Sysprogs forums › Forums › VisualGDB › multimedia libraries
- This topic has 3 replies, 2 voices, and was last updated 12 years, 7 months ago by
ket.
February 14, 2014 at 18:47 #729
mcuevas
ParticipantHello to all 🙂
i recently downloaded the trial version of Visual GBD and i compile a program in my Rasp Pi, all good here… 😀 BUT… i need use the multimedia libs and i dont know how agree
and to my project >o< .... in Qt-Creator i agree “QT += multimedia” and run the qmake… but here i dont know hoy do this D: can anyone help me please? February 14, 2014 at 20:50 #2909ket
The .pro file with your project name contains the QT statement you should add “multimedia” to. qmake is always run automatically by VisualGDB when building.
February 17, 2014 at 16:41 #2910mcuevas
ParticipantHello KEt, thanks for te response 🙂
i build im project but more errors appears… this is the build.log file
Build started 17/02/2014 12:41:02 p.m.. 1>Project "C:QtprojectsMultimediaMultimediaMultimedia.vcxproj" on node 2 (Build target(s)).
1>Build:
"C:Program Files (x86)SysprogsVisualGDB\VisualGDB.exe" /build "C:QtprojectsMultimediaMultimediaMultimedia.vcxproj" "/solution:C:QtprojectsMultimediaMultimedia.sln" "/config:Debug" "/platform:Win32"
VisualGDB: Attempting inline build...
VisualGDB: Sending 2 updated source files to build machine...
VisualGDB: Executing prebuild actions
VisualGDB: Run "qmake-qt4 Multimedia.pro CONFIGNAME=Debug " in directory "/tmp/VisualGDB/c/Qt/projects/Multimedia/Multimedia" on pi@192.168.137.225 (SSH)
1>Project MESSAGE : warning : unknown QT: multimediawidgets
VisualGDB: Run "make " in directory "/tmp/VisualGDB/c/Qt/projects/Multimedia/Multimedia" on pi@192.168.137.225 (SSH)
g++ -c -pipe -g -Wall -W -D_REENTRANT -DQT_WEBKIT -DQT_MULTIMEDIA_LIB -DQT_GUI_LIB -DQT_CORE_LIB -DQT_SHARED -I/usr/share/qt4/mkspecs/linux-g++ -I. -I/usr/include/qt4/QtCore -I/usr/include/qt4/QtGui -I/usr/include/qt4/QtMultimedia -I/usr/include/qt4 -IDebug -IDebug -o Debug/MainWindow.o MainWindow.cpp
g++ -c -pipe -g -Wall -W -D_REENTRANT -DQT_WEBKIT -DQT_MULTIMEDIA_LIB -DQT_GUI_LIB -DQT_CORE_LIB -DQT_SHARED -I/usr/share/qt4/mkspecs/linux-g++ -I. -I/usr/include/qt4/QtCore -I/usr/include/qt4/QtGui -I/usr/include/qt4/QtMultimedia -I/usr/include/qt4 -IDebug -IDebug -o Debug/Multimedia.o Multimedia.cpp
1>C:QtprojectsMultimediaMultimediaMultimedia.cpp(4,24): fatal error : QMediaPlayer: No such file or directory
compilation terminated.
make: *** [Debug/Multimedia.o] Error 1 Command exited with code 2
Executable: make
Arguments:
Directory: /tmp/VisualGDB/c/Qt/projects/Multimedia/Multimedia
1>C:Program Files (x86)MSBuildMicrosoft.Cppv4.0V110Microsoft.MakeFile.Targets(38,5): error MSB3073: The command ""C:Program Files (x86)SysprogsVisualGDB\VisualGDB.exe" /build "C:QtprojectsMultimediaMultimediaMultimedia.vcxproj" "/solution:C:QtprojectsMultimediaMultimedia.sln" "/config:Debug" "/platform:Win32"" exited with code 1.
1>Done Building Project "C:QtprojectsMultimediaMultimediaMultimedia.vcxproj" (Build target(s)) -- FAILED.
Build FAILED.
Time Elapsed 00:00:30.98
i dont know why happen this 😕
February 17, 2014 at 19:23 #2911ket
Based on this log and the line “warning : unknown QT: multimediawidgets”, you need a space in between i.e. “multimedia widgets”.
Based on “/usr/bin/ld: cannot find -lQtMultimedia”, libQtMultimedia cannot be found by the linker. Please verify that libQtMultimedia is installed on your Raspberry Pi (should be somewhere in /usr/lib where the other Qt libraries are).
As other Qt libraries are found, the standard Qt package for Raspberry Pi may not include it and you should install it separately. You may also need to build the library yourself if it is not available anywhere. -
