msp430 interrupt handler routine
Sysprogs forums Forums VisualGDB msp430 interrupt handler routine
  • #8299
    jerbucc
    Can someone tell me what the correct syntax for an interrupt is. I tried using same as Code composer code as below and I get an error? it doesn’t recognize __interrupt
    <div>//*****************************************************************************
    #pragma vector=TIMER1_A0_VECTOR
    __interrupt void IntervalWakeupISR (void)
    // Set flag to update panel, then wake from LPM3 sleep
    g_bUpdatePanel = true;
    LPM3_EXIT;
    }</div>
    <div></div>
    <div>//*****************************************************************************</div>
    #8307
    Please try the __attribute__((__interrupt__(vector))) syntax described here: http://stackoverflow.com/questions/15500826/how-to-declare-an-interrupt-handler-isr-in-mspgcc
