armeabi-v7a directory for symbols instead of obj/local/arm64-v8a.
Does the arm64-v8a directory exist? What does the VisualGDB Launcher Output say when you try to debug your project?
