Sysprogs forums › Forums › VisualGDB › MSB3073 compile error when trying to use cross-compiler on local PC
- This topic has 8 replies, 3 voices, and was last updated 10 years, 7 months ago by
October 11, 2015 at 00:10 #7055
wernert
ParticipantI’ve been using VisualGDB for over a year now, but recentyl had to re-install the OS on my entire machine. And since then I’m getting and error whenever I’m trying to use cross compiler to build for Raspberry Pi.
Details of my system:
- My PC’s OS : Windows 10
- Target : Raspberry Pi with Raspbian Jessie
- VisualGDB version 5.0
The error I get happens at the time when it tries to deploy and it says “Toolchain Test failed”
More details about the error:
Severity Code Description Project File Line
Error MSB3073 The command “”C:\Program Files (x86)\Sysprogs\VisualGDB\VisualGDB.exe” /build “d:\tmp\LinuxProject4\LinuxProject4\LinuxProject4.vcxproj” “/solution:d:\tmp\LinuxProject4\LinuxProject4.sln” “/config:Debug” “/platform:Win32″” exited with code 1. LinuxProject4 C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V140\Microsoft.MakeFile.Targets 37This is more details of what happens when it tries to make:
cmd.exe /c “C:\SysGCC\Raspberry\bin\make.exe”
g++ -ggdb -ffunction-sections -O0 -DDEBUG -c LinuxProject4.cpp -o Debug/LinuxProject4.o -MD -MF Debug/LinuxProject4.dep
process_begin: CreateProcess(NULL, g++ -ggdb -ffunction-sections -O0 -DDEBUG -c LinuxProject4.cpp -o Debug/LinuxProject4.o -MD -MF Debug/LinuxProject4.dep, …) failed.
make (e=2): The system cannot find the file specified.make: *** [Debug/LinuxProject4.o] Error 2
I cannot figure out what file it refers to. I looked at the VisualGDB Build Variables and they all see OK to me.
Important : I know that I can build the app successfully if I use the Raspberry Pi itself to compile, but I prefer to use the cross compiler on local computer as I have used in the past.
October 11, 2015 at 01:41 #7056wernert
ParticipantUpdate : I managed to get it to work after I switched the toolchain from raspberry-gcc4.9.2. (Jessie) to raspberry-gcc4.6 (Wheezy). Maybe there is something wrong in the Jessie toolchain?
October 13, 2015 at 03:54 #7059support
Thanks for letting us know. Our Jessie toolchain image was indeed missing some DLLs. We have updated the installer. Please re-download and re-install it.
February 16, 2016 at 07:26 #7653Hillel
ParticipantI’ve been using VisualGDB Trial Version.
I try to add a #include <BBBiolib.h>
Then I get the error message.
Thanks for the help
1>C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V140\Microsoft.MakeFile.Targets(37,5): error MSB3073: The command “”C:\Program Files (x86)\Sysprogs\VisualGDB\\VisualGDB.exe” /build “C:\visualstudioProjects\LinuxProject1_GPIO\LinuxProject1_GPIO\LinuxProject1_GPIO.vcxproj” “/solution:C:\visualstudioProjects\LinuxProject1_GPIO\LinuxProject1_GPIO.sln” “/config:Debug” “/platform:Win32″” exited with code 1.
========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 skipped =======-
This reply was modified 10 years, 7 months ago by
Hillel.
February 16, 2016 at 10:40 #7660support
KeymasterPlease check the Output window for more detailed error messages. If it does not help, please post the contents of the Output window here.
February 16, 2016 at 21:23 #7663Hillel
ParticipantI include the bcm2835.h library to controlling the Raspberry Pi GPIO .
when I compile on my computer without remote compiling I don’t get the error.
I tried to use the sync tool to load the nuw file (bcm2835.h) and I still get the error it’s look the same from the BeagleBone black.
the first one is without the error:1>—— Build started: Project: Raspberrypi, Configuration: Debug Win32 ——
1> VisualGDB: Run “make CONFIG=Debug” in directory “C:\visualstudioProjects\Raspberrypi\Raspberrypi” on (unspecified)
1> gcc -ggdb -ffunction-sections -O0 -DDEBUG -c Raspberrypi.c -o Debug/Raspberrypi.o -MD -MF Debug/Raspberrypi.dep
1> g++ -o Debug/Raspberrypi -Wl,-gc-sections -Wl,–start-group Debug/Raspberrypi.o -Wl,–rpath=’$ORIGIN’ -Wl,–end-group
========== Build: 1 succeeded, 0 failed, 0 up-to-date, 0 skipped ==========the second one
1> VisualGDB: Sending 1 updated source file to build machine…
1> VisualGDB: Run “make CONFIG=Debug” in directory “/tmp/VisualGDB/c/visualstudioProjects/Raspberrypi/Raspberrypi” on pi@192.168.1.19 (SSH)
1>C:\visualstudioProjects\Raspberrypi\Raspberrypi\Raspberrypi.c(2,77): fatal error : C:\Users\Hillel\Downloads\Raspberry PI\bcm2835-1.49\src\bcm2835.h: No such file or directory
1> #include “C:\Users\Hillel\Downloads\Raspberry PI\bcm2835-1.49\src\bcm2835.h”
1> ^
1> compilation terminated.
1> Makefile:163: recipe for target ‘Debug/Raspberrypi.o’ failed
1> make: *** [Debug/Raspberrypi.o] Error 1
1> ————————————————————-
1> Command exited with code 2
1> Executable: make
1> Arguments: CONFIG=Debug
1> Directory: /tmp/VisualGDB/c/visualstudioProjects/Raspberrypi/Raspberrypi
1>C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V140\Microsoft.MakeFile.Targets(37,5): error MSB3073: The command “”C:\Program Files (x86)\Sysprogs\VisualGDB\\VisualGDB.exe” /build “C:\visualstudioProjects\Raspberrypi\Raspberrypi\Raspberrypi.vcxproj” “/solution:C:\visualstudioProjects\Raspberrypi\Raspberrypi.sln” “/config:Debug” “/platform:Win32″” exited with code 1.
========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 skipped ==========-
Hillel.
February 17, 2016 at 09:19 #7666support
The problem happens because “C:\Users\Hillel\Downloads\Raspberry PI\bcm2835-1.49\src\bcm2835.h” is a path on the Windows machine and it’s not accessible when you build on Linux. Please consider uploading the bsm2835 library somewhere on the Raspberry Pi (e.g. /opt/src), specifying the directory with the .h files in the include directories in VisualGDB Project Properties and simply including <bsm2835.h> without the full path.
February 17, 2016 at 11:56 #7667Hillel
ParticipantI have placed the file : C:\Users\Hillel\AppData\Local\VisualGDB\RemoteSourceCache\192.168.1.19\0000
#include <stdio.h>
#include <bcm2835.h>
int main(int argc, char *argv[])
char sz[] = “Hello, World!\n”; /* Hover mouse over “sz” while debugging to see its contents */
printf(“%s”, sz);
fflush(stdout); /* <============== Put a breakpoint here */return 0;
}1>—— Build started: Project: Raspberrypi, Configuration: Debug Win32 ——
1>C:\visualstudioProjects\Raspberrypi\Raspberrypi\Raspberrypi.c(2,21): fatal error : bcm2835.h: No such file or directory
1> #include <bcm2835.h>
1> ^
1> Executable: make
Thanks for the helpFebruary 19, 2016 at 09:27 #7673support
Placing the file under RemoteSourceCache does not automatically upload it to the Linux machine. Please either upload it directly with SmarTTY or add a pre-build action to upload it during build.
